Deepstream 6.0.1 samples running failure
TensorRT Version : 8.4.0.6-ea
GPU Type : 3090ti
Nvidia Driver Version :510.+
CUDA Version : 11.6
CUDNN Version : 8.4.0
**deepstream-app version 6.0.1
**DeepStreamSDK 6.0.1
Operating System + Version : ubuntu18.04.6
running cmd:
GST_DEBUG=3 deepstream-app -c ./configs/deepstream-app/source2_1080p_dec_infer-resnet_demux_int8.txt
output:
0:00:00.107552642 134736 0x55fa7433c180 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<sink_sub_bin_encoder2:sink> Unable to try format: Unknown error -1
0:00:00.107585973 134736 0x55fa7433c180 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:<sink_sub_bin_encoder2:sink> Could not probe minimum capture size for pixelformat YM12
0:00:00.107592534 134736 0x55fa7433c180 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<sink_sub_bin_encoder2:sink> Unable to try format: Unknown error -1
0:00:00.107598838 134736 0x55fa7433c180 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:<sink_sub_bin_encoder2:sink> Could not probe maximum capture size for pixelformat YM12
0:00:00.107607370 134736 0x55fa7433c180 WARN v4l2 gstv4l2object.c:2388:gst_v4l2_object_add_interlace_mode:0x55fa73fde800 Failed to determine interlace mode
0:00:00.107619634 134736 0x55fa7433c180 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<sink_sub_bin_encoder2:sink> Unable to try format: Unknown error -1
0:00:00.107625204 134736 0x55fa7433c180 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:<sink_sub_bin_encoder2:sink> Could not probe minimum capture size for pixelformat NM12
0:00:00.107629245 134736 0x55fa7433c180 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<sink_sub_bin_encoder2:sink> Unable to try format: Unknown error -1
0:00:00.107634655 134736 0x55fa7433c180 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:<sink_sub_bin_encoder2:sink> Could not probe maximum capture size for pixelformat NM12
0:00:00.107639297 134736 0x55fa7433c180 WARN v4l2 gstv4l2object.c:2388:gst_v4l2_object_add_interlace_mode:0x55fa73fde800 Failed to determine interlace mode
0:00:00.107676136 134736 0x55fa7433c180 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<sink_sub_bin_encoder2:src> Unable to try format: Unknown error -1
0:00:00.107685593 134736 0x55fa7433c180 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:<sink_sub_bin_encoder2:src> Could not probe minimum capture size for pixelformat H264
0:00:00.107689886 134736 0x55fa7433c180 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<sink_sub_bin_encoder2:src> Unable to try format: Unknown error -1
0:00:00.107694447 134736 0x55fa7433c180 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:<sink_sub_bin_encoder2:src> Could not probe maximum capture size for pixelformat H264
0:00:00.107925574 134736 0x55fa7433c180 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<sink_sub_bin_encoder1:sink> Unable to try format: Unknown error -1
0:00:00.107934864 134736 0x55fa7433c180 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:<sink_sub_bin_encoder1:sink> Could not probe minimum capture size for pixelformat YM12
0:00:00.107939047 134736 0x55fa7433c180 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<sink_sub_bin_encoder1:sink> Unable to try format: Unknown error -1
0:00:00.107944009 134736 0x55fa7433c180 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:<sink_sub_bin_encoder1:sink> Could not probe maximum capture size for pixelformat YM12
0:00:00.107949506 134736 0x55fa7433c180 WARN v4l2 gstv4l2object.c:2388:gst_v4l2_object_add_interlace_mode:0x55fa73eee460 Failed to determine interlace mode
0:00:00.107959030 134736 0x55fa7433c180 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<sink_sub_bin_encoder1:sink> Unable to try format: Unknown error -1
0:00:00.107963760 134736 0x55fa7433c180 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:<sink_sub_bin_encoder1:sink> Could not probe minimum capture size for pixelformat NM12
0:00:00.107967859 134736 0x55fa7433c180 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<sink_sub_bin_encoder1:sink> Unable to try format: Unknown error -1
0:00:00.107972267 134736 0x55fa7433c180 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:<sink_sub_bin_encoder1:sink> Could not probe maximum capture size for pixelformat NM12
0:00:00.107976590 134736 0x55fa7433c180 WARN v4l2 gstv4l2object.c:2388:gst_v4l2_object_add_interlace_mode:0x55fa73eee460 Failed to determine interlace mode
