NvmsgBroker
NvmsgBroker not working in deepstreamtest-4
ERROR from element nvmsg-broker: Could not initialize supporting library.
Error details: gstnvmsgbroker.c(296): gst_nvmsgbroker_start (): /GstPipeline:dstest4-pipeline/GstNvMsgBroker:nvmsg-broker:
unable to open shared library
Returned, stopping playback
Deleting pipeline
could you help to set GST_DEBUG=4 and rerun the sample to get more details?
Also pls provide the DS version and platform which you used.
I have the same problem. Where do I set the GST_DEBUG?
Did you get your problem solved?
It seems it can’t find someone lib. Can you check which lib?
It seems like msgnvbroker is the lib
libnvdsgst_msgbroker.so is in
/usr/lib/aarch64-linux-gnu/gstreamer-1.0 or
/usr/lib/x86_64-linux-gnu/gstreamer-1.0
You can also build your own libnvdsgst_msgbroker.so in sources/gst-plugins/gst-nvmsgbroker
The command line is like this:
$ deepstream-test4-app -i -p --conn-str= -s <0/1>
Did you set “Proto adaptor library” ?
Yes, this works for me. Thank you Chris! I am now trying to add the whole frame data inside the meta data. Inside function “osd_sink_pad_buffer_probe”, the frame information is already in the format of metadata. Do you have any suggestions on how I can add the whole frame information into metadata?
Answered in [url]https://devtalk.nvidia.com/default/topic/1058327/deepstream-sdk/questions-regarding-test-application-4-/post/5368704/#5368704[/url]
Hi ChrisDing / qsu,
I am trying to run deepstream-test4-app using rabbitmq message broker. I have followed all the instructions in Readme and the advise given above. I have also ensured that I have a local RabbitMQ server running on localhost. However, I am not able to get the application to work.
Following is the error I am constantly getting:
Using winsys: x11
Running...
ERROR from element nvmsg-broker: Could not configure supporting library.
Error details: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvmsgbroker/gstnvmsgbroker.c(332): gst_nvmsgbroker_start (): /GstPipeline:dstest4-pipeline/GstNvMsgBroker:nvmsg-broker:
unable to connect to broker library
Deleting pipeline
I have not edited “cfg_amqp.txt”. It is as follows:
[message-broker]
password = guest
#optional
hostname = localhost
username = guest
port = 5672
exchange = amq.topic
topic = topicname
My command-line looks like the following:
./deepstream-test4-app -i /home/jetson/deepstream_sdk_v4.0_jetson/samples/streams/sample_720p.h264 -p /opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_amqp_proto.so --conn-str="localhost;5672;guest" -s 0
When I am trying out the basic send/receive tutorial from GitHub - rabbitmq/rabbitmq-tutorials: Tutorials for using RabbitMQ in various ways, it seems to work.
Kindly let me know where I am going wrong. Please help me out.
