logs from GST
0:00:00.000046023 171 0xbb4ef0 INFO GST_INIT gst.c:586:init_pre: Initializing GStreamer Core Library version 1.16.3
0:00:00.000061357 171 0xbb4ef0 INFO GST_INIT gst.c:587:init_pre: Using library installed in /usr/lib/x86_64-linux-gnu
0:00:00.000070195 171 0xbb4ef0 INFO GST_INIT gst.c:605:init_pre: Linux ivacv 5.15.0-76-generic #83~20.04.1-Ubuntu SMP Wed Jun 21 20:23:31 UTC 2023 x86_64
0:00:00.000233123 171 0xbb4ef0 INFO GST_INIT gstmessage.c:128:_priv_gst_message_initialize: init messages
0:00:00.000541064 171 0xbb4ef0 INFO GST_INIT gstcontext.c:84:_priv_gst_context_initialize: init contexts
0:00:00.000657884 171 0xbb4ef0 INFO GST_PLUGIN_LOADING gstplugin.c:318:_priv_gst_plugin_initialize: registering 0 static plugins
0:00:00.000722722 171 0xbb4ef0 INFO GST_PLUGIN_LOADING gstplugin.c:226:gst_plugin_register_static: registered static plugin "staticelements"
0:00:00.000731368 171 0xbb4ef0 INFO GST_PLUGIN_LOADING gstplugin.c:228:gst_plugin_register_static: added static plugin "staticelements", result: 1
0:00:00.000740653 171 0xbb4ef0 INFO GST_REGISTRY gstregistry.c:1733:ensure_current_registry: reading registry cache: /root/.cache/gstreamer-1.0/registry.x86_64.bin
0:00:00.005417139 171 0xbb4ef0 INFO GST_REGISTRY gstregistrybinary.c:621:priv_gst_registry_binary_read_cache: loaded /root/.cache/gstreamer-1.0/registry.x86_64.bin in 0.004658 seconds
0:00:00.005446898 171 0xbb4ef0 INFO GST_REGISTRY gstregistry.c:1592:scan_and_update_registry: Validating plugins from registry cache: /root/.cache/gstreamer-1.0/registry.x86_64.bin
0:00:00.006519416 171 0xbb4ef0 INFO GST_REGISTRY gstregistry.c:1691:scan_and_update_registry: Registry cache has not changed
0:00:00.006527726 171 0xbb4ef0 INFO GST_REGISTRY gstregistry.c:1768:ensure_current_registry: registry reading and updating done, result = 1
0:00:00.006532970 171 0xbb4ef0 INFO GST_INIT gst.c:806:init_post: GLib runtime version: 2.64.6
0:00:00.006538239 171 0xbb4ef0 INFO GST_INIT gst.c:808:init_post: GLib headers version: 2.64.6
0:00:00.006541712 171 0xbb4ef0 INFO GST_INIT gst.c:810:init_post: initialized GStreamer successfully
Creating Pipeline
0:00:00.031976117 171 0xbb4ef0 INFO GST_PLUGIN_LOADING gstplugin.c:902:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistream.so" loaded
0:00:00.031989820 171 0xbb4ef0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:360:gst_element_factory_create: creating element "nvstreammux" named "Stream-muxer"
0:00:00.032190626 171 0xbb4ef0 INFO GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:<GstNvStreamMux@0x144a020> adding pad 'src'
Creating streamux
Creating Pgie
0:00:00.067412628 171 0xbb4ef0 INFO GST_PLUGIN_LOADING gstplugin.c:902:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_infer.so" loaded
0:00:00.067434428 171 0xbb4ef0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:360:gst_element_factory_create: creating element "nvinfer" named "primary-inference"
0:00:00.067578585 171 0xbb4ef0 INFO GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:<GstBaseTransform@0x2029740> adding pad 'sink'
0:00:00.067612187 171 0xbb4ef0 INFO GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:<GstBaseTransform@0x2029740> adding pad 'src'
Creating nvvidconv
0:00:00.068620089 171 0xbb4ef0 INFO GST_PLUGIN_LOADING gstplugin.c:902:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libgstnvvideoconvert.so" loaded
0:00:00.068631073 171 0xbb4ef0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:360:gst_element_factory_create: creating element "nvvideoconvert" named "convertor"
0:00:00.068717204 171 0xbb4ef0 INFO GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:<GstBaseTransform@0x202f760> adding pad 'sink'
0:00:00.068728310 171 0xbb4ef0 INFO GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:<GstBaseTransform@0x202f760> adding pad 'src'
0:00:00.069372096 171 0xbb4ef0 INFO GST_PLUGIN_LOADING gstplugin.c:902:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstcoreelements.so" loaded
0:00:00.069383550 171 0xbb4ef0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:360:gst_element_factory_create: creating element "capsfilter" named "filter"
0:00:00.069414503 171 0xbb4ef0 INFO GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:<GstBaseTransform@0x20202e0> adding pad 'sink'
0:00:00.069427946 171 0xbb4ef0 INFO GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:<GstBaseTransform@0x20202e0> adding pad 'src'
0:00:00.069542224 171 0xbb4ef0 INFO GST_EVENT gstevent.c:1579:gst_event_new_reconfigure: creating reconfigure event
Creating nvosd
0:00:00.071468470 171 0xbb4ef0 INFO GST_PLUGIN_LOADING gstplugin.c:902:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_osd.so" loaded
0:00:00.071480383 171 0xbb4ef0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:360:gst_element_factory_create: creating element "nvdsosd" named "onscreendisplay"
0:00:00.071528295 171 0xbb4ef0 INFO GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:<GstBaseTransform@0x206a2b0> adding pad 'sink'
0:00:00.071539683 171 0xbb4ef0 INFO GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:<GstBaseTransform@0x206a2b0> adding pad 'src'
creating sink
0:00:00.071927663 171 0xbb4ef0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:360:gst_element_factory_create: creating element "fakesink" named "fakesink"
0:00:00.072045575 171 0xbb4ef0 INFO GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:<GstBaseSink@0x211cac0> adding pad 'sink'
Adding elements to Pipeline
linking elements to pipline
0:00:00.072496399 171 0xbb4ef0 INFO GST_ELEMENT_PADS gstutils.c:1771:gst_element_link_pads_full: trying to link element Stream-muxer:(any) to element primary-inference:(any)
0:00:00.072507854 171 0xbb4ef0 INFO GST_PADS gstutils.c:1034:gst_pad_check_link: trying to link Stream-muxer:src and primary-inference:sink
0:00:00.072535278 171 0xbb4ef0 INFO GST_PADS gstpad.c:4237:gst_pad_peer_query:<primary-inference:src> pad has no peer
0:00:00.072568278 171 0xbb4ef0 INFO GST_PADS gstutils.c:1587:prepare_link_maybe_ghosting: Stream-muxer and primary-inference in same bin, no need for ghost pads
0:00:00.072578997 171 0xbb4ef0 INFO GST_PADS gstpad.c:2377:gst_pad_link_prepare: trying to link Stream-muxer:src and primary-inference:sink
0:00:00.072585808 171 0xbb4ef0 INFO GST_PADS gstpad.c:4237:gst_pad_peer_query:<primary-inference:src> pad has no peer
0:00:00.072611954 171 0xbb4ef0 INFO GST_PADS gstpad.c:2585:gst_pad_link_full: linked Stream-muxer:src and primary-inference:sink, successful
