Dear Sir,
Thank you for cooperation
how can convert any object detection and tracking using deep learning (python code) to deep stream SDK code .
Please if you have any document illustrated that.
Best regards,
Dear Sir,
Best regards,
You can refer to python test2 sample, here is documentation,
Dear Sir,
Thank you for your cooperation
According your above answer, I went to execute python test2 sample, on jetson TX2 Then, the following error is display:
nujet@nujet-desktop:~$ cd /opt/nvidia/deepstream/deepstream-5.0/sources
nujet@nujet-desktop:/opt/nvidia/deepstream/deepstream-5.0/sources$ cd deepstream_python_apps
nujet@nujet-desktop:/opt/nvidia/deepstream/deepstream-5.0/sources/deepstream_python_apps$ cd apps
nujet@nujet-desktop:/opt/nvidia/deepstream/deepstream-5.0/sources/deepstream_python_apps/apps$ cd deepstream-test2
nujet@nujet-desktop:/opt/nvidia/deepstream/deepstream-5.0/sources/deepstream_python_apps/apps/deepstream-test2$ python3 deepstream_test_2.py /media/64989eb8-73c8-4747-8d86-d31663a02b0b/opt/nvidia/deepstream/deepstream-5.0/samples/streams/sample_1080p_h264.mp4
Creating Pipeline
Creating Source
Creating H264Parser
Creating Decoder
Creating EGLSink
Playing file /media/64989eb8-73c8-4747-8d86-d31663a02b0b/opt/nvidia/deepstream/deepstream-5.0/samples/streams/sample_1080p_h264.mp4
Adding elements to Pipeline
Linking elements in the Pipeline
Starting pipeline
Using winsys: x11
Opening in BLOCKING MODE
ERROR: Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-5.0/sources/deepstream_python_apps/apps/deepstream-test2/…/…/…/…/samples/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_int8.engine open error
0:00:02.518889261 7987 0x3c34d150 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger: NvDsInferContext[UID 4]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1690> [UID = 4]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-5.0/sources/deepstream_python_apps/apps/deepstream-test2/…/…/…/…/samples/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_int8.engine failed
0:00:02.519940717 7987 0x3c34d150 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger: NvDsInferContext[UID 4]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1797> [UID = 4]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-5.0/sources/deepstream_python_apps/apps/deepstream-test2/…/…/…/…/samples/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_int8.engine failed, try rebuild
0:00:02.519978349 7987 0x3c34d150 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger: NvDsInferContext[UID 4]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1715> [UID = 4]: Trying to create engine from model files
Warning: Flatten layer ignored. TensorRT implicitly flattens input to FullyConnected layers, but in other circumstances this will result in undefined behavior.
WARNING: INT8 not supported by platform. Trying FP16 mode.
INFO: [TRT]: Some tactics do not have sufficient workspace memory to run. Increasing workspace size may increase performance, please check verbose output.
INFO: [TRT]: Detected 1 inputs and 1 output network tensors.
ERROR: Serialize engine failed because of file path: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_fp16.engine opened error
0:00:29.393880845 7987 0x3c34d150 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger: NvDsInferContext[UID 4]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1743> [UID = 4]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_fp16.engine
INFO: [Implicit Engine Info]: layers num: 2
0 INPUT kFLOAT input_1 3x224x224
1 OUTPUT kFLOAT predictions/Softmax 6x1x1
0:00:29.432265486 7987 0x3c34d150 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus: [UID 4]: Load new model:dstest2_sgie3_config.txt sucessfully
ERROR: Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-5.0/sources/deepstream_python_apps/apps/deepstream-test2/…/…/…/…/samples/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_int8.engine open error
0:00:29.432631630 7987 0x3c34d150 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger: NvDsInferContext[UID 3]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1690> [UID = 3]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-5.0/sources/deepstream_python_apps/apps/deepstream-test2/…/…/…/…/samples/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_int8.engine failed
0:00:29.432689550 7987 0x3c34d150 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger: NvDsInferContext[UID 3]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1797> [UID = 3]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-5.0/sources/deepstream_python_apps/apps/deepstream-test2/…/…/…/…/samples/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_int8.engine failed, try rebuild
0:00:29.432728846 7987 0x3c34d150 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger: NvDsInferContext[UID 3]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1715> [UID = 3]: Trying to create engine from model files
ERROR: Serialize engine failed because of file path: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_fp16.engine opened error
0:00:56.073479948 7987 0x3c34d150 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger: NvDsInferContext[UID 3]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1743> [UID = 3]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_fp16.engine
1 OUTPUT kFLOAT predictions/Softmax 20x1x1
0:00:56.091153675 7987 0x3c34d150 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus: [UID 3]: Load new model:dstest2_sgie2_config.txt sucessfully
ERROR: Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-5.0/sources/deepstream_python_apps/apps/deepstream-test2/…/…/…/…/samples/models/Secondary_CarColor/resnet18.caffemodel_b16_gpu0_int8.engine open error
