x86, ubuntu 20.04, GeForce 1660Ti, CUDA 11.1
• DeepStream Version
5.1
• TensorRT Version
7.2.3-1
460.32.03
** ERROR: main:655: Failed to set pipeline to PAUSED
Quitting
ERROR from sink_sub_bin_sink1: Could not configure supporting library.
Debug info: gstnvmsgbroker.c(388): legacy_gst_nvmsgbroker_start (): /GstPipeline:pipeline/GstBin:sink_sub_bin1/GstNvMsgBroker:sink_sub_bin_sink1:
unable to connect to broker library
ERROR from sink_sub_bin_sink1: GStreamer error: state change failed and some element failed to post a proper error message with the reason for the failure.
Debug info: gstbasesink.c(5265): gst_base_sink_change_state (): /GstPipeline:pipeline/GstBin:sink_sub_bin1/GstNvMsgBroker:sink_sub_bin_sink1:
Failed to start
App run failed
It works when I run deepstream-test5 locally. And the kafka consumer can receive the detection results. However, it doesn’t work when I use Triton Inference Server within the docker container.
I build a custom docker image “custom_triton” based on 5.1-21.02-triton and run the docker container as follows:
Dockerfile:
FROM nvcr.io/nvidia/deepstream:5.1-21.02-triton
ADD config_new.txt /opt/nvidia/deepstream/deepstream-5.1/samples/configs/deepstream-app-trtis/
ADD dstest5_msgconv_sample_config.txt /opt/nvidia/deepstream/deepstream-5.1/samples/configs/deepstream-app-trtis/
CMD [“/bin/bash”]
WORKDIR /opt/nvidia/deepstream/deepstream-5.1/
sudo docker run --shm-size=1g --ulimit memlock=-1 --ulimit stack=67108864 --gpus all -p 8554:8554 -it --rm -v /tmp/.X11-unix:/tmp/.X11-unix -v /opt/nvidia/deepstream/deepstream-5.1/samples/trtis_model_repo:/opt/nvidia/deepstream/deepstream-5.1/samples/trtis_model_repo -e DISPLAY=$DISPLAY custom_triton:latest
Here is my configuration file:
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=kitti-trtis
[tiled-display]
enable=1
rows=1
columns=1
width=1280
height=720
gpu-id=0
nvbuf-memory-type=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP
type=2
uri=file://…/…/streams/sample_1080p_h264.mp4
num-sources=1
#drop-frame-interval=2
gpu-id=0
cudadec-memtype=0
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File 4=UDPSink 5=nvoverlaysink 6=MsgConvBroker
type=6
msg-conv-config=dstest5_msgconv_sample_config.txt
#(0): PAYLOAD_DEEPSTREAM - Deepstream schema payload
#(1): PAYLOAD_DEEPSTREAM_MINIMAL - Deepstream schema payload minimal
#(256): PAYLOAD_RESERVED - Reserved type
#(257): PAYLOAD_CUSTOM - Custom schema payload
msg-conv-payload-type=0
msg-broker-proto-lib=/opt/nvidia/deepstream/deepstream-5.1/lib/libnvds_kafka_proto.so
#Provide your msg-broker-conn-str here
msg-broker-conn-str=localhost;9092;guest_zyhe
topic=guest_zyhe
#Optional:
#msg-broker-config=…/…/deepstream-test4/cfg_kafka.txt
[sink1]
enable=0
type=1
sync=0
source-id=0
gpu-id=0
nvbuf-memory-type=0
[sink2]
enable=0
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265
codec=1
sync=0
#iframeinterval=10
bitrate=2000000
output-file=out.mp4
source-id=0
[osd]
enable=1
gpu-id=0
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
live-source=0
batch-size=1
batched-push-timeout=40000
width=1920
height=1080
enable-padding=0
nvbuf-memory-type=0
[primary-gie]
enable=1
#(0): nvinfer; (1): nvinferserver
plugin-type=1
#infer-raw-output-dir=trtis-output
batch-size=1
interval=0
gie-unique-id=1
config-file=config_infer_primary_detector_ssd_inception_v2_coco_2018_01_28.txt
[tests]
file-loop=1