deepstream-test4-app -i ../../../../samples/streams/sample_720p.h264 -p /opt/nvidia/deepstream/deepstream-4.0/lib/libnvds_azure_proto.so -c cfg_azure.txt -s 0 --no-display
I am trying to run deepstream-test4 but it throws the below error:
0:00:00.000149927  1352      0x7414a00 INFO                GST_INIT gst.c:586:init_pre: Initializing GStreamer Core Library version 1.14.5
0:00:00.000295566  1352      0x7414a00 INFO                GST_INIT gst.c:587:init_pre: Using library installed in /usr/lib/aarch64-linux-gnu
0:00:00.000335184  1352      0x7414a00 INFO                GST_INIT gst.c:607:init_pre: Linux smc-test-agx02 4.9.140-tegra #1 SMP PREEMPT Mon Dec 9 22:52:02 PST 2019 aarch64
0:00:00.000940045  1352      0x7414a00 INFO                GST_INIT gstmessage.c:127:_priv_gst_message_initialize: init messages
0:00:00.001938812  1352      0x7414a00 INFO                GST_INIT gstcontext.c:84:_priv_gst_context_initialize: init contexts
0:00:00.002308302  1352      0x7414a00 INFO      GST_PLUGIN_LOADING gstplugin.c:317:_priv_gst_plugin_initialize: registering 0 static plugins
0:00:00.002489494  1352      0x7414a00 INFO      GST_PLUGIN_LOADING gstplugin.c:225:gst_plugin_register_static: registered static plugin "staticelements"
0:00:00.002514551  1352      0x7414a00 INFO      GST_PLUGIN_LOADING gstplugin.c:227:gst_plugin_register_static: added static plugin "staticelements", result: 1
0:00:00.002553561  1352      0x7414a00 INFO            GST_REGISTRY gstregistry.c:1727:ensure_current_registry: reading registry cache: /home/smartcow/.cache/gstreamer-1.0/registry.aarch64.bin
0:00:00.031309326  1352      0x7414a00 INFO            GST_REGISTRY gstregistrybinary.c:621:priv_gst_registry_binary_read_cache: loaded /home/smartcow/.cache/gstreamer-1.0/registry.aarch64.bin in 0.028706 seconds
0:00:00.031448244  1352      0x7414a00 INFO            GST_REGISTRY gstregistry.c:1583:scan_and_update_registry: Validating plugins from registry cache: /home/smartcow/.cache/gstreamer-1.0/registry.aarch64.bin
0:00:00.033864327  1352      0x7414a00 INFO            GST_REGISTRY gstregistry.c:1685:scan_and_update_registry: Registry cache has not changed
0:00:00.033903657  1352      0x7414a00 INFO            GST_REGISTRY gstregistry.c:1762:ensure_current_registry: registry reading and updating done, result = 1
0:00:00.033938603  1352      0x7414a00 INFO                GST_INIT gst.c:807:init_post: GLib runtime version: 2.56.4
0:00:00.033958092  1352      0x7414a00 INFO                GST_INIT gst.c:809:init_post: GLib headers version: 2.56.4
0:00:00.033971532  1352      0x7414a00 INFO                GST_INIT gst.c:810:init_post: initialized GStreamer successfully
0:00:00.034062641  1352      0x7414a00 INFO     GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element "pipeline" named "dstest4-pipeline"
0:00:00.035520342  1352      0x7414a00 INFO      GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstcoreelements.so" loaded
0:00:00.035579096  1352      0x7414a00 INFO     GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element "filesrc" named "file-source"
0:00:00.035849989  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseSrc@0x7658220> adding pad 'src'
0:00:00.038034893  1352      0x7414a00 INFO      GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstvideoparsersbad.so" loaded
0:00:00.038084239  1352      0x7414a00 INFO     GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element "h264parse" named "h264-parser"
0:00:00.038305562  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseParse@0x7668a60> adding pad 'sink'
0:00:00.038361181  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseParse@0x7668a60> adding pad 'src'
0:00:00.038419647  1352      0x7414a00 INFO               baseparse gstbaseparse.c:3961:gst_base_parse_set_pts_interpolation:<GstH264Parse@0x7668a60> PTS interpolation: no
0:00:00.061760147  1352      0x7414a00 INFO      GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvideo4linux2.so" loaded
0:00:00.061834999  1352      0x7414a00 INFO     GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element "nvv4l2decoder" named "nvv4l2-decoder"
0:00:00.062174663  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstVideoDecoder@0x76c00c0> adding pad 'sink'
0:00:00.062216361  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstVideoDecoder@0x76c00c0> adding pad 'src'
