Run deepstream-app samples error
I pull this dockes image
nvcr.io/nvidia/deepstream:5.0-20.07-triton
and deepstream-app --version-all as follow:
deepstream-app version 5.0.0
DeepStreamSDK 5.0.0
CUDA Driver Version: 11.0 ==> my driver is 450.57
CUDA Runtime Version: 10.2
TensorRT Version: 7.0
cuDNN Version: 7.6
libNVWarp360 Version: 2.0.1d3
$pwd = /opt/nvidia/deepstream/deepstream-5.0/samples
and when i run command as follow:
deepstream-app -c configs/deepstream-app/source30_1080p_dec_infer-resnet_tiled_display_int8.txt
sink0[enable=1 and type=2] and others sink will be disable
the error message is:
libEGL warning: DRI3: failed to query the version
libEGL warning: DRI2: failed to authenticate
WARNING: …/nvdsinfer/nvdsinfer_func_utils.cpp:36 [TRT]: Current optimization profile is: 0. Please ensure there are no enqueued operations pending in this context prior to switching profiles
0:00:01.418222695 883 0x55a1a5d7eb80 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1701> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/…/…/models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine
INFO: …/nvdsinfer/nvdsinfer_model_builder.cpp:685 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:00:01.418337423 883 0x55a1a5d7eb80 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1805> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/…/…/models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine
0:00:01.420384703 883 0x55a1a5d7eb80 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/config_infer_primary.txt sucessfully
Runtime commands:
h: Print this help
q: Quit
    p: Pause
    r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
To go back to the tiled display, right-click anywhere on the window.
** INFO: <bus_callback:181>: Pipeline ready
cuGraphicsGLRegisterBuffer failed with error(304) gst_eglglessink_cuda_init texture = 1
0:00:01.910700691 883 0x55a197115de0 WARN nvinfer gstnvinfer.cpp:1975:gst_nvinfer_output_loop:<primary_gie> error: Internal data stream error.
0:00:01.910718675 883 0x55a197115de0 WARN nvinfer gstnvinfer.cpp:1975:gst_nvinfer_output_loop:<primary_gie> error: streaming stopped, reason not-negotiated (-4)
ERROR from primary_gie: Internal data stream error.
Debug info: gstnvinfer.cpp(1975): gst_nvinfer_output_loop (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInfer:primary_gie:
Quitting
ERROR from sink_bin_queue: Internal data stream error.
Debug info: gstqueue.c(988): gst_queue_handle_sink_event (): /GstPipeline:pipeline/GstBin:processing_bin_0/GstBin:sink_bin/GstQueue:sink_bin_queue:
ERROR from qtdemux7: Internal data stream error.
Debug info: qtdemux.c(6073): gst_qtdemux_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin7/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin7/GstQTDemux:qtdemux7:
sink1[enable=1 and type=3] and others sink will be disable
0:00:01.370292168 1169 0x7ff6f0002390 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1701> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/…/…/models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine
0:00:01.370367783 1169 0x7ff6f0002390 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1805> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/…/…/models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine
0:00:01.372437664 1169 0x7ff6f0002390 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/config_infer_primary.txt sucessfully
Runtime commands:
h: Print this help
q: Quit
    p: Pause
    r: Resume
ERROR from sink_sub_bin_encoder1: Device ‘/dev/nvhost-msenc’ failed during initialization
Debug info: gstv4l2object.c(4070): gst_v4l2_object_set_format_full (): /GstPipeline:pipeline/GstBin:processing_bin_0/GstBin:sink_bin/GstBin:sink_sub_bin1/nvv4l2h264enc:sink_sub_bin_encoder1:
Call to S_FMT failed for YM12 @ 1280x720: Unknown error -1
Quitting
so, anybody can tell me what happen,and how to solve this problem
by the way, my card is GTX2080TI
thanks
Please provide below information:
• DeepStream Version
• TensorRT Version
hey,
operate system is ubuntu16.04
graphic card is GTX2080ti
nvidia driver is 440.100
tensorrt version is 7.0
docker image is http://nvcr.io/nvidia/deepstream:5.0-20.07-triton
Make sure you can run outside docker to rule out any environments issue about issue using sink type 2, if still get the issue, you need to reinstall display driver with nvidia opengl selected.
and about issue using sink type 3, Can you find
ll /usr/lib/x86_64-linux-gnu/libnvidia-encode.so* ?
lrwxrwxrwx 1 root root 27 Sep 21 10:27 /usr/lib/x86_64-linux-gnu/libnvidia-encode.so.1 → libnvidia-encode.so.440.100*
-rwxr-xr-x 1 root root 103632 Sep 21 10:19 /usr/lib/x86_64-linux-gnu/libnvidia-encode.so.440.100*
these files in my container, what should i do next
create one soft link /usr/lib/x86_64-linux-gnu/libnvidia-encode.so which pointing to /usr/lib/x86_64-linux-gnu/libnvidia-encode.so.1, and try again.
it`s work
thanks