0:00:00.108006322 134736 0x55fa7433c180 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<sink_sub_bin_encoder1:src> Unable to try format: Unknown error -1
0:00:00.108010712 134736 0x55fa7433c180 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:<sink_sub_bin_encoder1:src> Could not probe minimum capture size for pixelformat H264
0:00:00.108014552 134736 0x55fa7433c180 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<sink_sub_bin_encoder1:src> Unable to try format: Unknown error -1
0:00:00.108018735 134736 0x55fa7433c180 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:<sink_sub_bin_encoder1:src> Could not probe maximum capture size for pixelformat H264
0:00:01.935204672 134736 0x55fa7433c180 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1900> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.0/samples/configs/deepstream-app/…/…/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine
INFO: …/nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:00:02.019313217 134736 0x55fa7433c180 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2004> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.0/samples/configs/deepstream-app/…/…/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine
0:00:02.020731736 134736 0x55fa7433c180 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream-6.0/samples/configs/deepstream-app/config_infer_primary.txt sucessfully
0:00:02.021547637 134736 0x55fa7433c180 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:02.021795037 134736 0x55fa7433c180 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:02.022126028 134736 0x55fa7433c180 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:02.022488069 134736 0x55fa7433c180 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
** INFO: <bus_callback:194>: Pipeline ready
0:00:02.035666164 134736 0x7f6e04032f70 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 1
0:00:02.035679244 134736 0x7f6e0804f770 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 1
0:00:02.035909438 134736 0x7f6e04032f70 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 2
0:00:02.035911562 134736 0x7f6e0804f770 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 2
0:00:02.091520058 134736 0x7f6dfc0130f0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:02.091558681 134736 0x7f6dfc0130f0 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat MJPG
0:00:02.091571614 134736 0x7f6dfc0130f0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:02.091587409 134736 0x7f6dfc0130f0 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat MJPG
0:00:02.091632110 134736 0x7f6dfc0130f0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:02.091646194 134736 0x7f6dfc0130f0 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat MPG4
0:00:02.091660659 134736 0x7f6dfc0130f0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:02.091674322 134736 0x7f6dfc0130f0 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat MPG4
0:00:02.091703090 134736 0x7f6dfc0130f0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:02.091719487 134736 0x7f6dfc0130f0 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat MPG2
0:00:02.091736987 134736 0x7f6dfc0130f0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:02.091749879 134736 0x7f6dfc0130f0 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat MPG2
0:00:02.091783724 134736 0x7f6dfc0130f0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:02.091797635 134736 0x7f6dfc0130f0 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat H265
0:00:02.091807596 134736 0x7f6dfc0130f0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:02.091818123 134736 0x7f6dfc0130f0 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat H265
0:00:02.091843600 134736 0x7f6dfc0130f0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:02.091857576 134736 0x7f6dfc0130f0 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat VP90
0:00:02.091867636 134736 0x7f6dfc0130f0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:02.091878764 134736 0x7f6dfc0130f0 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat VP90
0:00:02.091901792 134736 0x7f6dfc0130f0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:02.091912569 134736 0x7f6dfc0130f0 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat VP80