0:00:00.071738445  1352      0x7414a00 INFO      GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistream.so" loaded
0:00:00.071791919  1352      0x7414a00 INFO     GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element "nvstreammux" named "nvstreammux"
0:00:00.072230884  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstNvStreamMux@0x7716080> adding pad 'src'
0:00:00.115228092  1352      0x7414a00 INFO      GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_infer.so" loaded
0:00:00.115311200  1352      0x7414a00 INFO     GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element "nvinfer" named "primary-nvinference-engine"
0:00:00.115703795  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseTransform@0x7a4c5f0> adding pad 'sink'
0:00:00.115776726  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseTransform@0x7a4c5f0> adding pad 'src'
0:00:00.116872714  1352      0x7414a00 INFO      GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libgstnvvideoconvert.so" loaded
0:00:00.116927373  1352      0x7414a00 INFO     GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element "nvvideoconvert" named "nvvideo-converter"
0:00:00.117247132  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseTransform@0x7a529a0> adding pad 'sink'
0:00:00.117297471  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseTransform@0x7a529a0> adding pad 'src'
0:00:00.123272538  1352      0x7414a00 INFO      GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_osd.so" loaded
0:00:00.123373343  1352      0x7414a00 INFO     GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element "nvdsosd" named "nv-onscreendisplay"
0:00:00.123646988  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseTransform@0x7a6d7a0> adding pad 'sink'
0:00:00.123690382  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseTransform@0x7a6d7a0> adding pad 'src'
0:00:00.126659067  1352      0x7414a00 INFO      GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_msgconv.so" loaded
0:00:00.126710621  1352      0x7414a00 INFO     GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element "nvmsgconv" named "nvmsg-converter"
0:00:00.126972746  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseTransform@0x7ac8150> adding pad 'sink'
0:00:00.127015724  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseTransform@0x7ac8150> adding pad 'src'
0:00:00.127406334  1352      0x7414a00 INFO      GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_msgbroker.so" loaded
0:00:00.127454017  1352      0x7414a00 INFO     GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element "nvmsgbroker" named "nvmsg-broker"
0:00:00.127722285  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseSink@0x7acc9e0> adding pad 'sink'
0:00:00.127758511  1352      0x7414a00 INFO     GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element "tee" named "nvsink-tee"
0:00:00.127936696  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstTee@0x7ace000> adding pad 'sink'
0:00:00.127985626  1352      0x7414a00 INFO     GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element "queue" named "nvtee-que1"
0:00:00.128157186  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstQueue@0x7716380> adding pad 'sink'
0:00:00.128202180  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstQueue@0x7716380> adding pad 'src'
0:00:00.128258055  1352      0x7414a00 INFO     GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element "queue" named "nvtee-que2"
0:00:00.128324650  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstQueue@0x7716680> adding pad 'sink'
0:00:00.128396845  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstQueue@0x7716680> adding pad 'src'
0:00:00.128460912  1352      0x7414a00 INFO     GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element "fakesink" named "nvvideo-renderer"
0:00:00.128680059  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseSink@0x7ad61e0> adding pad 'sink'
0:00:00.128816257  1352      0x7414a00 INFO                 filesrc gstfilesrc.c:261:gst_file_src_set_location: filename : ../../../../samples/streams/sample_720p.h264
0:00:00.128835202  1352      0x7414a00 INFO                 filesrc gstfilesrc.c:262:gst_file_src_set_location: uri      : file:///opt/nvidia/deepstream/deepstream-4.0/samples/streams/sample_720p.h264
(deepstream-test4-app:1352): GLib-CRITICAL **: 10:53:47.538: g_strchug: assertion 'string != NULL' failed
