Nvidia Deepstream6.3 custom segmentation model inference error: Aborted (core dumped)
**• Hardware Platform Ubuntu 20.04 with Nvidia GeForce GTX 1080 Ti
**• DeepStream 6.3-triton-multiarch Docker image
**• TensorRT 8.5.3
**• NVIDIA GPU Driver version 555.42.02
**• Issue Type: Aborted (core dumped)
**• Detailed Error:
python3 deepstream_detection.py -i test.mp4
Frames will be saved in  out
Creating Pipeline
Creating streammux
Creating source_bin  0
Creating source bin
source-bin-00
Creating Pgie
Creating tiler
Creating nvvidconv
Creating nvosd
Creating EGLSink
Adding elements to Pipeline
Linking elements in the Pipeline
Now playing...
0 :  test.mp4
Starting pipeline
0:00:01.873294687 12158      0x3a84b60 INFO                 nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1988> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.3/sources/deepstream_python_apps/apps/deepstream-tickerdetection/model.engine
WARNING: [TRT]: The getMaxBatchSize() function should not be used with an engine built from a network created with NetworkDefinitionCreationFlag::kEXPLICIT_BATCH flag. This function will always return 1.
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 2
0   INPUT  kFLOAT input           360x640
1   OUTPUT kFLOAT output          180x320
python3: nvdsinfer_backend.cpp:135: virtual bool nvdsinfer::TrtBackendContext::canSupportBatchDims(int, const NvDsInferBatchDims&): Assertion `m_AllLayers[bindingIdx].inferDims.numDims == batchDims.dims.numDims' failed.
I wanted to use Nvidia Deepstream 6.3 to run my custom semantic segmentation model using deepstream python apps. The model takes input as [1,360,640] and outputs [1, 180, 320] as the binary mask. I initially has the pytorch .model file, which i converted into the onnx model, and finally converted into .engine file format. The error above occured. I don’t know how can i solve this. Any help will be much appreciated!
The following is my Config File:
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
tlt-model-key=none
infer-dims=1;360;640
model-engine-file=/opt/nvidia/deepstream/deepstream-6.3/sources/deepstream_python_apps/apps/deepstream-tickerdetection/model.engine
#labelfile-path=</path/to/your/label_file.txt>
uff-input-blob-name=input_1
batch-size=1
## 0=FP32, 1=INT8, 2=FP16 mode
network-mode=2
interval=0
gie-unique-id=1
#is-classifier=0
network-type=3
output-blob-names=output_mask
#parse-bbox-func-name=NvDsInferParseCustomSegMask
#custom-lib-path=</path/to/your/customparser.so>
The following is my deepstream.py file:
import sys
from syslog import LOG_WARNING
sys.path.append('../')
import gi
import configparser
gi.require_version('Gst', '1.0')
from gi.repository import GLib, Gst
from ctypes import *
import time
import sys
import math
import platform
from common.is_aarch_64 import is_aarch64
from common.bus_call import bus_call
from common.FPS import PERF_DATA
import numpy as np
import pyds
import cv2
import os
import os.path
from os import path
import argparse
perf_data = None
MAX_DISPLAY_LEN = 64
MUXER_OUTPUT_WIDTH = 1920
MUXER_OUTPUT_HEIGHT = 1080
MUXER_BATCH_TIMEOUT_USEC = 4000000
TILED_OUTPUT_WIDTH = 1920
TILED_OUTPUT_HEIGHT = 1080
GST_CAPS_FEATURES_NVMM = "memory:NVMM"
# tiler_sink_pad_buffer_probe  will extract metadata received on tiler sink pad
# and re-size and binarize segmentation mask array to save to image
def tiler_sink_pad_buffer_probe(pad, info, u_data):
    frame_number = 0
    num_rects = 0
    gst_buffer = info.get_buffer()
    if not gst_buffer:
        print("Unable to get GstBuffer ")
        return
    # Retrieve batch metadata from the gst_buffer
    # Note that pyds.gst_buffer_get_nvds_batch_meta() expects the
    # C address of gst_buffer as input, which is obtained with hash(gst_buffer)
    batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
    l_frame = batch_meta.frame_meta_list
    while l_frame is not None:
        try:
            # Note that l_frame.data needs a cast to pyds.NvDsFrameMeta
            # The casting is done by pyds.NvDsFrameMeta.cast()
            # The casting also keeps ownership of the underlying memory
            # in the C code, so the Python garbage collector will leave
            # it alone.
        except StopIteration:
            break
        frame_number = frame_meta.frame_num
        l_obj = frame_meta.obj_meta_list
        num_rects = frame_meta.num_obj_meta
        is_first_obj = True
        save_image = False
        obj_number = 0
        while l_obj is not None:
            try:
                # Casting l_obj.data to pyds.NvDsObjectMeta
                obj_meta = pyds.NvDsObjectMeta.cast(l_obj.data)
                break
            if is_first_obj and frame_number % 30 == 0:
                is_first_obj = False
                rectparams = obj_meta.rect_params # Retrieve rectparams for re-sizing mask to correct dims
                maskparams = obj_meta.mask_params # Retrieve maskparams
                mask_image = resize_mask(maskparams, math.floor(rectparams.width), math.floor(rectparams.height)) # Get resized mask array
                img_path = "{}/stream_{}/frame_{}.jpg".format(folder_name, frame_meta.pad_index, frame_number)
                cv2.imwrite(img_path, mask_image) # Save mask to image
            try:
                l_obj = l_obj.next
                obj_number += 1
                break
        print("Frame Number=", frame_number, "Number of Objects=", num_rects)
        # update frame rate through this probe
        stream_index = "stream{0}".format(frame_meta.pad_index)
        global perf_data
        perf_data.update_fps(stream_index)
        try:
            l_frame = l_frame.next
            break
    return Gst.PadProbeReturn.OK
def clip(val, low, high):
    if val < low:
        return low
    elif val > high:
        return high
    else:
        return val
# Resize and binarize mask array for interpretable segmentation mask
def resize_mask(maskparams, target_width, target_height):
    src = maskparams.get_mask_array() # Retrieve mask array
    dst = np.empty((target_height, target_width), src.dtype) # Initialize array to store re-sized mask
    original_width = maskparams.width
    original_height = maskparams.height
    ratio_h = float(original_height) / float(target_height)
    ratio_w = float(original_width) / float(target_width)
    threshold = maskparams.threshold
    channel = 1
    # Resize from original width/height to target width/height
    for y in range(target_height):
        for x in range(target_width):
            x0 = float(x) * ratio_w
            y0 = float(y) * ratio_h
            left = int(clip(math.floor(x0), 0.0, float(original_width - 1.0)))
            top = int(clip(math.floor(y0), 0.0, float(original_height - 1.0)))
            right = int(clip(math.ceil(x0), 0.0, float(original_width - 1.0)))
            bottom = int(clip(math.ceil(y0), 0.0, float(original_height - 1.0)))
            for c in range(channel):
                # H, W, C ordering
                # Note: lerp is shorthand for linear interpolation
                left_top_val = float(src[top * (original_width * channel) + left * (channel) + c])
                right_top_val = float(src[top * (original_width * channel) + right * (channel) + c])
                left_bottom_val = float(src[bottom * (original_width * channel) + left * (channel) + c])
                right_bottom_val = float(src[bottom * (original_width * channel) + right * (channel) + c])
                top_lerp = left_top_val + (right_top_val - left_top_val) * (x0 - left)
                bottom_lerp = left_bottom_val + (right_bottom_val - left_bottom_val) * (x0 - left)
                lerp = top_lerp + (bottom_lerp - top_lerp) * (y0 - top)
                if (lerp < threshold): # Binarize according to threshold
                    dst[y,x] = 0
                else:
                    dst[y,x] = 255
    return dst
def cb_newpad(decodebin, decoder_src_pad, data):
    print("In cb_newpad\n")
    caps = decoder_src_pad.get_current_caps()
    gststruct = caps.get_structure(0)
    gstname = gststruct.get_name()
    source_bin = data
    features = caps.get_features(0)