0:00:02.091922256 134736 0x7f6dfc0130f0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:02.091932370 134736 0x7f6dfc0130f0 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat VP80
0:00:02.091957705 134736 0x7f6dfc0130f0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:02.091968625 134736 0x7f6dfc0130f0 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat H264
0:00:02.091981311 134736 0x7f6dfc0130f0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:02.091999711 134736 0x7f6dfc0130f0 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat H264
0:00:02.092089546 134736 0x7f6dfc0130f0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:src Unable to try format: Unknown error -1
0:00:02.092103778 134736 0x7f6dfc0130f0 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:src Could not probe minimum capture size for pixelformat NM12
0:00:02.092113457 134736 0x7f6dfc0130f0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:src Unable to try format: Unknown error -1
0:00:02.092124817 134736 0x7f6dfc0130f0 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:src Could not probe maximum capture size for pixelformat NM12
0:00:02.092141794 134736 0x7f6dfc0130f0 WARN v4l2 gstv4l2object.c:2388:gst_v4l2_object_add_interlace_mode:0x7f6df001f020 Failed to determine interlace mode
0:00:02.092777377 134736 0x7f6df8013ad0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:02.092817244 134736 0x7f6df8013ad0 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe minimum capture size for pixelformat MJPG
0:00:02.092831664 134736 0x7f6df8013ad0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:02.092850529 134736 0x7f6df8013ad0 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe maximum capture size for pixelformat MJPG
0:00:02.092887829 134736 0x7f6df8013ad0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:02.092904838 134736 0x7f6df8013ad0 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe minimum capture size for pixelformat MPG4
0:00:02.092918850 134736 0x7f6df8013ad0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:02.092931904 134736 0x7f6df8013ad0 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe maximum capture size for pixelformat MPG4
0:00:02.092964663 134736 0x7f6df8013ad0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:02.092978525 134736 0x7f6df8013ad0 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe minimum capture size for pixelformat MPG2
0:00:02.092990103 134736 0x7f6df8013ad0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:02.093046784 134736 0x7f6df8013ad0 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe maximum capture size for pixelformat MPG2
0:00:02.093074806 134736 0x7f6df8013ad0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:02.093088886 134736 0x7f6df8013ad0 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe minimum capture size for pixelformat H265
0:00:02.093105326 134736 0x7f6df8013ad0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:02.093124824 134736 0x7f6df8013ad0 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe maximum capture size for pixelformat H265
0:00:02.093154977 134736 0x7f6df8013ad0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:02.093169672 134736 0x7f6df8013ad0 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe minimum capture size for pixelformat VP90
0:00:02.093180621 134736 0x7f6df8013ad0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:02.093194540 134736 0x7f6df8013ad0 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe maximum capture size for pixelformat VP90
0:00:02.093215561 134736 0x7f6df8013ad0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:02.093228196 134736 0x7f6df8013ad0 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe minimum capture size for pixelformat VP80
0:00:02.093241517 134736 0x7f6df8013ad0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:02.093254321 134736 0x7f6df8013ad0 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe maximum capture size for pixelformat VP80
0:00:02.093280996 134736 0x7f6df8013ad0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:02.093296693 134736 0x7f6df8013ad0 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe minimum capture size for pixelformat H264
0:00:02.093309756 134736 0x7f6df8013ad0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:02.093324316 134736 0x7f6df8013ad0 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe maximum capture size for pixelformat H264
