Hi again,
Thank you for the reply, I started the instructions from the deepsort readme to download the marssmall-128.pb file and converting it to the uff because I see that in the config file it is looking for the .uff file so I am in the process of installing tensorflow but I am having problems with h5py building wheel.
From the instructions on the nvidia page - Installing TensorFlow for Jetson Platform - NVIDIA Docs
and i get the fail when running this command:
sudo pip3 install --verbose --extra-index-url Index of /compute/redist/jp/v51 tensorflow==1.15.5+nv23.01
this is the output:
Using pip 23.2.1 from /usr/local/lib/python3.8/dist-packages/pip (python 3.8)
Looking in indexes: https://pypi.org/simple, https://developer.download.nvidia.com/compute/redist/jp/v51
Collecting tensorflow==1.15.5+nv23.01
Using cached https://developer.download.nvidia.com/compute/redist/jp/v51/tensorflow/tensorflow-1.15.5%2Bnv23.01-cp38-cp38-linux_aarch64.whl (359.4 MB)
Collecting absl-py>=0.9.0 (from tensorflow==1.15.5+nv23.01)
Using cached absl_py-1.4.0-py3-none-any.whl (126 kB)
Collecting astunparse==1.6.3 (from tensorflow==1.15.5+nv23.01)
Using cached astunparse-1.6.3-py2.py3-none-any.whl (12 kB)
Collecting astor==0.8.1 (from tensorflow==1.15.5+nv23.01)
Using cached astor-0.8.1-py2.py3-none-any.whl (27 kB)
Collecting gast==0.3.3 (from tensorflow==1.15.5+nv23.01)
Using cached gast-0.3.3-py2.py3-none-any.whl (9.7 kB)
Collecting google-pasta>=0.1.6 (from tensorflow==1.15.5+nv23.01)
Using cached google_pasta-0.2.0-py3-none-any.whl (57 kB)
Requirement already satisfied: keras-applications>=1.0.8 in /usr/local/lib/python3.8/dist-packages (from tensorflow==1.15.5+nv23.01) (1.0.8)
Requirement already satisfied: keras-preprocessing>=1.0.5 in /usr/local/lib/python3.8/dist-packages (from tensorflow==1.15.5+nv23.01) (1.1.2)
Collecting opt-einsum>=2.3.2 (from tensorflow==1.15.5+nv23.01)
Using cached opt_einsum-3.3.0-py3-none-any.whl (65 kB)
Requirement already satisfied: six>=1.10.0 in /usr/lib/python3/dist-packages (from tensorflow==1.15.5+nv23.01) (1.14.0)
Collecting protobuf<4.0.0,>=3.6.1 (from tensorflow==1.15.5+nv23.01)
Using cached protobuf-3.20.3-cp38-cp38-manylinux2014_aarch64.whl (918 kB)
Collecting tensorboard<1.16.0,>=1.15.0 (from tensorflow==1.15.5+nv23.01)
Using cached tensorboard-1.15.0-py3-none-any.whl (3.8 MB)
Collecting tensorflow-estimator==1.15.1 (from tensorflow==1.15.5+nv23.01)
Using cached tensorflow_estimator-1.15.1-py2.py3-none-any.whl (503 kB)
Collecting termcolor>=1.1.0 (from tensorflow==1.15.5+nv23.01)
Using cached termcolor-2.3.0-py3-none-any.whl (6.9 kB)
Collecting wrapt>=1.11.1 (from tensorflow==1.15.5+nv23.01)
Using cached wrapt-1.15.0-cp38-cp38-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (81 kB)
Collecting h5py==2.10.0 (from tensorflow==1.15.5+nv23.01)
Using cached h5py-2.10.0.tar.gz (301 kB)
Running command python setup.py egg_info
running egg_info
creating /tmp/pip-pip-egg-info-xhsz_oki/h5py.egg-info
writing /tmp/pip-pip-egg-info-xhsz_oki/h5py.egg-info/PKG-INFO
writing dependency_links to /tmp/pip-pip-egg-info-xhsz_oki/h5py.egg-info/dependency_links.txt
writing requirements to /tmp/pip-pip-egg-info-xhsz_oki/h5py.egg-info/requires.txt
writing top-level names to /tmp/pip-pip-egg-info-xhsz_oki/h5py.egg-info/top_level.txt
writing manifest file '/tmp/pip-pip-egg-info-xhsz_oki/h5py.egg-info/SOURCES.txt'
reading manifest file '/tmp/pip-pip-egg-info-xhsz_oki/h5py.egg-info/SOURCES.txt'
reading manifest template 'MANIFEST.in'
no previously-included directories found matching 'docs/_build'
no previously-included directories found matching 'docs_api/_build'
warning: no previously-included files found matching 'h5py/config.pxi'
warning: no previously-included files found matching 'h5py/defs.pxd'
warning: no previously-included files found matching 'h5py/defs.pyx'
warning: no previously-included files matching '.DS_Store' found under directory '*'
warning: no previously-included files found matching 'ci'
warning: no previously-included files found matching 'other'
warning: no previously-included files found matching '.github'
warning: no previously-included files matching '*' found under directory 'ci'
warning: no previously-included files matching '*' found under directory 'other'
warning: no previously-included files matching '*' found under directory '.github'
warning: no previously-included files found matching 'pavement.py'