0:00:00.072633730 171 0xbb4ef0 INFO GST_EVENT gstevent.c:1579:gst_event_new_reconfigure: creating reconfigure event
0:00:00.072638690 171 0xbb4ef0 INFO GST_EVENT gstpad.c:5812:gst_pad_send_event_unchecked:<Stream-muxer:src> Received event on flushing pad. Discarding
0:00:00.072649275 171 0xbb4ef0 INFO GST_ELEMENT_PADS gstutils.c:1771:gst_element_link_pads_full: trying to link element primary-inference:(any) to element convertor:(any)
0:00:00.072655581 171 0xbb4ef0 INFO GST_PADS gstutils.c:1034:gst_pad_check_link: trying to link primary-inference:src and convertor:sink
0:00:00.072668556 171 0xbb4ef0 INFO GST_PADS gstpad.c:4237:gst_pad_peer_query:<convertor:src> pad has no peer
0:00:00.072728446 171 0xbb4ef0 INFO GST_PADS gstutils.c:1587:prepare_link_maybe_ghosting: primary-inference and convertor in same bin, no need for ghost pads
0:00:00.072735795 171 0xbb4ef0 INFO GST_PADS gstpad.c:2377:gst_pad_link_prepare: trying to link primary-inference:src and convertor:sink
0:00:00.072747578 171 0xbb4ef0 INFO GST_PADS gstpad.c:4237:gst_pad_peer_query:<convertor:src> pad has no peer
0:00:00.072770687 171 0xbb4ef0 INFO GST_PADS gstpad.c:2585:gst_pad_link_full: linked primary-inference:src and convertor:sink, successful
0:00:00.072776677 171 0xbb4ef0 INFO GST_EVENT gstevent.c:1579:gst_event_new_reconfigure: creating reconfigure event
0:00:00.072781346 171 0xbb4ef0 INFO GST_EVENT gstpad.c:5812:gst_pad_send_event_unchecked:<primary-inference:src> Received event on flushing pad. Discarding
0:00:00.072790819 171 0xbb4ef0 INFO GST_ELEMENT_PADS gstutils.c:1771:gst_element_link_pads_full: trying to link element convertor:(any) to element filter:(any)
0:00:00.072797074 171 0xbb4ef0 INFO GST_PADS gstutils.c:1034:gst_pad_check_link: trying to link convertor:src and filter:sink
0:00:00.072822612 171 0xbb4ef0 INFO GST_PADS gstpad.c:4237:gst_pad_peer_query:<filter:src> pad has no peer
0:00:00.072831463 171 0xbb4ef0 INFO GST_PADS gstutils.c:1587:prepare_link_maybe_ghosting: convertor and filter in same bin, no need for ghost pads
0:00:00.072838623 171 0xbb4ef0 INFO GST_PADS gstpad.c:2377:gst_pad_link_prepare: trying to link convertor:src and filter:sink
0:00:00.072865150 171 0xbb4ef0 INFO GST_PADS gstpad.c:4237:gst_pad_peer_query:<filter:src> pad has no peer
0:00:00.072873923 171 0xbb4ef0 INFO GST_PADS gstpad.c:2585:gst_pad_link_full: linked convertor:src and filter:sink, successful
0:00:00.072878770 171 0xbb4ef0 INFO GST_EVENT gstevent.c:1579:gst_event_new_reconfigure: creating reconfigure event
0:00:00.072883249 171 0xbb4ef0 INFO GST_EVENT gstpad.c:5812:gst_pad_send_event_unchecked:<convertor:src> Received event on flushing pad. Discarding
0:00:00.072892414 171 0xbb4ef0 INFO GST_ELEMENT_PADS gstutils.c:1771:gst_element_link_pads_full: trying to link element filter:(any) to element onscreendisplay:(any)
0:00:00.072898799 171 0xbb4ef0 INFO GST_PADS gstutils.c:1034:gst_pad_check_link: trying to link filter:src and onscreendisplay:sink
0:00:00.072927336 171 0xbb4ef0 INFO GST_PADS gstpad.c:4237:gst_pad_peer_query:<onscreendisplay:src> pad has no peer
0:00:00.072940807 171 0xbb4ef0 INFO GST_PADS gstutils.c:1587:prepare_link_maybe_ghosting: filter and onscreendisplay in same bin, no need for ghost pads
0:00:00.072949665 171 0xbb4ef0 INFO GST_PADS gstpad.c:2377:gst_pad_link_prepare: trying to link filter:src and onscreendisplay:sink
0:00:00.072977884 171 0xbb4ef0 INFO GST_PADS gstpad.c:4237:gst_pad_peer_query:<onscreendisplay:src> pad has no peer
0:00:00.072990371 171 0xbb4ef0 INFO GST_PADS gstpad.c:2585:gst_pad_link_full: linked filter:src and onscreendisplay:sink, successful
0:00:00.072995041 171 0xbb4ef0 INFO GST_EVENT gstevent.c:1579:gst_event_new_reconfigure: creating reconfigure event
0:00:00.072999485 171 0xbb4ef0 INFO GST_EVENT gstpad.c:5812:gst_pad_send_event_unchecked:<filter:src> Received event on flushing pad. Discarding
0:00:00.073008525 171 0xbb4ef0 INFO GST_ELEMENT_PADS gstutils.c:1771:gst_element_link_pads_full: trying to link element onscreendisplay:(any) to element fakesink:(any)
0:00:00.073014684 171 0xbb4ef0 INFO GST_PADS gstutils.c:1034:gst_pad_check_link: trying to link onscreendisplay:src and fakesink:sink
0:00:00.073049985 171 0xbb4ef0 INFO GST_PADS gstutils.c:1587:prepare_link_maybe_ghosting: onscreendisplay and fakesink in same bin, no need for ghost pads
0:00:00.073057462 171 0xbb4ef0 INFO GST_PADS gstpad.c:2377:gst_pad_link_prepare: trying to link onscreendisplay:src and fakesink:sink
0:00:00.073093523 171 0xbb4ef0 INFO GST_PADS gstpad.c:2585:gst_pad_link_full: linked onscreendisplay:src and fakesink:sink, successful
0:00:00.073098910 171 0xbb4ef0 INFO GST_EVENT gstevent.c:1579:gst_event_new_reconfigure: creating reconfigure event
0:00:00.073103404 171 0xbb4ef0 INFO GST_EVENT gstpad.c:5812:gst_pad_send_event_unchecked:<onscreendisplay:src> Received event on flushing pad. Discarding
0:00:00.073509477 171 0xbb4ef0 INFO GST_ELEMENT_PADS gstelement.c:928:gst_element_get_static_pad: found pad onscreendisplay:sink
0:00:00.074216534 171 0xbb4ef0 INFO GST_STATES gstbin.c:2090:gst_bin_get_state_func:<pipeline0> getting state
(<enum GST_STATE_CHANGE_SUCCESS of type Gst.StateChangeReturn>, state=<enum GST_STATE_NULL of type Gst.State>, pending=<enum GST_STATE_VOID_PENDING of type Gst.State>)
0:00:00.074281059 171 0xbb4ef0 INFO GST_STATES gstbin.c:2503:gst_bin_element_set_state:<fakesink> current NULL pending VOID_PENDING, desired next READY
0:00:00.074289968 171 0xbb4ef0 INFO GST_STATES gstelement.c:2688:gst_element_continue_state:<fakesink> completed state change to READY
0:00:00.074296042 171 0xbb4ef0 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed:<fakesink> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.074324919 171 0xbb4ef0 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func:<pipeline0> child 'fakesink' changed state to 2(READY) successfully
0:00:00.074348938 171 0xbb4ef0 INFO GST_STATES gstbin.c:2503:gst_bin_element_set_state:<onscreendisplay> current NULL pending VOID_PENDING, desired next READY
0:00:00.074354517 171 0xbb4ef0 INFO GST_STATES gstelement.c:2688:gst_element_continue_state:<onscreendisplay> completed state change to READY
0:00:00.074359741 171 0xbb4ef0 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed:<onscreendisplay> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.074366621 171 0xbb4ef0 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func:<pipeline0> child 'onscreendisplay' changed state to 2(READY) successfully