0:00:02.093406932 134736 0x7f6df8013ad0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:src Unable to try format: Unknown error -1
0:00:02.093421199 134736 0x7f6df8013ad0 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:src Could not probe minimum capture size for pixelformat NM12
0:00:02.093431634 134736 0x7f6df8013ad0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:src Unable to try format: Unknown error -1
0:00:02.093444172 134736 0x7f6df8013ad0 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:src Could not probe maximum capture size for pixelformat NM12
0:00:02.093464824 134736 0x7f6df8013ad0 WARN v4l2 gstv4l2object.c:2388:gst_v4l2_object_add_interlace_mode:0x7f6df401f630 Failed to determine interlace mode
0:00:02.205691562 134736 0x7f6dfc0130f0 WARN v4l2videodec gstv4l2videodec.c:1685:gst_v4l2_video_dec_decide_allocation: Duration invalid, not setting latency
0:00:02.206131160 134736 0x7f6dfc0130f0 WARN v4l2bufferpool gstv4l2bufferpool.c:1065:gst_v4l2_buffer_pool_start:nvv4l2decoder0:pool:src Uncertain or not enough buffers, enabling copy threshold
0:00:02.207641972 134736 0x7f6df8013ad0 WARN v4l2videodec gstv4l2videodec.c:1685:gst_v4l2_video_dec_decide_allocation: Duration invalid, not setting latency
0:00:02.219667724 134736 0x7f6df8013ad0 WARN v4l2bufferpool gstv4l2bufferpool.c:1065:gst_v4l2_buffer_pool_start:nvv4l2decoder1:pool:src Uncertain or not enough buffers, enabling copy threshold
0:00:02.220082973 134736 0x7f6df000cf20 WARN v4l2bufferpool gstv4l2bufferpool.c:1512:gst_v4l2_buffer_pool_dqbuf:nvv4l2decoder0:pool:src Driver should never set v4l2_buffer.field to ANY
0:00:02.221564275 134736 0x7f6de8003320 WARN v4l2bufferpool gstv4l2bufferpool.c:1512:gst_v4l2_buffer_pool_dqbuf:nvv4l2decoder1:pool:src Driver should never set v4l2_buffer.field to ANY
Cuda failure: status=1 in cuResData at line 316
Cuda failure: status=1 in cuResData at line 348
** INFO: <bus_callback:180>: Pipeline running
0:00:02.304351015 134736 0x55fa73fd30a0 WARN v4l2bufferpool gstv4l2bufferpool.c:1065:gst_v4l2_buffer_pool_start:<sink_sub_bin_encoder1:pool:src> Uncertain or not enough buffers, enabling copy threshold
0:00:02.316713453 134736 0x55fa73f00ed0 WARN v4l2bufferpool gstv4l2bufferpool.c:1065:gst_v4l2_buffer_pool_start:<sink_sub_bin_encoder2:pool:src> Uncertain or not enough buffers, enabling copy threshold
Cuda failure: status=1 in cuResData at line 337
running samples error :
cmd:
output:
0:00:00.107563326 17116 0x5569f8d1ed80 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<sink_sub_bin_encoder2:sink> Unable to try format: Unknown error -1
0:00:00.107630411 17116 0x5569f8d1ed80 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:<sink_sub_bin_encoder2:sink> Could not probe minimum capture size for pixelformat YM12
0:00:00.107647321 17116 0x5569f8d1ed80 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<sink_sub_bin_encoder2:sink> Unable to try format: Unknown error -1
0:00:00.107663545 17116 0x5569f8d1ed80 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:<sink_sub_bin_encoder2:sink> Could not probe maximum capture size for pixelformat YM12
0:00:00.107684013 17116 0x5569f8d1ed80 WARN v4l2 gstv4l2object.c:2388:gst_v4l2_object_add_interlace_mode:0x5569f89a1c00 Failed to determine interlace mode
0:00:00.107723968 17116 0x5569f8d1ed80 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<sink_sub_bin_encoder2:sink> Unable to try format: Unknown error -1
0:00:00.107740917 17116 0x5569f8d1ed80 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:<sink_sub_bin_encoder2:sink> Could not probe minimum capture size for pixelformat NM12
0:00:00.107752502 17116 0x5569f8d1ed80 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<sink_sub_bin_encoder2:sink> Unable to try format: Unknown error -1
0:00:00.107766051 17116 0x5569f8d1ed80 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:<sink_sub_bin_encoder2:sink> Could not probe maximum capture size for pixelformat NM12
0:00:00.107779101 17116 0x5569f8d1ed80 WARN v4l2 gstv4l2object.c:2388:gst_v4l2_object_add_interlace_mode:0x5569f89a1c00 Failed to determine interlace mode
0:00:00.107886099 17116 0x5569f8d1ed80 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<sink_sub_bin_encoder2:src> Unable to try format: Unknown error -1