warning: no previously-included files found matching '*.yml'
warning: no previously-included files found matching '*.yaml'
warning: no previously-included files matching '__pycache__' found under directory '*'
warning: no previously-included files matching '*.py[co]' found under directory '*'
warning: no previously-included files found matching '.coveragerc'
warning: no previously-included files found matching '.mailmap'
warning: no previously-included files found matching 'rever.xsh'
no previously-included directories found matching 'news'
adding license file 'LICENSE'
adding license file 'AUTHORS'
Preparing metadata (setup.py) ... done
Collecting grpcio>=1.8.6 (from tensorflow==1.15.5+nv23.01)
Obtaining dependency information for grpcio>=1.8.6 from https://files.pythonhosted.org/packages/20/ae/627b64425ce31355824a3f38416ab36e0476895317b1cfe056f9d46c4972/grpcio-1.57.0-cp38-cp38-manylinux_2_17_aarch64.whl.metadata
Using cached grpcio-1.57.0-cp38-cp38-manylinux_2_17_aarch64.whl.metadata (4.0 kB)
Requirement already satisfied: wheel>=0.26 in /usr/lib/python3/dist-packages (from tensorflow==1.15.5+nv23.01) (0.34.2)
Requirement already satisfied: numpy>=1.20.0 in /usr/local/lib/python3.8/dist-packages (from tensorflow==1.15.5+nv23.01) (1.22.0)
Collecting markdown>=2.6.8 (from tensorboard<1.16.0,>=1.15.0->tensorflow==1.15.5+nv23.01)
Obtaining dependency information for markdown>=2.6.8 from https://files.pythonhosted.org/packages/1a/b5/228c1cdcfe138f1a8e01ab1b54284c8b83735476cb22b6ba251656ed13ad/Markdown-3.4.4-py3-none-any.whl.metadata
Using cached Markdown-3.4.4-py3-none-any.whl.metadata (6.9 kB)
Requirement already satisfied: setuptools>=41.0.0 in /usr/local/lib/python3.8/dist-packages (from tensorboard<1.16.0,>=1.15.0->tensorflow==1.15.5+nv23.01) (65.5.0)
Collecting werkzeug>=0.11.15 (from tensorboard<1.16.0,>=1.15.0->tensorflow==1.15.5+nv23.01)
Obtaining dependency information for werkzeug>=0.11.15 from https://files.pythonhosted.org/packages/9b/59/a7c32e3d8d0e546a206e0552a2c04444544f15c1da4a01df8938d20c6ffc/werkzeug-2.3.7-py3-none-any.whl.metadata
Using cached werkzeug-2.3.7-py3-none-any.whl.metadata (4.1 kB)
Collecting importlib-metadata>=4.4 (from markdown>=2.6.8->tensorboard<1.16.0,>=1.15.0->tensorflow==1.15.5+nv23.01)
Obtaining dependency information for importlib-metadata>=4.4 from https://files.pythonhosted.org/packages/cc/37/db7ba97e676af155f5fcb1a35466f446eadc9104e25b83366e8088c9c926/importlib_metadata-6.8.0-py3-none-any.whl.metadata
Using cached importlib_metadata-6.8.0-py3-none-any.whl.metadata (5.1 kB)
Collecting MarkupSafe>=2.1.1 (from werkzeug>=0.11.15->tensorboard<1.16.0,>=1.15.0->tensorflow==1.15.5+nv23.01)
Obtaining dependency information for MarkupSafe>=2.1.1 from https://files.pythonhosted.org/packages/8d/66/4a46c7f1402e0377a8b220fd4b53cc4f1b2337ab0d97f06e23acd1f579d1/MarkupSafe-2.1.3-cp38-cp38-manylinux_2_17_aarch64.manylinux2014_aarch64.whl.metadata
Using cached MarkupSafe-2.1.3-cp38-cp38-manylinux_2_17_aarch64.manylinux2014_aarch64.whl.metadata (3.0 kB)
Collecting zipp>=0.5 (from importlib-metadata>=4.4->markdown>=2.6.8->tensorboard<1.16.0,>=1.15.0->tensorflow==1.15.5+nv23.01)
Obtaining dependency information for zipp>=0.5 from https://files.pythonhosted.org/packages/8c/08/d3006317aefe25ea79d3b76c9650afabaf6d63d1c8443b236e7405447503/zipp-3.16.2-py3-none-any.whl.metadata
Using cached zipp-3.16.2-py3-none-any.whl.metadata (3.7 kB)
Using cached grpcio-1.57.0-cp38-cp38-manylinux_2_17_aarch64.whl (4.8 MB)
Using cached Markdown-3.4.4-py3-none-any.whl (94 kB)
Using cached werkzeug-2.3.7-py3-none-any.whl (242 kB)
Using cached importlib_metadata-6.8.0-py3-none-any.whl (22 kB)
Using cached MarkupSafe-2.1.3-cp38-cp38-manylinux_2_17_aarch64.manylinux2014_aarch64.whl (26 kB)
Using cached zipp-3.16.2-py3-none-any.whl (7.2 kB)
Building wheels for collected packages: h5py
Running command python setup.py bdist_wheel
running bdist_wheel
running build
running build_py
creating build
creating build/lib.linux-aarch64-cpython-38
creating build/lib.linux-aarch64-cpython-38/h5py
copying h5py/h5py_warnings.py -> build/lib.linux-aarch64-cpython-38/h5py
copying h5py/version.py -> build/lib.linux-aarch64-cpython-38/h5py
copying h5py/ipy_completer.py -> build/lib.linux-aarch64-cpython-38/h5py
copying h5py/highlevel.py -> build/lib.linux-aarch64-cpython-38/h5py
copying h5py/__init__.py -> build/lib.linux-aarch64-cpython-38/h5py
