Cannot run deepstream sample app
  • CUDA: 11.1
  • Hardware: GeForce GTX 1050 Ti
  • Driver: 460.32
  • DeepStream version: 5.1
  • TensorRT: 7.2.2.3
I am trying to run the source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt sample from the sources folder but it shows me a black video. Here is the log from the command line:
libEGL warning: DRI3: Screen seems not DRI3 capable
libEGL warning: DRI2: failed to authenticate
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:1523 Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-5.1/samples/configs/deepstream-app/…/…/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_int8.engine open error
0:00:00.327829369 17827 0x7f538c0022f0 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<secondary_gie_2> NvDsInferContext[UID 6]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1691> [UID = 6]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-5.1/samples/configs/deepstream-app/…/…/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_int8.engine failed
0:00:00.327860504 17827 0x7f538c0022f0 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<secondary_gie_2> NvDsInferContext[UID 6]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1798> [UID = 6]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-5.1/samples/configs/deepstream-app/…/…/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_int8.engine failed, try rebuild
0:00:00.327870327 17827 0x7f538c0022f0 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<secondary_gie_2> NvDsInferContext[UID 6]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1716> [UID = 6]: Trying to create engine from model files
Warning: Flatten layer ignored. TensorRT implicitly flattens input to FullyConnected layers, but in other circumstances this will result in undefined behavior.
INFO: …/nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: Reading Calibration Cache for calibrator: EntropyCalibration2
INFO: …/nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: Generated calibration scales using calibration cache. Make sure that calibration cache has latest scales.
INFO: …/nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: To regenerate calibration cache, please delete the existing one. TensorRT will generate a new calibration cache.
WARNING: …/nvdsinfer/nvdsinfer_func_utils.cpp:36 [TRT]: TensorRT was linked against cuBLAS/cuBLAS LT 11.3.0 but loaded cuBLAS/cuBLAS LT 11.2.1
INFO: …/nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: Detected 1 inputs and 1 output network tensors.
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:1495 Serialize engine failed because of file path: /opt/nvidia/deepstream/deepstream-5.1/samples/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_int8.engine opened error
0:00:12.572767498 17827 0x7f538c0022f0 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<secondary_gie_2> NvDsInferContext[UID 6]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1744> [UID = 6]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-5.1/samples/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_int8.engine
INFO: …/nvdsinfer/nvdsinfer_model_builder.cpp:685 [Implicit Engine Info]: layers num: 2
0 INPUT kFLOAT input_1 3x224x224
1 OUTPUT kFLOAT predictions/Softmax 20x1x1
0:00:12.576902981 17827 0x7f538c0022f0 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<secondary_gie_2> [UID 6]: Load new model:/opt/nvidia/deepstream/deepstream-5.1/samples/configs/deepstream-app/config_infer_secondary_carmake.txt sucessfully
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:1523 Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-5.1/samples/configs/deepstream-app/…/…/models/Secondary_CarColor/resnet18.caffemodel_b16_gpu0_int8.engine open error
0:00:12.577301938 17827 0x7f538c0022f0 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<secondary_gie_1> NvDsInferContext[UID 5]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1691> [UID = 5]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-5.1/samples/configs/deepstream-app/…/…/models/Secondary_CarColor/resnet18.caffemodel_b16_gpu0_int8.engine failed
0:00:12.577314486 17827 0x7f538c0022f0 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<secondary_gie_1> NvDsInferContext[UID 5]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1798> [UID = 5]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-5.1/samples/configs/deepstream-app/…/…/models/Secondary_CarColor/resnet18.caffemodel_b16_gpu0_int8.engine failed, try rebuild
0:00:12.577322657 17827 0x7f538c0022f0 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<secondary_gie_1> NvDsInferContext[UID 5]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1716> [UID = 5]: Trying to create engine from model files
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:1495 Serialize engine failed because of file path: /opt/nvidia/deepstream/deepstream-5.1/samples/models/Secondary_CarColor/resnet18.caffemodel_b16_gpu0_int8.engine opened error