0:00:00.107904378 17116 0x5569f8d1ed80 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:<sink_sub_bin_encoder2:src> Could not probe minimum capture size for pixelformat H264
0:00:00.107918273 17116 0x5569f8d1ed80 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<sink_sub_bin_encoder2:src> Unable to try format: Unknown error -1
0:00:00.107934478 17116 0x5569f8d1ed80 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:<sink_sub_bin_encoder2:src> Could not probe maximum capture size for pixelformat H264
0:00:00.108460750 17116 0x5569f8d1ed80 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<sink_sub_bin_encoder1:sink> Unable to try format: Unknown error -1
0:00:00.108483662 17116 0x5569f8d1ed80 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:<sink_sub_bin_encoder1:sink> Could not probe minimum capture size for pixelformat YM12
0:00:00.108495121 17116 0x5569f8d1ed80 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<sink_sub_bin_encoder1:sink> Unable to try format: Unknown error -1
0:00:00.108508431 17116 0x5569f8d1ed80 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:<sink_sub_bin_encoder1:sink> Could not probe maximum capture size for pixelformat YM12
0:00:00.108522975 17116 0x5569f8d1ed80 WARN v4l2 gstv4l2object.c:2388:gst_v4l2_object_add_interlace_mode:0x5569f88b9a50 Failed to determine interlace mode
0:00:00.108551104 17116 0x5569f8d1ed80 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<sink_sub_bin_encoder1:sink> Unable to try format: Unknown error -1
0:00:00.108565273 17116 0x5569f8d1ed80 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:<sink_sub_bin_encoder1:sink> Could not probe minimum capture size for pixelformat NM12
0:00:00.108583474 17116 0x5569f8d1ed80 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<sink_sub_bin_encoder1:sink> Unable to try format: Unknown error -1
0:00:00.108599654 17116 0x5569f8d1ed80 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:<sink_sub_bin_encoder1:sink> Could not probe maximum capture size for pixelformat NM12
0:00:00.108615417 17116 0x5569f8d1ed80 WARN v4l2 gstv4l2object.c:2388:gst_v4l2_object_add_interlace_mode:0x5569f88b9a50 Failed to determine interlace mode
0:00:00.108703181 17116 0x5569f8d1ed80 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<sink_sub_bin_encoder1:src> Unable to try format: Unknown error -1
0:00:00.108718669 17116 0x5569f8d1ed80 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:<sink_sub_bin_encoder1:src> Could not probe minimum capture size for pixelformat H264
0:00:00.108729586 17116 0x5569f8d1ed80 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:<sink_sub_bin_encoder1:src> Unable to try format: Unknown error -1
0:00:00.108742260 17116 0x5569f8d1ed80 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:<sink_sub_bin_encoder1:src> Could not probe maximum capture size for pixelformat H264
0:00:29.314437083 17116 0x5569f8d1ed80 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:29.314753845 17116 0x5569f8d1ed80 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:29.315067538 17116 0x5569f8d1ed80 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
0:00:29.315373626 17116 0x5569f8d1ed80 WARN basesrc gstbasesrc.c:3583:gst_base_src_start_complete: pad not activated yet
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
**PERF: FPS 0 (Avg) FPS 1 (Avg)
**PERF: 0.00 (0.00) 0.00 (0.00)
0:00:29.329026665 17116 0x7f0054039f70 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 1
0:00:29.329249319 17116 0x7f0044046770 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 1
0:00:29.329378122 17116 0x7f0054039f70 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 2
0:00:29.329422070 17116 0x7f0044046770 WARN qtdemux qtdemux.c:3031:qtdemux_parse_trex: failed to find fragment defaults for stream 2
0:00:29.386471822 17116 0x7f003c0138f0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:29.386513048 17116 0x7f003c0138f0 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat MJPG
0:00:29.386528046 17116 0x7f003c0138f0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:29.386541761 17116 0x7f003c0138f0 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat MJPG
0:00:29.386597510 17116 0x7f003c0138f0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:29.386617889 17116 0x7f003c0138f0 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat MPG4