0:00:00.074372435 171 0xbb4ef0 INFO GST_STATES gstbin.c:2503:gst_bin_element_set_state:<filter> current NULL pending VOID_PENDING, desired next READY
0:00:00.074377701 171 0xbb4ef0 INFO GST_STATES gstelement.c:2688:gst_element_continue_state:<filter> completed state change to READY
0:00:00.074382740 171 0xbb4ef0 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed:<filter> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.074391563 171 0xbb4ef0 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func:<pipeline0> child 'filter' changed state to 2(READY) successfully
0:00:00.074397339 171 0xbb4ef0 INFO GST_STATES gstbin.c:2503:gst_bin_element_set_state:<convertor> current NULL pending VOID_PENDING, desired next READY
0:00:00.074402653 171 0xbb4ef0 INFO GST_STATES gstelement.c:2688:gst_element_continue_state:<convertor> completed state change to READY
0:00:00.074407485 171 0xbb4ef0 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed:<convertor> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.074413505 171 0xbb4ef0 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func:<pipeline0> child 'convertor' changed state to 2(READY) successfully
0:00:00.074419149 171 0xbb4ef0 INFO GST_STATES gstbin.c:2503:gst_bin_element_set_state:<primary-inference> current NULL pending VOID_PENDING, desired next READY
0:00:00.074424168 171 0xbb4ef0 INFO GST_STATES gstelement.c:2688:gst_element_continue_state:<primary-inference> completed state change to READY
0:00:00.074429485 171 0xbb4ef0 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed:<primary-inference> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.074435499 171 0xbb4ef0 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func:<pipeline0> child 'primary-inference' changed state to 2(READY) successfully
0:00:00.074440780 171 0xbb4ef0 INFO GST_STATES gstbin.c:2503:gst_bin_element_set_state:<Stream-muxer> current NULL pending VOID_PENDING, desired next READY
0:00:00.117396186 171 0xbb4ef0 INFO GST_STATES gstelement.c:2688:gst_element_continue_state:<Stream-muxer> completed state change to READY
0:00:00.117413258 171 0xbb4ef0 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed:<Stream-muxer> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.117429446 171 0xbb4ef0 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func:<pipeline0> child 'Stream-muxer' changed state to 2(READY) successfully
0:00:00.117438332 171 0xbb4ef0 INFO GST_STATES gstelement.c:2660:gst_element_continue_state:<pipeline0> committing state from NULL to READY, pending PAUSED, next PAUSED
0:00:00.117443715 171 0xbb4ef0 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed:<pipeline0> notifying about state-changed NULL to READY (PAUSED pending)
0:00:00.117449353 171 0xbb4ef0 INFO GST_STATES gstelement.c:2668:gst_element_continue_state:<pipeline0> continue state change READY to PAUSED, final PAUSED
0:00:00.117462849 171 0xbb4ef0 INFO GST_STATES gstbin.c:2503:gst_bin_element_set_state:<fakesink> current READY pending VOID_PENDING, desired next PAUSED
0:00:00.117474388 171 0xbb4ef0 INFO GST_STATES gstbin.c:2959:gst_bin_change_state_func:<pipeline0> child 'fakesink' is changing state asynchronously to PAUSED
0:00:00.117480440 171 0xbb4ef0 INFO GST_STATES gstbin.c:2503:gst_bin_element_set_state:<onscreendisplay> current READY pending VOID_PENDING, desired next PAUSED
0:00:00.117658175 171 0xbb4ef0 INFO GST_STATES gstelement.c:2688:gst_element_continue_state:<onscreendisplay> completed state change to PAUSED
0:00:00.117664955 171 0xbb4ef0 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed:<onscreendisplay> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.117673674 171 0xbb4ef0 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func:<pipeline0> child 'onscreendisplay' changed state to 3(PAUSED) successfully
0:00:00.117707287 171 0xbb4ef0 INFO GST_STATES gstbin.c:2503:gst_bin_element_set_state:<filter> current READY pending VOID_PENDING, desired next PAUSED
0:00:00.117716859 171 0xbb4ef0 INFO GST_STATES gstelement.c:2688:gst_element_continue_state:<filter> completed state change to PAUSED
0:00:00.117721462 171 0xbb4ef0 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed:<filter> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.117727508 171 0xbb4ef0 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func:<pipeline0> child 'filter' changed state to 3(PAUSED) successfully
0:00:00.117733056 171 0xbb4ef0 INFO GST_STATES gstbin.c:2503:gst_bin_element_set_state:<convertor> current READY pending VOID_PENDING, desired next PAUSED
0:00:00.117741021 171 0xbb4ef0 INFO GST_STATES gstelement.c:2688:gst_element_continue_state:<convertor> completed state change to PAUSED
0:00:00.117761150 171 0xbb4ef0 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed:<convertor> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:00.117785481 171 0xbb4ef0 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func:<pipeline0> child 'convertor' changed state to 3(PAUSED) successfully
0:00:00.117791037 171 0xbb4ef0 INFO GST_STATES gstbin.c:2503:gst_bin_element_set_state:<primary-inference> current READY pending VOID_PENDING, desired next PAUSED
WARNING: [TRT]: Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors.
0:00:01.852258859 171 0xbb4ef0 INFO nvinfer gstnvinfer.cpp:680:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1909> [UID = 1]: deserialized trt engine from :/test/models/resnet10.caffemodel_b1_gpu0_int8.engine
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:00:01.862396082 171 0xbb4ef0 WARN nvinfer gstnvinfer.cpp:677:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::checkBackendParams() <nvdsinfer_context_impl.cpp:1841> [UID = 1]: Backend has maxBatchSize 1 whereas 12 has been requested
0:00:01.862539491 171 0xbb4ef0 WARN nvinfer gstnvinfer.cpp:677:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2018> [UID = 1]: deserialized backend context :/test/models/resnet10.caffemodel_b1_gpu0_int8.engine failed to match config params, trying rebuild
0:00:01.863779549 171 0xbb4ef0 INFO nvinfer gstnvinfer.cpp:680:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1923> [UID = 1]: Trying to create engine from model files
WARNING: [TRT]: The implicit batch dimension mode has been deprecated. Please create the network with NetworkDefinitionCreationFlag::kEXPLICIT_BATCH flag whenever possible.