    # Need to check if the pad created by the decodebin is for video and not
    # audio.
    if (gstname.find("video") != -1):
        # Link the decodebin pad only if decodebin has picked nvidia
        # decoder plugin nvdec_*. We do this by checking if the pad caps contain
        # NVMM memory features.
        if features.contains("memory:NVMM"):
            # Get the source bin ghost pad
            bin_ghost_pad = source_bin.get_static_pad("src")
            if not bin_ghost_pad.set_target(decoder_src_pad):
                sys.stderr.write("Failed to link decoder src pad to source bin ghost pad\n")
        else:
            sys.stderr.write(" Error: Decodebin did not pick nvidia decoder plugin.\n")
def decodebin_child_added(child_proxy, Object, name, user_data):
    print("Decodebin child added:", name, "\n")
    if name.find("decodebin") != -1:
        Object.connect("child-added", decodebin_child_added, user_data)
    if "source" in name:
        source_element = child_proxy.get_by_name("source")
        if source_element.find_property('drop-on-latency') != None:
            Object.set_property("drop-on-latency", True)
def create_source_bin(index, uri):
    print("Creating source bin")
    # Create a source GstBin to abstract this bin's content from the rest of the
    # pipeline
    bin_name = "source-bin-%02d" % index
    print(bin_name)
    nbin = Gst.Bin.new(bin_name)
    if not nbin:
        sys.stderr.write(" Unable to create source bin \n")
    # Source element for reading from the uri.
    # We will use decodebin and let it figure out the container format of the
    # stream and the codec and plug the appropriate demux and decode plugins.
    uri_decode_bin = Gst.ElementFactory.make("uridecodebin", "uri-decode-bin")
    if not uri_decode_bin:
        sys.stderr.write(" Unable to create uri decode bin \n")
    # We set the input uri to the source element
    uri_decode_bin.set_property("uri", uri)
    # Connect to the "pad-added" signal of the decodebin which generates a
    # callback once a new pad for raw data has beed created by the decodebin
    uri_decode_bin.connect("pad-added", cb_newpad, nbin)
    uri_decode_bin.connect("child-added", decodebin_child_added, nbin)
    # We need to create a ghost pad for the source bin which will act as a proxy
    # for the video decoder src pad. The ghost pad will not have a target right
    # now. Once the decode bin creates the video decoder and generates the
    # cb_newpad callback, we will set the ghost pad target to the video decoder
    # src pad.
    Gst.Bin.add(nbin, uri_decode_bin)
    bin_pad = nbin.add_pad(Gst.GhostPad.new_no_target("src", Gst.PadDirection.SRC))
    if not bin_pad:
        sys.stderr.write(" Failed to add ghost pad in source bin \n")
        return None
    return nbin
def main(stream_paths, output_folder):
    global perf_data
    perf_data = PERF_DATA(len(stream_paths))
    number_sources = len(stream_paths)
    global folder_name
    folder_name = output_folder
    if path.exists(folder_name):
        sys.stderr.write("The output folder %s already exists. Please remove it first.\n" % folder_name)
        sys.exit(1)
    os.mkdir(folder_name)
    print("Frames will be saved in ", folder_name)
    # Standard GStreamer initialization
    Gst.init(None)
    # Create gstreamer elements */
    # Create Pipeline element that will form a connection of other elements
    print("Creating Pipeline \n ")
    pipeline = Gst.Pipeline()
    is_live = False
    if not pipeline:
        sys.stderr.write(" Unable to create Pipeline \n")
    print("Creating streammux \n ")
