Hi everyone,
I am struggling to find a away to input a single cv::Mat frame into a Nvidia Deepstream Pipeline using c++. I tried the code below but I received the following Error message:
ERROR from element gstappsrc: Internal data stream error.
Error details: gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:dst_opencv/GstAppSrc:source: streaming stopped, reason not-negotiated (-4)
Returned, stopping playback
Deleting pipeline
If anyone have an idea how to do it or show me where I am doing wrong, I will be very thankful.
My Setup:
• Hardware Platform (GPU)
• DeepStream Version: 4.0.1
• TensorRT Version: 5.1.2.2
• NVIDIA GPU Driver Version: 440.100
#include <gst/gst.h>
#include <glib.h>
#include <math.h>
#include <string.h>
#include <sys/time.h>
#include <opencv2/core/core.hpp>
#include <opencv2/highgui/highgui.hpp>
#include "gstnvdsmeta.h"
#include "nvdsmeta_schema.h"
#include <gst/app/gstappsrc.h>
/* The muxer output resolution must be set if the input streams will be of
* different resolution. The muxer will scale all the input frames to this
* resolution. */
#define MUXER_OUTPUT_WIDTH 1920
#define MUXER_OUTPUT_HEIGHT 1080
#define TILED_OUTPUT_WIDTH 1920
#define TILED_OUTPUT_HEIGHT 1080
/* Muxer batch formation timeout, for e.g. 40 millisec. Should ideally be set
* based on the fastest source's framerate. */
#define MUXER_BATCH_TIMEOUT_USEC 4000000
/* NVIDIA Decoder source pad memory feature. This feature signifies that source
* pads having this capability will push GstBuffers containing cuda buffers. */
#define GST_CAPS_FEATURES_NVMM "memory:NVMM"
// detection models
#define MODEL_CONFIG "dstest3_pgie_config.txt"
//#define MODEL_CONFIG "yoloV2_pgie_config.txt"
//#define MODEL_CONFIG "fd_lpd_config.txt"
#define FPS_PRINT_INTERVAL 300
static gboolean bus_call (GstBus * bus, GstMessage * msg, gpointer data)
GMainLoop *loop = (GMainLoop *) data;
switch (GST_MESSAGE_TYPE (msg)) {
case GST_MESSAGE_EOS:
g_print ("End of stream\n");
g_main_loop_quit (loop);
break;
case GST_MESSAGE_WARNING:
gchar *debug;
GError *error;
gst_message_parse_warning (msg, &error, &debug);
g_printerr ("WARNING from element %s: %s\n",
GST_OBJECT_NAME (msg->src), error->message);
g_free (debug);
g_printerr ("Warning: %s\n", error->message);
g_error_free (error);
break;
case GST_MESSAGE_ERROR:
gchar *debug;
GError *error;
gst_message_parse_error (msg, &error, &debug);
g_printerr ("ERROR from element %s: %s\n",
if (debug)
g_printerr ("Error details: %s\n", debug);
g_free (debug);
break;
default:
break;
return TRUE;
static void cb_newpad (GstElement * decodebin, GstPad * decoder_src_pad, gpointer data)
g_print ("In cb_newpad\n");
GstCaps *caps = gst_pad_get_current_caps (decoder_src_pad);
const GstStructure *str = gst_caps_get_structure (caps, 0);
const gchar *name = gst_structure_get_name (str);
GstElement *source_bin = (GstElement *) data;
GstCapsFeatures *features = gst_caps_get_features (caps, 0);
/* Need to check if the pad created by the decodebin is for video and not
* audio. */
if (!strncmp (name, "video", 5)) {
/* Link the decodebin pad only if decodebin has picked nvidia
* decoder plugin nvdec_*. We do this by checking if the pad caps contain
* NVMM memory features. */
if (gst_caps_features_contains (features, GST_CAPS_FEATURES_NVMM)) {
/* Get the source bin ghost pad */
GstPad *bin_ghost_pad = gst_element_get_static_pad (source_bin, "src");
if (!gst_ghost_pad_set_target (GST_GHOST_PAD (bin_ghost_pad),
decoder_src_pad)) {
