• GeForce GTX 1660 Ti Mobile
• DeepStream 6.1
• Ubuntu 20.04
• TensorRT
• GStreamer 1.16.2
• NVIDIA driver 510.47.03
• CUDA 11.6 Update 1
I installed DeepStream 6.1 Quickstart Guide and I want to start “deepstream-app -c source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8_gpu1.txt”.
I just changed gpu-id in file source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8_gpu1.txt.
Full log:
WARNING: ../nvdsinfer/nvdsinfer_model_builder.cpp:1482 Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-6.1/samples/configs/deepstream-app/../../models/Secondary_CarMake/resnet18.caffemodel_b16_gpu1_int8.engine open error
0:00:00.966313691 49107 0x55b0a9b78920 WARN nvinfer gstnvinfer.cpp:643:gst_nvinfer_logger:<secondary_gie_2> NvDsInferContext[UID 6]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1888> [UID = 6]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-6.1/samples/configs/deepstream-app/../../models/Secondary_CarMake/resnet18.caffemodel_b16_gpu1_int8.engine failed
0:00:00.981483380 49107 0x55b0a9b78920 WARN nvinfer gstnvinfer.cpp:643:gst_nvinfer_logger:<secondary_gie_2> NvDsInferContext[UID 6]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1993> [UID = 6]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-6.1/samples/configs/deepstream-app/../../models/Secondary_CarMake/resnet18.caffemodel_b16_gpu1_int8.engine failed, try rebuild
0:00:00.981501369 49107 0x55b0a9b78920 INFO nvinfer gstnvinfer.cpp:646:gst_nvinfer_logger:<secondary_gie_2> NvDsInferContext[UID 6]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1914> [UID = 6]: Trying to create engine from model files
Warning: Flatten layer ignored. TensorRT implicitly flattens input to FullyConnected layers, but in other circumstances this will result in undefined behavior.
WARNING: ../nvdsinfer/nvdsinfer_model_builder.cpp:1454 Serialize engine failed because of file path: /opt/nvidia/deepstream/deepstream-6.1/samples/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_int8.engine opened error
0:00:19.369058944 49107 0x55b0a9b78920 WARN nvinfer gstnvinfer.cpp:643:gst_nvinfer_logger:<secondary_gie_2> NvDsInferContext[UID 6]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1941> [UID = 6]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-6.1/samples/models/Secondary_CarMake/resnet18.caffemodel_b16_gpu0_int8.engine
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 2
0 INPUT kFLOAT input_1 3x224x224
1 OUTPUT kFLOAT predictions/Softmax 20x1x1
0:00:19.393949001 49107 0x55b0a9b78920 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<secondary_gie_2> [UID 6]: Load new model:/opt/nvidia/deepstream/deepstream-6.1/samples/configs/deepstream-app/config_infer_secondary_carmake.txt sucessfully
WARNING: ../nvdsinfer/nvdsinfer_model_builder.cpp:1482 Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-6.1/samples/configs/deepstream-app/../../models/Secondary_CarColor/resnet18.caffemodel_b16_gpu1_int8.engine open error
0:00:19.829910183 49107 0x55b0a9b78920 WARN nvinfer gstnvinfer.cpp:643:gst_nvinfer_logger:<secondary_gie_1> NvDsInferContext[UID 5]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1888> [UID = 5]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-6.1/samples/configs/deepstream-app/../../models/Secondary_CarColor/resnet18.caffemodel_b16_gpu1_int8.engine failed
0:00:19.845048730 49107 0x55b0a9b78920 WARN nvinfer gstnvinfer.cpp:643:gst_nvinfer_logger:<secondary_gie_1> NvDsInferContext[UID 5]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1993> [UID = 5]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-6.1/samples/configs/deepstream-app/../../models/Secondary_CarColor/resnet18.caffemodel_b16_gpu1_int8.engine failed, try rebuild
0:00:19.845082527 49107 0x55b0a9b78920 INFO nvinfer gstnvinfer.cpp:646:gst_nvinfer_logger:<secondary_gie_1> NvDsInferContext[UID 5]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1914> [UID = 5]: Trying to create engine from model files
WARNING: ../nvdsinfer/nvdsinfer_model_builder.cpp:1454 Serialize engine failed because of file path: /opt/nvidia/deepstream/deepstream-6.1/samples/models/Secondary_CarColor/resnet18.caffemodel_b16_gpu0_int8.engine opened error
0:00:35.757243825 49107 0x55b0a9b78920 WARN nvinfer gstnvinfer.cpp:643:gst_nvinfer_logger:<secondary_gie_1> NvDsInferContext[UID 5]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1941> [UID = 5]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-6.1/samples/models/Secondary_CarColor/resnet18.caffemodel_b16_gpu0_int8.engine
1 OUTPUT kFLOAT predictions/Softmax 12x1x1
0:00:35.779397090 49107 0x55b0a9b78920 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<secondary_gie_1> [UID 5]: Load new model:/opt/nvidia/deepstream/deepstream-6.1/samples/configs/deepstream-app/config_infer_secondary_carcolor.txt sucessfully
