Hello @yuweiw , here’s the information you asked.
Pipeline
Command:
gst-launch-1.0 --gst-debug=v4l2videodec:5 rtspsrc location=rtsp://localhost/cbb48b92-f74d-4ad5-b8a9-3affbefcc17e_default/2faf8bbe-f526-48a8-89bc-a7431f60834e protocols=4 ! rtph264depay ! h264parse ! nvv4l2decoder ! fakesink
Output:
0:00:00.019013274 396 0x559a6952d300 DEBUG v4l2videodec gstv4l2videodec.c:1740:gst_v4l2_video_dec_sink_getcaps:<nvv4l2decoder0> Returning sink caps image/jpeg, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ]; video/x-h264, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ], stream-format=(string){ byte-stream }, alignment=(string){ au }; video/x-h265, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ], stream-format=(string){ byte-stream }, alignment=(string){ au }; video/mpeg, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ], mpegversion=(int)4, systemstream=(boolean)false, parsed=(boolean)true; video/mpeg, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ], mpegversion=(int)[ 1, 2 ], systemstream=(boolean)false, parsed=(boolean)true; video/x-divx, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ], divxversion=(int)[ 4, 5 ]; video/x-vp8, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ]; video/x-vp9, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ]
0:00:00.019115290 396 0x559a6952d300 DEBUG v4l2videodec gstv4l2videodec.c:1740:gst_v4l2_video_dec_sink_getcaps:<nvv4l2decoder0> Returning sink caps image/jpeg, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ]; video/x-h264, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ], stream-format=(string){ byte-stream }, alignment=(string){ au }; video/x-h265, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ], stream-format=(string){ byte-stream }, alignment=(string){ au }; video/mpeg, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ], mpegversion=(int)4, systemstream=(boolean)false, parsed=(boolean)true; video/mpeg, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ], mpegversion=(int)[ 1, 2 ], systemstream=(boolean)false, parsed=(boolean)true; video/x-divx, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ], divxversion=(int)[ 4, 5 ]; video/x-vp8, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ]; video/x-vp9, width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ]
0:00:00.019151517 396 0x559a6952d300 DEBUG v4l2videodec gstv4l2videodec.c:1716:gst_v4l2_video_dec_src_query:<nvv4l2decoder0> Returning src caps video/x-raw(memory:NVMM), width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ]
0:00:00.019175626 396 0x559a6952d300 DEBUG v4l2videodec gstv4l2videodec.c:1716:gst_v4l2_video_dec_src_query:<nvv4l2decoder0> Returning src caps video/x-raw(memory:NVMM), width=(int)[ 1, 2147483647 ], height=(int)[ 1, 2147483647 ], framerate=(fraction)[ 0/1, 2147483647/1 ]
Setting pipeline to PAUSED ...
0:00:00.019241825 396 0x559a6952d300 DEBUG v4l2videodec gstv4l2videodec.c:565:gst_v4l2_video_dec_open:<nvv4l2decoder0> Opening
0:00:00.064544468 396 0x559a6952d300 DEBUG v4l2videodec gstv4l2videodec.c:647:gst_v4l2_video_dec_start:<nvv4l2decoder0> Starting
Pipeline is live and does not need PREROLL ...