    # Create nvstreammux instance to form batches from one or more sources.
    streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
    if not streammux:
        sys.stderr.write(" Unable to create NvStreamMux \n")
    pipeline.add(streammux)
    for i in range(number_sources):
        os.mkdir(folder_name + "/stream_" + str(i))
        print("Creating source_bin ", i, " \n ")
        uri_name = stream_paths[i]
        if uri_name.find("rtsp://") == 0:
            is_live = True
        source_bin = create_source_bin(i, uri_name)
        if not source_bin:
            sys.stderr.write("Unable to create source bin \n")
        pipeline.add(source_bin)
        padname = "sink_%u" % i
        sinkpad = streammux.get_request_pad(padname)
        if not sinkpad:
            sys.stderr.write("Unable to create sink pad bin \n")
        srcpad = source_bin.get_static_pad("src")
        if not srcpad:
            sys.stderr.write("Unable to create src pad bin \n")
        srcpad.link(sinkpad)
    print("Creating Pgie \n ")
    pgie = Gst.ElementFactory.make("nvinfer", "primary-inference")
    if not pgie:
        sys.stderr.write(" Unable to create pgie \n")
    print("Creating tiler \n ")
    tiler = Gst.ElementFactory.make("nvmultistreamtiler", "nvtiler")
    if not tiler:
        sys.stderr.write(" Unable to create tiler \n")
    print("Creating nvvidconv \n ")
    nvvidconv = Gst.ElementFactory.make("nvvideoconvert", "convertor")
    if not nvvidconv:
        sys.stderr.write(" Unable to create nvvidconv \n")
    print("Creating nvosd \n ")
    nvosd = Gst.ElementFactory.make("nvdsosd", "onscreendisplay")
    if not nvosd:
        sys.stderr.write(" Unable to create nvosd \n")
    if is_aarch64():
        print("Creating nv3dsink \n")
        sink = Gst.ElementFactory.make("nv3dsink", "nv3d-sink")
        if not sink:
            sys.stderr.write(" Unable to create nv3dsink \n")
    else:
        print("Creating EGLSink \n")
        sink = Gst.ElementFactory.make("nveglglessink", "nvvideo-renderer")
        if not sink:
            sys.stderr.write(" Unable to create egl sink \n")
    if is_live:
        print("Atleast one of the sources is live")
        streammux.set_property('live-source', 1)
    streammux.set_property('width', 1920)
    streammux.set_property('height', 1080)
    streammux.set_property('batch-size', number_sources)
    streammux.set_property('batched-push-timeout', 4000000)
    pgie.set_property('config-file-path', "deepstream_tickerdetection_config.txt")
    pgie_batch_size = pgie.get_property("batch-size")
    if (pgie_batch_size != number_sources):
        print("WARNING: Overriding infer-config batch-size", pgie_batch_size, " with number of sources ",
              number_sources, " \n")
        pgie.set_property("batch-size", number_sources)
    tiler_rows = int(math.sqrt(number_sources))
    tiler_columns = int(math.ceil((1.0 * number_sources) / tiler_rows))
    tiler.set_property("rows", tiler_rows)
    tiler.set_property("columns", tiler_columns)
    tiler.set_property("width", TILED_OUTPUT_WIDTH)
    tiler.set_property("height", TILED_OUTPUT_HEIGHT)
    nvosd.set_property("display_mask", True) # Note: display-mask is supported only for process-mode=0 (CPU)
    nvosd.set_property('process_mode', 0)
    sink.set_property("sync", 0)
    sink.set_property("qos", 0)
    queue1=Gst.ElementFactory.make("queue","queue1")
    queue2=Gst.ElementFactory.make("queue","queue2")
    queue3=Gst.ElementFactory.make("queue","queue3")
    queue4=Gst.ElementFactory.make("queue","queue4")
    queue5=Gst.ElementFactory.make("queue","queue5")
    pipeline.add(queue1)
    pipeline.add(queue2)
    pipeline.add(queue3)
    pipeline.add(queue4)
    pipeline.add(queue5)