g_printerr ("Failed to link decoder src pad to source bin ghost pad\n");
gst_object_unref (bin_ghost_pad);
} else {
g_printerr ("Error: Decodebin did not pick nvidia decoder plugin.\n");
static void decodebin_child_added (GstChildProxy * child_proxy, GObject * object,gchar * name, gpointer user_data)
g_print ("Decodebin child added: %s\n", name);
if (g_strrstr (name, "decodebin") == name) {
g_signal_connect (G_OBJECT (object), "child-added",
G_CALLBACK (decodebin_child_added), user_data);
if (g_strstr_len (name, -1, "nvv4l2decoder") == name) {
g_print ("Seting bufapi_version\n");
g_object_set (object, "bufapi-version", TRUE, NULL);
void buffer_destroy(gpointer data) {cv::Mat* done = (cv::Mat*)data; delete done;}
static gboolean cb_need_data(GstElement* appsrc,guint unused_size,gpointer user_data)
g_print("cb_need_data function \n");
GstBuffer* buffer;
GstMapInfo map;
guint size,depth,height,width,step,channels;
GstFlowReturn ret;
guchar *data1;
g_print("userdata: %s \n",user_data);
cv::Mat frame=cv::imread((const char*)user_data, CV_LOAD_IMAGE_COLOR);
height = frame.size().height;
width = frame.size().width;
channels = frame.channels();
data1 = (guchar *)frame.data;
gsize sizeInBytes = height*width*channels;
g_print("frame_height: %d \n",height);
g_print("frame_width: %d \n",width);
g_print("frame_channels: %d \n",channels);
g_print("frame_size: %d \n",sizeInBytes);
buffer=gst_buffer_new_allocate(NULL,sizeInBytes,NULL);
gst_buffer_map(buffer,&map,GST_MAP_WRITE);
memcpy( (guchar *)map.data, data1, gst_buffer_get_size( buffer ) );
g_signal_emit_by_name (appsrc, "push-buffer", buffer, &ret);
if (ret != GST_FLOW_OK) {g_print("cv 2 gst got an error"); return false;}
gst_buffer_unref(buffer);
//gst_buffer_unmap (buffer, &map);
g_print("cv converted to gst \n ");
return true;
static GstPadProbeReturn tiler_src_pad_buffer_probe (GstPad * pad, GstPadProbeInfo * info,gpointer u_data)
char *msg;
g_object_get(G_OBJECT(u_data),"last-message",&msg,NULL);
if (msg!=NULL) {g_print("FPS =%s \n",msg);}
return GST_PAD_PROBE_OK;
//------------------MAIN---------------------------------
int main(int argc,char** argv)
GMainLoop *loop;
GstElement *pipeline,*sink,*tiler,*nvvidconv,*nvosd,*nvsink,*pgie; //,*streammux
GstElement* appsrc,*conv;
GstBus *bus;
guint bus_watch_id;
GstPad *tiler_src_pad;
guint num_sources;
guint tiler_rows,tiler_columns;
guint pgie_batch_size;
GstCaps *caps;
//check input args
if(argc <2) {g_printerr("Usage: %s <uri1> [uri2] ... [uriN] \n", argv[0]); return -1;}
num_sources=argc-1;
//start gstreamer
gst_init(&argc,&argv);
loop=g_main_loop_new(NULL,FALSE);
//Creating pipeline
pipeline=gst_pipeline_new("dst_opencv");
//streammux=gst_element_factory_make("nvstreammux","nvstream-muxer");
if(!pipeline){g_printerr("pipeline could not be created");}
//if(!streammux){g_printerr("Streammux could not be created");}
//gst_bin_add(GST_BIN(pipeline),streammux);
// Creating bin with all sources
appsrc=gst_element_factory_make("appsrc","source");
conv=gst_element_factory_make("videoconvert","conv");
g_object_set (G_OBJECT (appsrc), "caps",
gst_caps_new_simple ("video/x-raw",
"format", G_TYPE_STRING, "I420",
"width", G_TYPE_INT, 1200,
"height", G_TYPE_INT, 600,
"pixel-aspect-ratio", GST_TYPE_FRACTION, 1, 1,
NULL), NULL);
g_object_set(G_OBJECT(appsrc),"stream-type",0,"format",GST_FORMAT_TIME,NULL);
/* Use nvinfer to infer on batched frame. */
pgie = gst_element_factory_make ("nvinfer", "primary-nvinference-engine");
/* Use nvtiler to composite the batched frames into a 2D tiled array based