0:00:29.386629470 17116 0x7f003c0138f0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:29.386641890 17116 0x7f003c0138f0 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat MPG4
0:00:29.386668434 17116 0x7f003c0138f0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:29.386681172 17116 0x7f003c0138f0 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat MPG2
0:00:29.386691543 17116 0x7f003c0138f0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:29.386703508 17116 0x7f003c0138f0 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat MPG2
0:00:29.386736668 17116 0x7f003c0138f0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:29.386749647 17116 0x7f003c0138f0 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat H265
0:00:29.386765072 17116 0x7f003c0138f0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:29.386781106 17116 0x7f003c0138f0 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat H265
0:00:29.386806031 17116 0x7f003c0138f0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:29.386817795 17116 0x7f003c0138f0 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat VP90
0:00:29.386828671 17116 0x7f003c0138f0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:29.386840431 17116 0x7f003c0138f0 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat VP90
0:00:29.386861610 17116 0x7f003c0138f0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:29.386877584 17116 0x7f003c0138f0 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat VP80
0:00:29.386890698 17116 0x7f003c0138f0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:29.386903149 17116 0x7f003c0138f0 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat VP80
0:00:29.386928703 17116 0x7f003c0138f0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:29.386944234 17116 0x7f003c0138f0 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe minimum capture size for pixelformat H264
0:00:29.386955932 17116 0x7f003c0138f0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:sink Unable to try format: Unknown error -1
0:00:29.386974218 17116 0x7f003c0138f0 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:sink Could not probe maximum capture size for pixelformat H264
0:00:29.387080740 17116 0x7f0048012ad0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:29.387096080 17116 0x7f003c0138f0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:src Unable to try format: Unknown error -1
0:00:29.387121635 17116 0x7f0048012ad0 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe minimum capture size for pixelformat MJPG
0:00:29.387167787 17116 0x7f0048012ad0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:29.387144359 17116 0x7f003c0138f0 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:src Could not probe minimum capture size for pixelformat NM12
0:00:29.387211852 17116 0x7f003c0138f0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder0:src Unable to try format: Unknown error -1
0:00:29.387187938 17116 0x7f0048012ad0 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe maximum capture size for pixelformat MJPG
0:00:29.387227551 17116 0x7f003c0138f0 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder0:src Could not probe maximum capture size for pixelformat NM12
0:00:29.387284865 17116 0x7f0048012ad0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:29.387297746 17116 0x7f003c0138f0 WARN v4l2 gstv4l2object.c:2388:gst_v4l2_object_add_interlace_mode:0x7f003801d620 Failed to determine interlace mode
0:00:29.387299686 17116 0x7f0048012ad0 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe minimum capture size for pixelformat MPG4
0:00:29.387356695 17116 0x7f0048012ad0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:29.387369485 17116 0x7f0048012ad0 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe maximum capture size for pixelformat MPG4
0:00:29.387399549 17116 0x7f0048012ad0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:29.387416209 17116 0x7f0048012ad0 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe minimum capture size for pixelformat MPG2
0:00:29.387426833 17116 0x7f0048012ad0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:29.387438489 17116 0x7f0048012ad0 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe maximum capture size for pixelformat MPG2