creating build/lib.linux-aarch64-cpython-38/h5py/_hl
copying h5py/_hl/compat.py -> build/lib.linux-aarch64-cpython-38/h5py/_hl
copying h5py/_hl/dataset.py -> build/lib.linux-aarch64-cpython-38/h5py/_hl
copying h5py/_hl/base.py -> build/lib.linux-aarch64-cpython-38/h5py/_hl
copying h5py/_hl/vds.py -> build/lib.linux-aarch64-cpython-38/h5py/_hl
copying h5py/_hl/datatype.py -> build/lib.linux-aarch64-cpython-38/h5py/_hl
copying h5py/_hl/attrs.py -> build/lib.linux-aarch64-cpython-38/h5py/_hl
copying h5py/_hl/selections.py -> build/lib.linux-aarch64-cpython-38/h5py/_hl
copying h5py/_hl/group.py -> build/lib.linux-aarch64-cpython-38/h5py/_hl
copying h5py/_hl/dims.py -> build/lib.linux-aarch64-cpython-38/h5py/_hl
copying h5py/_hl/files.py -> build/lib.linux-aarch64-cpython-38/h5py/_hl
copying h5py/_hl/filters.py -> build/lib.linux-aarch64-cpython-38/h5py/_hl
copying h5py/_hl/__init__.py -> build/lib.linux-aarch64-cpython-38/h5py/_hl
copying h5py/_hl/selections2.py -> build/lib.linux-aarch64-cpython-38/h5py/_hl
creating build/lib.linux-aarch64-cpython-38/h5py/tests
copying h5py/tests/test_deprecation.py -> build/lib.linux-aarch64-cpython-38/h5py/tests
copying h5py/tests/test_file.py -> build/lib.linux-aarch64-cpython-38/h5py/tests
copying h5py/tests/test_dimension_scales.py -> build/lib.linux-aarch64-cpython-38/h5py/tests
copying h5py/tests/test_filters.py -> build/lib.linux-aarch64-cpython-38/h5py/tests
copying h5py/tests/common.py -> build/lib.linux-aarch64-cpython-38/h5py/tests
copying h5py/tests/test_h5pl.py -> build/lib.linux-aarch64-cpython-38/h5py/tests
copying h5py/tests/test_dims_dimensionproxy.py -> build/lib.linux-aarch64-cpython-38/h5py/tests
copying h5py/tests/test_group.py -> build/lib.linux-aarch64-cpython-38/h5py/tests
copying h5py/tests/test_datatype.py -> build/lib.linux-aarch64-cpython-38/h5py/tests
copying h5py/tests/test_file2.py -> build/lib.linux-aarch64-cpython-38/h5py/tests
copying h5py/tests/test_base.py -> build/lib.linux-aarch64-cpython-38/h5py/tests
copying h5py/tests/test_h5.py -> build/lib.linux-aarch64-cpython-38/h5py/tests
copying h5py/tests/test_dataset_swmr.py -> build/lib.linux-aarch64-cpython-38/h5py/tests
copying h5py/tests/test_dtype.py -> build/lib.linux-aarch64-cpython-38/h5py/tests
copying h5py/tests/test_objects.py -> build/lib.linux-aarch64-cpython-38/h5py/tests
copying h5py/tests/test_h5d_direct_chunk.py -> build/lib.linux-aarch64-cpython-38/h5py/tests
copying h5py/tests/test_dataset.py -> build/lib.linux-aarch64-cpython-38/h5py/tests
copying h5py/tests/test_attrs_data.py -> build/lib.linux-aarch64-cpython-38/h5py/tests
copying h5py/tests/test_selections.py -> build/lib.linux-aarch64-cpython-38/h5py/tests
copying h5py/tests/test_threads.py -> build/lib.linux-aarch64-cpython-38/h5py/tests
copying h5py/tests/test_h5p.py -> build/lib.linux-aarch64-cpython-38/h5py/tests
copying h5py/tests/test_file_image.py -> build/lib.linux-aarch64-cpython-38/h5py/tests
copying h5py/tests/test_attribute_create.py -> build/lib.linux-aarch64-cpython-38/h5py/tests
copying h5py/tests/test_completions.py -> build/lib.linux-aarch64-cpython-38/h5py/tests
copying h5py/tests/test_dataset_getitem.py -> build/lib.linux-aarch64-cpython-38/h5py/tests
copying h5py/tests/test_h5t.py -> build/lib.linux-aarch64-cpython-38/h5py/tests
copying h5py/tests/__init__.py -> build/lib.linux-aarch64-cpython-38/h5py/tests
copying h5py/tests/test_slicing.py -> build/lib.linux-aarch64-cpython-38/h5py/tests
copying h5py/tests/test_attrs.py -> build/lib.linux-aarch64-cpython-38/h5py/tests
copying h5py/tests/test_h5f.py -> build/lib.linux-aarch64-cpython-38/h5py/tests
creating build/lib.linux-aarch64-cpython-38/h5py/tests/test_vds
copying h5py/tests/test_vds/test_lowlevel_vds.py -> build/lib.linux-aarch64-cpython-38/h5py/tests/test_vds
copying h5py/tests/test_vds/test_highlevel_vds.py -> build/lib.linux-aarch64-cpython-38/h5py/tests/test_vds
copying h5py/tests/test_vds/test_virtual_source.py -> build/lib.linux-aarch64-cpython-38/h5py/tests/test_vds
copying h5py/tests/test_vds/__init__.py -> build/lib.linux-aarch64-cpython-38/h5py/tests/test_vds
running build_ext
Loading library to get version: /usr/lib/aarch64-linux-gnu/hdf5/serial/libhdf5.so
Autodetected HDF5 1.10.4
Summary of the h5py configuration
Path to HDF5: None
HDF5 Version: '1.10.4'
MPI Enabled: False
Rebuild Required: True