* on the source of the frames. */
tiler = gst_element_factory_make ("nvmultistreamtiler", "nvtiler");
nvvidconv=gst_element_factory_make ("nvvideoconvert","nvvideo-converter");
/* Use convertor to convert from NV12 to RGBA as required by nvosd */
// nvvidconv = gst_element_factory_make ("nvvideoconvert", "nvvideo-converter");
nvosd=gst_element_factory_make("nvdsosd","nv-onscreendisplay");
nvsink=gst_element_factory_make ("nveglglessink", "nvvideo-renderer"); //show on display
//nvsink=gst_element_factory_make("fakesink","nvvideo-render"); //Dont show frames on screen
sink=gst_element_factory_make("fpsdisplaysink","fps_display");
//sink=gst_element_factory_make("autovideosink","videosink");
//check if all plugin were created
if(!appsrc){g_printerr("appsrc could not be created"); return -1;}
if(!conv){g_printerr("conv could not be created"); return -1;}
if(!tiler){g_printerr("tiler could not be created"); return -1;}
if(!sink){g_printerr("sink could not be created"); return -1;}
if(!nvvidconv){g_printerr("nvvidconv could not be created"); return -1;}
if(!pgie){g_printerr("pgie could not be created"); return -1;}
if(!nvosd){g_printerr("nvosd could not be created"); return -1;}
//set streammux
/* Configure the nvinfer element using the nvinfer config file. */
g_object_set (G_OBJECT (pgie),"config-file-path", MODEL_CONFIG, NULL);
/* Override the batch-size set in the config file with the number of sources. */
g_object_get (G_OBJECT (pgie), "batch-size", &pgie_batch_size, NULL);
if (pgie_batch_size != num_sources) {
g_printerr("WARNING: Overriding infer-config batch-size (%d) with number of sources (%d)\n",pgie_batch_size, num_sources);
g_object_set (G_OBJECT (pgie), "batch-size", num_sources, NULL);}
//g_print("Flag \n");
//set tiler
tiler_rows = (guint) sqrt (num_sources);
tiler_columns = (guint) ceil (1.0 * num_sources / tiler_rows);
/* we set the tiler properties here */
g_object_set (G_OBJECT (tiler), "rows", tiler_rows, "columns", tiler_columns,
"width", TILED_OUTPUT_WIDTH, "height", TILED_OUTPUT_HEIGHT, NULL);
/* we add a message handler */
bus = gst_pipeline_get_bus (GST_PIPELINE (pipeline));
bus_watch_id = gst_bus_add_watch (bus, bus_call, loop);
gst_object_unref (bus);
//set fps sink
g_object_set (G_OBJECT (sink), "text-overlay", FALSE, "video-sink", nvsink, "sync", FALSE, NULL);
//linking all elements
gst_bin_add_many(GST_BIN(pipeline),appsrc,conv,pgie,tiler,nvvidconv,nvosd,sink,NULL);
if (!gst_element_link_many(appsrc,conv,pgie,tiler,nvvidconv,nvosd,sink,NULL)){g_printerr("Elements could not be linked"); return -1;}
tiler_src_pad = gst_element_get_static_pad (pgie, "src");
if (!tiler_src_pad) {g_print ("Unable to get src pad\n");}
else{gst_pad_add_probe (tiler_src_pad, GST_PAD_PROBE_TYPE_BUFFER,tiler_src_pad_buffer_probe, (gpointer)sink, NULL);}
g_signal_connect (appsrc, "need-data", G_CALLBACK (cb_need_data),(gpointer)argv[1]);
/* Set the pipeline to "playing" state */
g_print ("Now playing:");
for (int i = 0; i < num_sources; i++) {g_print (" %s,", argv[i + 1]);}
g_print ("\n");
gst_element_set_state (pipeline, GST_STATE_PLAYING);
/* Wait till pipeline encounters an error or EOS */
g_print ("Running...\n");
g_main_loop_run (loop);
/* Out of the main loop, clean up nicely */
g_print ("Returned, stopping playback\n");
gst_element_set_state (pipeline, GST_STATE_NULL);
g_print ("Deleting pipeline\n");
gst_object_unref (GST_OBJECT (pipeline));
g_source_remove (bus_watch_id);
g_main_loop_unref (loop);
return 0;
