• Hardware Platform (Jetson / GPU) → dGPU
• DeepStream Version → 5.0
• TensorRT Version → 7.0
• NVIDIA GPU Driver Version (valid for GPU only) → 440.82
So, I was testing the deepstream-test4 app, below are the steps that i followed(on aws instance):
start a ZooKeeper server
started kafka server
created a topic test (localhost:9092)
started deepstream-5.0:devel docker container
cd deepstream-test4 && make
Kafka:
$ sudo apt-get install libglib2.0 libglib2.0-dev
$ sudo apt-get install libjansson4 libjansson-dev
$ sudo apt-get install librdkafka1=0.11.3-1build1
Entered this command:
./deepstream-test4-app -i ../../../../samples/streams/sample_720p.h264 -p /opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_kafka_proto.so --conn-str="localhost;9092;test" --no-display -s 0
And then I got this error:
Now playing: ../../../../samples/streams/sample_720p.h264
Running...
ERROR from element nvmsg-broker: Could not configure supporting library.
Error details: gstnvmsgbroker.c(332): gst_nvmsgbroker_start (): /GstPipeline:dstest4-pipeline/GstNvMsgBroker:nvmsg-broker:
unable to connect to broker library
Returned, stopping playback
Deleting pipeline
thanks in advance.