Executing api_gen rebuild of defs
Executing cythonize()
[ 1/23] Cythonizing /tmp/pip-install-g16hq_w6/h5py_0a8692ab49b44833b48657c74c70266c/h5py/_conv.pyx
warning: h5py/config.pxi:3:0: The 'DEF' statement is deprecated and will be removed in a future Cython version. Consider using global variables, constants, and in-place literals instead. See https://github.com/cython/cython/issues/4310
warning: h5py/config.pxi:4:0: The 'DEF' statement is deprecated and will be removed in a future Cython version. Consider using global variables, constants, and in-place literals instead. See https://github.com/cython/cython/issues/4310
warning: h5py/config.pxi:5:0: The 'DEF' statement is deprecated and will be removed in a future Cython version. Consider using global variables, constants, and in-place literals instead. See https://github.com/cython/cython/issues/4310
warning: h5py/config.pxi:6:0: The 'DEF' statement is deprecated and will be removed in a future Cython version. Consider using global variables, constants, and in-place literals instead. See https://github.com/cython/cython/issues/4310
warning: h5py/config.pxi:7:0: The 'DEF' statement is deprecated and will be removed in a future Cython version. Consider using global variables, constants, and in-place literals instead. See https://github.com/cython/cython/issues/4310
warning: h5py/config.pxi:8:0: The 'DEF' statement is deprecated and will be removed in a future Cython version. Consider using global variables, constants, and in-place literals instead. See https://github.com/cython/cython/issues/4310
warning: h5py/defs.pxd:57:0: The 'IF' statement is deprecated and will be removed in a future Cython version. Consider using runtime conditions or C macros instead. See https://github.com/cython/cython/issues/4310
warning: h5py/defs.pxd:59:0: The 'IF' statement is deprecated and will be removed in a future Cython version. Consider using runtime conditions or C macros instead. See https://github.com/cython/cython/issues/4310
warning: h5py/defs.pxd:61:0: The 'IF' statement is deprecated and will be removed in a future Cython version. Consider using runtime conditions or C macros instead. See https://github.com/cython/cython/issues/4310
warning: h5py/defs.pxd:63:0: The 'IF' statement is deprecated and will be removed in a future Cython version. Consider using runtime conditions or C macros instead. See https://github.com/cython/cython/issues/4310
warning: h5py/defs.pxd:65:0: The 'IF' statement is deprecated and will be removed in a future Cython version. Consider using runtime conditions or C macros instead. See https://github.com/cython/cython/issues/4310
warning: h5py/defs.pxd:67:0: The 'IF' statement is deprecated and will be removed in a future Cython version. Consider using runtime conditions or C macros instead. See https://github.com/cython/cython/issues/4310
warning: h5py/defs.pxd:92:0: The 'IF' statement is deprecated and will be removed in a future Cython version. Consider using runtime conditions or C macros instead. See https://github.com/cython/cython/issues/4310
warning: h5py/defs.pxd:94:0: The 'IF' statement is deprecated and will be removed in a future Cython version. Consider using runtime conditions or C macros instead. See https://github.com/cython/cython/issues/4310
warning: h5py/defs.pxd:96:0: The 'IF' statement is deprecated and will be removed in a future Cython version. Consider using runtime conditions or C macros instead. See https://github.com/cython/cython/issues/4310
warning: h5py/defs.pxd:97:4: The 'IF' statement is deprecated and will be removed in a future Cython version. Consider using runtime conditions or C macros instead. See https://github.com/cython/cython/issues/4310
warning: h5py/defs.pxd:99:0: The 'IF' statement is deprecated and will be removed in a future Cython version. Consider using runtime conditions or C macros instead. See https://github.com/cython/cython/issues/4310
warning: h5py/defs.pxd:100:4: The 'IF' statement is deprecated and will be removed in a future Cython version. Consider using runtime conditions or C macros instead. See https://github.com/cython/cython/issues/4310
warning: h5py/defs.pxd:102:0: The 'IF' statement is deprecated and will be removed in a future Cython version. Consider using runtime conditions or C macros instead. See https://github.com/cython/cython/issues/4310