0:00:32.262393265 171 0xbb4ef0 INFO nvinfer gstnvinfer.cpp:680:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1955> [UID = 1]: serialize cuda engine to file: /test/models/resnet10.caffemodel_b12_gpu0_int8.engine successfully
0:00:32.275641805 171 0xbb4ef0 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<primary-inference> [UID 1]: Load new model:model_config.txt sucessfully
0:00:32.275663711 171 0xbb4ef0 INFO GST_STATES gstelement.c:2688:gst_element_continue_state:<primary-inference> completed state change to PAUSED
0:00:32.275671250 171 0xbb4ef0 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed:<primary-inference> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:32.275682417 171 0xbb4ef0 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func:<pipeline0> child 'primary-inference' changed state to 3(PAUSED) successfully
0:00:32.275690415 171 0xbb4ef0 INFO GST_STATES gstbin.c:2503:gst_bin_element_set_state:<Stream-muxer> current READY pending VOID_PENDING, desired next PAUSED
0:00:32.275771266 171 0xbb4ef0 INFO GST_STATES gstelement.c:2688:gst_element_continue_state:<Stream-muxer> completed state change to PAUSED
0:00:32.275778488 171 0xbb4ef0 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed:<Stream-muxer> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:32.275786167 171 0xbb4ef0 INFO GST_STATES gstbin.c:2952:gst_bin_change_state_func:<pipeline0> child 'Stream-muxer' changed state to 3(PAUSED) successfully
0:00:32.275816501 171 0xbb4ef0 INFO GST_STATES gstbin.c:2090:gst_bin_get_state_func:<pipeline0> getting state
0:00:32.275822514 171 0xbb4ef0 INFO GST_STATES gstelement.c:2404:gst_element_get_state_func:<pipeline0> waiting for element to commit state
0:00:32.275827398 171 0xbb4ef0 INFO GST_STATES gstelement.c:2419:gst_element_get_state_func:<pipeline0> timed out
(<enum GST_STATE_CHANGE_ASYNC of type Gst.StateChangeReturn>, state=<enum GST_STATE_READY of type Gst.State>, pending=<enum GST_STATE_PAUSED of type Gst.State>)
Starting pipeline
0:00:33.276758478 171 0x2045260 INFO GST_STATES gstbin.c:2090:gst_bin_get_state_func:<pipeline0> getting state
0:00:33.276848440 171 0x2045260 INFO GST_STATES gstelement.c:2404:gst_element_get_state_func:<pipeline0> waiting for element to commit state
0:00:33.276875228 171 0x2045260 INFO GST_STATES gstelement.c:2419:gst_element_get_state_func:<pipeline0> timed out
(<enum GST_STATE_CHANGE_ASYNC of type Gst.StateChangeReturn>, state=<enum GST_STATE_READY of type Gst.State>, pending=<enum GST_STATE_PLAYING of type Gst.State>)
debug--------------------------------> adding source
Calling Start 1
creating uridecodebin forrtsp://admin:123456@192.168.99.81
source-bin-01
0:00:42.286231234 171 0xbb4ef0 INFO GST_PLUGIN_LOADING gstplugin.c:902:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstplayback.so" loaded
0:00:42.286246347 171 0xbb4ef0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:360:gst_element_factory_create: creating element "uridecodebin" named "source-bin-01"
0:00:42.286481811 171 0xbb4ef0 INFO GST_STATES gstelement.c:2660:gst_element_continue_state:<source-bin-01> committing state from NULL to READY, pending PLAYING, next PAUSED
0:00:42.286492489 171 0xbb4ef0 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed:<source-bin-01> notifying about state-changed NULL to READY (PLAYING pending)
0:00:42.286508108 171 0xbb4ef0 INFO GST_STATES gstelement.c:2668:gst_element_continue_state:<source-bin-01> continue state change READY to PAUSED, final PLAYING
0:00:42.287074856 171 0xbb4ef0 INFO GST_PLUGIN_LOADING gstplugin.c:902:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstrtsp.so" loaded
0:00:42.287085070 171 0xbb4ef0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:360:gst_element_factory_create: creating element "rtspsrc" named "source"
0:00:42.287494257 171 0xbb4ef0 INFO GST_PLUGIN_LOADING gstplugin.c:902:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstrealmedia.so" loaded
0:00:42.287504184 171 0xbb4ef0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element "rtspreal"
0:00:42.287808840 171 0xbb4ef0 INFO GST_PLUGIN_LOADING gstplugin.c:902:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstasf.so" loaded
0:00:42.287818080 171 0xbb4ef0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element "rtspwms"
Decodebin child added: source
0:00:42.288114499 171 0xbb4ef0 INFO task gsttask.c:460:gst_task_set_lock: setting stream lock 0x14ecc948 on task 0x14cc74d0
0:00:42.288126983 171 0xbb4ef0 INFO GST_STATES gstelement.c:2660:gst_element_continue_state:<source> committing state from NULL to READY, pending PAUSED, next PAUSED
0:00:42.288134483 171 0xbb4ef0 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed:<source> notifying about state-changed NULL to READY (PAUSED pending)
0:00:42.288150291 171 0xbb4ef0 INFO GST_STATES gstelement.c:2668:gst_element_continue_state:<source> continue state change READY to PAUSED, final PAUSED
0:00:42.288199431 171 0xbb4ef0 INFO GST_STATES gstelement.c:2688:gst_element_continue_state:<source> completed state change to PAUSED
0:00:42.288207163 171 0xbb4ef0 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed:<source> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:42.288222174 171 0xbb4ef0 INFO GST_STATES gstbin.c:3421:bin_handle_async_done:<source-bin-01> committing state from READY to PAUSED, old pending PLAYING
0:00:42.288226945 171 0xbb4ef0 INFO GST_STATES gstbin.c:3444:bin_handle_async_done:<source-bin-01> completed state change, pending VOID
0:00:42.288232071 171 0xbb4ef0 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed:<source-bin-01> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:42.288240719 171 0xbb4ef0 INFO GST_STATES gstelement.c:2679:gst_element_continue_state:<source-bin-01> nothing pending
STATE CHANGE NO PREROLL
0:00:42.293766306 171 0x1245180 INFO rtspsrc gstrtspsrc.c:7788:gst_rtspsrc_retrieve_sdp:<source> Now using version: 1.0
0:00:42.299504990 171 0x1245180 INFO GST_PLUGIN_LOADING gstplugin.c:902:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstudp.so" loaded
0:00:42.299519806 171 0x1245180 INFO GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element "udpsrc"
0:00:42.299605656 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:<GstBaseSrc@0x7f43540231e0> adding pad 'src'
0:00:42.299658733 171 0x1245180 INFO udpsrc gstudpsrc.c:1420:gst_udpsrc_open:<udpsrc0> setting udp buffer of 524288 bytes
0:00:42.299668450 171 0x1245180 INFO udpsrc gstudpsrc.c:1439:gst_udpsrc_open:<udpsrc0> forcibly setting udp buffer of 524288 bytes
0:00:42.299677963 171 0x1245180 WARN udpsrc gstudpsrc.c:1445:gst_udpsrc_open:<udpsrc0> warning: Could not create a buffer of requested 524288 bytes (Operation not permitted). Need net.admin privilege?
0:00:42.299688929 171 0x1245180 INFO GST_ERROR_SYSTEM gstelement.c:2153:gst_element_message_full_with_details:<udpsrc0> posting message: Could not get/set settings from/on resource.
0:00:42.299697939 171 0x1245180 INFO GST_ERROR_SYSTEM gstelement.c:2180:gst_element_message_full_with_details:<udpsrc0> posted warning message: Could not get/set settings from/on resource.
