It reports errors when I launch composer from DeepStream SDK devel container image
• Hardware Platform (Jetson / GPU) : NVIDIA P102-100, CUDA: 11.8
• DeepStream Version : 6.2.0
• TensorRT Version : 8.5.2
• NVIDIA GPU Driver Version (valid for GPU only) : 525.85.12
• Issue Type( questions, new requirements, bugs): questions
Command for start the composer in docker:
$ xhost +
$ docker run -it --entrypoint /bin/bash --gpus all --rm --network=host -e DISPLAY=${DISPLAY} -v /tmp/.X11-unix/:/tmp/.X11-unix --privileged -v /var/run/docker.sock:/var/run/docker.sock nvcr.io/nvidia/deepstream:6.2-devel
$ composer
I synced Repo and opened the file ‘/opt/nvidia/deepstream/deepstream-6.2/reference_graphs/deepstream-test1/deepstream-test1.yaml’ and ran it. The errors are reported as follows:
Running deepstream-test1.yaml
[INFO] Writing manifest to /tmp/ds.deepstream-test1/manifest.yaml
2023-05-18 08:11:20,373 - Registry - INFO - Installing graph ...
2023-05-18 08:11:20,429 - Registry - INFO -
Requested target configuration:
arch: x86_64 os: linux distribution: ubuntu_20.04 cuda: 11.8 cudnn: 8.6.0 tensorrt: 8.5.1 deepstream: 6.2 vpi: 2.1.6
Selected extension variants:
StandardExtension
Version: 2.1.0 Variant: arch: x86_64 os: linux distribution: ubuntu_20.04 cuda: 11.8
MultimediaExtension
NvDsInterfaceExt
Version: 1.1.0 Variant: arch: x86_64 os: linux distribution: ubuntu_20.04 deepstream: 6.2
NvDsBaseExt
Version: 1.2.0 Variant: arch: x86_64 os: linux distribution: ubuntu_20.04 deepstream: 6.2
NvDsInferenceExt
NvDsMuxDemuxExt
NvDsOutputSinkExt
NvDsSampleModelsExt
NvDsSourceExt
Version: 1.1.1 Variant: arch: x86_64 os: linux distribution: ubuntu_20.04 deepstream: 6.2
NvDsInferenceUtilsExt
NvDsVisualizationExt
Graph installed to output directory
2023-05-18 08:13:45.486 INFO  gxf/gxe/gxe.cpp@180: Creating context
2023-05-18 08:13:46.086 INFO  gxf/gxe/gxe.cpp@105: Loading app: '/opt/nvidia/deepstream/deepstream-6.2/reference_graphs/deepstream-test1/deepstream-test1.yaml'
2023-05-18 08:13:46.086 INFO  gxf/std/yaml_file_loader.cpp@129: Loading GXF entities from YAML file '/opt/nvidia/deepstream/deepstream-6.2/reference_graphs/deepstream-test1/deepstream-test1.yaml'...
2023-05-18 08:13:46.090 INFO  gxf/gxe/gxe.cpp@249: Initializing...
2023-05-18 08:13:46 [655,723ms] [Error] [omni.kit.app._impl] [py stderr]:
2023-05-18 08:13:46 [655,724ms] [Error] [omni.kit.app._impl] [py stderr]:
2023-05-18 08:13:46 [655,724ms] [Error] [omni.kit.app._impl] [py stderr]: (gst-plugin-scanner:165): GStreamer-WARNING **: 08:13:46.392: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstopenmpt.so': libmpg123.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:165): GStreamer-WARNING **: 08:13:46.392: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstopenmpt.so': libmpg123.so.0: cannot open shared object file: No such file or directory2023-05-18 08:13:46 [655,724ms] [Error] [omni.kit.app._impl] [py stderr]:
2023-05-18 08:13:46 [656,005ms] [Error] [omni.kit.app._impl] [py stderr]:
2023-05-18 08:13:46 [656,006ms] [Error] [omni.kit.app._impl] [py stderr]: (gst-plugin-scanner:165): GStreamer-WARNING **: 08:13:46.669: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstmpeg2dec.so': libmpeg2.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:165): GStreamer-WARNING **: 08:13:46.669: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstmpeg2dec.so': libmpeg2.so.0: cannot open shared object file: No such file or directory2023-05-18 08:13:46 [656,006ms] [Error] [omni.kit.app._impl] [py stderr]:
2023-05-18 08:13:47 [657,219ms] [Error] [omni.kit.app._impl] [py stderr]:
2023-05-18 08:13:47 [657,220ms] [Error] [omni.kit.app._impl] [py stderr]:
2023-05-18 08:13:47 [657,220ms] [Error] [omni.kit.app._impl] [py stderr]: (gst-plugin-scanner:165): GStreamer-WARNING **: 08:13:47.855: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libtritonserver.so: cannot open shared object file: No such file or directory
(gst-plugin-scanner:165): GStreamer-WARNING **: 08:13:47.855: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libtritonserver.so: cannot open shared object file: No such file or directory2023-05-18 08:13:47 [657,220ms] [Error] [omni.kit.app._impl] [py stderr]:
2023-05-18 08:13:48 [657,400ms] [Error] [omni.kit.app._impl] [py stderr]:
2023-05-18 08:13:48 [657,400ms] [Error] [omni.kit.app._impl] [py stderr]: (gst-plugin-scanner:165): GStreamer-WARNING **: 08:13:48.050: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so': librivermax.so.0: cannot open shared object file: No such file or directory
file or directory2023-05-18 08:13:48 [657,400ms] [Error] [omni.kit.app._impl] [py stderr]:
2023-05-18 08:13:48.392 INFO  extensions/nvdsbase/nvds_scheduler.cpp@270: This program is linked against GStreamer 1.16.3
2023-05-18 08:13:48.395 INFO  extensions/nvdssource/nvurisrcbin.hpp@24: initialize: nvurisrcbin single_source_input
2023-05-18 08:13:48.395 INFO  extensions/nvdsmuxdemux/nvstreammux.hpp@27: initialize: nvstreammux streammux
2023-05-18 08:13:48.395 INFO  extensions/nvdsinference/nvinferbin.hpp@24: initialize: nvinferbin object_detector
2023-05-18 08:13:48.395 INFO  extensions/nvdsvisualization/nvosdbin.hpp@24: initialize: nvosdbin onscreen_display
2023-05-18 08:13:48.398 INFO  extensions/nvdsoutputsink/nvvideorenderersinkbin.hpp@24: initialize: nvvideorenderersinkbin video_renderer
2023-05-18 08:13:48.399 INFO  gxf/gxe/gxe.cpp@256: Running...
2023-05-18 08:13:48.399 INFO  extensions/nvdsbase/nvds_scheduler.cpp@121: Scheduling 5 elements and 1 components
2023-05-18 08:13:48.399 INFO  extensions/nvdssource/nvurisrcbin.hpp@32: create_element: nvurisrcbin single_source_input
2023-05-18 08:13:48.627 INFO  extensions/nvdssource/nvurisrcbin.hpp@56: bin_add: nvurisrcbin single_source_input
2023-05-18 08:13:48.627 INFO  extensions/nvdsmuxdemux/nvstreammux.hpp@37: create_element: nvstreammux streammux
2023-05-18 08:13:48.629 INFO  extensions/nvdsmuxdemux/nvstreammux.hpp@61: bin_add: nvstreammux streammux
2023-05-18 08:13:48.629 INFO  extensions/nvdsinference/nvinferbin.hpp@32: create_element: nvinferbin object_detector
2023-05-18 08:13:48.631 INFO  extensions/nvdsinference/nvinferbin.hpp@56: bin_add: nvinferbin object_detector
2023-05-18 08:13:48.632 INFO  extensions/nvdsvisualization/nvosdbin.hpp@32: create_element: nvosdbin onscreen_display
2023-05-18 08:13:48.637 INFO  extensions/nvdsvisualization/nvosdbin.hpp@56: bin_add: nvosdbin onscreen_display
2023-05-18 08:13:48.637 INFO  extensions/nvdsoutputsink/nvvideorenderersinkbin.hpp@32: create_element: nvvideorenderersinkbin video_renderer
2023-05-18 08:13:48.638 INFO  extensions/nvdsoutputsink/nvvideorenderersinkbin.hpp@54: bin_add: nvvideorenderersinkbin video_renderer
2023-05-18 08:13:58 [667,782ms] [Error] [omni.kit.app._impl] [py stderr]: 0:00:12.358602337   164 0x7f4efcecb0f0 WARN                 nvinfer gstnvinfer.cpp:677:gst_nvinfer_logger:<nvinfer_bin_nvinfer> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1897> [UID = 1]: deserialize engine from file :/tmp/ds.deepstream-test1/gxf/sample_models/primary.resnet10.caffemodel_b1_gpu0_int8.engine failed
0:00:12.358602337   164 0x7f4efcecb0f0 WARN                 nvinfer gstnvinfer.cpp:677:gst_nvinfer_logger:<nvinfer_bin_nvinfer> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1897> [UID = 1]: deserialize engine from file :/tmp/ds.deepstream-test1/gxf/sample_models/primary.resnet10.caffemodel_b1_gpu0_int8.engine failed2023-05-18 08:13:58 [667,782ms] [Error] [omni.kit.app._impl] [py stderr]:
2023-05-18 08:13:58 [667,909ms] [Error] [omni.kit.app._impl] [py stderr]: 0:00:12.469605101   164 0x7f4efcecb0f0 WARN                 nvinfer gstnvinfer.cpp:677:gst_nvinfer_logger:<nvinfer_bin_nvinfer> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2002>
[UID = 1]: deserialize backend context from engine from file :/tmp/ds.deepstream-test1/gxf/sample_models/primary.resnet10.caffemodel_b1_gpu0_int8.engine failed, try rebuild
0:00:12.469605101   164 0x7f4efcecb0f0 WARN                 nvinfer gstnvinfer.cpp:677:gst_nvinfer_logger:<nvinfer_bin_nvinfer> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2002> [UID = 1]: deserialize backend context from engine from file :/tmp/ds.deepstream-test1/gxf/sample_models/primary.resnet10.caffemodel_b1_gpu0_int8.engine failed, try rebuild2023-05-18 08:13:58 [667,910ms] [Error] [omni.kit.app._impl] [py stderr]:
2023-05-18 08:13:58 [667,910ms] [Error] [omni.kit.app._impl] [py stderr]: 0:00:12.470066310   164 0x7f4efcecb0f0 INFO                 nvinfer gstnvinfer.cpp:680:gst_nvinfer_logger:<nvinfer_bin_nvinfer> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1923> [UID = 1]: Trying to create engine from model files
0:00:12.470066310   164 0x7f4efcecb0f0 INFO                 nvinfer gstnvinfer.cpp:680:gst_nvinfer_logger:<nvinfer_bin_nvinfer> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1923> [UID = 1]: Trying to create engine from model files2023-05-18 08:13:58 [667,910ms] [Error] [omni.kit.app._impl] [py stderr]:
2023-05-18 08:15:33 [762,572ms] [Error] [omni.kit.app._impl] [py stderr]: 0:01:47.141576630   164 0x7f4efcecb0f0 INFO                 nvinfer gstnvinfer.cpp:680:gst_nvinfer_logger:<nvinfer_bin_nvinfer> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1955> [UID = 1]: serialize cuda engine to file: /tmp/ds.deepstream-test1/gxf/sample_models/primary.resnet10.caffemodel_b1_gpu0_int8.engine successfully
0:01:47.141576630   164 0x7f4efcecb0f0 INFO                 nvinfer gstnvinfer.cpp:680:gst_nvinfer_logger:<nvinfer_bin_nvinfer> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1955> [UID = 1]: serialize cuda engine to file: /tmp/ds.deepstream-test1/gxf/sample_models/primary.resnet10.caffemodel_b1_gpu0_int8.engine successfully2023-05-18 08:15:33 [762,575ms] [Error] [omni.kit.app._impl] [py stderr]:
2023-05-18 08:15:33 [762,706ms] [Error] [omni.kit.app._impl] [py stderr]: 0:01:47.278550236   164 0x7f4efcecb0f0 INFO                 nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<nvinfer_bin_nvinfer> [UID 1]: Load new model:/tmp/ds.deepstream-test1/gxf/sample_models/config_infer_primary.txt sucessfully
0:01:47.278550236   164 0x7f4efcecb0f0 INFO                 nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<nvinfer_bin_nvinfer> [UID 1]: Load new model:/tmp/ds.deepstream-test1/gxf/sample_models/config_infer_primary.txt sucessfully2023-05-18 08:15:33 [762,707ms] [Error] [omni.kit.app._impl] [py stderr]
WARNING: [TRT]: CUDA lazy loading is not enabled. Enabling it can significantly reduce device memory usage. See `CUDA_MODULE_LOADING` in https://docs.nvidia.com/cuda/cuda-c-programming-guide/index.html#env-vars
WARNING: ../nvdsinfer/nvdsinfer_model_builder.cpp:1487 Deserialize engine failed because file path: /tmp/ds.deepstream-test1/gxf/sample_models/primary.resnet10.caffemodel_b1_gpu0_int8.engine open error
WARNING: [TRT]: The implicit batch dimension mode has been deprecated. Please create the network with NetworkDefinitionCreationFlag::kEXPLICIT_BATCH flag whenever possible.
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 3
0   INPUT  kFLOAT input_1         3x368x640
1   OUTPUT kFLOAT conv2d_bbox     16x23x40
2   OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
Running...