0:00:23.374954835 17827 0x7f538c0022f0 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<secondary_gie_1> NvDsInferContext[UID 5]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1744> [UID = 5]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-5.1/samples/models/Secondary_CarColor/resnet18.caffemodel_b16_gpu0_int8.engine
1 OUTPUT kFLOAT predictions/Softmax 12x1x1
0:00:23.378312530 17827 0x7f538c0022f0 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<secondary_gie_1> [UID 5]: Load new model:/opt/nvidia/deepstream/deepstream-5.1/samples/configs/deepstream-app/config_infer_secondary_carcolor.txt sucessfully
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:1523 Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-5.1/samples/configs/deepstream-app/…/…/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_int8.engine open error
0:00:23.378878953 17827 0x7f538c0022f0 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<secondary_gie_0> NvDsInferContext[UID 4]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1691> [UID = 4]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-5.1/samples/configs/deepstream-app/…/…/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_int8.engine failed
0:00:23.378893791 17827 0x7f538c0022f0 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<secondary_gie_0> NvDsInferContext[UID 4]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1798> [UID = 4]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-5.1/samples/configs/deepstream-app/…/…/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_int8.engine failed, try rebuild
0:00:23.378902501 17827 0x7f538c0022f0 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<secondary_gie_0> NvDsInferContext[UID 4]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1716> [UID = 4]: Trying to create engine from model files
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:1495 Serialize engine failed because of file path: /opt/nvidia/deepstream/deepstream-5.1/samples/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_int8.engine opened error
0:00:33.117599527 17827 0x7f538c0022f0 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<secondary_gie_0> NvDsInferContext[UID 4]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1744> [UID = 4]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-5.1/samples/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_int8.engine
1 OUTPUT kFLOAT predictions/Softmax 6x1x1
0:00:33.121063151 17827 0x7f538c0022f0 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<secondary_gie_0> [UID 4]: Load new model:/opt/nvidia/deepstream/deepstream-5.1/samples/configs/deepstream-app/config_infer_secondary_vehicletypes.txt sucessfully
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream-5.1/lib/libnvds_mot_klt.so
gstnvtracker: Optional NvMOT_RemoveStreams not implemented
gstnvtracker: Batch processing is OFF
gstnvtracker: Past frame output is OFF
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:1523 Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-5.1/samples/configs/deepstream-app/…/…/models/Primary_Detector/resnet10.caffemodel_b4_gpu0_int8.engine open error
0:00:33.126425889 17827 0x7f538c0022f0 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1691> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-5.1/samples/configs/deepstream-app/…/…/models/Primary_Detector/resnet10.caffemodel_b4_gpu0_int8.engine failed
0:00:33.126442002 17827 0x7f538c0022f0 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1798> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-5.1/samples/configs/deepstream-app/…/…/models/Primary_Detector/resnet10.caffemodel_b4_gpu0_int8.engine failed, try rebuild
0:00:33.126451180 17827 0x7f538c0022f0 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1716> [UID = 1]: Trying to create engine from model files
INFO: …/nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: Detected 1 inputs and 2 output network tensors.
ERROR: …/nvdsinfer/nvdsinfer_model_builder.cpp:1495 Serialize engine failed because of file path: /opt/nvidia/deepstream/deepstream-5.1/samples/models/Primary_Detector/resnet10.caffemodel_b4_gpu0_int8.engine opened error
0:00:40.314617275 17827 0x7f538c0022f0 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1744> [UID = 1]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-5.1/samples/models/Primary_Detector/resnet10.caffemodel_b4_gpu0_int8.engine
INFO: …/nvdsinfer/nvdsinfer_model_builder.cpp:685 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:00:40.317316343 17827 0x7f538c0022f0 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream-5.1/samples/configs/deepstream-app/config_infer_primary.txt sucessfully
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
To go back to the tiled display, right-click anywhere on the window.