0:00:42.299705421 171 0x1245180 WARN udpsrc gstudpsrc.c:1455:gst_udpsrc_open:<udpsrc0> have udp buffer of 212992 bytes while 524288 were requested
0:00:42.299717888 171 0x1245180 INFO GST_STATES gstelement.c:2688:gst_element_continue_state:<udpsrc0> completed state change to READY
0:00:42.299726631 171 0x1245180 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed:<udpsrc0> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:42.299779145 171 0x1245180 INFO GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element "udpsrc"
0:00:42.299791392 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:<GstBaseSrc@0x7f43540268d0> adding pad 'src'
0:00:42.299825684 171 0x1245180 INFO udpsrc gstudpsrc.c:1459:gst_udpsrc_open:<udpsrc1> have udp buffer of 106496 bytes
0:00:42.299836847 171 0x1245180 INFO GST_STATES gstelement.c:2688:gst_element_continue_state:<udpsrc1> completed state change to READY
0:00:42.299843912 171 0x1245180 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed:<udpsrc1> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:42.302570872 171 0x1245180 INFO GST_PLUGIN_LOADING gstplugin.c:902:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstrtpmanager.so" loaded
0:00:42.302583449 171 0x1245180 INFO GST_ELEMENT_FACTORY gstelementfactory.c:360:gst_element_factory_create: creating element "rtpbin" named "manager"
0:00:42.302740684 171 0x1245180 INFO GST_STATES gstelement.c:2660:gst_element_continue_state:<manager> committing state from NULL to READY, pending PAUSED, next PAUSED
0:00:42.302750812 171 0x1245180 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed:<manager> notifying about state-changed NULL to READY (PAUSED pending)
0:00:42.302767442 171 0x1245180 INFO GST_STATES gstelement.c:2668:gst_element_continue_state:<manager> continue state change READY to PAUSED, final PAUSED
0:00:42.302775702 171 0x1245180 INFO GST_STATES gstelement.c:2688:gst_element_continue_state:<manager> completed state change to PAUSED
0:00:42.302781234 171 0x1245180 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed:<manager> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:42.302811566 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:925:gst_element_get_static_pad: no such pad 'recv_rtp_sink_0' in element "manager"
0:00:42.302831298 171 0x1245180 INFO GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element "rtpsession"
0:00:42.302992987 171 0x1245180 INFO GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element "rtpssrcdemux"
0:00:42.303029580 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:<GstRtpSsrcDemux@0x13a12b0> adding pad 'sink'
0:00:42.303039711 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:<GstRtpSsrcDemux@0x13a12b0> adding pad 'rtcp_sink'
0:00:42.303575860 171 0x1245180 INFO GST_PLUGIN_LOADING gstplugin.c:902:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstrtp.so" loaded
0:00:42.303589006 171 0x1245180 INFO GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element "rtpstorage"
0:00:42.303631448 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:<GstRtpStorage@0x14cc75a0> adding pad 'src'
0:00:42.303639344 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:<GstRtpStorage@0x14cc75a0> adding pad 'sink'
0:00:42.303696305 171 0x1245180 INFO GST_STATES gstelement.c:2660:gst_element_continue_state:<rtpssrcdemux0> committing state from NULL to READY, pending PAUSED, next PAUSED
0:00:42.303704875 171 0x1245180 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed:<rtpssrcdemux0> notifying about state-changed NULL to READY (PAUSED pending)
0:00:42.303717941 171 0x1245180 INFO GST_STATES gstelement.c:2668:gst_element_continue_state:<rtpssrcdemux0> continue state change READY to PAUSED, final PAUSED
0:00:42.303727017 171 0x1245180 INFO GST_STATES gstelement.c:2688:gst_element_continue_state:<rtpssrcdemux0> completed state change to PAUSED
0:00:42.303732942 171 0x1245180 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed:<rtpssrcdemux0> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:42.303744867 171 0x1245180 INFO GST_STATES gstelement.c:2660:gst_element_continue_state:<rtpsession0> committing state from NULL to READY, pending PAUSED, next PAUSED
0:00:42.303751192 171 0x1245180 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed:<rtpsession0> notifying about state-changed NULL to READY (PAUSED pending)
0:00:42.303759789 171 0x1245180 INFO GST_STATES gstelement.c:2668:gst_element_continue_state:<rtpsession0> continue state change READY to PAUSED, final PAUSED
0:00:42.303765696 171 0x1245180 INFO GST_STATES gstelement.c:2688:gst_element_continue_state:<rtpsession0> completed state change to PAUSED
0:00:42.303772984 171 0x1245180 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed:<rtpsession0> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:42.303783999 171 0x1245180 INFO GST_STATES gstelement.c:2660:gst_element_continue_state:<rtpstorage0> committing state from NULL to READY, pending PAUSED, next PAUSED
0:00:42.303790370 171 0x1245180 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed:<rtpstorage0> notifying about state-changed NULL to READY (PAUSED pending)
0:00:42.303813892 171 0x1245180 INFO GST_STATES gstelement.c:2668:gst_element_continue_state:<rtpstorage0> continue state change READY to PAUSED, final PAUSED
0:00:42.303823546 171 0x1245180 INFO GST_STATES gstelement.c:2688:gst_element_continue_state:<rtpstorage0> completed state change to PAUSED
0:00:42.303829639 171 0x1245180 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed:<rtpstorage0> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:42.303840132 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:925:gst_element_get_static_pad: no such pad 'recv_rtp_sink' in element "rtpsession0"
0:00:42.303856069 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:<rtpsession0> adding pad 'recv_rtp_sink'
0:00:42.303868377 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:<rtpsession0> adding pad 'recv_rtp_src'
0:00:42.303904116 171 0x1245180 INFO GST_PADS gstpad.c:2377:gst_pad_link_prepare: trying to link recv_rtp_sink_0:proxypad0 and rtpsession0:recv_rtp_sink
0:00:42.303912982 171 0x1245180 INFO GST_PADS gstpad.c:2585:gst_pad_link_full: linked recv_rtp_sink_0:proxypad0 and rtpsession0:recv_rtp_sink, successful
0:00:42.303918464 171 0x1245180 INFO GST_EVENT gstevent.c:1579:gst_event_new_reconfigure: creating reconfigure event
0:00:42.303928807 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:<manager> adding pad 'recv_rtp_sink_0'
0:00:42.303938472 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:928:gst_element_get_static_pad: found pad rtpsession0:recv_rtp_src
0:00:42.303945946 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:928:gst_element_get_static_pad: found pad rtpstorage0:sink
0:00:42.303954309 171 0x1245180 INFO GST_PADS gstpad.c:2377:gst_pad_link_prepare: trying to link rtpsession0:recv_rtp_src and rtpstorage0:sink
0:00:42.303964554 171 0x1245180 INFO GST_PADS gstpad.c:4237:gst_pad_peer_query:<rtpstorage0:src> pad has no peer
0:00:42.303972980 171 0x1245180 INFO GST_PADS gstpad.c:2585:gst_pad_link_full: linked rtpsession0:recv_rtp_src and rtpstorage0:sink, successful
0:00:42.303978304 171 0x1245180 INFO GST_EVENT gstevent.c:1579:gst_event_new_reconfigure: creating reconfigure event
0:00:42.303988220 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:928:gst_element_get_static_pad: found pad rtpstorage0:src
0:00:42.303994702 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:928:gst_element_get_static_pad: found pad rtpssrcdemux0:sink
0:00:42.304002254 171 0x1245180 INFO GST_PADS gstpad.c:2377:gst_pad_link_prepare: trying to link rtpstorage0:src and rtpssrcdemux0:sink
0:00:42.304008884 171 0x1245180 INFO GST_PADS gstpad.c:2585:gst_pad_link_full: linked rtpstorage0:src and rtpssrcdemux0:sink, successful
0:00:42.304017839 171 0x1245180 INFO GST_EVENT gstevent.c:1579:gst_event_new_reconfigure: creating reconfigure event
0:00:42.304032153 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:925:gst_element_get_static_pad: no such pad 'recv_rtcp_sink_0' in element "manager"
0:00:42.304040345 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:925:gst_element_get_static_pad: no such pad 'recv_rtcp_sink' in element "rtpsession0"
0:00:42.304054524 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:<rtpsession0> adding pad 'recv_rtcp_sink'
0:00:42.304066012 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:<rtpsession0> adding pad 'sync_src'