    print("Adding elements to Pipeline \n")
    pipeline.add(pgie)
    pipeline.add(tiler)
    pipeline.add(nvvidconv)
    pipeline.add(nvosd)
    pipeline.add(sink)
    print("Linking elements in the Pipeline \n")
    streammux.link(queue1)
    queue1.link(pgie)
    pgie.link(queue2)
    queue2.link(tiler)
    tiler.link(queue3)
    queue3.link(nvvidconv)
    nvvidconv.link(queue4)
    queue4.link(nvosd)
    nvosd.link(queue5)
    queue5.link(sink)
    # create an event loop and feed gstreamer bus mesages to it
    loop = GLib.MainLoop()
    bus = pipeline.get_bus()
    bus.add_signal_watch()
    bus.connect("message", bus_call, loop)
    tiler_sink_pad = tiler.get_static_pad("sink")
    if not tiler_sink_pad:
        sys.stderr.write(" Unable to get src pad \n")
    else:
        tiler_sink_pad.add_probe(Gst.PadProbeType.BUFFER, tiler_sink_pad_buffer_probe, 0)
        # perf callback function to print fps every 5 sec
        GLib.timeout_add(5000, perf_data.perf_print_callback)
    # List the sources
    print("Now playing...")
    for i, source in enumerate(stream_paths):
        print(i, ": ", source)
    print("Starting pipeline \n")
    # start play back and listed to events
    pipeline.set_state(Gst.State.PLAYING)
    try:
        loop.run()
    except:
        pass
    # cleanup
    print("Exiting app\n")
    pipeline.set_state(Gst.State.NULL)
def parse_args():
    parser = argparse.ArgumentParser(prog="deepstream_segmask.py",
                description="deepstream-segmask takes multiple URI streams as input" \
                    " and re-sizes and binarizes segmentation mask arrays to save to image")
    parser.add_argument(
        "-i",
        "--input",
        help="Path to input streams",
        nargs="+",
        metavar="URIs",
        default=["a"],
        required=True,
        "-o",
        "--output",
        metavar="output_folder_name",
        default="out",
        help="Name of folder to output mask images",
    args = parser.parse_args()
    stream_paths = args.input
    output_folder = args.output
    return stream_paths, output_folder
if __name__ == '__main__':
    stream_paths, output_folder = parse_args()
    sys.exit(main(stream_paths, output_folder))
This error means that there may be some problems with your engine file, which is caused by numDims not matching the configuration file.
You can refer to this file /opt/nvidia/deepstream/deepstream/sources/libs/nvdsinfer/nvdsinfer_backend.cpp
Then adjust your onnx model or the gie configuration file
bool
TrtBackendContext::canSupportBatchDims(int bindingIdx,
        const NvDsInferBatchDims& batchDims)
    assert((int)m_AllLayers.size() > bindingIdx);
    assert((int)m_AllLayers[bindingIdx].isInput == 1);
    /* Number of dimensions should match. */
    assert(m_AllLayers[bindingIdx].inferDims.numDims == batchDims.dims.numDims);
I think, my model takes in gray scale image/video feed. which requires the input to be [1,360,640] where 1 is the channel value representing the gray scale. The deepstream is confusing it with the batch dimension. Is there a way in the deepstream6.3 where my input can be by default transformed into gray scale before being input to the model?
According to this:
Starting pipeline
0:00:01.873409559 12722      0x3688360 INFO                 nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1988> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.3/sources/deepstream_python_apps/apps/deepstream-tickerdetection/model.engine
The input is 360x640, so this I believe this implies gray scale where it omits 1 for the gray scale(not sure of this). But when I set this as infer-dims = 360x640. I have also added the following to the config.txt file for the input to be transformed into gray scale.
