My problem: I come across the error with message Segmentation Fault (core dumped) in every DeepStream pipeline I run in Jetson AGX Orin. These pipelines were successfully executing in x86 devices but I cannot make any of them running on Jetson AGX Orin.
For this issue, I tried to run deepstream-test5 but I also tested DeepStream-YOLO examples and other samples, and came across the same error: Segmentation Fault (core dumped) and I couldn’t find the root cause yet. I did not perform any action other than sample READMEs and official docs.
Any kind of help is appreciated.
Output really confused me because I confirmed that my RTSP link is valid since I can play it using VLC player. Here are the command and the logs.
./deepstream-test5-app -c configs/test5_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt -p 0
0:00:07.136738154 7822 0xaaaae080ed30 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2092> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.4/sources/apps/sample_apps/deepstream-test5/configs/../../../../../samples/models/Primary_Detector/resnet18_trafficcamnet.etlt_b2_gpu0_int8.engine
INFO: [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x544x960
1 OUTPUT kFLOAT output_bbox/BiasAdd 16x34x60
2 OUTPUT kFLOAT output_cov/Sigmoid 4x34x60
0:00:07.540946288 7822 0xaaaae080ed30 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2195> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.4/sources/apps/sample_apps/deepstream-test5/configs/../../../../../samples/models/Primary_Detector/resnet18_trafficcamnet.etlt_b2_gpu0_int8.engine
0:00:07.549883941 7822 0xaaaae080ed30 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream-6.4/sources/apps/sample_apps/deepstream-test5/configs/../../../../../samples/configs/deepstream-app/config_infer_primary.txt sucessfully
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
To go back to the tiled display, right-click anywhere on the window.
Active sources : 0
**PERF: FPS 0 (Avg) FPS 1 (Avg)
Thu May 30 07:35:07 2024
**PERF: 0.00 (0.00) 0.00 (0.00)
** INFO: <bus_callback:301>: Pipeline ready
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NvMMLiteBlockCreate : Block : BlockType = 261
Stream format not found, dropping the frame
** INFO: <bus_callback:287>: Pipeline running
My configuration:
Here are the differences w/ /opt/nvidia/deepstream/deepstream-6.4/sources/apps/sample_apps/deepstream-test5/configs/test5_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt. I disabled few things to make pipeline simpler.
- RTSP links are updated in
source0andsource1. sink1is disabled. (cloud messages)trackeris disabled.secondary-gie0andsecondary-gie1are disabled.
