DeepStream 1.1.8 demo app deepstream-test1 failed
I have DeepStream 1.1.8 installed, and try to run 1.1.8 deepstream-test1.
It failed with below log, and idea?
daniel@daniel-nvidia:/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/apps/deepstream-test1$ python3 deepstream_test_1.py ../../../../samples/streams/sample_1080p_h265.mp4
Creating Pipeline
Creating Source
Creating H264Parser
Creating Decoder
Creating nv3dsink
Playing file ../../../../samples/streams/sample_1080p_h265.mp4
Adding elements to Pipeline
Linking elements in the Pipeline
Starting pipeline
Opening in BLOCKING MODE
0:00:00.243507056  6794     0x2e0f9d50 WARN                 nvinfer gstnvinfer.cpp:679:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1174> [UID = 1]: Warning, OpenCV has been deprecated. Using NMS for clustering instead of cv::groupRectangles with topK = 20 and NMS Threshold = 0.5
WARNING: Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-6.3/sources/deepstream_python_apps/apps/deepstream-test1/../../../../samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine open error
0:00:03.602520933  6794     0x2e0f9d50 WARN                 nvinfer gstnvinfer.cpp:679:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1976> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-6.3/sources/deepstream_python_apps/apps/deepstream-test1/../../../../samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine failed
0:00:03.802825029  6794     0x2e0f9d50 WARN                 nvinfer gstnvinfer.cpp:679:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2081> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-6.3/sources/deepstream_python_apps/apps/deepstream-test1/../../../../samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine failed, try rebuild
0:00:03.802894439  6794     0x2e0f9d50 INFO                 nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:2002> [UID = 1]: Trying to create engine from model files
WARNING: [TRT]: The implicit batch dimension mode has been deprecated. Please create the network with NetworkDefinitionCreationFlag::kEXPLICIT_BATCH flag whenever possible.
WARNING: Serialize engine failed because of file path: /opt/nvidia/deepstream/deepstream-6.3/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine opened error
0:01:03.548221958  6794     0x2e0f9d50 WARN                 nvinfer gstnvinfer.cpp:679:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:2029> [UID = 1]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-6.3/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine
INFO: [Implicit Engine Info]: layers num: 3
0   INPUT  kFLOAT input_1         3x368x640
1   OUTPUT kFLOAT conv2d_bbox     16x23x40
2   OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:01:03.810714929  6794     0x2e0f9d50 INFO                 nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<primary-inference> [UID 1]: Load new model:dstest1_pgie_config.txt sucessfully
Error: gst-stream-error-quark: Internal data stream error. (1): gstbaseparse.c(3666): gst_base_parse_loop (): /GstPipeline:pipeline0/GstH264Parse:h264-parser:
streaming stopped, reason not-negotiated (-4)
nvstreammux: Successfully handled EOS for source_id=0
Test Environment:
Software part of jetson-stats 4.2.12 - (c) 2024, Raffaello Bonghi
Model: NVIDIA Orin Nano Developer Kit - Jetpack 5.1.4 [L4T 35.6.0]
NV Power Mode[0]: 15W
Serial Number: [XXX Show with: jetson_release -s XXX]
Hardware:
 - P-Number: p3767-0005
 - Module: NVIDIA Jetson Orin Nano (Developer kit)
Platform:
 - Distribution: Ubuntu 20.04 focal
 - Release: 5.10.216-tegra
jtop:
 - Version: 4.2.12
 - Service: Active
Libraries:
 - CUDA: 11.4.315
 - cuDNN: 8.6.0.166
 - TensorRT: 8.5.2.2
 - VPI: 2.4.8
 - OpenCV: 4.9.0 - with CUDA: YES
DeepStream C/C++ SDK version: 6.3
Python Environment:
Python 3.8.10
    GStreamer:                   YES (1.16.3)
  NVIDIA CUDA:                   YES (ver 11.4, CUFFT CUBLAS FAST_MATH)
        OpenCV version: 4.9.0  CUDA True
          YOLO version: 8.3.33
         Torch version: 2.1.0a0+41361538.nv23.06
   Torchvision version: 0.16.1+fdea156
DeepStream SDK version: 1.1.8
Test1 can only support h264 streams. For h265 mp4 files, please use test3.
OK.
Now I didn’t find resnet10.caffemodel_b1_gpu0_int8.engine see below ls result.
in foler: /opt/nvidia/deepstream/deepstream-6.3/sources/deepstream_python_apps/apps/deepstream-test1/../../../../samples/models/Primary_Detector/.