warning: h5py/defs.pxd:168:0: The 'IF' statement is deprecated and will be removed in a future Cython version. Consider using runtime conditions or C macros instead. See https://github.com/cython/cython/issues/4310
warning: h5py/defs.pxd:204:0: The 'IF' statement is deprecated and will be removed in a future Cython version. Consider using runtime conditions or C macros instead. See https://github.com/cython/cython/issues/4310
warning: h5py/defs.pxd:232:0: The 'IF' statement is deprecated and will be removed in a future Cython version. Consider using runtime conditions or C macros instead. See https://github.com/cython/cython/issues/4310
warning: h5py/defs.pxd:234:0: The 'IF' statement is deprecated and will be removed in a future Cython version. Consider using runtime conditions or C macros instead. See https://github.com/cython/cython/issues/4310
warning: h5py/defs.pxd:236:0: The 'IF' statement is deprecated and will be removed in a future Cython version. Consider using runtime conditions or C macros instead. See https://github.com/cython/cython/issues/4310
warning: h5py/defs.pxd:238:0: The 'IF' statement is deprecated and will be removed in a future Cython version. Consider using runtime conditions or C macros instead. See https://github.com/cython/cython/issues/4310
warning: h5py/defs.pxd:240:0: The 'IF' statement is deprecated and will be removed in a future Cython version. Consider using runtime conditions or C macros instead. See https://github.com/cython/cython/issues/4310
warning: h5py/defs.pxd:242:0: The 'IF' statement is deprecated and will be removed in a future Cython version. Consider using runtime conditions or C macros instead. See https://github.com/cython/cython/issues/4310
warning: h5py/defs.pxd:248:0: The 'IF' statement is deprecated and will be removed in a future Cython version. Consider using runtime conditions or C macros instead. See https://github.com/cython/cython/issues/4310
warning: h5py/defs.pxd:250:0: The 'IF' statement is deprecated and will be removed in a future Cython version. Consider using runtime conditions or C macros instead. See https://github.com/cython/cython/issues/4310
warning: h5py/defs.pxd:252:0: The 'IF' statement is deprecated and will be removed in a future Cython version. Consider using runtime conditions or C macros instead. See https://github.com/cython/cython/issues/4310
warning: h5py/defs.pxd:254:0: The 'IF' statement is deprecated and will be removed in a future Cython version. Consider using runtime conditions or C macros instead. See https://github.com/cython/cython/issues/4310
warning: h5py/defs.pxd:256:0: The 'IF' statement is deprecated and will be removed in a future Cython version. Consider using runtime conditions or C macros instead. See https://github.com/cython/cython/issues/4310
warning: h5py/defs.pxd:258:0: The 'IF' statement is deprecated and will be removed in a future Cython version. Consider using runtime conditions or C macros instead. See https://github.com/cython/cython/issues/4310
warning: h5py/defs.pxd:290:0: The 'IF' statement is deprecated and will be removed in a future Cython version. Consider using runtime conditions or C macros instead. See https://github.com/cython/cython/issues/4310
warning: h5py/defs.pxd:292:0: The 'IF' statement is deprecated and will be removed in a future Cython version. Consider using runtime conditions or C macros instead. See https://github.com/cython/cython/issues/4310
warning: h5py/defs.pxd:294:0: The 'IF' statement is deprecated and will be removed in a future Cython version. Consider using runtime conditions or C macros instead. See https://github.com/cython/cython/issues/4310
warning: h5py/defs.pxd:296:0: The 'IF' statement is deprecated and will be removed in a future Cython version. Consider using runtime conditions or C macros instead. See https://github.com/cython/cython/issues/4310
warning: h5py/defs.pxd:298:0: The 'IF' statement is deprecated and will be removed in a future Cython version. Consider using runtime conditions or C macros instead. See https://github.com/cython/cython/issues/4310
warning: h5py/defs.pxd:300:0: The 'IF' statement is deprecated and will be removed in a future Cython version. Consider using runtime conditions or C macros instead. See https://github.com/cython/cython/issues/4310
warning: h5py/defs.pxd:302:0: The 'IF' statement is deprecated and will be removed in a future Cython version. Consider using runtime conditions or C macros instead. See https://github.com/cython/cython/issues/4310