WARNING: ../nvdsinfer/nvdsinfer_model_builder.cpp:1482 Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-6.1/samples/configs/deepstream-app/../../models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu1_int8.engine open error
0:00:36.195648830 49107 0x55b0a9b78920 WARN nvinfer gstnvinfer.cpp:643:gst_nvinfer_logger:<secondary_gie_0> NvDsInferContext[UID 4]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1888> [UID = 4]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-6.1/samples/configs/deepstream-app/../../models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu1_int8.engine failed
0:00:36.212946766 49107 0x55b0a9b78920 WARN nvinfer gstnvinfer.cpp:643:gst_nvinfer_logger:<secondary_gie_0> NvDsInferContext[UID 4]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1993> [UID = 4]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-6.1/samples/configs/deepstream-app/../../models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu1_int8.engine failed, try rebuild
0:00:36.213017536 49107 0x55b0a9b78920 INFO nvinfer gstnvinfer.cpp:646:gst_nvinfer_logger:<secondary_gie_0> NvDsInferContext[UID 4]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1914> [UID = 4]: Trying to create engine from model files
WARNING: ../nvdsinfer/nvdsinfer_model_builder.cpp:1454 Serialize engine failed because of file path: /opt/nvidia/deepstream/deepstream-6.1/samples/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_int8.engine opened error
0:00:51.108483466 49107 0x55b0a9b78920 WARN nvinfer gstnvinfer.cpp:643:gst_nvinfer_logger:<secondary_gie_0> NvDsInferContext[UID 4]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1941> [UID = 4]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-6.1/samples/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_int8.engine
1 OUTPUT kFLOAT predictions/Softmax 6x1x1
0:00:51.129664632 49107 0x55b0a9b78920 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<secondary_gie_0> [UID 4]: Load new model:/opt/nvidia/deepstream/deepstream-6.1/samples/configs/deepstream-app/config_infer_secondary_vehicletypes.txt sucessfully
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
gstnvtracker: Batch processing is ON
gstnvtracker: Past frame output is ON
[NvMultiObjectTracker] Initialized
WARNING: ../nvdsinfer/nvdsinfer_model_builder.cpp:1482 Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-6.1/samples/configs/deepstream-app/../../models/Primary_Detector/resnet10.caffemodel_b4_gpu1_int8.engine open error
0:00:51.583861146 49107 0x55b0a9b78920 WARN nvinfer gstnvinfer.cpp:643:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1888> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-6.1/samples/configs/deepstream-app/../../models/Primary_Detector/resnet10.caffemodel_b4_gpu1_int8.engine failed
0:00:51.602565913 49107 0x55b0a9b78920 WARN nvinfer gstnvinfer.cpp:643:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1993> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-6.1/samples/configs/deepstream-app/../../models/Primary_Detector/resnet10.caffemodel_b4_gpu1_int8.engine failed, try rebuild
0:00:51.602585603 49107 0x55b0a9b78920 INFO nvinfer gstnvinfer.cpp:646:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1914> [UID = 1]: Trying to create engine from model files
WARNING: ../nvdsinfer/nvdsinfer_model_builder.cpp:1454 Serialize engine failed because of file path: /opt/nvidia/deepstream/deepstream-6.1/samples/models/Primary_Detector/resnet10.caffemodel_b4_gpu0_int8.engine opened error
0:01:12.765085173 49107 0x55b0a9b78920 WARN nvinfer gstnvinfer.cpp:643:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1941> [UID = 1]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-6.1/samples/models/Primary_Detector/resnet10.caffemodel_b4_gpu0_int8.engine
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:01:12.783855927 49107 0x55b0a9b78920 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream-6.1/samples/configs/deepstream-app/config_infer_primary.txt sucessfully
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
To go back to the tiled display, right-click anywhere on the window.
**PERF: FPS 0 (Avg) FPS 1 (Avg) FPS 2 (Avg) FPS 3 (Avg)
**PERF: 0.00 (0.00) 0.00 (0.00) 0.00 (0.00) 0.00 (0.00)
** INFO: <bus_callback:194>: Pipeline ready
cuGraphicsGLRegisterBuffer failed with error(219) gst_eglglessink_cuda_init texture = 1
** INFO: <bus_callback:180>: Pipeline running
**PERF: 301.75 (1.18) 301.75 (1.18) 301.75 (1.18) 301.75 (1.18)
ERROR from secondary_gie_bin_queue: Internal data stream error.
Debug info: gstqueue.c(988): gst_queue_handle_sink_event (): /GstPipeline:pipeline/GstBin:secondary_gie_bin/GstQueue:secondary_gie_bin_queue:
streaming stopped, reason not-negotiated (-4)
Quitting
ERROR from sink_bin_queue: Internal data stream error.
Debug info: gstqueue.c(988): gst_queue_handle_sink_event (): /GstPipeline:pipeline/GstBin:processing_bin_0/GstBin:sink_bin/GstQueue:sink_bin_queue:
[NvMultiObjectTracker] De-initialized
App run failed
