Thanks Ying. I tried your way, still got some error.
/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/apps/deepstream-test3# python3 ./deepstream_test_3.py -i file:///tmp/tmp
tmp.ac5nJnJ6iQ/ tmp02xk5uav/
root@eai-awai-fof:/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/apps/deepstream-test3# py
thon3 ./deepstream_test_3.py -i file:///opt/nvidia/deepstream/deepstream-6.2/samples/streams/sample_720p.h264
{‘input’: [‘file:///opt/nvidia/deepstream/deepstream-6.2/samples/streams/sample_720p.h264’], ‘configfile’: None, ‘pgie’: None, ‘no_display’: False, ‘file_loop’: False, ‘disable_probe’: False, ‘silent’: False}
(gst-plugin-scanner:1950): GStreamer-WARNING **: 14:33:41.451: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so’: librivermax.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:1950): GStreamer-WARNING **: 14:33:41.519: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so’: libtritonserver.so: cannot open shared object file: No such file or directory
Creating Pipeline
Creating streamux
Creating source_bin 0
Creating source bin
source-bin-00
Creating Pgie
Creating tiler
Creating nvvidconv
Creating nvosd
Creating EGLSink
Adding elements to Pipeline
Linking elements in the Pipeline
Now playing…
0 : file:///opt/nvidia/deepstream/deepstream-6.2/samples/streams/sample_720p.h264
Starting pipeline
libEGL warning: DRI2: failed to authenticate
WARNING: [TRT]: CUDA lazy loading is not enabled. Enabling it can significantly reduce device memory usage. See CUDA_MODULE_LOADING in CUDA C++ Programming Guide
WARNING: …/nvdsinfer/nvdsinfer_model_builder.cpp:1487 Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/apps/deepstream-test3/…/…/…/…/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine open error
0:00:05.072368872 1949 0x267f4a0 WARN nvinfer gstnvinfer.cpp:677:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1897> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/apps/deepstream-test3/…/…/…/…/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine failed
0:00:05.208453438 1949 0x267f4a0 WARN nvinfer gstnvinfer.cpp:677:gst_nvinfer_logger: NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2002> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-6.2/sources/deepstream_python_apps/apps/deepstream-test3/…/…/…/…/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine failed, try rebuild
0:00:05.208513808 1949 0x267f4a0 INFO nvinfer gstnvinfer.cpp:680:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1923> [UID = 1]: Trying to create engine from model files
WARNING: [TRT]: The implicit batch dimension mode has been deprecated. Please create the network with NetworkDefinitionCreationFlag::kEXPLICIT_BATCH flag whenever possible.
0:00:32.038840520 1949 0x267f4a0 INFO nvinfer gstnvinfer.cpp:680:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1955> [UID = 1]: serialize cuda engine to file: /opt/nvidia/deepstream/deepstream-6.2/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine successfully
INFO: …/nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:00:32.207607793 1949 0x267f4a0 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus: [UID 1]: Load new model:dstest3_pgie_config.txt sucessfully
Decodebin child added: source
Decodebin child added: decodebin0
**PERF: {‘stream0’: 0.0}
Decodebin child added: h264parse0
Decodebin child added: capsfilter0
Decodebin child added: nvv4l2decoder0
In cb_newpad
gstname= video/x-raw
features= <Gst.CapsFeatures object at 0x7f3a83fc05e0 (GstCapsFeatures at 0x1035c20)>
Frame Number= 0 Number of Objects= 12 Vehicle_count= 8 Person_count= 4
Frame Number= 1 Number of Objects= 11 Vehicle_count= 8 Person_count= 3
Frame Number= 2 Number of Objects= 11 Vehicle_count= 7 Person_count= 4
Frame Number= 3 Number of Objects= 13 Vehicle_count= 8 Person_count= 5
cuGraphicsGLRegisterBuffer failed with error(219) gst_eglglessink_cuda_init texture = 1
Frame Number= 4 Number of Objects= 12 Vehicle_count= 8 Person_count= 4
Frame Number= 5 Number of Objects= 12 Vehicle_count= 8 Person_count= 4
Frame Number= 6 Number of Objects= 11 Vehicle_count= 7 Person_count= 4
Frame Number= 7 Number of Objects= 11 Vehicle_count= 7 Person_count= 4
Frame Number= 8 Number of Objects= 10 Vehicle_count= 6 Person_count= 4
Frame Number= 9 Number of Objects= 12 Vehicle_count= 8 Person_count= 4
Frame Number= 10 Number of Objects= 15 Vehicle_count= 11 Person_count= 4
Frame Number= 11 Number of Objects= 13 Vehicle_count= 10 Person_count= 3
Frame Number= 12 Number of Objects= 12 Vehicle_count= 9 Person_count= 3
Frame Number= 13 Number of Objects= 10 Vehicle_count= 8 Person_count= 2
0:00:32.695356217 1949 0x1f86000 WARN nvinfer gstnvinfer.cpp:2369:gst_nvinfer_output_loop: error: Internal data stream error.
0:00:32.695368943 1949 0x1f86000 WARN nvinfer gstnvinfer.cpp:2369:gst_nvinfer_output_loop: error: streaming stopped, reason not-negotiated (-4)
Error: gst-stream-error-quark: Internal data stream error. (1): gstnvinfer.cpp(2369): gst_nvinfer_output_loop (): /GstPipeline:pipeline0/GstNvInfer:primary-inference:
Frame Number= 14 Number of Objects= 8 Vehicle_count= 6 Person_count= 2
Exiting app
nvstreammux: Successfully handled EOS for source_id=0
