Extract raw image from appsink always empty
**• Hardware Platform Jetson **
• DeepStream Version 6.4
• JetPack Version 6.0 DP
• TensorRT Version 8.6.2.3
• Issue Type questions
I want input image to appsrc and save inference result with raw image.
My pipeline look like this
app-source → nvvidconv → caps filter → pgie → nvvidconv → caps filter → appsink
I try to get image buffer at appsink new-sample is come. I can get inference result, but the image always empty.
Is there anything I’ve set up wrong?
here my code
 * Copyright (c) 2022-2023, NVIDIA CORPORATION. All rights reserved.
 * Permission is hereby granted, free of charge, to any person obtaining a
 * copy of this software and associated documentation files (the "Software"),
 * to deal in the Software without restriction, including without limitation
 * the rights to use, copy, modify, merge, publish, distribute, sublicense,
 * and/or sell copies of the Software, and to permit persons to whom the
 * Software is furnished to do so, subject to the following conditions:
 * The above copyright notice and this permission notice shall be included in
 * all copies or substantial portions of the Software.
 * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
 * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
 * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.  IN NO EVENT SHALL
 * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
 * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
 * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
 * DEALINGS IN THE SOFTWARE.
#include <gst/gst.h>
#include <gst/app/gstappsrc.h>
#include <gst/app/gstappsink.h>
#include <glib.h>
#include <stdio.h>
#include <string.h>
#include <cuda_runtime_api.h>
#include "gstnvdsmeta.h"
#include "nvbufsurface.h"
#include "webcam.h"
#include <opencv2/opencv.hpp>
#include <Poco/LocalDateTime.h>
#define MAX_DISPLAY_LEN 64
#define PGIE_CLASS_ID_VEHICLE 0
#define PGIE_CLASS_ID_PERSON 2
#define CUSTOM_PTS 1
#define NVINFER_PLUGIN "nvinfer"
#define NVINFERSERVER_PLUGIN "nvinferserver"
#define PGIE_CONFIG_FILE  "config_infer_primary_yoloV8.txt"
/* Muxer batch formation timeout, for e.g. 40 millisec. Should ideally be set
 * based on the fastest source's framerate. */
#define MUXER_BATCH_TIMEOUT_USEC 33000
gint frame_number = 0;
/* Structure to contain all our information for appsrc,
 * so we can pass it to callbacks */
typedef struct _AppSrcData
  GstElement *app_source;
  long frame_size;
  FILE *file;                   /* Pointer to the raw video file */
  guint fps;                    /* To set the FPS value */
  guint sourceid;               /* To control the GSource */
  GstClockTime timestamp;
} AppSrcData;
/* new_sample is an appsink callback that will extract metadata received
 * tee sink pad and update params for drawing rectangle,
 *object information etc. */
static GstFlowReturn
//new_sample (GstElement *sink, gpointer * data)
new_sample (GstAppSink *sink, gpointer * data)
  GstSample *sample;
  GstBuffer *buf = NULL;
  guint num_rects = 0;
  NvDsObjectMeta *obj_meta = NULL;
  guint vehicle_count = 0;
  guint person_count = 0;
  NvDsMetaList *l_frame = NULL;
  NvDsMetaList *l_obj = NULL;
  unsigned long int pts = 0;
  int sample_width = 0;
  int sample_height = 0;
  GstMapInfo map;
  const GstStructure *info = NULL;
  GstCaps *caps = NULL;
  NvBufSurface *surface = NULL;
  sample = gst_app_sink_pull_sample (GST_APP_SINK (sink));
  if (gst_app_sink_is_eos (GST_APP_SINK (sink))) {
    g_print ("EOS received in Appsink********\n");
  do
    if(sample == NULL)
      break;
    /* Obtain GstBuffer from sample and then extract metadata from it. */
    buf = gst_sample_get_buffer (sample);
    char *src_data = NULL;
    if (!gst_buffer_map(buf, &map, GST_MAP_READ))
      g_print("Error: Failed to map gst buffer\n");
      break;
    caps = gst_sample_get_caps(sample);
    if (caps == NULL)
      g_print("get caps is null");
      break;
    info = gst_caps_get_structure(caps, 0);
    if (info == NULL)
      g_print("get info is null");
      break;
    // -------- Read frame and convert to opencv format --------
    // convert gstreamer data to OpenCV Mat, you could actually
    // resolve height / width from caps...