(deepstream-test4-app:1352): GLib-CRITICAL **: 10:53:47.538: g_strchomp: assertion 'string != NULL' failed
0:00:00.130192451  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstelement.c:917:gst_element_get_static_pad: no such pad 'sink_0' in element "nvstreammux"
0:00:00.130270022  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<nvstreammux> adding pad 'sink_0'
0:00:00.130300168  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad nvv4l2-decoder:src
0:00:00.130330793  1352      0x7414a00 INFO                GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link nvv4l2-decoder:src and nvstreammux:sink_0
0:00:00.130370763  1352      0x7414a00 INFO                GST_PADS gstpad.c:4232:gst_pad_peer_query:<nvstreammux:src> pad has no peer
0:00:00.130463535  1352      0x7414a00 INFO                GST_PADS gstpad.c:2586:gst_pad_link_full: linked nvv4l2-decoder:src and nvstreammux:sink_0, successful
0:00:00.130484464  1352      0x7414a00 INFO               GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.130503345  1352      0x7414a00 INFO               GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<nvv4l2-decoder:src> Received event on flushing pad. Discarding
0:00:00.130537363  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element file-source:(any) to element h264-parser:(any)
0:00:00.130561300  1352      0x7414a00 INFO                GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link file-source:src and h264-parser:sink
0:00:00.130593078  1352      0x7414a00 INFO                GST_PADS gstpad.c:4232:gst_pad_peer_query:<h264-parser:src> pad has no peer
0:00:00.130623127  1352      0x7414a00 INFO                GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: file-source and h264-parser in same bin, no need for ghost pads
0:00:00.130648280  1352      0x7414a00 INFO                GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link file-source:src and h264-parser:sink
0:00:00.130670777  1352      0x7414a00 INFO                GST_PADS gstpad.c:4232:gst_pad_peer_query:<h264-parser:src> pad has no peer
0:00:00.130696667  1352      0x7414a00 INFO                GST_PADS gstpad.c:2586:gst_pad_link_full: linked file-source:src and h264-parser:sink, successful
0:00:00.130711899  1352      0x7414a00 INFO               GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.130727580  1352      0x7414a00 INFO               GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<file-source:src> Received event on flushing pad. Discarding
0:00:00.130760478  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element h264-parser:(any) to element nvv4l2-decoder:(any)
0:00:00.130801728  1352      0x7414a00 INFO                GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link h264-parser:src and nvv4l2-decoder:sink
0:00:00.130851458  1352      0x7414a00 INFO                GST_PADS gstpad.c:4232:gst_pad_peer_query:<nvstreammux:src> pad has no peer
0:00:00.131136399  1352      0x7414a00 INFO                GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: h264-parser and nvv4l2-decoder in same bin, no need for ghost pads
0:00:00.131167185  1352      0x7414a00 INFO                GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link h264-parser:src and nvv4l2-decoder:sink
0:00:00.131194642  1352      0x7414a00 INFO                GST_PADS gstpad.c:4232:gst_pad_peer_query:<nvstreammux:src> pad has no peer
0:00:00.131350714  1352      0x7414a00 INFO                GST_PADS gstpad.c:2586:gst_pad_link_full: linked h264-parser:src and nvv4l2-decoder:sink, successful
0:00:00.131368474  1352      0x7414a00 INFO               GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.131385915  1352      0x7414a00 INFO               GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<h264-parser:src> Received event on flushing pad. Discarding
0:00:00.131411452  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element nvstreammux:(any) to element primary-nvinference-engine:(any)
0:00:00.131433918  1352      0x7414a00 INFO                GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link nvstreammux:src and primary-nvinference-engine:sink
0:00:00.131466431  1352      0x7414a00 INFO                GST_PADS gstpad.c:4232:gst_pad_peer_query:<primary-nvinference-engine:src> pad has no peer