#change the input to gray scale
model-color-format=2
My updated Config.txt was :
[property]
gpu-id=0
tlt-model-key=none
infer-dims=360;640
batch-size=1
network-mode=0
interval=0
gie-unique-id=1
network-type=3
The following errors pops when executed with the updated config.txt.
python3 deepstream_tickerdetection.py -i test.mp4
Creating Pipeline
Creating streammux
Creating source bin
source-bin-00
Creating Pgie
Creating tiler
Creating nvvidconv
Creating nvosd
Creating EGLSink
Error. 'infer-dims' array length is 2. Should be 3 as [c;h;w] order.
Failed to parse group property
** ERROR: <gst_nvinfer_parse_config_file:1319>: failed
Now playing...
0 :  test.mp4
Starting pipeline
0:00:00.143454431 12746      0x2cb0b60 WARN                 nvinfer gstnvinfer.cpp:844:gst_nvinfer_start:<primary-inference> error: Configuration file parsing failed
0:00:00.143492397 12746      0x2cb0b60 WARN                 nvinfer gstnvinfer.cpp:844:gst_nvinfer_start:<primary-inference> error: Config file path: deepstream_tickerdetection_config.txt
0:00:00.143513748 12746      0x2cb0b60 WARN                GST_PADS gstpad.c:1142:gst_pad_set_active:<primary-inference:sink> Failed to activate pad
Error: gst-library-error-quark: Configuration file parsing failed (5): gstnvinfer.cpp(844): gst_nvinfer_start (): /GstPipeline:pipeline0/GstNvInfer:primary-inference:
Exiting app
This is no problem
There is a problem with the dims configuration
I understand that this is the problem, but how and where should i look or change things to solve this issue?
Do you think changes like the image pre-processing would be required in the following code to solve the dimension problem?
import sys
import gi
import configparser
import time
import sys
import math
import platform
import numpy as np
import pyds
import cv2
import os
import os.path
from os import path
import argparse
perf_data = None
    frame_number = 0
    num_rects = 0
    if not gst_buffer:
        return
        try:
            # it alone.
            break
        is_first_obj = True
        save_image = False
        obj_number = 0
            try:
                break
            try:
                l_obj = l_obj.next
                obj_number += 1
                break
        global perf_data
        try:
            break
    if val < low:
        return low
    elif val > high:
        return high
    else:
        return val
    channel = 1
                # H, W, C ordering
                    dst[y,x] = 0
                else:
                    dst[y,x] = 255
    return dst
    source_bin = data
    # audio.
        else:
    # pipeline
    print(bin_name)
    if not nbin:
    # src pad.
    if not bin_pad:
        return None
    return nbin
    global perf_data
    global folder_name
        sys.exit(1)
    Gst.init(None)
    is_live = False
    if not pipeline:
    if not streammux:
            is_live = True
        if not source_bin:
        if not sinkpad:
        if not srcpad:
    if not pgie:
    if not tiler:
    if not nvvidconv:
    if not nvosd:
    if is_aarch64():
        if not sink:
    else:
        if not sink:
    if is_live:
    pipeline.add(pgie)
    pipeline.add(tiler)
    pipeline.add(nvosd)
    pipeline.add(sink)
    queue1.link(pgie)
    pgie.link(queue2)
    queue2.link(tiler)
    tiler.link(queue3)
    queue4.link(nvosd)
    nvosd.link(queue5)
    queue5.link(sink)
    else:
    # List the sources
    try:
        loop.run()
    except:
        pass
    # cleanup
def parse_args():
        "-i",
        "--input",
        nargs="+",
        metavar="URIs",
        default=["a"],
        required=True,
        "-o",
        "--output",
        default="out",
nvinfer is open source, you can find the source code at
/opt/nvidia/deepstream/deepstream-7.0/sources/gst-plugins/gst-nvinfer and
/opt/nvidia/deepstream/deepstream-7.0/sources/libs/nvdsinfer
In addition, the relevant documents are here
According to your description, I think this should be 1;360;640
You can also refer to this example
/opt/nvidia/deepstream/deepstream-7.0/sources/apps/sample_apps/deepstream-segmentation-test
nvsegvisual can be used for segmentation visualization,Use gst-inspect-1.0 nvsegvisual to get more information