****** NvDsScheduler Runtime Keyboard controls:
p: Pause pipeline
r: Resume pipeline
q: Quit pipeline
2023-05-18 08:15:33.380 INFO  extensions/nvdsbase/nvds_scheduler.cpp@398: NvDsScheduler Pipeline ready
2023-05-18 08:15:33 [762,766ms] [Error] [omni.kit.app._impl] [py stderr]: WARNING from element nvurisrc_bin_src_elem: No decoder available for type 'audio/mpeg, mpegversion=(int)4, framed=(boolean)true, stream-format=(string)raw, level=(string)2, base-profile=(string)lc, profile=(string)lc, codec_data=(buffer)119056e500, rate=(int)48000, channels=(int)2'.
framed=(boolean)true, stream-format=(string)raw, level=(string)2, base-profile=(string)lc, profile=(string)lc, codec_data=(buffer)119056e500, rate=(int)48000, channels=(int)2'.2023-05-18 08:15:33 [762,766ms] [Error] [omni.kit.app._impl] [py stderr]:
Error String : Feature not supported on this GPUError Code : 801
2023-05-18 08:15:33 [762,950ms] [Error] [omni.kit.app._impl] [py stderr]: 2023-05-18 08:15:33.608 ERROR extensions/nvdsbase/nvds_scheduler.cpp@312: Error from /GstPipeline:NvDsScheduler-Pipeline/GstDsNvUriSrcBin:single_source_input/single_source_input/GstURIDecodeBin:nvurisrc_bin_src_elem/GstDecodeBin:decodebin0/nvv4l2decoder:nvv4l2decoder0: Failed to process frame.
2023-05-18 08:15:33.608 ERROR extensions/nvdsbase/nvds_scheduler.cpp@312: Error from /GstPipeline:NvDsScheduler-Pipeline/GstDsNvUriSrcBin:single_source_input/single_source_input/GstURIDecodeBin:nvurisrc_bin_src_elem/GstDecodeBin:decodebin0/nvv4l2decoder:nvv4l2decoder0: Failed to process frame.2023-05-18 08:15:33 [762,950ms] [Error] [omni.kit.app._impl] [py stderr]:
2023-05-18 08:15:33 [762,950ms] [Error] [omni.kit.app._impl] [py stderr]: gstv4l2videodec.c(1804): gst_v4l2_video_dec_handle_frame (): /GstPipeline:NvDsScheduler-Pipeline/GstDsNvUriSrcBin:single_source_input/single_source_input/GstURIDecodeBin:nvurisrc_bin_src_elem/GstDecodeBin:decodebin0/nvv4l2decoder:nvv4l2decoder0:
gstv4l2videodec.c(1804): gst_v4l2_video_dec_handle_frame (): /GstPipeline:NvDsScheduler-Pipeline/GstDsNvUriSrcBin:single_source_input/single_source_input/GstURIDecodeBin:nvurisrc_bin_src_elem/GstDecodeBin:decodebin0/nvv4l2decoder:nvv4l2decoder0:2023-05-18 08:15:33 [762,950ms] [Error] [omni.kit.app._impl] [py stderr]:
2023-05-18 08:15:33 [762,950ms] [Error] [omni.kit.app._impl] [py stderr]: Maybe be due to not enough memory or failing driver
Maybe be due to not enough memory or failing driver2023-05-18 08:15:33 [762,950ms] [Error] [omni.kit.app._impl] [py stderr]:
2023-05-18 08:15:33 [762,951ms] [Error] [omni.kit.app._impl] [py stderr]: 2023-05-18 08:15:33.610 ERROR extensions/nvdsbase/nvds_scheduler.cpp@312: Error from /GstPipeline:NvDsScheduler-Pipeline/GstDsNvUriSrcBin:single_source_input/single_source_input/GstURIDecodeBin:nvurisrc_bin_src_elem/GstDecodeBin:decodebin0/GstQTDemux:qtdemux0: Internal data stream error.