**PERF: FPS 0 (Avg) FPS 1 (Avg) FPS 2 (Avg) FPS 3 (Avg)
**PERF: 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00)
** INFO: <bus_callback:181>: Pipeline ready
** INFO: <bus_callback:167>: Pipeline running
KLT Tracker Init
KLT Tracker Init
KLT Tracker Init
KLT Tracker Init
cuGraphicsGLRegisterBuffer failed with error(304) gst_eglglessink_cuda_init texture = 1
**PERF: 44.00 (1.04) 44.00 (1.04) 44.00 (1.04) 44.00 (1.04)
**PERF: 0.00 (0.51) 0.00 (0.51) 0.00 (0.51) 0.00 (0.51)
**PERF: 0.00 (0.34) 0.00 (0.34) 0.00 (0.34) 0.00 (0.34)
ERROR from secondary_gie_bin_queue: Internal data stream error.
Debug info: gstqueue.c(988): gst_queue_handle_sink_event (): /GstPipeline:pipeline/GstBin:secondary_gie_bin/GstQueue:secondary_gie_bin_queue:
streaming stopped, reason not-negotiated (-4)
Quitting
ERROR from sink_bin_queue: Internal data stream error.
Debug info: gstqueue.c(988): gst_queue_handle_sink_event (): /GstPipeline:pipeline/GstBin:processing_bin_0/GstBin:sink_bin/GstQueue:sink_bin_queue:
App run failed
I have read a few other posts recommending that i should use a fakesink instead. I changed sink0 type to fake sink and got the following results (but the video did not show):
0:00:00.314218664 17935 0x5594bea71720 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<secondary_gie_2> NvDsInferContext[UID 6]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1691> [UID = 6]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-5.1/samples/configs/deepstream-app/…/…/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_int8.engine failed
0:00:00.314247514 17935 0x5594bea71720 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<secondary_gie_2> NvDsInferContext[UID 6]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1798> [UID = 6]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-5.1/samples/configs/deepstream-app/…/…/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_int8.engine failed, try rebuild
0:00:00.314260273 17935 0x5594bea71720 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<secondary_gie_2> NvDsInferContext[UID 6]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1716> [UID = 6]: Trying to create engine from model files
0:00:10.546889484 17935 0x5594bea71720 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<secondary_gie_2> NvDsInferContext[UID 6]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1744> [UID = 6]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-5.1/samples/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_int8.engine
0:00:10.550708162 17935 0x5594bea71720 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<secondary_gie_2> [UID 6]: Load new model:/opt/nvidia/deepstream/deepstream-5.1/samples/configs/deepstream-app/config_infer_secondary_carmake.txt sucessfully
0:00:10.551080100 17935 0x5594bea71720 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<secondary_gie_1> NvDsInferContext[UID 5]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1691> [UID = 5]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-5.1/samples/configs/deepstream-app/…/…/models/Secondary_CarColor/resnet18.caffemodel_b16_gpu0_int8.engine failed
0:00:10.551112828 17935 0x5594bea71720 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<secondary_gie_1> NvDsInferContext[UID 5]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1798> [UID = 5]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-5.1/samples/configs/deepstream-app/…/…/models/Secondary_CarColor/resnet18.caffemodel_b16_gpu0_int8.engine failed, try rebuild
0:00:10.551121386 17935 0x5594bea71720 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<secondary_gie_1> NvDsInferContext[UID 5]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1716> [UID = 5]: Trying to create engine from model files
0:00:19.611419885 17935 0x5594bea71720 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<secondary_gie_1> NvDsInferContext[UID 5]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1744> [UID = 5]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-5.1/samples/models/Secondary_CarColor/resnet18.caffemodel_b16_gpu0_int8.engine
0:00:19.614665092 17935 0x5594bea71720 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<secondary_gie_1> [UID 5]: Load new model:/opt/nvidia/deepstream/deepstream-5.1/samples/configs/deepstream-app/config_infer_secondary_carcolor.txt sucessfully