0:00:29.387468417 17116 0x7f0048012ad0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:29.387487877 17116 0x7f0048012ad0 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe minimum capture size for pixelformat H265
0:00:29.387505400 17116 0x7f0048012ad0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:29.387517765 17116 0x7f0048012ad0 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe maximum capture size for pixelformat H265
0:00:29.387543231 17116 0x7f0048012ad0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:29.387557354 17116 0x7f0048012ad0 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe minimum capture size for pixelformat VP90
0:00:29.387572650 17116 0x7f0048012ad0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:29.387595135 17116 0x7f0048012ad0 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe maximum capture size for pixelformat VP90
0:00:29.387618948 17116 0x7f0048012ad0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:29.387634388 17116 0x7f0048012ad0 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe minimum capture size for pixelformat VP80
0:00:29.387647444 17116 0x7f0048012ad0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:29.387664553 17116 0x7f0048012ad0 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe maximum capture size for pixelformat VP80
0:00:29.387694647 17116 0x7f0048012ad0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:29.387708963 17116 0x7f0048012ad0 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe minimum capture size for pixelformat H264
0:00:29.387720637 17116 0x7f0048012ad0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:sink Unable to try format: Unknown error -1
0:00:29.387732722 17116 0x7f0048012ad0 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:sink Could not probe maximum capture size for pixelformat H264
0:00:29.387817070 17116 0x7f0048012ad0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:src Unable to try format: Unknown error -1
0:00:29.387829265 17116 0x7f0048012ad0 WARN v4l2 gstv4l2object.c:2937:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:src Could not probe minimum capture size for pixelformat NM12
0:00:29.387840430 17116 0x7f0048012ad0 WARN v4l2 gstv4l2object.c:3051:gst_v4l2_object_get_nearest_size:nvv4l2decoder1:src Unable to try format: Unknown error -1
0:00:29.387851640 17116 0x7f0048012ad0 WARN v4l2 gstv4l2object.c:2943:gst_v4l2_object_probe_caps_for_format:nvv4l2decoder1:src Could not probe maximum capture size for pixelformat NM12
0:00:29.387870198 17116 0x7f0048012ad0 WARN v4l2 gstv4l2object.c:2388:gst_v4l2_object_add_interlace_mode:0x7f003001e430 Failed to determine interlace mode
0:00:29.499296002 17116 0x7f003c0138f0 WARN v4l2videodec gstv4l2videodec.c:1685:gst_v4l2_video_dec_decide_allocation: Duration invalid, not setting latency
0:00:29.499823577 17116 0x7f003c0138f0 WARN v4l2bufferpool gstv4l2bufferpool.c:1065:gst_v4l2_buffer_pool_start:nvv4l2decoder0:pool:src Uncertain or not enough buffers, enabling copy threshold
0:00:29.501643793 17116 0x7f003800e720 WARN v4l2bufferpool gstv4l2bufferpool.c:1512:gst_v4l2_buffer_pool_dqbuf:nvv4l2decoder0:pool:src Driver should never set v4l2_buffer.field to ANY
0:00:29.503691852 17116 0x7f0048012ad0 WARN v4l2videodec gstv4l2videodec.c:1685:gst_v4l2_video_dec_decide_allocation: Duration invalid, not setting latency
0:00:29.503992774 17116 0x7f0048012ad0 WARN v4l2bufferpool gstv4l2bufferpool.c:1065:gst_v4l2_buffer_pool_start:nvv4l2decoder1:pool:src Uncertain or not enough buffers, enabling copy threshold
0:00:29.518006200 17116 0x7f0028002f20 WARN v4l2bufferpool gstv4l2bufferpool.c:1512:gst_v4l2_buffer_pool_dqbuf:nvv4l2decoder1:pool:src Driver should never set v4l2_buffer.field to ANY
0:00:29.570435250 17116 0x5569f88cc2d0 WARN v4l2bufferpool gstv4l2bufferpool.c:1065:gst_v4l2_buffer_pool_start:<sink_sub_bin_encoder2:pool:src> Uncertain or not enough buffers, enabling copy threshold
0:00:29.580111139 17116 0x5569f88cc720 WARN v4l2bufferpool gstv4l2bufferpool.c:1065:gst_v4l2_buffer_pool_start:<sink_sub_bin_encoder1:pool:src> Uncertain or not enough buffers, enabling copy threshold
Cuda failure: status=1 in cuResData at line 281
Can you lower driver to 470.63, try again?
You must install the following components:
  • Ubuntu 18.04
  • GStreamer 1.14.5
  • NVIDIA driver 470.63.01
  • CUDA 11.4
  • TensorRT 8.0.1
