Deepstream 6.3 python apps , deepstream_test4/ Segmentation fault (core dumped)
When I run this Deepstream Python App:
/opt/nvidia/deepstream/deepstream-6.3/sources/deepstream_python_apps/apps/deepstream_test4/deepstream_test_4.py
I get this fault:
cpp:328:notifyLoadModelStatus: [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream-6.3/sources/deepstream_python_apps/apps/deepstream_test4/dstest4_pgie_config.txt sucessfully
Frame Number = 0 Vehicle Count = 9 Person Count = 4
I can get the program to run if I block out
#MAX_TIME_STAMP_LEN = 32
in the program. But then I get this error:
NameError: name ‘MAX_TIME_STAMP_LEN’ is not defined
Here is the code:
import sys
sys.path.append(‘../’)
import gi
gi.require_version(‘Gst’, ‘1.0’)
from gi.repository import GLib, Gst
import sys
from optparse import OptionParser
from common.is_aarch_64 import is_aarch64
from common.bus_call import bus_call
from common.utils import long_to_uint64
import pyds
MAX_DISPLAY_LEN = 64
PGIE_CLASS_ID_VEHICLE = 0
PGIE_CLASS_ID_BICYCLE = 1
PGIE_CLASS_ID_PERSON = 2
PGIE_CLASS_ID_ROADSIGN = 3
MUXER_OUTPUT_WIDTH = 1920
MUXER_OUTPUT_HEIGHT = 1080
MUXER_BATCH_TIMEOUT_USEC = 4000000
input_file = None
schema_type = 0
proto_lib = “/opt/nvidia/deepstream/deepstream-6.3/lib/libnvds_mqtt_proto.so”
conn_str = “localhost;1883;testTopic”
cfg_file = “/opt/nvidia/deepstream/deepstream-6.3/sources/deepstream_python_apps/apps/deepstream-test4/cfg_mqtt.txt”
topic = “topic”
no_display = False
PGIE_CONFIG_FILE = “dstest4_pgie_config.txt”
MSCONV_CONFIG_FILE = “dstest4_msgconv_config.txt”
pgie_classes_str = [“Vehicle”, “TwoWheeler”, “Person”, “Roadsign”]
Callback function for deep-copying an NvDsEventMsgMeta struct
def meta_copy_func(data, user_data):
# Cast data to pyds.NvDsUserMeta
user_meta = pyds.NvDsUserMeta.cast(data)
src_meta_data = user_meta.user_meta_data
# Cast src_meta_data to pyds.NvDsEventMsgMeta
srcmeta = pyds.NvDsEventMsgMeta.cast(src_meta_data)
# Duplicate the memory contents of srcmeta to dstmeta
# First use pyds.get_ptr() to get the C address of srcmeta, then
# use pyds.memdup() to allocate dstmeta and copy srcmeta into it.
# pyds.memdup returns C address of the allocated duplicate.
dstmeta_ptr = pyds.memdup(pyds.get_ptr(srcmeta),
sys.getsizeof(pyds.NvDsEventMsgMeta))
# Cast the duplicated memory to pyds.NvDsEventMsgMeta
dstmeta = pyds.NvDsEventMsgMeta.cast(dstmeta_ptr)
# Duplicate contents of ts field. Note that reading srcmeat.ts
# returns its C address. This allows to memory operations to be
# performed on it.
dstmeta.ts = pyds.memdup(srcmeta.ts, MAX_TIME_STAMP_LEN + 1)