# Copyright (c) 2018-2022, NVIDIA CORPORATION. All rights reserved.
# Permission is hereby granted, free of charge, to any person obtaining a
# copy of this software and associated documentation files (the "Software"),
# to deal in the Software without restriction, including without limitation
# the rights to use, copy, modify, merge, publish, distribute, sublicense,
# and/or sell copies of the Software, and to permit persons to whom the
# Software is furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in
# all copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
# THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
# FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
# DEALINGS IN THE SOFTWARE.
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=1
rows=1
columns=2
width=1280
height=720
gpu-id=0
nvbuf-memory-type=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP
type=4
uri=rtsp://172.16.44.172:8554/mystream
num-sources=1
gpu-id=0
nvbuf-memory-type=0
# smart record specific fields, valid only for source type=4
# 0 = disable, 1 = through cloud events, 2 = through cloud + local events
#smart-record=1
# 0 = mp4, 1 = mkv
#smart-rec-container=0
#smart-rec-file-prefix
#smart-rec-dir-path
# smart record cache size in seconds
#smart-rec-cache
# default duration of recording in seconds.
#smart-rec-default-duration
# duration of recording in seconds.
# this will override default value.
#smart-rec-duration
# seconds before the current time to start recording.
#smart-rec-start-time
# value in seconds to dump video stream.
#smart-rec-interval
[source1]
enable=1
type=4
num-sources=1
gpu-id=0
nvbuf-memory-type=0
#smart-record=1
# 0 = mp4, 1 = mkv
#smart-rec-dir-path
#smart-rec-cache
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
type=2
sync=0
source-id=0
gpu-id=0
nvbuf-memory-type=0
[sink1]
enable=0
#Type - 1=FakeSink 2=EglSink 3=File 4=UDPSink 5=nvdrmvideosink 6=MsgConvBroker
type=6
msg-conv-config=dstest5_msgconv_sample_config.txt
#(0): PAYLOAD_DEEPSTREAM - Deepstream schema payload
#(1): PAYLOAD_DEEPSTREAM_MINIMAL - Deepstream schema payload minimal
#(2): PAYLOAD_DEEPSTREAM_PROTOBUF - Deepstream schema protobuf encoded payload
#(256): PAYLOAD_RESERVED - Reserved type
#(257): PAYLOAD_CUSTOM - Custom schema payload
msg-conv-payload-type=0
#(0): Create payload using NvdsEventMsgMeta
#(1): New Api to create payload using NvDsFrameMeta
msg-conv-msg2p-new-api=0
#Frame interval at which payload is generated
msg-conv-frame-interval=30
msg-broker-proto-lib=/opt/nvidia/deepstream/deepstream/lib/libnvds_kafka_proto.so
#Provide your msg-broker-conn-str here
msg-broker-conn-str=<host>;<port>;<topic>
topic=<topic>
#Optional:
#msg-broker-config=/opt/nvidia/deepstream/deepstream/sources/libs/kafka_protocol_adaptor/cfg_kafka.txt
#new-api=0
#(0) Use message adapter library api's
#(1) Use new msgbroker library api's
[sink2]
enable=0
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265 3=mpeg4
## only SW mpeg4 is supported right now.
codec=3
sync=1
bitrate=2000000
output-file=out.mp4
source-id=0
# sink type = 6 by default creates msg converter + broker.
# To use multiple brokers use this group for converter and use
# sink type = 6 with disable-msgconv = 1
[message-converter]
enable=0
#(2): PAYLOAD_DEEPSTREAM_PROTOBUF - Deepstream schema protobuf payload
# Name of library having custom implementation.
#msg-conv-msg2p-lib=<val>
# Id of component in case only selected message to parse.
#msg-conv-comp-id=<val>
# Configure this group to enable cloud message consumer.
[message-consumer0]
enable=0
config-file=/opt/nvidia/deepstream/deepstream/sources/libs/kafka_protocol_adaptor/cfg_kafka.txt