0:00:00.131547011  1352      0x7414a00 INFO                GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: nvstreammux and primary-nvinference-engine in same bin, no need for ghost pads
0:00:00.131572804  1352      0x7414a00 INFO                GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link nvstreammux:src and primary-nvinference-engine:sink
0:00:00.131595749  1352      0x7414a00 INFO                GST_PADS gstpad.c:4232:gst_pad_peer_query:<primary-nvinference-engine:src> pad has no peer
0:00:00.131639879  1352      0x7414a00 INFO                GST_PADS gstpad.c:2586:gst_pad_link_full: linked nvstreammux:src and primary-nvinference-engine:sink, successful
0:00:00.131656104  1352      0x7414a00 INFO               GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.131668905  1352      0x7414a00 INFO               GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<nvstreammux:src> Received event on flushing pad. Discarding
0:00:00.131693162  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element primary-nvinference-engine:(any) to element nvvideo-converter:(any)
0:00:00.131714027  1352      0x7414a00 INFO                GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link primary-nvinference-engine:src and nvvideo-converter:sink
0:00:00.131766605  1352      0x7414a00 INFO                GST_PADS gstpad.c:4232:gst_pad_peer_query:<nvvideo-converter:src> pad has no peer
0:00:00.131946934  1352      0x7414a00 INFO                GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: primary-nvinference-engine and nvvideo-converter in same bin, no need for ghost pads
0:00:00.131998072  1352      0x7414a00 INFO                GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link primary-nvinference-engine:src and nvvideo-converter:sink
0:00:00.132094653  1352      0x7414a00 INFO                GST_PADS gstpad.c:4232:gst_pad_peer_query:<nvvideo-converter:src> pad has no peer
0:00:00.132201410  1352      0x7414a00 INFO                GST_PADS gstpad.c:2586:gst_pad_link_full: linked primary-nvinference-engine:src and nvvideo-converter:sink, successful
0:00:00.132218531  1352      0x7414a00 INFO               GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.132235204  1352      0x7414a00 INFO               GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<primary-nvinference-engine:src> Received event on flushing pad. Discarding
0:00:00.132260645  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element nvvideo-converter:(any) to element nv-onscreendisplay:(any)
0:00:00.132282534  1352      0x7414a00 INFO                GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link nvvideo-converter:src and nv-onscreendisplay:sink
0:00:00.132389067  1352      0x7414a00 INFO                GST_PADS gstpad.c:4232:gst_pad_peer_query:<nv-onscreendisplay:src> pad has no peer
0:00:00.132432941  1352      0x7414a00 INFO                GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: nvvideo-converter and nv-onscreendisplay in same bin, no need for ghost pads
0:00:00.132458318  1352      0x7414a00 INFO                GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link nvvideo-converter:src and nv-onscreendisplay:sink
0:00:00.132560339  1352      0x7414a00 INFO                GST_PADS gstpad.c:4232:gst_pad_peer_query:<nv-onscreendisplay:src> pad has no peer
0:00:00.132602485  1352      0x7414a00 INFO                GST_PADS gstpad.c:2586:gst_pad_link_full: linked nvvideo-converter:src and nv-onscreendisplay:sink, successful
0:00:00.132618582  1352      0x7414a00 INFO               GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.132634326  1352      0x7414a00 INFO               GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<nvvideo-converter:src> Received event on flushing pad. Discarding
0:00:00.132658328  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element nv-onscreendisplay:(any) to element nvsink-tee:(any)
0:00:00.132679417  1352      0x7414a00 INFO                GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link nv-onscreendisplay:src and nvsink-tee:sink
0:00:00.132821471  1352      0x7414a00 INFO                GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: nv-onscreendisplay and nvsink-tee in same bin, no need for ghost pads
0:00:00.132845120  1352      0x7414a00 INFO                GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link nv-onscreendisplay:src and nvsink-tee:sink