0:00:19.615057122 17935 0x5594bea71720 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<secondary_gie_0> NvDsInferContext[UID 4]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1691> [UID = 4]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-5.1/samples/configs/deepstream-app/…/…/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_int8.engine failed
0:00:19.615075507 17935 0x5594bea71720 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<secondary_gie_0> NvDsInferContext[UID 4]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1798> [UID = 4]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-5.1/samples/configs/deepstream-app/…/…/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_int8.engine failed, try rebuild
0:00:19.615088729 17935 0x5594bea71720 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<secondary_gie_0> NvDsInferContext[UID 4]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1716> [UID = 4]: Trying to create engine from model files
0:00:27.857808521 17935 0x5594bea71720 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<secondary_gie_0> NvDsInferContext[UID 4]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1744> [UID = 4]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-5.1/samples/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_int8.engine
0:00:27.860722361 17935 0x5594bea71720 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<secondary_gie_0> [UID 4]: Load new model:/opt/nvidia/deepstream/deepstream-5.1/samples/configs/deepstream-app/config_infer_secondary_vehicletypes.txt sucessfully
0:00:27.863703816 17935 0x5594bea71720 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1691> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-5.1/samples/configs/deepstream-app/…/…/models/Primary_Detector/resnet10.caffemodel_b4_gpu0_int8.engine failed
0:00:27.863717760 17935 0x5594bea71720 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1798> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-5.1/samples/configs/deepstream-app/…/…/models/Primary_Detector/resnet10.caffemodel_b4_gpu0_int8.engine failed, try rebuild
0:00:27.863725834 17935 0x5594bea71720 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1716> [UID = 1]: Trying to create engine from model files
0:00:34.121950547 17935 0x5594bea71720 WARN nvinfer gstnvinfer.cpp:616:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1744> [UID = 1]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-5.1/samples/models/Primary_Detector/resnet10.caffemodel_b4_gpu0_int8.engine
0:00:34.124192841 17935 0x5594bea71720 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream-5.1/samples/configs/deepstream-app/config_infer_primary.txt sucessfully
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
KLT Tracker Init
KLT Tracker Init
KLT Tracker Init
KLT Tracker Init
**PERF: 32.27 (32.04) 32.27 (32.04) 32.27 (32.04) 32.27 (32.04)
**PERF: 30.02 (31.10) 30.02 (31.10) 30.02 (31.10) 30.02 (31.10)
**PERF: 30.00 (30.73) 30.00 (30.73) 30.00 (30.73) 30.00 (30.73)
**PERF: 30.01 (30.54) 30.01 (30.54) 30.01 (30.54) 30.01 (30.54)
**PERF: 29.99 (30.43) 29.99 (30.43) 29.99 (30.43) 29.99 (30.43)
**PERF: 29.99 (30.36) 29.99 (30.36) 29.99 (30.36) 29.99 (30.36)
**PERF: 30.00 (30.31) 30.00 (30.31) 30.00 (30.31) 30.00 (30.31)
**PERF: 30.01 (30.27) 30.01 (30.27) 30.01 (30.27) 30.01 (30.27)
**PERF: 30.00 (30.24) 30.00 (30.24) 30.00 (30.24) 30.00 (30.24)
** INFO: <bus_callback:204>: Received EOS. Exiting …
Quitting
App run successful
How can i display the video to see the actual results?
Such error shows that your cuda and TensorRT versions are not correct. Please refer to the instruction of Quickstart Guide — DeepStream 6.3 Release documentation to install dependencies and deepstream SDK correctly.
I have managed to install a previous version of TensorRT ( 7.2.1.6 ) and now i am not getting that error. I still can’t see the video and i tried with both fakesink and eglsink in the sample txt.
L.E.
So i have been able to run the sample app with the above TensorRT version. All that was missing was the display driver which for some reason it did not upgrade to version 460.32
Thank you for your help!
