Problem running deepstream 2.0 reference sample
Hello all. I’m trying to run deepstream-app sample with the “source4_720p_dec_infer-resnet_tracker_sgie_tiled_display_int8_gpu1.txt” configuration file which is provided in samples/configs/deepstream-app. When I execute the command - “deepstream-app -c source4_720p_dec_infer-resnet_tracker_sgie_tiled_display_int8_gpu1.txt”, I get the following error:
** (deepstream-app:2835): CRITICAL **: gst_ffmpeg_cfg_set_property: assertion 'qdata->size == sizeof (gint64)' failed
Unable to set device in gst_nvstreammux_change_state
** ERROR: <main:490>: Failed to set pipeline to PAUSED
Quitting
App run failed
The config file is as follows:
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
flow-original-resolution=1
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=1
rows=2
columns=2
width=1280
height=720
gpu-id=1
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI
type=3
uri=file://../../streams/sample_720p.mp4
num-sources=4
gpu-id=1
[sink0]
enable=0
#Type - 1=FakeSink 2=EglSink 3=File
type=2
sync=1
source-id=0
gpu-id=0
[sink1]
enable=1
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265 3=mpeg4
## only SW mpeg4 is supported right now.
codec=3
sync=0
bitrate=2000000
output-file=out.mp4
source-id=0
[osd]
enable=1
gpu-id=1
osd-mode=1
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Arial
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
[primary-gie]
enable=1
gpu-id=1
net-scale-factor=0.0039215697906911373
model-file=../../models/Primary_Detector/resnet10.caffemodel
proto-file=../../models/Primary_Detector/resnet10.prototxt
model-cache=../../models/Primary_Detector/resnet10.caffemodel_b4_int8.cache
labelfile-path=../../models/Primary_Detector/labels.txt
int8-calib-file=../../models/Primary_Detector/cal_trt4.bin
net-stride=16
batch-size=4
## 0=FP32, 1=INT8, 2=FP16 mode
network-mode=1
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
num-classes=4
class-thresholds=0.2;0.2;0.1;0.2
class-eps=0.2;0.2;0.2;0.2
class-group-thresholds=1;1;1;1
roi-top-offset=0;0;0;0
roi-bottom-offset=0;0;0;0
detected-min-w=0;0;0;0
detected-min-h=0;0;0;0
detected-max-w=1280;1280;1280;1280
detected-max-h=720;720;720;720
interval=0
gie-unique-id=1
parse-func=4
output-bbox-name=conv2d_bbox
output-blob-names=conv2d_cov
parser-bbox-norm=35.0;35.0
#config-file=config_infer_resnet.txt
[tracker]
enable=1
tracker-width=640
tracker-height=368
gpu-id=1
[secondary-gie0]
enable=1
net-scale-factor=1
model-file=../../models/Secondary_VehicleTypes/resnet18.caffemodel
proto-file=../../models/Secondary_VehicleTypes/resnet18.prototxt
model-cache=../../models/Secondary_VehicleTypes/resnet18.caffemodel_b16_int8.cache
mean-file=../../models/Secondary_VehicleTypes/mean.ppm
labelfile-path=../../models/Secondary_VehicleTypes/labels.txt
int8-calib-file=../../models/Secondary_VehicleTypes/cal_trt4.bin
gpu-id=1
batch-size=16
num-classes=6
network-mode=1
detected-min-w=128
detected-min-h=128
detected-max-w=1280
detected-max-h=720
model-color-format=1
gie-unique-id=4
operate-on-gie-id=1
operate-on-class-ids=0;
is-classifier=1
output-blob-names=predictions/Softmax
classifier-async-mode=1
classifier-threshold=0.51
[secondary-gie1]
enable=1
net-scale-factor=1
model-file=../../models/Secondary_CarColor/resnet18.caffemodel
proto-file=../../models/Secondary_CarColor/resnet18.prototxt
model-cache=../../models/Secondary_CarColor/resnet18.caffemodel_b16_int8.cache
mean-file=../../models/Secondary_CarColor/mean.ppm
labelfile-path=../../models/Secondary_CarColor/labels.txt
batch-size=16
network-mode=1
detected-min-w=128
detected-min-h=128
detected-max-w=1280
detected-max-h=720
num-classes=12
gpu-id=1
gie-unique-id=5
operate-on-gie-id=1
is-classifier=1
[secondary-gie2]
enable=1
net-scale-factor=1
model-file=../../models/Secondary_CarMake/resnet18.caffemodel
proto-file=../../models/Secondary_CarMake/resnet18.prototxt
model-cache=../../models/Secondary_CarMake/resnet18.caffemodel_b16_int8.cache
mean-file=../../models/Secondary_CarMake/mean.ppm
labelfile-path=../../models/Secondary_CarMake/labels.txt
int8-calib-file=../../models/Secondary_CarMake/cal_trt4.bin
batch-size=16
network-mode=1
num-classes=24
detected-min-w=128
detected-min-h=128
detected-max-w=1280
detected-max-h=720
gpu-id=1
gie-unique-id=6
operate-on-gie-id=1
is-classifier=1
[tests]
file-loop=0
  • If it is worth mentioning, I was able to successfully run the application with the other two configuration files in the same directory: “source30_720p_dec_infer-resnet_tiled_display_int8.txt” and " and “source4_720p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt”.