    gst_structure_get_int(info, "width", &sample_width);
    gst_structure_get_int(info, "height", &sample_height);
    g_print("image width %d height %d\n", sample_width, sample_height);
    if (map.data == NULL)
      g_print("appsink buffer data empty\n");
      return GST_FLOW_OK;
    for (auto i = 0; i < 32; i++)
      for (auto j = 0; j < 32; j++)
        g_print("%x ", map.data[i * sample_width + j]);
      g_print("\n");
    surface = (NvBufSurface *)map.data;
    g_print("NvBufSurface mem tpye %d\n", surface->memType);
    g_print("NvBufSurface surfaceList %x\n", surface->surfaceList); // always NULL
    gst_buffer_unmap (buf, &map);
    NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta (buf);
    for (l_frame = batch_meta->frame_meta_list; l_frame != NULL;
        l_frame = l_frame->next) {
      NvDsFrameMeta *frame_meta = (NvDsFrameMeta *) (l_frame->data);
      guint  batch_id = frame_meta->batch_id;
      pts = frame_meta->buf_pts;
      for (l_obj = frame_meta->obj_meta_list; l_obj != NULL;
          l_obj = l_obj->next) {
        obj_meta = (NvDsObjectMeta *) (l_obj->data);
        int left = obj_meta->rect_params.left;
        int top = obj_meta->rect_params.top;
        int width = obj_meta->rect_params.width;
        int height = obj_meta->rect_params.height;
        auto conf = obj_meta->confidence;
        auto uuid = obj_meta->object_id;
        auto lable = obj_meta->class_id;
        g_print("label %d - conf : %f width %d height %d\n", lable, conf, width, height);
    g_print ("Frame Number = %d Number of objects = %d "
        "Vehicle Count = %d Person Count = %d PTS = %" GST_TIME_FORMAT "\n",
        frame_number, num_rects, vehicle_count, person_count,
        GST_TIME_ARGS (pts));
    frame_number++;
    gst_sample_unref (sample);
    return GST_FLOW_OK;
  } while (false) ;
  return GST_FLOW_ERROR;
static gboolean
bus_call (GstBus * bus, GstMessage * msg, gpointer data)
  GMainLoop *loop = (GMainLoop *) data;
  switch (GST_MESSAGE_TYPE (msg)) {
    case GST_MESSAGE_EOS:
      g_print ("End of stream\n");
      g_main_loop_quit (loop);
      break;
    case GST_MESSAGE_ERROR:{
      gchar *debug;
      GError *error;
      gst_message_parse_error (msg, &error, &debug);
      g_printerr ("ERROR from element %s: %s\n",
          GST_OBJECT_NAME (msg->src), error->message);
      if (debug)
        g_printerr ("Error details: %s\n", debug);
      g_free (debug);
      g_error_free (error);
      break;
    default:
      break;
  return TRUE;
int
main (int argc, char *argv[])
  GMainLoop *loop = NULL;
  GstElement *pipeline = NULL, *nvvidconv1 = NULL, *caps_filter = NULL, *caps_filter2 = NULL,
      *streammux = NULL, *sink = NULL, *pgie = NULL, *nvvidconv2 = NULL,*appsink = NULL;
  GstBus *bus = NULL;
  guint bus_watch_id;
  AppSrcData data;
  GstCapsFeatures *feature = NULL;
  GstPad *tee_source_pad1, *tee_source_pad2;
  GstPad *osd_sink_pad, *appsink_sink_pad;
  gboolean is_nvinfer_server = FALSE;
  const gchar* new_mux_str = g_getenv("USE_NEW_NVSTREAMMUX");
  gboolean use_new_mux = !g_strcmp0(new_mux_str, "yes");
  //cv::namedWindow("debug", cv::WINDOW_NORMAL);
  Webcam test_webcam(0);
  int current_device = -1;
  cudaGetDevice(&current_device);
  struct cudaDeviceProp prop;
  cudaGetDeviceProperties(&prop, current_device);
  gchar *format = NULL, *input_stream = NULL;
  long fps = 10, width = 640, height = 480;
  format = "BGR"; // I420, NV12
  /* Initialize custom data structure */
  memset (&data, 0, sizeof (data));
  //RGBA
  data.frame_size = width * height * 3;
  data.fps = fps;
  /* Standard GStreamer initialization */
  gst_init (&argc, &argv);
  loop = g_main_loop_new (NULL, FALSE);
