Hi! I used the docker image nvcr.io/nvidia/deepstream:4.0-19.07 to run the deepstram-app app, but it produced the error “Segmentation fault (core dumped)” randomly. The followings are the detail I did:
1, download the docker image and create a container;
2, in the container, run “deepstream-app -c movie_test.txt”, the config file “movie_test.txt” is presented at the buttom, with the following modifications:
but all of them produced the error “Segmentation fault (core dumped)” after a while, from 5minutes to 20 minutes.
my GPU is 1080Ti, with Driver Version: 418.39, CUDA Version: 10.1.
Please help me to fix this error, thank you in advance!
The config file I used:
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=1
rows=3
columns=3
width=1280
height=720
gpu-id=0
#(0): nvbuf-mem-default - Default memory allocated, specific to particular platform
#(1): nvbuf-mem-cuda-pinned - Allocate Pinned/Host cuda memory, applicable for Tesla
#(2): nvbuf-mem-cuda-device - Allocate Device cuda memory, applicable for Tesla
#(3): nvbuf-mem-cuda-unified - Allocate Unified cuda memory, applicable for Tesla
#(4): nvbuf-mem-surface-array - Allocate Surface Array memory, applicable for Jetson
nvbuf-memory-type=0
[ds-example]
enable=1
processing-width=640
processing-height=360
full-frame=1
unique-id=15
gpu-id=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP
type=2
uri=file://../../streams/GTO.11.FeiXue.x264-OGG.mkv
num-sources=1
drop-frame-interval=0
gpu-id=0
num-extra-surfaces=0
# (0): memtype_device - Memory type Device
# (1): memtype_pinned - Memory type Host Pinned
# (2): memtype_unified - Memory type Unified
cudadec-memtype=0
camera-id=901
[source1]
enable=1
type=2
uri=file://../../streams/GTO.01.FeiXue.x264-OGG.mkv
num-sources=1
gpu-id=0
cudadec-memtype=0
camera-id=902
[source2]
enable=1
type=2
uri=file://../../streams/GTO.02.FeiXue.x264-OGG.mkv
num-sources=1
gpu-id=0
cudadec-memtype=0
camera-id=903
[source3]
enable=1
type=3
uri=file://../../streams/GTO.03.FeiXue.x264-OGG.mkv
num-sources=1
gpu-id=0
cudadec-memtype=0
[source4]
enable=1
type=3
uri=file://../../streams/GTO.04.FeiXue.x264-OGG.mkv
num-sources=1
gpu-id=0
cudadec-memtype=0
[source5]
enable=1
type=3
uri=file://../../streams/GTO.05.FeiXue.x264-OGG.mkv
num-sources=1
gpu-id=0
cudadec-memtype=0
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
type=2
sync=0
source-id=0
gpu-id=0
nvbuf-memory-type=0
[sink1]
enable=0
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265
codec=1
sync=0
#iframeinterval=10
bitrate=2000000
output-file=out.mp4
source-id=0
[sink2]
enable=0
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming
type=4
#1=h264 2=h265
codec=1
sync=0
bitrate=4000000
# set below properties in case of RTSPStreaming
rtsp-port=8554
udp-port=5400
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=0
batch-size=300
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40
## Set muxer output width and height
width=1920
height=1080
##Enable to maintain aspect ratio wrt source, and allow black borders, works
##along with width, height properties
enable-padding=0
nvbuf-memory-type=0
# config-file property is mandatory for any gie section.
# Other properties are optional and if set will override the properties set in
# the infer config file.
[primary-gie]
enable=1
gpu-id=0
model-engine-file=../../models/Primary_Detector/resnet10.caffemodel_b30_int8.engine
#Required to display the PGIE labels, should be added even when using config-file
#property
batch-size=30
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
interval=0
#Required by the app for SGIE, when used along with config-file property
gie-unique-id=1
nvbuf-memory-type=0
config-file=config_infer_primary.txt
[tracker]
enable=1
tracker-width=640
tracker-height=368
#ll-lib-file=/opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_mot_iou.so
ll-lib-file=/opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_nvdcf.so
#ll-lib-file=/opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_mot_klt.so
#ll-config-file required for DCF/IOU only
ll-config-file=tracker_config.yml
#ll-config-file=iou_config.txt
gpu-id=0
#enable-batch-process applicable to DCF only
enable-batch-process=1
[tests]
file-loop=1
