Error when running Deepstream example
我运行程序的时候出现了如下的问题,这是怎么回事呢??
这是我的GPU相关信息
• DeepStream Version
• TensorRT Version
• The pipeline being used
@wsj101 Please raise your topic in English.
The following error occurred when I ran the test case, What’s going on here?
This is my GPU information, Does my GPU not support real-time display of running results?
• TensorRT Version
• Hardware Platform GPU
• DeepStream Version 6.1
• NVIDIA GPU Driver Version 470.129.06
• Issue Type questions
• How to reproduce the issue ? When I run sample app the error occurred
Which sample app? The command you used? The complete log?
This one : deepstream-app -c source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt
I find if I modification [sink0] enable=0, this can be work, but it also can’t real time disply anything, just output the result
Can you run “gst-inspect-1.0” and show us the result?
Seems your EGL driver is not installed correctly. Please install your machine according to Quickstart Guide — DeepStream 6.1.1 Release documentation
The driver version should be 510.47.03
Thanks, I will be try
@wsj101 Can you let us know if it is still an issue? We may close this topic if the issue is solved.
