I am currently trying to install the DeepStream SDK (v1.5) on a Jetson TX2 flashed with Jetpack 3.2. However, after following the instructions in the ReadMe, I try to run the sample application and get these error messages:
nvidia@tegra-ubuntu:~$ nvgstiva-app -c /home/nvidia/configs/PGIE-FP16-CarType-CarMake-CarColor.txt
** ERROR: <create_secondary_gie:105>: Failed to create 'secondary_gie_0'
** ERROR: <create_secondary_gie:235>: create_secondary_gie failed
** ERROR: <create_secondary_gie_bin:364>: create_secondary_gie_bin failed
** ERROR: <create_processing_instance:926>: create_processing_instance failed
** ERROR: <create_pipeline:1062>: create_pipeline failed
** ERROR: <main:384>: Failed to create pipeline
Quitting
App run failed
I then try to make from source and get these errors:
nvidia@tegra-ubuntu:~/nvgstiva-app_sources/nvgstiva-app$ make
cc -o nvgstiva-app nvgstiva_app_main.o src/nvgstiva_source_bin.o src/nvgstiva_metadata_pool.o src/nvgstiva_color_detector_bin.o src/nvgstiva_config_file_parser.o src/nvgstiva_common.o src/nvgstiva_split_bin.o src/nvgstiva_sink_bin.o src/nvgstiva_perf.o src/nvgstiva_app.o src/nvgstiva_dsexample.o src/nvgstiva_secondary_gie_bin.o src/nvgstiva_face_detector_bin.o src/nvgstiva_osd_bin.o src/nvgstiva_tracker_bin.o src/nvgstiva_primary_gie_bin.o -lgstnvivameta -lnvid_mapper `pkg-config --libs gstreamer-1.0`
/usr/bin/ld: cannot find -lnvid_mapper
collect2: error: ld returned 1 exit status
Makefile:37: recipe for target 'nvgstiva-app' failed
make: *** [nvgstiva-app] Error 1
I’ve found other topics with the same problems, but it seems like they were created a few months ago and were with DeepStream v1.0, which didn’t support Jetpack 3.2. Is there something else I’m missing?
Any help or pointers in the right direction would be greatly appreciated!