# Copy the sensorStr. This field is a string property. The getter (read)
# returns its C address. The setter (write) takes string as input,
# allocates a string buffer and copies the input string into it.
# pyds.get_string() takes C address of a string and returns the reference
# to a string object and the assignment inside the binder copies content.
dstmeta.sensorStr = pyds.get_string(srcmeta.sensorStr)
if srcmeta.objSignature.size > 0:
dstmeta.objSignature.signature = pyds.memdup(
srcmeta.objSignature.signature, srcmeta.objSignature.size)
dstmeta.objSignature.size = srcmeta.objSignature.size
if srcmeta.extMsgSize > 0:
if srcmeta.objType == pyds.NvDsObjectType.NVDS_OBJECT_TYPE_VEHICLE:
srcobj = pyds.NvDsVehicleObject.cast(srcmeta.extMsg)
obj = pyds.alloc_nvds_vehicle_object()
obj.type = pyds.get_string(srcobj.type)
obj.make = pyds.get_string(srcobj.make)
obj.model = pyds.get_string(srcobj.model)
obj.color = pyds.get_string(srcobj.color)
obj.license = pyds.get_string(srcobj.license)
obj.region = pyds.get_string(srcobj.region)
dstmeta.extMsg = obj
dstmeta.extMsgSize = sys.getsizeof(pyds.NvDsVehicleObject)
if srcmeta.objType == pyds.NvDsObjectType.NVDS_OBJECT_TYPE_PERSON:
srcobj = pyds.NvDsPersonObject.cast(srcmeta.extMsg)
obj = pyds.alloc_nvds_person_object()
obj.age = srcobj.age
obj.gender = pyds.get_string(srcobj.gender)
obj.cap = pyds.get_string(srcobj.cap)
obj.hair = pyds.get_string(srcobj.hair)
obj.apparel = pyds.get_string(srcobj.apparel)
return dstmeta
Callback function for freeing an NvDsEventMsgMeta instance
def meta_free_func(data, user_data):
srcmeta = pyds.NvDsEventMsgMeta.cast(user_meta.user_meta_data)
# pyds.free_buffer takes C address of a buffer and frees the memory
# It’s a NOP if the address is NULL
pyds.free_buffer(srcmeta.ts)
pyds.free_buffer(srcmeta.sensorStr)
pyds.free_buffer(srcmeta.objSignature.signature)
srcmeta.objSignature.size = 0
pyds.free_buffer(obj.type)
pyds.free_buffer(obj.color)
pyds.free_buffer(obj.make)
pyds.free_buffer(obj.model)
pyds.free_buffer(obj.license)
pyds.free_buffer(obj.region)
pyds.free_buffer(obj.gender)
pyds.free_buffer(obj.cap)
pyds.free_buffer(obj.hair)
pyds.free_buffer(obj.apparel)
pyds.free_gbuffer(srcmeta.extMsg)
srcmeta.extMsgSize = 0
def generate_vehicle_meta(data):
obj = pyds.NvDsVehicleObject.cast(data)
obj.type = “sedan”
obj.color = “blue”
obj.make = “Bugatti”
obj.model = “M”
obj.license = “XX1234”
obj.region = “CA”
return obj
def generate_person_meta(data):
obj = pyds.NvDsPersonObject.cast(data)
obj.age = 45
obj.cap = “none”
obj.hair = “black”
obj.gender = “male”
obj.apparel = “formal”
return obj
def generate_event_msg_meta(data, class_id):
meta = pyds.NvDsEventMsgMeta.cast(data)
meta.sensorId = 0
meta.placeId = 0
meta.moduleId = 0
meta.sensorStr = “sensor-0”
meta.ts = pyds.alloc_buffer(MAX_TIME_STAMP_LEN + 1)
pyds.generate_ts_rfc3339(meta.ts, MAX_TIME_STAMP_LEN)
# This demonstrates how to attach custom objects.
# Any custom object as per requirement can be generated and attached
# like NvDsVehicleObject / NvDsPersonObject. Then that object should
# be handled in payload generator library (nvmsgconv.cpp) accordingly.
if class_id == PGIE_CLASS_ID_VEHICLE:
meta.type = pyds.NvDsEventType.NVDS_EVENT_MOVING
meta.objType = pyds.NvDsObjectType.NVDS_OBJECT_TYPE_VEHICLE
meta.objClassId = PGIE_CLASS_ID_VEHICLE
obj = generate_vehicle_meta(obj)
meta.extMsg = obj
if class_id == PGIE_CLASS_ID_PERSON:
meta.type = pyds.NvDsEventType.NVDS_EVENT_ENTRY
meta.objType = pyds.NvDsObjectType.NVDS_OBJECT_TYPE_PERSON
meta.objClassId = PGIE_CLASS_ID_PERSON
obj = generate_person_meta(obj)
meta.extMsg = obj
meta.extMsgSize = sys.getsizeof(pyds.NvDsPersonObject)
return meta
osd_sink_pad_buffer_probe will extract metadata received on OSD sink pad
and update params for drawing rectangle, object information etc.
IMPORTANT NOTE:
a) probe() callbacks are synchronous and thus holds the buffer
(info.get_buffer()) from traversing the pipeline until user return.
b) loops inside probe() callback could be costly in python.