warning: h5py/defs.pxd:304:0: The 'IF' statement is deprecated and will be removed in a future Cython version. Consider using runtime conditions or C macros instead. See https://github.com/cython/cython/issues/4310
warning: h5py/defs.pxd:306:0: The 'IF' statement is deprecated and will be removed in a future Cython version. Consider using runtime conditions or C macros instead. See https://github.com/cython/cython/issues/4310
warning: h5py/defs.pxd:340:0: The 'IF' statement is deprecated and will be removed in a future Cython version. Consider using runtime conditions or C macros instead. See https://github.com/cython/cython/issues/4310
warning: h5py/defs.pxd:342:0: The 'IF' statement is deprecated and will be removed in a future Cython version. Consider using runtime conditions or C macros instead. See https://github.com/cython/cython/issues/4310
warning: h5py/api_types_hdf5.pxd:55:2: The 'IF' statement is deprecated and will be removed in a future Cython version. Consider using runtime conditions or C macros instead. See https://github.com/cython/cython/issues/4310
warning: h5py/api_types_hdf5.pxd:128:2: The 'IF' statement is deprecated and will be removed in a future Cython version. Consider using runtime conditions or C macros instead. See https://github.com/cython/cython/issues/4310
warning: h5py/api_types_hdf5.pxd:197:2: The 'IF' statement is deprecated and will be removed in a future Cython version. Consider using runtime conditions or C macros instead. See https://github.com/cython/cython/issues/4310
warning: h5py/api_types_hdf5.pxd:418:2: 'H5D_layout_t' redeclared
warning: h5py/api_types_hdf5.pxd:425:2: 'H5D_alloc_time_t' redeclared
warning: h5py/api_types_hdf5.pxd:432:2: 'H5D_space_status_t' redeclared
warning: h5py/api_types_hdf5.pxd:438:2: 'H5D_fill_time_t' redeclared
warning: h5py/api_types_hdf5.pxd:444:2: 'H5D_fill_value_t' redeclared
warning: h5py/api_types_hdf5.pxd:456:7: 'H5F_close_degree_t' redeclared
warning: h5py/api_types_hdf5.pxd:462:2: 'H5FD_mem_t' redeclared
warning: h5py/api_types_hdf5.pxd:560:2: 'H5T_cset_t' redeclared
warning: h5py/api_types_hdf5.pxd:739:7: 'H5Z_EDC_t' redeclared
warning: h5py/api_types_ext.pxd:14:0: The 'IF' statement is deprecated and will be removed in a future Cython version. Consider using runtime conditions or C macros instead. See https://github.com/cython/cython/issues/4310
warning: h5py/api_types_ext.pxd:35:0: The 'IF' statement is deprecated and will be removed in a future Cython version. Consider using runtime conditions or C macros instead. See https://github.com/cython/cython/issues/4310
warning: h5py/api_types_ext.pxd:71:2: The 'IF' statement is deprecated and will be removed in a future Cython version. Consider using runtime conditions or C macros instead. See https://github.com/cython/cython/issues/4310
warning: h5py/api_types_hdf5.pxd:419:4: 'H5D_LAYOUT_ERROR' redeclared
warning: h5py/api_types_hdf5.pxd:420:4: 'H5D_COMPACT' redeclared
warning: h5py/api_types_hdf5.pxd:421:4: 'H5D_CONTIGUOUS' redeclared
warning: h5py/api_types_hdf5.pxd:422:4: 'H5D_CHUNKED' redeclared
warning: h5py/api_types_hdf5.pxd:423:4: 'H5D_NLAYOUTS' redeclared
warning: h5py/api_types_hdf5.pxd:426:4: 'H5D_ALLOC_TIME_ERROR' redeclared
warning: h5py/api_types_hdf5.pxd:427:4: 'H5D_ALLOC_TIME_DEFAULT' redeclared
warning: h5py/api_types_hdf5.pxd:428:4: 'H5D_ALLOC_TIME_EARLY' redeclared
warning: h5py/api_types_hdf5.pxd:429:4: 'H5D_ALLOC_TIME_LATE' redeclared
warning: h5py/api_types_hdf5.pxd:430:4: 'H5D_ALLOC_TIME_INCR' redeclared
warning: h5py/api_types_hdf5.pxd:433:4: 'H5D_SPACE_STATUS_ERROR' redeclared
warning: h5py/api_types_hdf5.pxd:434:4: 'H5D_SPACE_STATUS_NOT_ALLOCATED' redeclared
warning: h5py/api_types_hdf5.pxd:435:4: 'H5D_SPACE_STATUS_PART_ALLOCATED' redeclared
warning: h5py/api_types_hdf5.pxd:436:4: 'H5D_SPACE_STATUS_ALLOCATED' redeclared
warning: h5py/api_types_hdf5.pxd:439:4: 'H5D_FILL_TIME_ERROR' redeclared
warning: h5py/api_types_hdf5.pxd:440:4: 'H5D_FILL_TIME_ALLOC' redeclared
warning: h5py/api_types_hdf5.pxd:441:4: 'H5D_FILL_TIME_NEVER' redeclared
warning: h5py/api_types_hdf5.pxd:442:4: 'H5D_FILL_TIME_IFSET' redeclared
warning: h5py/api_types_hdf5.pxd:445:4: 'H5D_FILL_VALUE_ERROR' redeclared
warning: h5py/api_types_hdf5.pxd:446:4: 'H5D_FILL_VALUE_UNDEFINED' redeclared
