Deepstream-test5 can not run correct
  1. I want to run deepstream-test5 in nvidia jetson agx orin dk.
  2. install kafka, and start related servers. test the servers can work.
bin/zookeeper-server-start.sh config/zookeeper.properties
bin/kafka-server-start.sh config/server.properties
  1. install related depond software. and change the config file
  2. start run demo
root@orin-root:/home/orin/workspace/deepstream-6.3/sources/apps/sample_apps/deepstream-test5# ./deepstream-test5-app -c configs/test5_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt
** ERROR: <main:1504>: Failed to set pipeline to PAUSED
Quitting
nvstreammux: Successfully handled EOS for source_id=0
nvstreammux: Successfully handled EOS for source_id=1
ERROR from sink_sub_bin_sink1: GStreamer error: state change failed and some element failed to post a proper error message with the reason for the failure.
Debug info: gstbasesink.c(5367): gst_base_sink_change_state (): /GstPipeline:pipeline/GstBin:processing_bin_0/GstBin:sink_bin/GstBin:sink_sub_bin1/GstNv3dSink:sink_sub_bin_sink1:
Failed to start
App run failed
the config file
test5_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt (8.8 KB)
env
Software part of jetson-stats 4.2.4 - (c) 2024, Raffaello Bonghi
Model: Jetson AGX Orin Developer Kit - Jetpack 5.1.2 [L4T 35.4.1]
NV Power Mode[0]: MAXN
Serial Number: [XXX Show with: jetson_release -s XXX]
Hardware:
 - P-Number: p3701-0005
 - Module: NVIDIA Jetson AGX Orin (64GB ram)
Platform:
 - Distribution: Ubuntu 20.04 focal
 - Release: 5.10.120-tegra
jtop:
 - Version: 4.2.4
 - Service: Active
Libraries:
 - CUDA: 11.4.315
 - cuDNN: 8.6.0.166
 - TensorRT: 5.1.2
 - VPI: 2.3.9
 - Vulkan: 1.3.204
 - OpenCV: 4.6.0 - with CUDA: YES
Could you add the GST_DEBUG=3 at the top of your command and attach the new log?