0:00:56.091565129 7987 0x3c34d150 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger: NvDsInferContext[UID 2]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1690> [UID = 2]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-5.0/sources/deepstream_python_apps/apps/deepstream-test2/…/…/…/…/samples/models/Secondary_CarColor/resnet18.caffemodel_b16_gpu0_int8.engine failed
0:00:56.091610633 7987 0x3c34d150 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger: NvDsInferContext[UID 2]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1797> [UID = 2]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-5.0/sources/deepstream_python_apps/apps/deepstream-test2/…/…/…/…/samples/models/Secondary_CarColor/resnet18.caffemodel_b16_gpu0_int8.engine failed, try rebuild
0:00:56.091641193 7987 0x3c34d150 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger: NvDsInferContext[UID 2]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1715> [UID = 2]: Trying to create engine from model files
ERROR: Serialize engine failed because of file path: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Secondary_CarColor/resnet18.caffemodel_b16_gpu0_fp16.engine opened error
0:01:20.246172783 7987 0x3c34d150 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger: NvDsInferContext[UID 2]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1743> [UID = 2]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Secondary_CarColor/resnet18.caffemodel_b16_gpu0_fp16.engine
1 OUTPUT kFLOAT predictions/Softmax 12x1x1
0:01:20.265758291 7987 0x3c34d150 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus: [UID 2]: Load new model:dstest2_sgie1_config.txt sucessfully
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_mot_klt.so
gstnvtracker: Optional NvMOT_RemoveStreams not implemented
gstnvtracker: Batch processing is OFF
gstnvtracker: Past frame output is OFF
ERROR: Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-5.0/sources/deepstream_python_apps/apps/deepstream-test2/…/…/…/…/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine open error
0:01:20.489770083 7987 0x3c34d150 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1690> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-5.0/sources/deepstream_python_apps/apps/deepstream-test2/…/…/…/…/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine failed
0:01:20.489814595 7987 0x3c34d150 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1797> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-5.0/sources/deepstream_python_apps/apps/deepstream-test2/…/…/…/…/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine failed, try rebuild
0:01:20.489840163 7987 0x3c34d150 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1715> [UID = 1]: Trying to create engine from model files
INFO: [TRT]: Detected 1 inputs and 2 output network tensors.
ERROR: Serialize engine failed because of file path: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_fp16.engine opened error
0:01:35.269191009 7987 0x3c34d150 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1743> [UID = 1]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_fp16.engine
INFO: [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:01:35.278569579 7987 0x3c34d150 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus: [UID 1]: Load new model:dstest2_pgie_config.txt sucessfully
Error: gst-stream-error-quark: Internal data stream error. (1): gstbaseparse.c(3611): gst_base_parse_loop (): /GstPipeline:pipeline0/GstH264Parse:h264-parser:
streaming stopped, reason not-negotiated (-4)
^A^Z
[1]+ Stopped python3 deepstream_test_2.py /media/64989eb8-73c8-4747-8d86-d31663a02b0b/opt/nvidia/deepstream/deepstream-5.0/samples/streams/sample_1080p_h264.mp4
nujet@nujet-desktop:/opt/nvidia/deepstream/deepstream-5.0/sources/deepstream_python_apps/apps/deepstream-test2$ sudo modprobe v4l2loopback
[sudo] password for nujet:
Sorry, try again.
modprobe: FATAL: Module v4l2loopback not found in directory /lib/modules/4.9.140-tegra
nujet@nujet-desktop:/opt/nvidia/deepstream/deepstream-5.0/sources/deepstream_python_apps/apps/deepstream-test2$ insmod v4l2loopback.ko
insmod: ERROR: could not load module v4l2loopback.ko: No such file or directory
nujet@nujet-desktop:/opt/nvidia/deepstream/deepstream-5.0/sources/deepstream_python_apps/apps/deepstream-test2$ sudo apt update
Hit:1 Index of /ubuntu-ports bionic InRelease
Hit:2 https://repo.download.nvidia.com/jetson/common r32.4 InRelease
Get:3 Index of /ubuntu-ports bionic-updates InRelease [88.7 kB]
Hit:4 https://repo.download.nvidia.com/jetson/t186 r32.4 InRelease
Get:5 Index of /ubuntu-ports bionic-backports InRelease [74.6 kB]
Get:6 Index of /ubuntu-ports bionic-security InRelease [88.7 kB]
Get:7 Index of /ubuntu-ports bionic-updates/main arm64 DEP-11 Metadata [289 kB]
Get:8 Index of /ubuntu-ports bionic-updates/universe arm64 DEP-11 Metadata [283 kB]
Get:9 Index of /ubuntu-ports bionic-backports/universe arm64 DEP-11 Metadata [9,292 B]
Get:10 Index of /ubuntu-ports bionic-security/main arm64 DEP-11 Metadata [42.8 kB]
Get:11 Index of /ubuntu-ports bionic-security/universe arm64 DEP-11 Metadata [54.4 kB]
Fetched 931 kB in 6s (155 kB/s)
Reading package lists… Done
Building dependency tree
Reading state information… Done
All packages are up to date.
nujet@nujet-desktop:/opt/nvidia/deepstream/deepstream-5.0/sources/deepstream_python_apps/apps/deepstream-test2$ sudo apt install --reinstall nvidia-l4t-gstreame
E: Unable to locate package nvidia-l4t-gstreame
nujet@nujet-desktop:/opt/nvidia/deepstream/deepstream-5.0/sources/deepstream_python_apps/apps/deepstream-test2$ sudo apt install --reinstall nvidia-l4t-gstreamer
0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
Need to get 629 kB of archives.