0:00:42.304077847 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:928:gst_element_get_static_pad: found pad rtpsession0:sync_src
0:00:42.304084099 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:928:gst_element_get_static_pad: found pad rtpssrcdemux0:rtcp_sink
0:00:42.304092224 171 0x1245180 INFO GST_PADS gstpad.c:2377:gst_pad_link_prepare: trying to link rtpsession0:sync_src and rtpssrcdemux0:rtcp_sink
0:00:42.304098875 171 0x1245180 INFO GST_PADS gstpad.c:2585:gst_pad_link_full: linked rtpsession0:sync_src and rtpssrcdemux0:rtcp_sink, successful
0:00:42.304103775 171 0x1245180 INFO GST_EVENT gstevent.c:1579:gst_event_new_reconfigure: creating reconfigure event
0:00:42.304119209 171 0x1245180 INFO GST_PADS gstpad.c:2377:gst_pad_link_prepare: trying to link recv_rtcp_sink_0:proxypad1 and rtpsession0:recv_rtcp_sink
0:00:42.304126187 171 0x1245180 INFO GST_PADS gstpad.c:2585:gst_pad_link_full: linked recv_rtcp_sink_0:proxypad1 and rtpsession0:recv_rtcp_sink, successful
0:00:42.304130840 171 0x1245180 INFO GST_EVENT gstevent.c:1579:gst_event_new_reconfigure: creating reconfigure event
0:00:42.304139315 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:<manager> adding pad 'recv_rtcp_sink_0'
0:00:42.304157359 171 0x1245180 INFO rtspsrc gstrtspsrc.c:3953:gst_rtspsrc_stream_configure_manager:<source> configure bandwidth in session 0x2020f10
0:00:42.304166656 171 0x1245180 INFO rtspsrc gstrtspsrc.c:3958:gst_rtspsrc_stream_configure_manager:<source> setting AS: 3000.000000
0:00:42.304193873 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:928:gst_element_get_static_pad: found pad udpsrc0:src
0:00:42.304204462 171 0x1245180 INFO GST_PADS gstpad.c:2377:gst_pad_link_prepare: trying to link udpsrc0:src and manager:recv_rtp_sink_0
0:00:42.304211232 171 0x1245180 INFO GST_PADS gstpad.c:2585:gst_pad_link_full: linked udpsrc0:src and manager:recv_rtp_sink_0, successful
0:00:42.304216017 171 0x1245180 INFO GST_EVENT gstevent.c:1579:gst_event_new_reconfigure: creating reconfigure event
0:00:42.304221451 171 0x1245180 INFO GST_EVENT gstpad.c:5812:gst_pad_send_event_unchecked:<udpsrc0:src> Received event on flushing pad. Discarding
0:00:42.304235715 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:928:gst_element_get_static_pad: found pad udpsrc1:src
0:00:42.304248089 171 0x1245180 INFO GST_PADS gstpad.c:2377:gst_pad_link_prepare: trying to link udpsrc1:src and manager:recv_rtcp_sink_0
0:00:42.304254799 171 0x1245180 INFO GST_PADS gstpad.c:2585:gst_pad_link_full: linked udpsrc1:src and manager:recv_rtcp_sink_0, successful
0:00:42.304259607 171 0x1245180 INFO GST_EVENT gstevent.c:1579:gst_event_new_reconfigure: creating reconfigure event
0:00:42.304265424 171 0x1245180 INFO GST_EVENT gstpad.c:5812:gst_pad_send_event_unchecked:<udpsrc1:src> Received event on flushing pad. Discarding
0:00:42.304311412 171 0x1245180 INFO GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element "udpsink"
0:00:42.304376515 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:<GstBaseSink@0x7f4354049d40> adding pad 'sink'
0:00:42.304411397 171 0x1245180 INFO GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element "fakesrc"
0:00:42.304469101 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:<GstBaseSrc@0x7f435404c0e0> adding pad 'src'
0:00:42.304493981 171 0x1245180 INFO GST_ELEMENT_PADS gstutils.c:1771:gst_element_link_pads_full: trying to link element fakesrc0:src to element udpsink0:sink
0:00:42.304500667 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:928:gst_element_get_static_pad: found pad fakesrc0:src
0:00:42.304505929 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:928:gst_element_get_static_pad: found pad udpsink0:sink
0:00:42.304512075 171 0x1245180 INFO GST_PADS gstutils.c:1587:prepare_link_maybe_ghosting: fakesrc0 and udpsink0 in same bin, no need for ghost pads
0:00:42.304520378 171 0x1245180 INFO GST_PADS gstpad.c:2377:gst_pad_link_prepare: trying to link fakesrc0:src and udpsink0:sink
0:00:42.304526910 171 0x1245180 INFO GST_PADS gstpad.c:2585:gst_pad_link_full: linked fakesrc0:src and udpsink0:sink, successful
0:00:42.304531676 171 0x1245180 INFO GST_EVENT gstevent.c:1579:gst_event_new_reconfigure: creating reconfigure event
0:00:42.304536947 171 0x1245180 INFO GST_EVENT gstpad.c:5812:gst_pad_send_event_unchecked:<fakesrc0:src> Received event on flushing pad. Discarding
0:00:42.304572653 171 0x1245180 INFO GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element "udpsink"
0:00:42.304592571 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:<GstBaseSink@0x7f435404e530> adding pad 'sink'
0:00:42.304630436 171 0x1245180 INFO GST_STATES gstelement.c:2660:gst_element_continue_state:<udpsink1> committing state from NULL to READY, pending PLAYING, next PAUSED
0:00:42.304637867 171 0x1245180 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed:<udpsink1> notifying about state-changed NULL to READY (PLAYING pending)
0:00:42.304645806 171 0x1245180 INFO GST_STATES gstelement.c:2668:gst_element_continue_state:<udpsink1> continue state change READY to PAUSED, final PLAYING
0:00:42.304655262 171 0x1245180 INFO GST_STATES gstelement.c:2660:gst_element_continue_state:<udpsink1> committing state from READY to PAUSED, pending PLAYING, next PLAYING
0:00:42.304661513 171 0x1245180 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed:<udpsink1> notifying about state-changed READY to PAUSED (PLAYING pending)
0:00:42.304668406 171 0x1245180 INFO GST_STATES gstelement.c:2668:gst_element_continue_state:<udpsink1> continue state change PAUSED to PLAYING, final PLAYING
0:00:42.304674159 171 0x1245180 INFO GST_STATES gstelement.c:2688:gst_element_continue_state:<udpsink1> completed state change to PLAYING
0:00:42.304679733 171 0x1245180 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed:<udpsink1> notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:42.304691150 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:928:gst_element_get_static_pad: found pad udpsink1:sink
0:00:42.304699240 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:925:gst_element_get_static_pad: no such pad 'send_rtcp_src_0' in element "manager"
0:00:42.304706769 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:925:gst_element_get_static_pad: no such pad 'send_rtcp_src' in element "rtpsession0"
0:00:42.304722887 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:<rtpsession0> adding pad 'send_rtcp_src'
0:00:42.304742254 171 0x1245180 INFO GST_PADS gstpad.c:2377:gst_pad_link_prepare: trying to link rtpsession0:send_rtcp_src and send_rtcp_src_0:proxypad2
0:00:42.304754313 171 0x1245180 INFO GST_PADS gstpad.c:2585:gst_pad_link_full: linked rtpsession0:send_rtcp_src and send_rtcp_src_0:proxypad2, successful
0:00:42.304759429 171 0x1245180 INFO GST_EVENT gstevent.c:1579:gst_event_new_reconfigure: creating reconfigure event
0:00:42.304769395 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:<manager> adding pad 'send_rtcp_src_0'
0:00:42.304780109 171 0x1245180 INFO GST_PADS gstpad.c:2377:gst_pad_link_prepare: trying to link manager:send_rtcp_src_0 and udpsink1:sink
0:00:42.304786580 171 0x1245180 INFO GST_PADS gstpad.c:2585:gst_pad_link_full: linked manager:send_rtcp_src_0 and udpsink1:sink, successful
0:00:42.304791357 171 0x1245180 INFO GST_EVENT gstevent.c:1579:gst_event_new_reconfigure: creating reconfigure event
0:00:42.304835944 171 0x1245180 INFO GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element "udpsrc"
0:00:42.304848018 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:<GstBaseSrc@0x7f4354053060> adding pad 'src'
0:00:42.304887573 171 0x1245180 INFO udpsrc gstudpsrc.c:1420:gst_udpsrc_open:<udpsrc2> setting udp buffer of 524288 bytes
0:00:42.304895717 171 0x1245180 INFO udpsrc gstudpsrc.c:1439:gst_udpsrc_open:<udpsrc2> forcibly setting udp buffer of 524288 bytes
0:00:42.304904231 171 0x1245180 WARN udpsrc gstudpsrc.c:1445:gst_udpsrc_open:<udpsrc2> warning: Could not create a buffer of requested 524288 bytes (Operation not permitted). Need net.admin privilege?
0:00:42.304913287 171 0x1245180 INFO GST_ERROR_SYSTEM gstelement.c:2153:gst_element_message_full_with_details:<udpsrc2> posting message: Could not get/set settings from/on resource.
0:00:42.304921826 171 0x1245180 INFO GST_ERROR_SYSTEM gstelement.c:2180:gst_element_message_full_with_details:<udpsrc2> posted warning message: Could not get/set settings from/on resource.
