I have got a problem when excute
deepstream-app -c source4_720p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
To go back to the tiled display, right-click anywhere on the window.
** INFO: <bus_callback:75>: Pipeline ready
nvstreamtiler: batchSize set as 4
cuGraphicsGLRegisterBuffer failed with error(304) gst_eglglessink_cuda_init texture = 1
** INFO: <bus_callback:60>: Pipeline running
**PERF: FPS 0 (Avg) FPS 1 (Avg) FPS 2 (Avg) FPS 3 (Avg)
**PERF: -nan (-nan) 76.73 (76.73) 76.73 (76.73) -nan (-nan)
Error from secondary_gie_bin_queue: Internal data flow error.
Debug info: gstqueue.c(992): gst_queue_handle_sink_event (): /GstPipeline:pipeline/GstBin:secondary_gie_bin/GstQueue:secondary_gie_bin_queue:
streaming task paused, reason not-negotiated (-4)
Quitting
App run failed
here are some informations:
1.my ~/.bashrc herr:
#Deepstream
export GST_PLUGIN_PATH=“/usr/lib/x86_64-linux-gnu/gstreamer-1.0/”
export LD_LIBRARY_PATH=“/usr/local/deepstream/lib:$LD_LIBRARY_PATH”
#opencv 3.4.0
export LD_LIBRARY_PATH=“/usr/local/lib:$LD_LIBRARY_PATH”
#GSTREAMER
export C_INCLUDE_PATH=/usr/include/gstreamer-1.0:$C_INCLUDE_PATH
export CPLUS_INCLUDE_PATH=/usr/include/gstreamer-1.0:$CPLUS_INCLUDE_PATH
cuda
export PATH=“/usr/local/cuda/bin:$PATH”
export PATH=“/usr/local/cuda:$PATH”
export LD_LIBRARY_PATH=“/usr/local/cuda/lib64:$LD_LIBRARY_PATH”
export CUDA_INSTALL_DIR=/usr/local/cuda
Tensorrt4
export LD_LIBRARY_PATH=“/home/bj-1603-0007/XFF_Deepstream/Downloads/TensorRT-4.0.1.6/lib:$LD_LIBRARY_PATH”
2.I am working on a server with two 1080ti(gpu-id:0 and 2) and one P4(gpu-id:1),
and the source30_720p_dec_infer-resnet_tiled_display_int8.txt it use gpu 0
Any message is appreciated!Thanks Thanks and Thanks!
