Internal Data Stream Error while running sample apps on Deepstream 6.0
• Hardware Platform GPU
• DeepStream Version 6.0
• JetPack Version N/A
• TensorRT 8.0
• NVIDIA GPU Driver Version 470
• Issue Type Internal Data stream error
**• Followed the installation process for deepstream SDK 6.0 dGPU on uunutu then cd to samples directory and ran the command
deepstream-app -c configs/deepstream-app/source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8_gpu1.txt
Apart from this I changed the config file to gpu-id=0, whereever it said 1 since I only have one gpu and it was giving me a different error otherwise.
On running the command, deepstream window pops up stays for a while but this error comes up and the window shuts down.
0:01:20.724125354 21813 0x563ccde6a770 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2840:gst_eglglessink_setcaps:<sink_sub_bin_sink1> Failed to configure caps
0:01:21.820307113 21813 0x563ccde6a770 ERROR nveglglessink ext/eglgles/gsteglglessink.c:2840:gst_eglglessink_setcaps:<sink_sub_bin_sink1> Failed to configure caps
**PERF: 10.59 (1.19) 13.24 (1.49) 10.59 (1.19) 10.59 (1.19)
**PERF: 0.00 (0.48) 0.00 (0.60) 0.00 (0.48) 0.00 (0.48)
**PERF: 0.00 (0.30) 0.00 (0.37) 0.00 (0.30) 0.00 (0.30)
**PERF: 0.00 (0.22) 0.00 (0.27) 0.00 (0.22) 0.00 (0.22)
**PERF: 0.00 (0.17) 0.00 (0.21) 0.00 (0.17) 0.00 (0.17)
**PERF: 0.00 (0.14) 0.00 (0.18) 0.00 (0.14) 0.00 (0.14)
**PERF: 0.00 (0.12) 0.00 (0.15) 0.00 (0.12) 0.00 (0.12)
**PERF: 0.00 (0.10) 0.00 (0.13) 0.00 (0.10) 0.00 (0.10)
**PERF: 0.00 (0.09) 0.00 (0.12) 0.00 (0.09) 0.00 (0.09)
**PERF: 0.00 (0.08) 0.00 (0.10) 0.00 (0.08) 0.00 (0.08)
0:02:13.787735451 21813 0x563cce139630 WARN queue gstqueue.c:988:gst_queue_handle_sink_event:<secondary_gie_bin_queue> error: Internal data stream error.
0:02:13.787768646 21813 0x563cce139630 WARN queue gstqueue.c:988:gst_queue_handle_sink_event:<secondary_gie_bin_queue> error: streaming stopped, reason not-negotiated (-4)
ERROR from secondary_gie_bin_queue: Internal data stream error.
Debug info: gstqueue.c(988): gst_queue_handle_sink_event (): /GstPipeline:pipeline/GstBin:secondary_gie_bin/GstQueue:secondary_gie_bin_queue:
Quitting
0:02:13.798161259 21813 0x7fdaf00022a0 WARN queue gstqueue.c:988:gst_queue_handle_sink_event:<sink_bin_queue> error: Internal data stream error.
0:02:13.798183206 21813 0x7fdaf00022a0 WARN queue gstqueue.c:988:gst_queue_handle_sink_event:<sink_bin_queue> error: streaming stopped, reason not-negotiated (-4)
ERROR from sink_bin_queue: Internal data stream error.
Debug info: gstqueue.c(988): gst_queue_handle_sink_event (): /GstPipeline:pipeline/GstBin:processing_bin_0/GstBin:sink_bin/GstQueue:sink_bin_queue:
[NvMultiObjectTracker] De-initialized
App run failed
Can you run with “source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt” without changing anything?