So users shall optimize according to their use-case.
def osd_sink_pad_buffer_probe(pad, info, u_data):
frame_number = 0
# Intiallizing object counter with 0.
obj_counter = {
PGIE_CLASS_ID_VEHICLE: 0,
PGIE_CLASS_ID_PERSON: 0,
PGIE_CLASS_ID_BICYCLE: 0,
PGIE_CLASS_ID_ROADSIGN: 0
gst_buffer = info.get_buffer()
if not gst_buffer:
print(“Unable to get GstBuffer “)
return
# Retrieve batch metadata from the gst_buffer
# Note that pyds.gst_buffer_get_nvds_batch_meta() expects the
# C address of gst_buffer as input, which is obtained with hash(gst_buffer)
batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
if not batch_meta:
return Gst.PadProbeReturn.OK
l_frame = batch_meta.frame_meta_list
while l_frame is not None:
try:
# Note that l_frame.data needs a cast to pyds.NvDsFrameMeta
# The casting is done by pyds.NvDsFrameMeta.cast()
# The casting also keeps ownership of the underlying memory
# in the C code, so the Python garbage collector will leave
# it alone.
except StopIteration:
continue
is_first_object = True
# Short example of attribute access for frame_meta:
# print(“Frame Number is “, frame_meta.frame_num)
# print(“Source id is “, frame_meta.source_id)
# print(“Batch id is “, frame_meta.batch_id)
# print(“Source Frame Width “, frame_meta.source_frame_width)
# print(“Source Frame Height “, frame_meta.source_frame_height)
# print(“Num object meta “, frame_meta.num_obj_meta)
frame_number = frame_meta.frame_num
l_obj = frame_meta.obj_meta_list
while l_obj is not None:
try:
obj_meta = pyds.NvDsObjectMeta.cast(l_obj.data)
continue
# Update the object text display
txt_params = obj_meta.text_params
# Set display_text. Any existing display_text string will be
# freed by the bindings module.
txt_params.display_text = pgie_classes_str[obj_meta.class_id]
obj_counter[obj_meta.class_id] += 1
# Font , font-color and font-size
txt_params.font_params.font_name = “Serif”
txt_params.font_params.font_size = 10
# set(red, green, blue, alpha); set to White
txt_params.font_params.font_color.set(1.0, 1.0, 1.0, 1.0)
# Text background color
txt_params.set_bg_clr = 1
# set(red, green, blue, alpha); set to Black
txt_params.text_bg_clr.set(0.0, 0.0, 0.0, 1.0)
# Ideally NVDS_EVENT_MSG_META should be attached to buffer by the
# component implementing detection / recognition logic.
# Here it demonstrates how to use / attach that meta data.
if is_first_object and (frame_number % 30) == 0:
# Frequency of messages to be send will be based on use case.
# Here message is being sent for first object every 30 frames.
# Allocating an NvDsEventMsgMeta instance and getting
# reference to it. The underlying memory is not manged by
# Python so that downstream plugins can access it. Otherwise
# the garbage collector will free it when this probe exits.
msg_meta = pyds.alloc_nvds_event_msg_meta()
msg_meta.bbox.top = obj_meta.rect_params.top
msg_meta.bbox.left = obj_meta.rect_params.left
msg_meta.bbox.width = obj_meta.rect_params.width
msg_meta.bbox.height = obj_meta.rect_params.height
msg_meta.frameId = frame_number
msg_meta.trackingId = long_to_uint64(obj_meta.object_id)
msg_meta.confidence = obj_meta.confidence
msg_meta = generate_event_msg_meta(msg_meta, obj_meta.class_id)
user_event_meta = pyds.nvds_acquire_user_meta_from_pool(
batch_meta)
if user_event_meta:
user_event_meta.user_meta_data = msg_meta
user_event_meta.base_meta.meta_type = pyds.NvDsMetaType.NVDS_EVENT_MSG_META
# Setting callbacks in the event msg meta. The bindings
# layer will wrap these callables in C functions.
# Currently only one set of callbacks is supported.
pyds.user_copyfunc(user_event_meta, meta_copy_func)
pyds.user_releasefunc(user_event_meta, meta_free_func)
pyds.nvds_add_user_meta_to_frame(frame_meta,
user_event_meta)
else:
print(“Error in attaching event meta to buffer\n”)
is_first_object = False
try:
l_obj = l_obj.next
break
try:
l_frame = l_frame.next
break
print(“Frame Number =”, frame_number, “Vehicle Count =”,
obj_counter[PGIE_CLASS_ID_VEHICLE], “Person Count =”,
obj_counter[PGIE_CLASS_ID_PERSON])
def main(args):
Gst.init(None)
# registering callbacks
pyds.register_user_copyfunc(meta_copy_func)
pyds.register_user_releasefunc(meta_free_func)
print(“Creating Pipeline \n “)
pipeline = Gst.Pipeline()
if not pipeline:
sys.stderr.write(” Unable to create Pipeline \n”)
print(“Creating Source \n “)
source = Gst.ElementFactory.make(“filesrc”, “file-source”)
if not source:
sys.stderr.write(” Unable to create Source \n”)
print(“Creating H264Parser \n”)
h264parser = Gst.ElementFactory.make(“h264parse”, “h264-parser”)
if not h264parser:
sys.stderr.write(” Unable to create h264 parser \n”)
print(“Creating Decoder \n”)
decoder = Gst.ElementFactory.make(“nvv4l2decoder”, “nvv4l2-decoder”)
if not decoder:
sys.stderr.write(” Unable to create Nvv4l2 Decoder \n”)
streammux = Gst.ElementFactory.make(“nvstreammux”, “Stream-muxer”)
if not streammux:
sys.stderr.write(” Unable to create NvStreamMux \n”)
pgie = Gst.ElementFactory.make(“nvinfer”, “primary-inference”)
if not pgie:
sys.stderr.write(” Unable to create pgie \n”)
nvvidconv = Gst.ElementFactory.make(“nvvideoconvert”, “convertor”)
if not nvvidconv:
sys.stderr.write(” Unable to create nvvidconv \n”)
nvosd = Gst.ElementFactory.make(“nvdsosd”, “onscreendisplay”)
if not nvosd:
sys.stderr.write(” Unable to create nvosd \n”)
msgconv = Gst.ElementFactory.make(“nvmsgconv”, “nvmsg-converter”)
if not msgconv:
sys.stderr.write(” Unable to create msgconv \n”)
msgbroker = Gst.ElementFactory.make(“nvmsgbroker”, “nvmsg-broker”)
if not msgbroker:
sys.stderr.write(" Unable to create msgbroker \n")
tee = Gst.ElementFactory.make(“tee”, “nvsink-tee”)
if not tee:
sys.stderr.write(" Unable to create tee \n")
queue1 = Gst.ElementFactory.make(“queue”, “nvtee-que1”)
if not queue1:
sys.stderr.write(" Unable to create queue1 \n")
queue2 = Gst.ElementFactory.make(“queue”, “nvtee-que2”)
if not queue2:
sys.stderr.write(" Unable to create queue2 \n")
if no_display:
print(“Creating FakeSink \n”)
sink = Gst.ElementFactory.make(“fakesink”, “fakesink”)
if not sink:
sys.stderr.write(" Unable to create fakesink \n")
else:
if is_aarch64():
print(“Creating nv3dsink \n”)
sink = Gst.ElementFactory.make(“nv3dsink”, “nv3d-sink”)
if not sink:
sys.stderr.write(" Unable to create nv3dsink \n")
else:
print(“Creating EGLSink \n”)
sink = Gst.ElementFactory.make(“nveglglessink”, “nvvideo-renderer”)
if not sink:
sys.stderr.write(" Unable to create egl sink \n")
print(“Playing file %s " % input_file)
source.set_property(‘location’, input_file)
streammux.set_property(‘width’, 1920)
streammux.set_property(‘height’, 1080)
streammux.set_property(‘batch-size’, 1)
streammux.set_property(‘batched-push-timeout’, 4000000)
pgie.set_property(‘config-file-path’, PGIE_CONFIG_FILE)
msgconv.set_property(‘config’, MSCONV_CONFIG_FILE)
msgconv.set_property(‘payload-type’, schema_type)
msgbroker.set_property(‘proto-lib’, proto_lib)
msgbroker.set_property(‘conn-str’, conn_str)
if cfg_file is not None:
msgbroker.set_property(‘config’, cfg_file)
if topic is not None:
msgbroker.set_property(‘topic’, topic)
msgbroker.set_property(‘sync’, False)
print(“Adding elements to Pipeline \n”)
pipeline.add(source)
pipeline.add(h264parser)
pipeline.add(decoder)
pipeline.add(streammux)
pipeline.add(pgie)
pipeline.add(nvvidconv)
pipeline.add(nvosd)
pipeline.add(tee)
pipeline.add(queue1)
pipeline.add(queue2)
pipeline.add(msgconv)
pipeline.add(msgbroker)
pipeline.add(sink)
print(“Linking elements in the Pipeline \n”)
source.link(h264parser)
h264parser.link(decoder)
sinkpad = streammux.get_request_pad(“sink_0”)
if not sinkpad:
sys.stderr.write(” Unable to get the sink pad of streammux \n")
srcpad = decoder.get_static_pad(“src”)
if not srcpad:
sys.stderr.write(" Unable to get source pad of decoder \n")
srcpad.link(sinkpad)
streammux.link(pgie)
pgie.link(nvvidconv)
nvvidconv.link(nvosd)
nvosd.link(tee)
queue1.link(msgconv)
msgconv.link(msgbroker)
queue2.link(sink)
sink_pad = queue1.get_static_pad(“sink”)
tee_msg_pad = tee.get_request_pad(‘src_%u’)
tee_render_pad = tee.get_request_pad(“src_%u”)
if not tee_msg_pad or not tee_render_pad:
sys.stderr.write(“Unable to get request pads\n”)
tee_msg_pad.link(sink_pad)
sink_pad = queue2.get_static_pad(“sink”)
tee_render_pad.link(sink_pad)
# create an event loop and feed gstreamer bus messages to it
loop = GLib.MainLoop()
bus = pipeline.get_bus()
bus.add_signal_watch()
bus.connect(“message”, bus_call, loop)
osdsinkpad = nvosd.get_static_pad(“sink”)
if not osdsinkpad:
sys.stderr.write(" Unable to get sink pad of nvosd \n")
osdsinkpad.add_probe(Gst.PadProbeType.BUFFER, osd_sink_pad_buffer_probe, 0)
print(“Starting pipeline \n”)
# start play back and listed to events
pipeline.set_state(Gst.State.PLAYING)
try:
loop.run()
except:
pass
# cleanup
pyds.unset_callback_funcs()
pipeline.set_state(Gst.State.NULL)
Parse and validate input arguments
def parse_args():
parser = OptionParser()
parser.add_option(“-c”, “–cfg-file”, dest=“cfg_file”,
help=“Set the adaptor config file. Optional if "
“connection string has relevant details.”,
metavar=“FILE”)
parser.add_option(”-i", “–input-file”, dest=“input_file”,
help=“Set the input H264 file”, metavar=“FILE”)
parser.add_option(“-p”, “–proto-lib”, dest=“proto_lib”,
help=“Absolute path of adaptor library”, metavar=“PATH”)
parser.add_option(“”, “–conn-str”, dest=“conn_str”,
help=“Connection string of backend server. Optional if "
“it is part of config file.”, metavar=“STR”)
parser.add_option(”-s", “–schema-type”, dest=“schema_type”, default=“0”,
help=“Type of message schema (0=Full, 1=minimal), "
“default=0”, metavar=”<0|1>“)
parser.add_option(”-t", “–topic”, dest=“topic”,
help=“Name of message topic. Optional if it is part of "
“connection string or config file.”, metavar=“TOPIC”)
parser.add_option(”", “–no-display”, action=“store_true”,
dest=“no_display”, default=False,
help=“Disable display”)
(options, args) = parser.parse_args()
global cfg_file
global input_file
global proto_lib
global conn_str
global topic
global schema_type
global no_display
cfg_file = options.cfg_file
input_file = options.input_file
proto_lib = options.proto_lib
conn_str = options.conn_str
topic = options.topic
no_display = options.no_display
if not (proto_lib and input_file):
print("Usage: python3 deepstream_test_4.py -i -p "
“ --conn-str=”)
return 1
schema_type = 0 if options.schema_type == “0” else 1
if name == ‘main’:
ret = parse_args()
# If argument parsing fails, returns failure (non-zero)
if ret == 1:
sys.exit(1)
sys.exit(main(sys.argv))
Have you made any changes to the code? If there are any, you can just attach your diffs.
Could you use the gdb tool for preliminary analyze of the crash?