0:00:42.304929405 171 0x1245180 WARN udpsrc gstudpsrc.c:1455:gst_udpsrc_open:<udpsrc2> have udp buffer of 212992 bytes while 524288 were requested
0:00:42.304941374 171 0x1245180 INFO GST_STATES gstelement.c:2688:gst_element_continue_state:<udpsrc2> completed state change to READY
0:00:42.304948449 171 0x1245180 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed:<udpsrc2> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:42.304984067 171 0x1245180 INFO GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element "udpsrc"
0:00:42.304994648 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:<GstBaseSrc@0x7f4354053480> adding pad 'src'
0:00:42.305027721 171 0x1245180 INFO udpsrc gstudpsrc.c:1459:gst_udpsrc_open:<udpsrc3> have udp buffer of 106496 bytes
0:00:42.305038520 171 0x1245180 INFO GST_STATES gstelement.c:2688:gst_element_continue_state:<udpsrc3> completed state change to READY
0:00:42.305045203 171 0x1245180 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed:<udpsrc3> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:42.307647243 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:925:gst_element_get_static_pad: no such pad 'recv_rtp_sink_1' in element "manager"
0:00:42.307666774 171 0x1245180 INFO GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element "rtpsession"
0:00:42.307690144 171 0x1245180 INFO GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element "rtpssrcdemux"
0:00:42.307704057 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:<GstRtpSsrcDemux@0x13a13e0> adding pad 'sink'
0:00:42.307718097 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:<GstRtpSsrcDemux@0x13a13e0> adding pad 'rtcp_sink'
0:00:42.307726456 171 0x1245180 INFO GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element "rtpstorage"
0:00:42.307744636 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:<GstRtpStorage@0x14cc76c0> adding pad 'src'
0:00:42.307750595 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:<GstRtpStorage@0x14cc76c0> adding pad 'sink'
0:00:42.307797110 171 0x1245180 INFO GST_STATES gstelement.c:2660:gst_element_continue_state:<rtpssrcdemux1> committing state from NULL to READY, pending PAUSED, next PAUSED
0:00:42.307805946 171 0x1245180 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed:<rtpssrcdemux1> notifying about state-changed NULL to READY (PAUSED pending)
0:00:42.307819462 171 0x1245180 INFO GST_STATES gstelement.c:2668:gst_element_continue_state:<rtpssrcdemux1> continue state change READY to PAUSED, final PAUSED
0:00:42.307828558 171 0x1245180 INFO GST_STATES gstelement.c:2688:gst_element_continue_state:<rtpssrcdemux1> completed state change to PAUSED
0:00:42.307834913 171 0x1245180 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed:<rtpssrcdemux1> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:42.307851138 171 0x1245180 INFO GST_STATES gstelement.c:2660:gst_element_continue_state:<rtpsession1> committing state from NULL to READY, pending PAUSED, next PAUSED
0:00:42.307857955 171 0x1245180 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed:<rtpsession1> notifying about state-changed NULL to READY (PAUSED pending)
0:00:42.307868058 171 0x1245180 INFO GST_STATES gstelement.c:2668:gst_element_continue_state:<rtpsession1> continue state change READY to PAUSED, final PAUSED
0:00:42.307873588 171 0x1245180 INFO GST_STATES gstelement.c:2688:gst_element_continue_state:<rtpsession1> completed state change to PAUSED
0:00:42.307878970 171 0x1245180 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed:<rtpsession1> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:42.307891441 171 0x1245180 INFO GST_STATES gstelement.c:2660:gst_element_continue_state:<rtpstorage1> committing state from NULL to READY, pending PAUSED, next PAUSED
0:00:42.307902058 171 0x1245180 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed:<rtpstorage1> notifying about state-changed NULL to READY (PAUSED pending)
0:00:42.307909377 171 0x1245180 INFO GST_STATES gstelement.c:2668:gst_element_continue_state:<rtpstorage1> continue state change READY to PAUSED, final PAUSED
0:00:42.307917924 171 0x1245180 INFO GST_STATES gstelement.c:2688:gst_element_continue_state:<rtpstorage1> completed state change to PAUSED
0:00:42.307924000 171 0x1245180 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed:<rtpstorage1> notifying about state-changed READY to PAUSED (VOID_PENDING pending)
0:00:42.307932320 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:925:gst_element_get_static_pad: no such pad 'recv_rtp_sink' in element "rtpsession1"
0:00:42.307947090 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:<rtpsession1> adding pad 'recv_rtp_sink'
0:00:42.307959355 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:<rtpsession1> adding pad 'recv_rtp_src'
0:00:42.307980917 171 0x1245180 INFO GST_PADS gstpad.c:2377:gst_pad_link_prepare: trying to link recv_rtp_sink_1:proxypad3 and rtpsession1:recv_rtp_sink
0:00:42.307988695 171 0x1245180 INFO GST_PADS gstpad.c:2585:gst_pad_link_full: linked recv_rtp_sink_1:proxypad3 and rtpsession1:recv_rtp_sink, successful
0:00:42.307993604 171 0x1245180 INFO GST_EVENT gstevent.c:1579:gst_event_new_reconfigure: creating reconfigure event
0:00:42.308004442 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:<manager> adding pad 'recv_rtp_sink_1'
0:00:42.308013247 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:928:gst_element_get_static_pad: found pad rtpsession1:recv_rtp_src
0:00:42.308019809 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:928:gst_element_get_static_pad: found pad rtpstorage1:sink
0:00:42.308027892 171 0x1245180 INFO GST_PADS gstpad.c:2377:gst_pad_link_prepare: trying to link rtpsession1:recv_rtp_src and rtpstorage1:sink
0:00:42.308036897 171 0x1245180 INFO GST_PADS gstpad.c:4237:gst_pad_peer_query:<rtpstorage1:src> pad has no peer
0:00:42.308045428 171 0x1245180 INFO GST_PADS gstpad.c:2585:gst_pad_link_full: linked rtpsession1:recv_rtp_src and rtpstorage1:sink, successful
0:00:42.308051166 171 0x1245180 INFO GST_EVENT gstevent.c:1579:gst_event_new_reconfigure: creating reconfigure event
0:00:42.308061888 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:928:gst_element_get_static_pad: found pad rtpstorage1:src
0:00:42.308068363 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:928:gst_element_get_static_pad: found pad rtpssrcdemux1:sink
0:00:42.308075065 171 0x1245180 INFO GST_PADS gstpad.c:2377:gst_pad_link_prepare: trying to link rtpstorage1:src and rtpssrcdemux1:sink
0:00:42.308081582 171 0x1245180 INFO GST_PADS gstpad.c:2585:gst_pad_link_full: linked rtpstorage1:src and rtpssrcdemux1:sink, successful
0:00:42.308086756 171 0x1245180 INFO GST_EVENT gstevent.c:1579:gst_event_new_reconfigure: creating reconfigure event
0:00:42.308099127 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:925:gst_element_get_static_pad: no such pad 'recv_rtcp_sink_1' in element "manager"
0:00:42.308106885 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:925:gst_element_get_static_pad: no such pad 'recv_rtcp_sink' in element "rtpsession1"
0:00:42.308120862 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:<rtpsession1> adding pad 'recv_rtcp_sink'
0:00:42.308133589 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:<rtpsession1> adding pad 'sync_src'
0:00:42.308148357 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:928:gst_element_get_static_pad: found pad rtpsession1:sync_src