subscribe-topic-list=<topic1>;<topic2>;<topicN>
# Use this option if message has sensor name as id instead of index (0,1,2 etc.).
#sensor-list-file=dstest5_msgconv_sample_config.txt
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Arial
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=0
batch-size=2
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40000
## Set muxer output width and height
width=1920
height=1080
##Enable to maintain aspect ratio wrt source, and allow black borders, works
##along with width, height properties
enable-padding=0
nvbuf-memory-type=0
## If set to TRUE, system timestamp will be attached as ntp timestamp
## If set to FALSE, ntp timestamp from rtspsrc, if available, will be attached
# attach-sys-ts-as-ntp=1
# config-file property is mandatory for any gie section.
# Other properties are optional and if set will override the properties set in
# the infer config file.
[primary-gie]
enable=1
gpu-id=0
#Required to display the PGIE labels, should be added even when using config-file
#property
batch-size=2
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
interval=0
#Required by the app for SGIE, when used along with config-file property
gie-unique-id=1
nvbuf-memory-type=0
model-engine-file=../../../../../samples/models/Primary_Detector/resnet18_trafficcamnet.etlt_b2_gpu0_int8.engine
labelfile-path=../../../../../samples/models/Primary_Detector/labels.txt
config-file=../../../../../samples/configs/deepstream-app/config_infer_primary.txt
#infer-raw-output-dir=../../../../../samples/primary_detector_raw_output/
[tracker]
enable=0
# For NvDCF and NvDeepSORT tracker, tracker-width and tracker-height must be a multiple of 32, respectively
tracker-width=960
tracker-height=544
ll-lib-file=/opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
# ll-config-file required to set different tracker types
# ll-config-file=../../../../../samples/configs/deepstream-app/config_tracker_IOU.yml
# ll-config-file=../../../../../samples/configs/deepstream-app/config_tracker_NvSORT.yml
ll-config-file=../../../../../samples/configs/deepstream-app/config_tracker_NvDCF_perf.yml
# ll-config-file=../../../../../samples/configs/deepstream-app/config_tracker_NvDCF_accuracy.yml
# ll-config-file=../../../../../samples/configs/deepstream-app/config_tracker_NvDeepSORT.yml
gpu-id=0
display-tracking-id=1
[secondary-gie0]
enable=0
gpu-id=0
gie-unique-id=4
operate-on-gie-id=1
operate-on-class-ids=0;
batch-size=16
config-file=../../../../../samples/configs/deepstream-app/config_infer_secondary_vehicletypes.txt
labelfile-path=../../../../../samples/models/Secondary_VehicleTypes/labels.txt
model-engine-file=../../../../../samples/models/Secondary_VehicleTypes/resnet18_vehicletypenet.etlt_b16_gpu0_int8.engine
[secondary-gie1]
enable=0
gpu-id=0
gie-unique-id=5
operate-on-gie-id=1
batch-size=16
config-file=../../../../../samples/configs/deepstream-app/config_infer_secondary_vehiclemake.txt
labelfile-path=../../../../../samples/models/Secondary_VehicleMake/labels.txt
model-engine-file=../../../../../samples/models/Secondary_VehicleMake/resnet18_vehiclemakenet.etlt_b16_gpu0_int8.engine
[tests]
file-loop=0
Steps to recreate environment & reproduce the issue:
First, I start a Docker container as mentioned here.
xhost +
docker run -it --rm --runtime nvidia --detach --net=host --gpus all -e DISPLAY=$DISPLAY --device /dev/snd -v /tmp/.X11-unix/:/tmp/.X11-unix nvcr.io/nvidia/deepstream:6.4-triton-multiarch
docker ps
docker exec -it <CONTAINER-ID> bash
Then I run these commands to install some of the requirements.
apt-get update
apt-get install -y kmod # for the logs about lsmod and so
/opt/nvidia/deepstream/deepstream-6.4/user_additional_install.sh # for the errors about decoders
I go into the example deepstream-test5 and install & build the required packages.
# from the README of deepstream-test5
apt-get install libgstreamer-plugins-base1.0-dev libgstreamer1.0-dev \
libgstrtspserver-1.0-dev libx11-dev libjson-glib-dev libyaml-cpp-dev -y
# from the README of kafka_protocol_adaptor
git clone https://github.com/confluentinc/librdkafka.git
cd librdkafka
git checkout tags/v2.2.0
./configure # --enable-ssl
make
make install
cp /usr/local/lib/librdkafka* /opt/nvidia/deepstream/deepstream/lib/
ldconfig
apt-get install libglib2.0 libglib2.0-dev -y
apt-get install libjansson4 libjansson-dev -y
apt-get install libssl-dev -y
apt-get install protobuf-compiler -y
cd /opt/nvidia/deepstream/deepstream-6.4/sources/apps/sample_apps/deepstream-test5
export CUDA_VER=12.2
make
Then I configure the pipeline /opt/nvidia/deepstream/deepstream-6.4/sources/apps/sample_apps/deepstream-test5/configs/test5_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt as I stated in the beginning of the post and run the pipeline. These were all the steps I go through before running the pipeline.
My setup:
• Hardware Platform: Jetson AGX Orin 64 Gb
• DeepStream Version: 6.4 - Docker image: nvcr.io/nvidia/deepstream:6.4-triton-multiarch
• JetPack Version: 6
• TensorRT Version: 8.6.2.3-1+cuda12.2
• Issue Type: Bug
