Can not run: deepstream-test5 while deepstream-test1/test2/test3/test4 all run OK
  1. Per README file, after make, I issued commands to run the test5 example:
./deepstream-test5-app -c configs/test5_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt -p 0
or
./deepstream-test5-app -c configs/test5_config_file_src_infer.txt -p 1
But I got following erros:
** ERROR: main:1451: Failed to set pipeline to PAUSED
Quitting
ERROR from sink_sub_bin_sink2: Could not configure supporting library.
Debug info: gstnvmsgbroker.c(388): legacy_gst_nvmsgbroker_start (): /GstPipeline:pipeline/GstBin:sink_sub_bin2/GstNvMsgBroker:sink_sub_bin_sink2:
unable to connect to broker library
ERROR from sink_sub_bin_sink2: GStreamer error: state change failed and some element failed to post a proper error message with the reason for the failure.
Debug info: gstbasesink.c(5265): gst_base_sink_change_state (): /GstPipeline:pipeline/GstBin:sink_sub_bin2/GstNvMsgBroker:sink_sub_bin_sink2:
Failed to start
App run failed
Can you please advise how to fix the problem?
• Hardware Platform (Jetson / GPU) - RTX2080 dGPU
• DeepStream Version - 5.0
• JetPack Version (valid for Jetson only) N/A
• TensorRT Version - 7.0
• NVIDIA GPU Driver Version (valid for GPU only): 450.80
Can you attach your config file?
@Amycao,
I just uploaded the config file: test5_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt.
After I have looked into that file more, I have found the problem may be related to:
  1. #Provide your msg-broker-conn-str here : missing the important information for topic/host/port
    msg-broker-conn-str=;;
  2. missing the video: uri=rtsp://foo.com/stream1.mp4 and uri=rtsp://foo.com/stream2.mp4
I think that #1 is the main problem.
Hope that you can give me some suggestions.
test5_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt (7.8 KB)
you need to config kafka server ip and toppic or set enabled = 0 at sink1 group
for your reference
msg-broker-conn-str=ip;9092 // ip for broker running on host
topic=dstest //topic created
For how to setup kafka broker on your machine & create topic(s)
@armcao, thanks. Here is what I have done which can get the test5 to run:
in in the config files: test5_config_file_src_infer.txt and test5_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt, I have added the information:
msg-broker-conn-str=localhost;9092;quickstart-events
#msg-broker-conn-str=;;
  1. downloaded the kafka_2.13-2.7.0 and opened the three shells and do:
bin/zookeeper-server-start.sh config/zookeeper.properties
bin/kafka-server-start.sh config/server.properties
bin/kafka-topics.sh --create --topic quickstart-events --bootstrap-server localhost:9092
  1. then run the test5
./deepstream-test5-app -c configs/test5_config_file_src_infer.txt -p 1 and
bin/kafka-console-consumer.sh --topic quickstart-events --from-beginning --bootstrap-server localhost:9092
change to
topic=quickstart-events