0:00:00.133019945  1352      0x7414a00 INFO                GST_PADS gstpad.c:2586:gst_pad_link_full: linked nv-onscreendisplay:src and nvsink-tee:sink, successful
0:00:00.133038986  1352      0x7414a00 INFO               GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.133056267  1352      0x7414a00 INFO               GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<nv-onscreendisplay:src> Received event on flushing pad. Discarding
0:00:00.133081996  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element nvtee-que1:(any) to element nvmsg-converter:(any)
0:00:00.133109485  1352      0x7414a00 INFO                GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link nvtee-que1:src and nvmsg-converter:sink
0:00:00.133132878  1352      0x7414a00 INFO                GST_PADS gstpad.c:4232:gst_pad_peer_query:<nvtee-que1:sink> pad has no peer
0:00:00.133157359  1352      0x7414a00 INFO                GST_PADS gstpad.c:4232:gst_pad_peer_query:<nvmsg-converter:src> pad has no peer
0:00:00.133185905  1352      0x7414a00 INFO                GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: nvtee-que1 and nvmsg-converter in same bin, no need for ghost pads
0:00:00.133208562  1352      0x7414a00 INFO                GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link nvtee-que1:src and nvmsg-converter:sink
0:00:00.133228307  1352      0x7414a00 INFO                GST_PADS gstpad.c:4232:gst_pad_peer_query:<nvtee-que1:sink> pad has no peer
0:00:00.133255316  1352      0x7414a00 INFO                GST_PADS gstpad.c:4232:gst_pad_peer_query:<nvmsg-converter:src> pad has no peer
0:00:00.133279669  1352      0x7414a00 INFO                GST_PADS gstpad.c:2586:gst_pad_link_full: linked nvtee-que1:src and nvmsg-converter:sink, successful
0:00:00.133294998  1352      0x7414a00 INFO               GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.133310455  1352      0x7414a00 INFO               GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<nvtee-que1:src> Received event on flushing pad. Discarding
0:00:00.133347640  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element nvmsg-converter:(any) to element nvmsg-broker:(any)
0:00:00.133369977  1352      0x7414a00 INFO                GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link nvmsg-converter:src and nvmsg-broker:sink
0:00:00.133391066  1352      0x7414a00 INFO                GST_PADS gstpad.c:4232:gst_pad_peer_query:<nvtee-que1:sink> pad has no peer
0:00:00.133423164  1352      0x7414a00 INFO                GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: nvmsg-converter and nvmsg-broker in same bin, no need for ghost pads
0:00:00.133446141  1352      0x7414a00 INFO                GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link nvmsg-converter:src and nvmsg-broker:sink
0:00:00.133467518  1352      0x7414a00 INFO                GST_PADS gstpad.c:4232:gst_pad_peer_query:<nvtee-que1:sink> pad has no peer
0:00:00.133497375  1352      0x7414a00 INFO                GST_PADS gstpad.c:2586:gst_pad_link_full: linked nvmsg-converter:src and nvmsg-broker:sink, successful
0:00:00.133513280  1352      0x7414a00 INFO               GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.133528577  1352      0x7414a00 INFO               GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<nvmsg-converter:src> Received event on flushing pad. Discarding
0:00:00.133554594  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element nvtee-que2:(any) to element nvvideo-renderer:(any)
0:00:00.133575843  1352      0x7414a00 INFO                GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link nvtee-que2:src and nvvideo-renderer:sink
0:00:00.133595588  1352      0x7414a00 INFO                GST_PADS gstpad.c:4232:gst_pad_peer_query:<nvtee-que2:sink> pad has no peer
0:00:00.133622149  1352      0x7414a00 INFO                GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: nvtee-que2 and nvvideo-renderer in same bin, no need for ghost pads
0:00:00.133644582  1352      0x7414a00 INFO                GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link nvtee-que2:src and nvvideo-renderer:sink
0:00:00.133664167  1352      0x7414a00 INFO                GST_PADS gstpad.c:4232:gst_pad_peer_query:<nvtee-que2:sink> pad has no peer