  • I disabled sink 0 and enabled sink 1 in the configuration file to write the output into a video instead of displaying it as it is being run on a cloud instance.
  • As mentioned in another post (https://devtalk.nvidia.com/default/topic/1038286/deepstream-for-tesla/can-t-run-sample-example), I tried running nvidia-smi and the deviceQuery sample in cuda an they work fine. The outputs came out to be the following:
For nvidia-smi:
Wed Dec 12 13:59:22 2018
| NVIDIA-SMI 396.37                 Driver Version: 396.37                    |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|   0  Quadro P4000        Off  | 00000000:00:05.0 Off |                  N/A |
|  0%   34C    P0    28W / 105W |      0MiB /  8119MiB |      0%      Default |
| Processes:                                                       GPU Memory |
|  GPU       PID   Type   Process name                             Usage      |
|  No running processes found                                                 |
For deviceQuery sample:
CUDA Device Query (Runtime API) version (CUDART static linking)
Detected 1 CUDA Capable device(s)
Device 0: "Quadro P4000"
  CUDA Driver Version / Runtime Version          9.2 / 9.2
  CUDA Capability Major/Minor version number:    6.1
  Total amount of global memory:                 8120 MBytes (8513978368 bytes)
  (14) Multiprocessors, (128) CUDA Cores/MP:     1792 CUDA Cores
  GPU Max Clock rate:                            1480 MHz (1.48 GHz)
  Memory Clock rate:                             3802 Mhz
  Memory Bus Width:                              256-bit
  L2 Cache Size:                                 2097152 bytes
  Maximum Texture Dimension Size (x,y,z)         1D=(131072), 2D=(131072, 65536), 3D=(16384, 16384, 16384)
  Maximum Layered 1D Texture Size, (num) layers  1D=(32768), 2048 layers
  Maximum Layered 2D Texture Size, (num) layers  2D=(32768, 32768), 2048 layers
  Total amount of constant memory:               65536 bytes
  Total amount of shared memory per block:       49152 bytes
  Total number of registers available per block: 65536
  Warp size:                                     32
  Maximum number of threads per multiprocessor:  2048
  Maximum number of threads per block:           1024
  Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
  Max dimension size of a grid size    (x,y,z): (2147483647, 65535, 65535)
  Maximum memory pitch:                          2147483647 bytes
  Texture alignment:                             512 bytes
  Concurrent copy and kernel execution:          Yes with 2 copy engine(s)
  Run time limit on kernels:                     No
  Integrated GPU sharing Host Memory:            No
  Support host page-locked memory mapping:       Yes
  Alignment requirement for Surfaces:            Yes
  Device has ECC support:                        Disabled
  Device supports Unified Addressing (UVA):      Yes
  Device supports Compute Preemption:            Yes
  Supports Cooperative Kernel Launch:            Yes
  Supports MultiDevice Co-op Kernel Launch:      Yes
  Device PCI Domain ID / Bus ID / location ID:   0 / 0 / 5
  Compute Mode:
     < Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 9.2, CUDA Runtime Version = 9.2, NumDevs = 1
Result = PASS
Any ideas on how to solve the problem and run the deepstream-app with “source4_720p_dec_infer-resnet_tracker_sgie_tiled_display_int8_gpu1.txt” configuration file?
Okay. I guess it is just because there’s just a single GPU and hence, GPU with device ID=1 doesn’t exist.
We did not test it on Quadro P4000
I got the same error in T4 in amazon, but I changed to id=0 because I only had 1 gpu, maybe you have to do that in config file.
As I see, the main id change should be in streammux section in the .txt
And success.