  /* Create gstreamer elements */
  /* Create Pipeline element that will form a connection of other elements */
  pipeline = gst_pipeline_new ("dstest-appsrc-pipeline");
  if (!pipeline) {
    g_printerr ("Pipeline could not be created. Exiting.\n");
    return -1;
  /* App Source element for reading from raw video file */
  data.app_source = gst_element_factory_make ("appsrc", "app-source");
  if (!data.app_source) {
    g_printerr ("Appsrc element could not be created. Exiting.\n");
    return -1;
  /* Use convertor to convert from software buffer to GPU buffer */
  nvvidconv1 =
      gst_element_factory_make ("nvvideoconvert", "nvvideo-converter1");
  if (!nvvidconv1) {
    g_printerr ("nvvideoconvert1 could not be created. Exiting.\n");
    return -1;
  caps_filter = gst_element_factory_make ("capsfilter", "capsfilter");
  if (!caps_filter) {
    g_printerr ("Caps_filter could not be created. Exiting.\n");
    return -1;
  caps_filter2 = gst_element_factory_make ("capsfilter", "capsfilter2");
  if (!caps_filter2) {
    g_printerr ("Caps_filter2 could not be created. Exiting.\n");
    return -1;
  /* Create nvstreammux instance to form batches from one or more sources. */
  streammux = gst_element_factory_make ("nvstreammux", "stream-muxer");
  if (!streammux) {
    g_printerr ("nvstreammux could not be created. Exiting.\n");
    return -1;
  /* Use nvinfer to run inferencing on streammux's output,
   * behaviour of inferencing is set through config file */
  pgie = gst_element_factory_make (NVINFER_PLUGIN, "primary-nvinference-engine");
  if (!pgie) {
    g_printerr ("Primary nvinfer could not be created. Exiting.\n");
    return -1;
  /* Use convertor to convert from NV12 to RGBA as required by nvdsosd */
  nvvidconv2 =
      gst_element_factory_make ("nvvideoconvert", "nvvideo-converter2");
  if (!nvvidconv2) {
    g_printerr ("nvvideoconvert2 could not be created. Exiting.\n");
    return -1;
  appsink = gst_element_factory_make ("appsink", "app-sink");
  if (!appsink) {
    g_printerr ("Appsink element could not be created. Exiting.\n");
    return -1;
  /* Configure appsrc */
  g_object_set (data.app_source, "caps",
      gst_caps_new_simple ("video/x-raw",
          "format", G_TYPE_STRING, format,
          "width", G_TYPE_INT, width,
          "height", G_TYPE_INT, height,
          "framerate", GST_TYPE_FRACTION, data.fps, 1, NULL), NULL);
#if !CUSTOM_PTS
  g_object_set (G_OBJECT (data.app_source), "do-timestamp", TRUE, NULL);
#endif
  caps = gst_caps_new_simple ("video/x-raw", "format", G_TYPE_STRING,
      "NV12", NULL);
  feature = gst_caps_features_new ("memory:NVMM", NULL);
  gst_caps_set_features (caps, 0, feature);
  g_object_set (G_OBJECT (caps_filter), "caps", caps, NULL);
  g_object_set(G_OBJECT(caps_filter2), "caps", gst_caps_new_simple("video/x-raw",
                                   "format", G_TYPE_STRING, "BGR", NULL), NULL);
  g_object_set(G_OBJECT(nvvidconv1), "compute-hw", 1, NULL);
  g_object_set(G_OBJECT(nvvidconv2), "compute-hw", 1, NULL);
  g_object_set(appsink, "caps",
                                   // "format", G_TYPE_STRING, "NV12", NULL),
               NULL);
  /* Set streammux properties */
  if (!use_new_mux) {
    g_object_set (G_OBJECT (streammux), "width", width, "height",
      height, "batch-size", 1, "live-source", TRUE,
      "batched-push-timeout", MUXER_BATCH_TIMEOUT_USEC, NULL);
  else {
    g_object_set (G_OBJECT (streammux), "batch-size", 1,
  g_object_set (G_OBJECT (pgie), "config-file-path", PGIE_CONFIG_FILE, NULL);
  //g_object_set (G_OBJECT (pgie), "input-tensor-meta", TRUE , NULL);
  /* we add a message handler */
  bus = gst_pipeline_get_bus (GST_PIPELINE (pipeline));