0:00:00.133690857  1352      0x7414a00 INFO                GST_PADS gstpad.c:2586:gst_pad_link_full: linked nvtee-que2:src and nvvideo-renderer:sink, successful
0:00:00.133703561  1352      0x7414a00 INFO               GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.133719082  1352      0x7414a00 INFO               GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<nvtee-que2:src> Received event on flushing pad. Discarding
0:00:00.133741739  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad nvtee-que1:sink
0:00:00.133829551  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<nvsink-tee> adding pad 'src_0'
0:00:00.133871377  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<nvsink-tee> adding pad 'src_1'
0:00:00.133897458  1352      0x7414a00 INFO                GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link nvsink-tee:src_0 and nvtee-que1:sink
0:00:00.134099612  1352      0x7414a00 INFO                GST_PADS gstpad.c:2586:gst_pad_link_full: linked nvsink-tee:src_0 and nvtee-que1:sink, successful
0:00:00.134117629  1352      0x7414a00 INFO               GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.134130974  1352      0x7414a00 INFO               GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<nvsink-tee:src_0> Received event on flushing pad. Discarding
0:00:00.134172575  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad nvtee-que2:sink
0:00:00.134197697  1352      0x7414a00 INFO                GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link nvsink-tee:src_1 and nvtee-que2:sink
0:00:00.134377129  1352      0x7414a00 INFO                GST_PADS gstpad.c:2586:gst_pad_link_full: linked nvsink-tee:src_1 and nvtee-que2:sink, successful
0:00:00.134396010  1352      0x7414a00 INFO               GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.134413355  1352      0x7414a00 INFO               GST_EVENT gstpad.c:5808:gst_pad_send_event_unchecked:<nvsink-tee:src_1> Received event on flushing pad. Discarding
0:00:00.134437836  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad nv-onscreendisplay:sink
Now playing: ../../../../samples/streams/sample_720p.h264
0:00:00.134558514  1352      0x7414a00 INFO              GST_STATES gstbin.c:2506:gst_bin_element_set_state:<nvvideo-renderer> current NULL pending VOID_PENDING, desired next READY
0:00:00.134582579  1352      0x7414a00 INFO              GST_STATES gstelement.c:2676:gst_element_continue_state:<nvvideo-renderer> completed state change to READY
0:00:00.134601748  1352      0x7414a00 INFO              GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<nvvideo-renderer> notifying about state-changed NULL to READY (VOID_PENDING pending)
0:00:00.134648758  1352      0x7414a00 INFO              GST_STATES gstbin.c:2954:gst_bin_change_state_func:<dstest4-pipeline> child 'nvvideo-renderer' changed state to 2(READY) successfully
0:00:00.134672567  1352      0x7414a00 INFO              GST_STATES gstbin.c:2506:gst_bin_element_set_state:<nvmsg-broker> current NULL pending VOID_PENDING, desired next READY
(deepstream-test4-app:1352): GLib-CRITICAL **: 10:53:47.543: g_strrstr: assertion 'haystack != NULL' failed
0:00:00.139292114  1352      0x7414a00 WARN             nvmsgbroker gstnvmsgbroker.c:303:gst_nvmsgbroker_start:<nvmsg-broker> error: unable to open shared library
0:00:00.139358614  1352      0x7414a00 INFO        GST_ERROR_SYSTEM gstelement.c:2145:gst_element_message_full_with_details:<nvmsg-broker> posting message: Could not initialize supporting library.
0:00:00.139417080  1352      0x7414a00 INFO        GST_ERROR_SYSTEM gstelement.c:2172:gst_element_message_full_with_details:<nvmsg-broker> posted error message: Could not initialize supporting library.
0:00:00.139468443  1352      0x7414a00 WARN                basesink gstbasesink.c:5265:gst_base_sink_change_state:<nvmsg-broker> error: Failed to start
0:00:00.139514845  1352      0x7414a00 INFO        GST_ERROR_SYSTEM gstelement.c:2145:gst_element_message_full_with_details:<nvmsg-broker> posting message: GStreamer error: state change failed and some element failed to post a proper error message with the reason for the failure.
0:00:00.139543870  1352      0x7414a00 INFO        GST_ERROR_SYSTEM gstelement.c:2172:gst_element_message_full_with_details:<nvmsg-broker> posted error message: GStreamer error: state change failed and some element failed to post a proper error message with the reason for the failure.