Progress: (open) Opening Stream
Progress: (connect) Connecting to rtsp://localhost/cbb48b92-f74d-4ad5-b8a9-3affbefcc17e_default/2faf8bbe-f526-48a8-89bc-a7431f60834e
Progress: (open) Retrieving server options
Progress: (open) Retrieving media info
Progress: (request) SETUP stream 0
Progress: (open) Opened Stream
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Progress: (request) Sending PLAY request
0:00:03.692429416 396 0x7fe1680075e0 DEBUG v4l2videodec gstv4l2videodec.c:1740:gst_v4l2_video_dec_sink_getcaps:<nvv4l2decoder0> Returning sink caps video/x-h264, width=(int)[ 1, 32768 ], height=(int)[ 1, 32768 ], framerate=(fraction)[ 0/1, 2147483647/1 ], stream-format=(string)byte-stream, alignment=(string)au, parsed=(boolean)true
0:00:03.692555984 396 0x7fe1680075e0 DEBUG v4l2videodec gstv4l2videodec.c:1740:gst_v4l2_video_dec_sink_getcaps:<nvv4l2decoder0> Returning sink caps video/x-h264, width=(int)[ 1, 32768 ], height=(int)[ 1, 32768 ], framerate=(fraction)[ 0/1, 2147483647/1 ], stream-format=(string)byte-stream, alignment=(string)au, parsed=(boolean)true
0:00:03.692630633 396 0x7fe1680075e0 DEBUG v4l2videodec gstv4l2videodec.c:1740:gst_v4l2_video_dec_sink_getcaps:<nvv4l2decoder0> Returning sink caps video/x-h264, width=(int)[ 1, 32768 ], height=(int)[ 1, 32768 ], framerate=(fraction)[ 0/1, 2147483647/1 ], stream-format=(string)byte-stream, alignment=(string)au, parsed=(boolean)true
0:00:03.692665349 396 0x7fe1680075e0 DEBUG v4l2videodec gstv4l2videodec.c:704:gst_v4l2_video_dec_set_format:<nvv4l2decoder0> Setting format: video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, parsed=(boolean)true
0:00:03.694768156 396 0x7fe1680075e0 DEBUG v4l2videodec gstv4l2videodec.c:1740:gst_v4l2_video_dec_sink_getcaps:<nvv4l2decoder0> Returning sink caps video/x-h264, width=(int)3840, height=(int)2160, framerate=(fraction)0/1, stream-format=(string)byte-stream, alignment=(string)au, parsed=(boolean)true, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, profile=(string)high, level=(string)5.1
0:00:03.694805890 396 0x7fe1680075e0 DEBUG v4l2videodec gstv4l2videodec.c:704:gst_v4l2_video_dec_set_format:<nvv4l2decoder0> Setting format: video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, width=(int)3840, height=(int)2160, framerate=(fraction)0/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true, profile=(string)high, level=(string)5.1
0:00:03.695454075 396 0x7fe1680075e0 DEBUG v4l2videodec gstv4l2videodec.c:1349:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Handling frame 0
0:00:03.695467086 396 0x7fe1680075e0 DEBUG v4l2videodec gstv4l2videodec.c:1389:gst_v4l2_video_dec_handle_frame:<nvv4l2decoder0> Sending header
Note that the pipeline gets stuck right after starting. No further output is generated in the console.
I also used ffprobe to make sure the camera was up:
ffprobe rtsp://localhost/cbb48b92-f74d-4ad5-b8a9-3affbefcc17e_default/2faf8bbe-f526-48a8-89bc-a7431f60834e
ffprobe version 3.4.8-0ubuntu0.2 Copyright (c) 2007-2020 the FFmpeg developers
built with gcc 7 (Ubuntu 7.5.0-3ubuntu1~18.04)
configuration: --prefix=/usr --extra-version=0ubuntu0.2 --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --enable-gpl --disable-stripping --enable-avresample --enable-avisynth --enable-gnutls --enable-ladspa --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-libgsm --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librubberband --enable-librsvg --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libssh --enable-libtheora --enable-libtwolame --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzmq --enable-libzvbi --enable-omx --enable-openal --enable-opengl --enable-sdl2 --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libopencv --enable-libx264 --enable-shared
libavutil 55. 78.100 / 55. 78.100
libavcodec 57.107.100 / 57.107.100
libavformat 57. 83.100 / 57. 83.100
libavdevice 57. 10.100 / 57. 10.100
libavfilter 6.107.100 / 6.107.100
libavresample 3. 7. 0 / 3. 7. 0
libswscale 4. 8.100 / 4. 8.100
libswresample 2. 9.100 / 2. 9.100
libpostproc 54. 7.100 / 54. 7.100
[rtsp @ 0x55785053c080] method SETUP failed: 461 Unsupported transport
Input #0, rtsp, from 'rtsp://localhost/cbb48b92-f74d-4ad5-b8a9-3affbefcc17e_default/2faf8bbe-f526-48a8-89bc-a7431f60834e':
Duration: N/A, start: 0.034000, bitrate: N/A
Stream #0:0: Video: h264 (High), yuvj420p(pc, bt709, progressive), 3840x2160, 30 tbr, 90k tbn, 180k tbc
Video
The rtsp stream is local. I used the following command to dump the rtsp stream into a file:
ffmpeg -i rtsp://localhost/cbb48b92-f74d-4ad5-b8a9-3affbefcc17e_default/2faf8bbe-f526-48a8-89bc-a7431f60834e -acodec copy -vcodec copy video.mp4
I am going to send to you the file in a few minutes.
Thank you for your help!
