• Hardware Platform (Jetson / GPU) : jetson nano • DeepStream Version : 2.0 DP • JetPack Version (valid for Jetson only) : 4.4 DP • TensorRT Version : 7.1
1- How much deep stream can busy then jetson nano when lunch deep stream FaceDetection-IR?
2- Is it possible to deploy the FaceDetection-IR with deepstream sdk on multi-stream RTSP simultaneously? Is it easy work?
2- In the https://ngc.nvidia.com/catalog/models/nvidia:tlt_facedetectir, How do I run the facedetection on Deep stream, in the example this show peoplenet?
I saw a demo of jetson nano, that process 8 streams 1080p30 as the same time,
1- If demo prcoessed 8 stream 1080p as the same time, we need 8 model loaded and 8 frames passed to the models and process as the same time, but I want to know, How we can load 8 models together in 4 GB ram? Is it possible? I feel thay used one model and processes the frames of 8 streams one by one? and we also need amout of memory for resizing the 1080 to input size of models and CPU and GPU used share memory, right?
Now, it does not work like this.
As below diagram shows, 8 streams send their frames to nvstreammux, nnvstreammux could batch these frames as one batch,then send to nvinfer to do inference (each inference loop processes 8 frames).
stream#1 -> |
… | -> nvstreammux (batch the frames, e.g. one batch=8 frames) --> nvinfer (one model) -->
stream#8 -> |
1- How many models used in that demo for 8 streams, one model for all?
2- The model a the one time processed 1 frame, right? don’t use input size of (N>1,H,W,C) and processed at the same time?
3- In my opinion, If the the model proccessed one frame with 80 FPS then for 8 streams we can do 10 FPS for each model, right? If so, How to do 8 streams with 30 FPS? this is not online?
3-
In this demo one stream is for people detection and this is used Peoplenet(DetectNet2+resnet) and this network has 10 FPS on jetson nano, I don’t know how this process 1080, 30FPS?
So the jetson nano has a separate hardware for scaling the images? different from decoder hardware?
Because I connected the USB TPU to jetson nano, I need to captures the decoded and resized the streams passed into TPU, How I can to capture the frames of streams from decoder/VIC in array format?
I used the below codes for decoder and resacaling, the decoder used hardware by run sudo tegrastats I show NVDEC, for rescaling hardware, How I can check?
In the deep stream config sample, there is a interval options, what is that?
I have 8 stream 1080 and use detectnet_v2_resnet10 for detection, If I set the interval=0 and the process is became very slow and when I set interval=4, then the process is ok and fast, that mean I used every 4 frame for processing?
the part code of source8_1080p_dec_infer-resnet_tracker_tiled_display_fp16_nano.txt :
[primary-gie]
enable=1
gpu-id=0
model-engine-file=../../models/Primary_Detector_Nano/resnet10.caffemodel_b8_gpu0_fp16.engine
batch-size=8
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
interval=4
gie-unique-id=1
nvbuf-memory-type=0
config-file=config_infer_primary_nano.txt
Thanks,
that say interval is Specifies the number of consecutive batches to be skipped for inference
If we have 8 RTSP and we set batch-size=8 and interval=4, then we capture every 4 frame for each stream, right? If so, what’s difference between interval and drop-frame-rate in gstreamer option?
drop-frame-interval drops the frames from source, it affects all following components, e.g. display, encoding. For exmaple, with drop-frame-interval=4 for 30fps stream, the display can only receive 6 fps. interval onlys affects the inference components,