warning: h5py/api_types_hdf5.pxd:447:4: 'H5D_FILL_VALUE_DEFAULT' redeclared
warning: h5py/api_types_hdf5.pxd:448:4: 'H5D_FILL_VALUE_USER_DEFINED' redeclared
warning: h5py/api_types_hdf5.pxd:457:4: 'H5F_CLOSE_WEAK' redeclared
warning: h5py/api_types_hdf5.pxd:458:4: 'H5F_CLOSE_SEMI' redeclared
warning: h5py/api_types_hdf5.pxd:459:4: 'H5F_CLOSE_STRONG' redeclared
warning: h5py/api_types_hdf5.pxd:460:4: 'H5F_CLOSE_DEFAULT' redeclared
warning: h5py/api_types_hdf5.pxd:463:4: 'H5FD_MEM_NOLIST' redeclared
warning: h5py/api_types_hdf5.pxd:464:4: 'H5FD_MEM_DEFAULT' redeclared
warning: h5py/api_types_hdf5.pxd:465:4: 'H5FD_MEM_SUPER' redeclared
warning: h5py/api_types_hdf5.pxd:466:4: 'H5FD_MEM_BTREE' redeclared
warning: h5py/api_types_hdf5.pxd:467:4: 'H5FD_MEM_DRAW' redeclared
warning: h5py/api_types_hdf5.pxd:468:4: 'H5FD_MEM_GHEAP' redeclared
warning: h5py/api_types_hdf5.pxd:469:4: 'H5FD_MEM_LHEAP' redeclared
warning: h5py/api_types_hdf5.pxd:470:4: 'H5FD_MEM_OHDR' redeclared
warning: h5py/api_types_hdf5.pxd:471:4: 'H5FD_MEM_NTYPES' redeclared
warning: h5py/api_types_hdf5.pxd:561:4: 'H5T_CSET_ERROR' redeclared
warning: h5py/api_types_hdf5.pxd:562:4: 'H5T_CSET_ASCII' redeclared
warning: h5py/api_types_hdf5.pxd:705:2: 'H5Z_filter_t' redeclared
warning: h5py/api_types_hdf5.pxd:740:6: 'H5Z_ERROR_EDC' redeclared
warning: h5py/api_types_hdf5.pxd:741:6: 'H5Z_DISABLE_EDC' redeclared
warning: h5py/api_types_hdf5.pxd:742:6: 'H5Z_ENABLE_EDC' redeclared
warning: h5py/api_types_hdf5.pxd:743:6: 'H5Z_NO_EDC' redeclared
Error compiling Cython file:
# License: Standard 3-clause BSD; see "license.txt" for full license terms
# and contributor agreement.
from defs cimport *
from _objects cimport class ObjectID
h5py/h5t.pxd:12:22: Expected an identifier
Low-level type-conversion routines.
from h5 import get_config
from h5r cimport Reference, RegionReference, hobj_ref_t, hdset_reg_ref_t
from h5t cimport H5PY_OBJ, typewrap, py_create, TypeID
h5py/_conv.pyx:18:0: 'h5py/h5t/H5PY_OBJ.pxd' not found
h5py/_conv.pyx:18:0: 'h5py/h5t/typewrap.pxd' not found
h5py/_conv.pyx:18:0: 'h5py/h5t/py_create.pxd' not found
h5py/_conv.pyx:18:0: 'h5py/h5t/TypeID.pxd' not found
cdef struct vlen_t:
size_t len
void* ptr
cdef int conv_vlen2ndarray(void* ipt, void* opt, np.dtype elem_dtype,
TypeID intype, TypeID outtype) except -1:
h5py/_conv.pyx:680:8: 'TypeID' is not a type identifier
cdef struct vlen_t:
size_t len
void* ptr
h5py/_conv.pyx:680:23: 'TypeID' is not a type identifier
return 0
cdef int conv_ndarray2vlen(void* ipt, void* opt,
h5py/_conv.pyx:788:8: 'TypeID' is not a type identifier
return 0
h5py/_conv.pyx:788:23: 'TypeID' is not a type identifier
size_t nl, size_t buf_stride, size_t bkg_stride, void *buf_i,
void *bkg_i, hid_t dxpl) except -1:
cdef int command = cdata[0].command
cdef size_t src_size, dst_size
cdef TypeID supertype
h5py/_conv.pyx:620:9: 'TypeID' is not a type identifier
cdef TypeID outtype
h5py/_conv.pyx:621:9: 'TypeID' is not a type identifier
h5py/_conv.pyx:718:9: 'TypeID' is not a type identifier
cdef TypeID outtype
h5py/_conv.pyx:719:9: 'TypeID' is not a type identifier
pass
elif command == H5T_CONV_CONV:
# need to pass element dtype to converter
supertype = typewrap(H5Tget_super(src_id))
h5py/_conv.pyx:640:20: 'typewrap' is not a constant, variable or function identifier
dt = supertype.dtype
outtype = py_create(dt)
h5py/_conv.pyx:642:18: 'py_create' is not a constant, variable or function identifier
cdef char* buf = <char*>buf_i
if command == H5T_CONV_INIT:
cdata[0].need_bkg = H5T_BKG_NO
if not H5Tequal(src_id, H5PY_OBJ) or H5Tget_class(dst_id) != H5T_VLEN:
h5py/_conv.pyx:730:32: 'H5PY_OBJ' is not a constant, variable or function identifier
return -2
supertype = typewrap(H5Tget_super(dst_id))
h5py/_conv.pyx:732:20: 'typewrap' is not a constant, variable or function identifier
return -2
for i from 0 <= i < nl:
memcpy(&pdata_elem, pdata+i, sizeof(pdata_elem))
if supertype != py_create((<np.ndarray> pdata_elem).dtype, 1):
h5py/_conv.pyx:735:28: 'py_create' is not a constant, variable or function identifier
if nl == 0:
return 0
memcpy(&pdata_elem, pdata, sizeof(pdata_elem))
supertype = py_create((<np.ndarray> pdata_elem).dtype)
h5py/_conv.pyx:753:20: 'py_create' is not a constant, variable or function identifier
return 0
outtype = typewrap(H5Tget_super(dst_id))
h5py/_conv.pyx:754:18: 'typewrap' is not a constant, variable or function identifier
enum = H5Tenum_create(H5T_STD_I32LE)