  bus_watch_id = gst_bus_add_watch (bus, bus_call, loop);
  gst_object_unref (bus);
  /* Set up the pipeline */
  /* we add all elements into the pipeline */
  gst_bin_add_many (GST_BIN (pipeline),
      data.app_source, nvvidconv1, caps_filter, streammux, pgie,
      nvvidconv2, caps_filter2, appsink, NULL);
  GstPad *sinkpad, *srcpad;
  gchar pad_name_sink[16] = "sink_0";
  gchar pad_name_src[16] = "src";
  sinkpad = gst_element_request_pad_simple (streammux, pad_name_sink);
  if (!sinkpad) {
    g_printerr ("Streammux request sink pad failed. Exiting.\n");
    return -1;
  srcpad = gst_element_get_static_pad (caps_filter, pad_name_src);
  if (!srcpad) {
    g_printerr ("Decoder request src pad failed. Exiting.\n");
    return -1;
  if (gst_pad_link (srcpad, sinkpad) != GST_PAD_LINK_OK) {
    g_printerr ("Failed to link caps filter to stream muxer. Exiting.\n");
    return -1;
  gst_object_unref (sinkpad);
  gst_object_unref (srcpad);
  /* we link the elements together */
  /* app-source -> nvvidconv -> caps filter ->
   * pgie -> nvvidconv -> caps filter -> appsink */
  g_print ("start link\n");
  if (!gst_element_link_many (data.app_source, nvvidconv1, caps_filter, NULL) ||
      //!gst_element_link_many (streammux, pgie, nvvidconv2, caps_filter2, appsink, NULL)) {
    g_printerr ("Elements could not be linked: Exiting.\n");
    return -1;
  g_print ("link success\n");
  /* Configure appsink to extract data from DeepStream pipeline */
  g_object_set (appsink, "emit-signals", TRUE, "async", FALSE, NULL);
  /* Callback to access buffer and object info. */
  g_signal_connect (appsink, "new-sample", G_CALLBACK (new_sample), NULL);
  /* Set the pipeline to "playing" state */
  g_print ("Now playing:\n");
  gst_element_set_state (pipeline, GST_STATE_PLAYING);
  test_webcam.setReadDataCallback(
    [&](const cv::Mat &frame) {
      GstBuffer *buffer;
      guint size = frame.rows * frame.step;
      GstFlowReturn gstret;
      GstMapInfo map;
      buffer = gst_buffer_new_allocate(NULL, size, NULL);
      gst_buffer_map(buffer, &map, GST_MAP_WRITE);
      memcpy(map.data, frame.data, size);
      gst_buffer_unmap(buffer, &map);
      /* increment the timestamp every 1/2 second */
       GST_BUFFER_PTS (buffer) = data.timestamp;
       GST_BUFFER_DURATION (buffer) = gst_util_uint64_scale_int (1, GST_SECOND, 30);
       data.timestamp += GST_BUFFER_DURATION (buffer);
      Poco::LocalDateTime st;
      g_signal_emit_by_name(data.app_source, "push-buffer", buffer, &gstret);
      gst_buffer_unref(buffer);
      Poco::LocalDateTime et;
      if (gstret != GST_FLOW_OK) {
			  g_print("ret not ok! \n");
      } else {
        g_print("ret ok! %d \n", (et-st).totalMilliseconds());
  /* Wait till pipeline encounters an error or EOS */
  g_print ("Running...\n");
  //g_main_loop_run (loop);
  while(true)
    auto c = cv::waitKey(10);
    if(c =='q')
      break;
  /* Out of the main loop, clean up nicely */
  g_print ("Returned, stopping playback\n");
  gst_element_set_state (pipeline, GST_STATE_NULL);
  g_print ("Deleting pipeline\n");
  gst_object_unref (GST_OBJECT (pipeline));
  g_source_remove (bus_watch_id);
  g_main_loop_unref (loop);
  return 0;
I use our demo deepstream-appsrc-test to print the pointer, it works normally. You can compare your code with our demo code yourself. Also you need to use %p to print a pointer not %x.
NvBufSurface surfaceList 0x7f8d8c009860
image width 1280 height 720
NvBufSurface mem tpye 2
I finally realized that the setup parameters of my two GstCaps shared the same GstCapsFeatures, which resulted in an incorrect format conversion and an empty image.
Everything’s fine now.