Is there any other commands for generating engine file?
daniel@daniel-nvidia:/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/apps/deepstream-test1$ python3 deepstream_test_1.py ../../../../samples/streams/sample_1080p_h264.mp4
Creating Pipeline
Creating Source
Creating H264Parser
Creating Decoder
Creating nv3dsink
Playing file ../../../../samples/streams/sample_1080p_h264.mp4
Starting pipeline
0:00:00.247816564  7090      0x52a6350 WARN                 nvinfer gstnvinfer.cpp:679:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1174> [UID = 1]: Warning, OpenCV has been deprecated. Using NMS for clustering instead of cv::groupRectangles with topK = 20 and NMS Threshold = 0.5
0:00:03.637079430  7090      0x52a6350 WARN                 nvinfer gstnvinfer.cpp:679:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1976> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-6.3/sources/deepstream_python_apps/apps/deepstream-test1/../../../../samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine failed
0:00:03.831326663  7090      0x52a6350 WARN                 nvinfer gstnvinfer.cpp:679:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2081> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-6.3/sources/deepstream_python_apps/apps/deepstream-test1/../../../../samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine failed, try rebuild
0:00:03.831464683  7090      0x52a6350 INFO                 nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:2002> [UID = 1]: Trying to create engine from model files
0:01:01.147313702  7090      0x52a6350 WARN                 nvinfer gstnvinfer.cpp:679:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:2029> [UID = 1]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-6.3/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine
0:01:01.410171072  7090      0x52a6350 INFO                 nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<primary-inference> [UID 1]: Load new model:dstest1_pgie_config.txt sucessfully
daniel@daniel-nvidia:/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/apps/deepstream-test1$ ls /opt/nvidia/deepstream/deepstream-6.3/sources/deepstream_python_apps/apps/deepstream-test1/../../../../samples/models/Primary_Detector/
cal_trt.bin  labels.txt  resnet10.caffemodel  resnet10.prototxt
For test1, only h264 stream is supported. please use the below command line
python3 deepstream_test_1.py /opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.h264
Or
python3 deepstream_test_3.py -i file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h265.mp4
Really appreciated with those commands, which works fine.
Just a few questions:
A: It seems deepstream_test_1.py can’t work with /opt/nvidia/deepstream/deepstream/samples/streams/sample_1080p_h264.mp4. Why this sample_1080p_h264.mp4 file failed test1?
B: Real time video uses RTP, so I just simply substitue input with python3 deepstream_test_3.py -i rtp://@:5600. I got segfault, and video-viewer rtp://@:5600 --input-codec=h265 works fine. Any suggestion or idea?
$ python3 deepstream_test_3.py rtp://@:5600
usage: deepstream_test_3 [-h] -i URIs [URIs ...] [-c config_location.txt] [-g {nvinfer,nvinferserver,nvinferserver-grpc}] [--no-display] [--file-loop]
                         [--disable-probe] [-s]
deepstream_test_3: error: the following arguments are required: -i/--input
daniel@daniel-nvidia:/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/apps/deepstream-test3$ python3 deepstream_test_3.py -i rtp://@:5600
{'input': ['rtp://@:5600'], 'configfile': None, 'pgie': None, 'no_display': False, 'file_loop': False, 'disable_probe': False, 'silent': False}
Creating Pipeline
Creating streamux
Creating source_bin  0
Creating source bin
source-bin-00
Creating Pgie
Creating tiler
Creating nvvidconv
Creating nvosd
Creating nv3dsink
Now playing...
0 :  rtp://@:5600
Starting pipeline
WARNING: Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-6.3/sources/deepstream_python_apps/apps/deepstream-test3/../../../../samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine open error
0:00:03.104594983  8938 0xffff240022f0 WARN                 nvinfer gstnvinfer.cpp:679:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1976> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-6.3/sources/deepstream_python_apps/apps/deepstream-test3/../../../../samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine failed
0:00:03.316993784  8938 0xffff240022f0 WARN                 nvinfer gstnvinfer.cpp:679:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2081> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-6.3/sources/deepstream_python_apps/apps/deepstream-test3/../../../../samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine failed, try rebuild
0:00:03.317088090  8938 0xffff240022f0 INFO                 nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:2002> [UID = 1]: Trying to create engine from model files
0:01:00.968961302  8938 0xffff240022f0 WARN                 nvinfer gstnvinfer.cpp:679:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:2029> [UID = 1]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-6.3/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine
0:01:01.232700445  8938 0xffff240022f0 INFO                 nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<primary-inference> [UID 1]: Load new model:dstest3_pgie_config.txt sucessfully
Decodebin child added: source
Please check README and source code, for test1, pipeline is filesrc --> h264parser ......, which means mp4 format cannot be parsed.
MP4 is a container that can be used to encapsulate audio and video. It requires qtmux to parse the video stream.
When using gstreamer to play rtp multicast, you need to manually specify capabilities. The uridecodebin element cannot automatically obtain this information.
I don’t know what tool video-viewer is, but from the parameters you specified, you also need to specify capabilities.
You need to modify the pipeline of test3 as follows
gst-launch-1.0 udpsrc port=5600 buffer-size=8388608 ! application/x-rtp,encoding-name=H265,payload=96 ! rtph265depay ! h265parse ! nvv4l2decoder ! nv3dsink