2023-05-18 08:15:33.610 ERROR extensions/nvdsbase/nvds_scheduler.cpp@312: Error from /GstPipeline:NvDsScheduler-Pipeline/GstDsNvUriSrcBin:single_source_input/single_source_input/GstURIDecodeBin:nvurisrc_bin_src_elem/GstDecodeBin:decodebin0/GstQTDemux:qtdemux0: Internal data stream error.2023-05-18 08:15:33 [762,951ms] [Error] [omni.kit.app._impl] [py stderr]:
2023-05-18 08:15:33 [762,951ms] [Error] [omni.kit.app._impl] [py stderr]: 2023-05-18 08:15:33.610 ERROR extensions/nvdsbase/nvds_scheduler.cpp@314: Debug info:
2023-05-18 08:15:33.610 ERROR extensions/nvdsbase/nvds_scheduler.cpp@314: Debug info:2023-05-18 08:15:33 [762,951ms] [Error] [omni.kit.app._impl] [py stderr]:
2023-05-18 08:15:33 [762,951ms] [Error] [omni.kit.app._impl] [py stderr]: qtdemux.c(6619): gst_qtdemux_loop (): /GstPipeline:NvDsScheduler-Pipeline/GstDsNvUriSrcBin:single_source_input/single_source_input/GstURIDecodeBin:nvurisrc_bin_src_elem/GstDecodeBin:decodebin0/GstQTDemux:qtdemux0:
2023-05-18 08:15:33 [762,952ms] [Error] [omni.kit.app._impl] [py stderr]: streaming stopped, reason error (-5)
streaming stopped, reason error (-5)2023-05-18 08:15:33 [762,952ms] [Error] [omni.kit.app._impl] [py stderr]:
2023-05-18 08:15:33 [762,952ms] [Error] [omni.kit.app._impl] [py stderr]: 2023-05-18 08:15:33.610 ERROR extensions/nvdsbase/nvds_scheduler.cpp@349: Error from /GstPipeline:NvDsScheduler-Pipeline/GstDsNvUriSrcBin:single_source_input/single_source_input/GstURIDecodeBin:nvurisrc_bin_src_elem/GstDecodeBin:decodebin0/nvv4l2decoder:nvv4l2decoder0: Failed to process frame.
2023-05-18 08:15:33.610 ERROR extensions/nvdsbase/nvds_scheduler.cpp@349: Error from /GstPipeline:NvDsScheduler-Pipeline/GstDsNvUriSrcBin:single_source_input/single_source_input/GstURIDecodeBin:nvurisrc_bin_src_elem/GstDecodeBin:decodebin0/nvv4l2decoder:nvv4l2decoder0: Failed to process frame.2023-05-18 08:15:33 [762,952ms] [Error] [omni.kit.app._impl] [py stderr]:
2023-05-18 08:15:33 [762,952ms] [Error] [omni.kit.app._impl] [py stderr]: 2023-05-18 08:15:33.610 ERROR extensions/nvdsbase/nvds_scheduler.cpp@351: Debug info:
2023-05-18 08:15:33.610 ERROR extensions/nvdsbase/nvds_scheduler.cpp@351: Debug info:2023-05-18 08:15:33 [762,952ms] [Error] [omni.kit.app._impl] [py stderr]:
2023-05-18 08:15:33 [762,953ms] [Error] [omni.kit.app._impl] [py stderr]: gstv4l2videodec.c(1804): gst_v4l2_video_dec_handle_frame (): /GstPipeline:NvDsScheduler-Pipeline/GstDsNvUriSrcBin:single_source_input/single_source_input/GstURIDecodeBin:nvurisrc_bin_src_elem/GstDecodeBin:decodebin0/nvv4l2decoder:nvv4l2decoder0:
gstv4l2videodec.c(1804): gst_v4l2_video_dec_handle_frame (): /GstPipeline:NvDsScheduler-Pipeline/GstDsNvUriSrcBin:single_source_input/single_source_input/GstURIDecodeBin:nvurisrc_bin_src_elem/GstDecodeBin:decodebin0/nvv4l2decoder:nvv4l2decoder0:2023-05-18 08:15:33 [762,953ms] [Error] [omni.kit.app._impl] [py stderr]:
2023-05-18 08:15:33 [762,953ms] [Error] [omni.kit.app._impl] [py stderr]: Maybe be due to not enough memory or failing driver
Maybe be due to not enough memory or failing driver2023-05-18 08:15:33 [762,953ms] [Error] [omni.kit.app._impl] [py stderr]:
Returned, stopping playback
Deleting pipeline
2023-05-18 08:15:38.576 INFO  gxf/gxe/gxe.cpp@278: Deinitializing...
2023-05-18 08:15:38.577 INFO  gxf/gxe/gxe.cpp@285: Destroying context
2023-05-18 08:15:38.578 INFO  gxf/gxe/gxe.cpp@291: Context destroyed.
End deepstream-test1.yaml
[INFO] Graph installation directory /tmp/ds.deepstream-test1 and manifest /tmp/ds.deepstream-test1/manifest.yaml retained
The rest test files also have the similar errors.
Please run “/opt/nvidia/deepstream/deepstream/user_additional_install.sh” in the docker before you run any graph.