vlentype = H5Tvlen_create(H5T_STD_I32LE)
pyobj = H5PY_OBJ
h5py/_conv.pyx:860:12: 'H5PY_OBJ' is not a constant, variable or function identifier
File "<string>", line 2, in <module>
File "<pip-setuptools-caller>", line 34, in <module>
File "/tmp/pip-install-g16hq_w6/h5py_0a8692ab49b44833b48657c74c70266c/setup.py", line 140, in <module>
setup(
File "/usr/local/lib/python3.8/dist-packages/setuptools/__init__.py", line 87, in setup
return distutils.core.setup(**attrs)
File "/usr/local/lib/python3.8/dist-packages/setuptools/_distutils/core.py", line 185, in setup
return run_commands(dist)
File "/usr/local/lib/python3.8/dist-packages/setuptools/_distutils/core.py", line 201, in run_commands
dist.run_commands()
File "/usr/local/lib/python3.8/dist-packages/setuptools/_distutils/dist.py", line 968, in run_commands
self.run_command(cmd)
File "/usr/local/lib/python3.8/dist-packages/setuptools/dist.py", line 1217, in run_command
super().run_command(command)
File "/usr/local/lib/python3.8/dist-packages/setuptools/_distutils/dist.py", line 987, in run_command
cmd_obj.run()
File "/usr/lib/python3/dist-packages/wheel/bdist_wheel.py", line 223, in run
self.run_command('build')
File "/usr/local/lib/python3.8/dist-packages/setuptools/_distutils/cmd.py", line 319, in run_command
self.distribution.run_command(command)
cmd_obj.run()
File "/usr/local/lib/python3.8/dist-packages/setuptools/_distutils/command/build.py", line 132, in run
self.run_command(cmd_name)
cmd_obj.run()
File "/tmp/pip-install-g16hq_w6/h5py_0a8692ab49b44833b48657c74c70266c/setup_build.py", line 207, in run
self.extensions = cythonize(self._make_extensions(config),
File "/usr/local/lib/python3.8/dist-packages/Cython/Build/Dependencies.py", line 1134, in cythonize
cythonize_one(*args)
File "/usr/local/lib/python3.8/dist-packages/Cython/Build/Dependencies.py", line 1301, in cythonize_one
raise CompileError(None, pyx_file)
Cython.Compiler.Errors.CompileError: /tmp/pip-install-g16hq_w6/h5py_0a8692ab49b44833b48657c74c70266c/h5py/_conv.pyx
error: subprocess-exited-with-error
× python setup.py bdist_wheel did not run successfully.
│ exit code: 1
╰─> See above for output.
note: This error originates from a subprocess, and is likely not a problem with pip.
full command: /usr/bin/python3 -u -c '
exec(compile('"'"''"'"''"'"'
# This is <pip-setuptools-caller> -- a caller that pip uses to run setup.py
# - It imports setuptools before invoking setup.py, to enable projects that directly
# import from `distutils.core` to work with newer packaging standards.
# - It provides a clear error message when setuptools is not installed.
# - It sets `sys.argv[0]` to the underlying `setup.py`, when invoking `setup.py` so
# setuptools doesn'"'"'t think the script is `-c`. This avoids the following warning:
# manifest_maker: standard file '"'"'-c'"'"' not found".
# - It generates a shim setup.py, for handling setup.cfg-only projects.
import os, sys, tokenize
try:
import setuptools
except ImportError as error:
print(
"ERROR: Can not execute `setup.py` since setuptools is not available in "
"the build environment.",
file=sys.stderr,
sys.exit(1)
__file__ = %r
sys.argv[0] = __file__
if os.path.exists(__file__):
filename = __file__
with tokenize.open(__file__) as f:
setup_py_code = f.read()
else:
filename = "<auto-generated setuptools caller>"
setup_py_code = "from setuptools import setup; setup()"
exec(compile(setup_py_code, filename, "exec"))
'"'"''"'"''"'"' % ('"'"'/tmp/pip-install-g16hq_w6/h5py_0a8692ab49b44833b48657c74c70266c/setup.py'"'"',), "<pip-setuptools-caller>", "exec"))' bdist_wheel -d /tmp/pip-wheel-otppdim9
cwd: /tmp/pip-install-g16hq_w6/h5py_0a8692ab49b44833b48657c74c70266c/
Building wheel for h5py (setup.py) ... error
ERROR: Failed building wheel for h5py
Running setup.py clean for h5py
Running command python setup.py clean
running clean
removing 'build/lib.linux-aarch64-cpython-38' (and everything under it)
'build/bdist.linux-aarch64' does not exist -- can't clean it
'build/scripts-3.8' does not exist -- can't clean it
removing 'build'
Failed to build h5py
ERROR: Could not build wheels for h5py, which is required to install pyproject.toml-based projects
I have seen similar threads that say that because of the downstream effects of h5py being updated, but I can not seem to get it to install. Do you have any suggestions?
Thank you again for all of the assistance