After this operation, 0 B of additional disk space will be used.
Get:1 https://repo.download.nvidia.com/jetson/t186 r32.4/main arm64 nvidia-l4t-gstreamer arm64 32.4.4-20201016123640 [629 kB]
Fetched 629 kB in 5s (115 kB/s)
debconf: delaying package configuration, since apt-utils is not installed
(Reading database … 163481 files and directories currently installed.)
Preparing to unpack …/nvidia-l4t-gstreamer_32.4.4-20201016123640_arm64.deb …
Unpacking nvidia-l4t-gstreamer (32.4.4-20201016123640) over (32.4.4-20201016123640) …
Setting up nvidia-l4t-gstreamer (32.4.4-20201016123640) …
Creating Pipeline
Creating Source
Creating H264Parser
Creating Decoder
Creating EGLSink
Starting pipeline
Using winsys: x11
0:00:01.547018613 15290 0x39673350 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger: NvDsInferContext[UID 4]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1690> [UID = 4]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-5.0/sources/deepstream_python_apps/apps/deepstream-test2/…/…/…/…/samples/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_int8.engine failed
0:00:01.547090613 15290 0x39673350 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger: NvDsInferContext[UID 4]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1797> [UID = 4]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-5.0/sources/deepstream_python_apps/apps/deepstream-test2/…/…/…/…/samples/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_int8.engine failed, try rebuild
0:00:01.547115349 15290 0x39673350 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger: NvDsInferContext[UID 4]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1715> [UID = 4]: Trying to create engine from model files
0:00:26.285693943 15290 0x39673350 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger: NvDsInferContext[UID 4]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1743> [UID = 4]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_fp16.engine
0:00:26.323766385 15290 0x39673350 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus: [UID 4]: Load new model:dstest2_sgie3_config.txt sucessfully
0:00:26.324088913 15290 0x39673350 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger: NvDsInferContext[UID 3]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1690> [UID = 3]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-5.0/sources/deepstream_python_apps/apps/deepstream-test2/…/…/…/…/samples/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_int8.engine failed
0:00:26.324127761 15290 0x39673350 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger: NvDsInferContext[UID 3]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1797> [UID = 3]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-5.0/sources/deepstream_python_apps/apps/deepstream-test2/…/…/…/…/samples/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_int8.engine failed, try rebuild
0:00:26.324153329 15290 0x39673350 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger: NvDsInferContext[UID 3]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1715> [UID = 3]: Trying to create engine from model files
0:00:52.828158967 15290 0x39673350 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger: NvDsInferContext[UID 3]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1743> [UID = 3]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_fp16.engine
0:00:52.845846133 15290 0x39673350 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus: [UID 3]: Load new model:dstest2_sgie2_config.txt sucessfully
0:00:52.846333077 15290 0x39673350 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger: NvDsInferContext[UID 2]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1690> [UID = 2]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-5.0/sources/deepstream_python_apps/apps/deepstream-test2/…/…/…/…/samples/models/Secondary_CarColor/resnet18.caffemodel_b16_gpu0_int8.engine failed
0:00:52.846375701 15290 0x39673350 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger: NvDsInferContext[UID 2]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1797> [UID = 2]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-5.0/sources/deepstream_python_apps/apps/deepstream-test2/…/…/…/…/samples/models/Secondary_CarColor/resnet18.caffemodel_b16_gpu0_int8.engine failed, try rebuild
0:00:52.846403413 15290 0x39673350 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger: NvDsInferContext[UID 2]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1715> [UID = 2]: Trying to create engine from model files
0:01:16.892289336 15290 0x39673350 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger: NvDsInferContext[UID 2]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1743> [UID = 2]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Secondary_CarColor/resnet18.caffemodel_b16_gpu0_fp16.engine
0:01:16.912771606 15290 0x39673350 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus: [UID 2]: Load new model:dstest2_sgie1_config.txt sucessfully
0:01:17.065879744 15290 0x39673350 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1690> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-5.0/sources/deepstream_python_apps/apps/deepstream-test2/…/…/…/…/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine failed
0:01:17.065930080 15290 0x39673350 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1797> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-5.0/sources/deepstream_python_apps/apps/deepstream-test2/…/…/…/…/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine failed, try rebuild
0:01:17.065960896 15290 0x39673350 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1715> [UID = 1]: Trying to create engine from model files
0:01:31.512198532 15290 0x39673350 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1743> [UID = 1]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_fp16.engine
0:01:31.519296995 15290 0x39673350 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus: [UID 1]: Load new model:dstest2_pgie_config.txt sucessfully
Please can you help me.
Best regards,
test2 python sample only accept H264 elementary stream. well, if you want to try with other format, container, you could refer to test3 sample.