0:00:42.308154489 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:928:gst_element_get_static_pad: found pad rtpssrcdemux1:rtcp_sink
0:00:42.308162703 171 0x1245180 INFO GST_PADS gstpad.c:2377:gst_pad_link_prepare: trying to link rtpsession1:sync_src and rtpssrcdemux1:rtcp_sink
0:00:42.308169676 171 0x1245180 INFO GST_PADS gstpad.c:2585:gst_pad_link_full: linked rtpsession1:sync_src and rtpssrcdemux1:rtcp_sink, successful
0:00:42.308174802 171 0x1245180 INFO GST_EVENT gstevent.c:1579:gst_event_new_reconfigure: creating reconfigure event
0:00:42.308190799 171 0x1245180 INFO GST_PADS gstpad.c:2377:gst_pad_link_prepare: trying to link recv_rtcp_sink_1:proxypad4 and rtpsession1:recv_rtcp_sink
0:00:42.308198065 171 0x1245180 INFO GST_PADS gstpad.c:2585:gst_pad_link_full: linked recv_rtcp_sink_1:proxypad4 and rtpsession1:recv_rtcp_sink, successful
0:00:42.308203359 171 0x1245180 INFO GST_EVENT gstevent.c:1579:gst_event_new_reconfigure: creating reconfigure event
0:00:42.308211766 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:<manager> adding pad 'recv_rtcp_sink_1'
0:00:42.308222464 171 0x1245180 INFO rtspsrc gstrtspsrc.c:3953:gst_rtspsrc_stream_configure_manager:<source> configure bandwidth in session 0x2021250
0:00:42.308230765 171 0x1245180 INFO rtspsrc gstrtspsrc.c:3958:gst_rtspsrc_stream_configure_manager:<source> setting AS: 64000.000000
0:00:42.308251284 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:928:gst_element_get_static_pad: found pad udpsrc2:src
0:00:42.308261386 171 0x1245180 INFO GST_PADS gstpad.c:2377:gst_pad_link_prepare: trying to link udpsrc2:src and manager:recv_rtp_sink_1
0:00:42.308268094 171 0x1245180 INFO GST_PADS gstpad.c:2585:gst_pad_link_full: linked udpsrc2:src and manager:recv_rtp_sink_1, successful
0:00:42.308273370 171 0x1245180 INFO GST_EVENT gstevent.c:1579:gst_event_new_reconfigure: creating reconfigure event
0:00:42.308279605 171 0x1245180 INFO GST_EVENT gstpad.c:5812:gst_pad_send_event_unchecked:<udpsrc2:src> Received event on flushing pad. Discarding
0:00:42.308293331 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:928:gst_element_get_static_pad: found pad udpsrc3:src
0:00:42.308301665 171 0x1245180 INFO GST_PADS gstpad.c:2377:gst_pad_link_prepare: trying to link udpsrc3:src and manager:recv_rtcp_sink_1
0:00:42.308308170 171 0x1245180 INFO GST_PADS gstpad.c:2585:gst_pad_link_full: linked udpsrc3:src and manager:recv_rtcp_sink_1, successful
0:00:42.308312976 171 0x1245180 INFO GST_EVENT gstevent.c:1579:gst_event_new_reconfigure: creating reconfigure event
0:00:42.308318077 171 0x1245180 INFO GST_EVENT gstpad.c:5812:gst_pad_send_event_unchecked:<udpsrc3:src> Received event on flushing pad. Discarding
0:00:42.308355095 171 0x1245180 INFO GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element "udpsink"
0:00:42.308374032 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:<GstBaseSink@0x7f43540579f0> adding pad 'sink'
0:00:42.308408054 171 0x1245180 INFO GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element "fakesrc"
0:00:42.308418687 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:<GstBaseSrc@0x7f435404c4c0> adding pad 'src'
0:00:42.308438979 171 0x1245180 INFO GST_ELEMENT_PADS gstutils.c:1771:gst_element_link_pads_full: trying to link element fakesrc1:src to element udpsink2:sink
0:00:42.308445695 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:928:gst_element_get_static_pad: found pad fakesrc1:src
0:00:42.308451305 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:928:gst_element_get_static_pad: found pad udpsink2:sink
0:00:42.308456867 171 0x1245180 INFO GST_PADS gstutils.c:1587:prepare_link_maybe_ghosting: fakesrc1 and udpsink2 in same bin, no need for ghost pads
0:00:42.308464852 171 0x1245180 INFO GST_PADS gstpad.c:2377:gst_pad_link_prepare: trying to link fakesrc1:src and udpsink2:sink
0:00:42.308471334 171 0x1245180 INFO GST_PADS gstpad.c:2585:gst_pad_link_full: linked fakesrc1:src and udpsink2:sink, successful
0:00:42.308476144 171 0x1245180 INFO GST_EVENT gstevent.c:1579:gst_event_new_reconfigure: creating reconfigure event
0:00:42.308481806 171 0x1245180 INFO GST_EVENT gstpad.c:5812:gst_pad_send_event_unchecked:<fakesrc1:src> Received event on flushing pad. Discarding
0:00:42.308517331 171 0x1245180 INFO GST_ELEMENT_FACTORY gstelementfactory.c:363:gst_element_factory_create: creating element "udpsink"
0:00:42.308528119 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:<GstBaseSink@0x7f435405aa70> adding pad 'sink'
0:00:42.308567533 171 0x1245180 INFO GST_STATES gstelement.c:2660:gst_element_continue_state:<udpsink3> committing state from NULL to READY, pending PLAYING, next PAUSED
0:00:42.308578967 171 0x1245180 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed:<udpsink3> notifying about state-changed NULL to READY (PLAYING pending)
0:00:42.308586665 171 0x1245180 INFO GST_STATES gstelement.c:2668:gst_element_continue_state:<udpsink3> continue state change READY to PAUSED, final PLAYING
0:00:42.308595664 171 0x1245180 INFO GST_STATES gstelement.c:2660:gst_element_continue_state:<udpsink3> committing state from READY to PAUSED, pending PLAYING, next PLAYING
0:00:42.308603114 171 0x1245180 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed:<udpsink3> notifying about state-changed READY to PAUSED (PLAYING pending)
0:00:42.308609396 171 0x1245180 INFO GST_STATES gstelement.c:2668:gst_element_continue_state:<udpsink3> continue state change PAUSED to PLAYING, final PLAYING
0:00:42.308614878 171 0x1245180 INFO GST_STATES gstelement.c:2688:gst_element_continue_state:<udpsink3> completed state change to PLAYING
0:00:42.308620706 171 0x1245180 INFO GST_STATES gstelement.c:2588:_priv_gst_element_state_changed:<udpsink3> notifying about state-changed PAUSED to PLAYING (VOID_PENDING pending)
0:00:42.308632853 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:928:gst_element_get_static_pad: found pad udpsink3:sink
0:00:42.308640289 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:925:gst_element_get_static_pad: no such pad 'send_rtcp_src_1' in element "manager"
0:00:42.308647740 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:925:gst_element_get_static_pad: no such pad 'send_rtcp_src' in element "rtpsession1"
0:00:42.308662107 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:<rtpsession1> adding pad 'send_rtcp_src'
0:00:42.308680692 171 0x1245180 INFO GST_PADS gstpad.c:2377:gst_pad_link_prepare: trying to link rtpsession1:send_rtcp_src and send_rtcp_src_1:proxypad5
0:00:42.308688322 171 0x1245180 INFO GST_PADS gstpad.c:2585:gst_pad_link_full: linked rtpsession1:send_rtcp_src and send_rtcp_src_1:proxypad5, successful
0:00:42.308693445 171 0x1245180 INFO GST_EVENT gstevent.c:1579:gst_event_new_reconfigure: creating reconfigure event
0:00:42.308702838 171 0x1245180 INFO GST_ELEMENT_PADS gstelement.c:671:gst_element_add_pad:<manager> adding pad 'send_rtcp_src_1'
0:00:42.308713031 171 0x1245180 INFO GST_PADS gstpad.c:2377:gst_pad_link_prepare: trying to link manager:send_rtcp_src_1 and udpsink3:sink
0:00:42.308719855 171 0x1245180 INFO GST_PADS gstpad.c:2585:gst_pad_link_full: linked manager:send_rtcp_src_1 and udpsink3:sink, successful
0:00:42.308724776 171 0x1245180 INFO GST_EVENT gstevent.c:1579:gst_event_new_reconfigure: creating reconfigure event