0:00:00.139586368  1352      0x7414a00 INFO              GST_STATES gstelement.c:2961:gst_element_change_state:<nvmsg-broker> have FAILURE change_state return
0:00:00.139605793  1352      0x7414a00 INFO              GST_STATES gstelement.c:2549:gst_element_abort_state:<nvmsg-broker> aborting state from NULL to READY
0:00:00.139648387  1352      0x7414a00 INFO              GST_STATES gstbin.c:2970:gst_bin_change_state_func:<dstest4-pipeline> child 'nvmsg-broker' failed to go to state 2(READY)
0:00:00.139740648  1352      0x7414a00 INFO              GST_STATES gstelement.c:2676:gst_element_continue_state:<nvvideo-renderer> completed state change to NULL
0:00:00.139761865  1352      0x7414a00 INFO              GST_STATES gstelement.c:2579:_priv_gst_element_state_changed:<nvvideo-renderer> notifying about state-changed READY to NULL (VOID_PENDING pending)
0:00:00.139791530  1352      0x7414a00 INFO              GST_STATES gstelement.c:2676:gst_element_continue_state:<nvmsg-broker> completed state change to NULL
0:00:00.139819915  1352      0x7414a00 INFO              GST_STATES gstelement.c:2676:gst_element_continue_state:<nvtee-que2> completed state change to NULL
0:00:00.139841869  1352      0x7414a00 INFO              GST_STATES gstelement.c:2676:gst_element_continue_state:<nvmsg-converter> completed state change to NULL
0:00:00.139864110  1352      0x7414a00 INFO              GST_STATES gstelement.c:2676:gst_element_continue_state:<nvtee-que1> completed state change to NULL
0:00:00.139885871  1352      0x7414a00 INFO              GST_STATES gstelement.c:2676:gst_element_continue_state:<nvsink-tee> completed state change to NULL
0:00:00.139950546  1352      0x7414a00 INFO              GST_STATES gstelement.c:2676:gst_element_continue_state:<nv-onscreendisplay> completed state change to NULL
0:00:00.139976979  1352      0x7414a00 INFO              GST_STATES gstelement.c:2676:gst_element_continue_state:<nvvideo-converter> completed state change to NULL
0:00:00.139999604  1352      0x7414a00 INFO              GST_STATES gstelement.c:2676:gst_element_continue_state:<primary-nvinference-engine> completed state change to NULL
0:00:00.140476107  1352      0x7414a00 INFO              GST_STATES gstelement.c:2676:gst_element_continue_state:<nvstreammux> completed state change to NULL
0:00:00.140511820  1352      0x7414a00 INFO              GST_STATES gstelement.c:2676:gst_element_continue_state:<nvv4l2-decoder> completed state change to NULL
0:00:00.140536846  1352      0x7414a00 INFO              GST_STATES gstelement.c:2676:gst_element_continue_state:<h264-parser> completed state change to NULL
0:00:00.140559695  1352      0x7414a00 INFO              GST_STATES gstelement.c:2676:gst_element_continue_state:<file-source> completed state change to NULL
0:00:00.140588432  1352      0x7414a00 INFO              GST_STATES gstelement.c:2961:gst_element_change_state:<dstest4-pipeline> have FAILURE change_state return
Running...
Error details: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvmsgbroker/gstnvmsgbroker.c(303): gst_nvmsgbroker_start (): /GstPipeline:dstest4-pipeline/GstNvMsgBroker:nvmsg-broker:
0:00:00.140736663  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad:<nvsink-tee> removing pad 'src_0'
0:00:00.140757560  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstpad.c:2134:gst_pad_unlink: unlinking nvsink-tee:src_0(0x7ae80c0) and nvtee-que1:sink(0x7aca760)
0:00:00.140796890  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstpad.c:2188:gst_pad_unlink: unlinked nvsink-tee:src_0 and nvtee-que1:sink
0:00:00.140834108  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad:<nvsink-tee> removing pad 'src_1'
0:00:00.140855517  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstpad.c:2134:gst_pad_unlink: unlinking nvsink-tee:src_1(0x7ae8320) and nvtee-que2:sink(0x7acac00)
0:00:00.140879230  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstpad.c:2188:gst_pad_unlink: unlinked nvsink-tee:src_1 and nvtee-que2:sink
0:00:00.140950305  1352      0x7414a00 INFO              GST_STATES gstbin.c:2506:gst_bin_element_set_state:<nvvideo-renderer> current NULL pending VOID_PENDING, desired next NULL
0:00:00.140974914  1352      0x7414a00 INFO              GST_STATES gstbin.c:2623:gst_bin_element_set_state:<nvvideo-renderer> skipping transition from NULL to  NULL
0:00:00.140993699  1352      0x7414a00 INFO              GST_STATES gstbin.c:2954:gst_bin_change_state_func:<dstest4-pipeline> child 'nvvideo-renderer' changed state to 1(NULL) successfully
0:00:00.141014788  1352      0x7414a00 INFO              GST_STATES gstbin.c:2506:gst_bin_element_set_state:<nvmsg-broker> current NULL pending VOID_PENDING, desired next NULL
0:00:00.141037925  1352      0x7414a00 INFO              GST_STATES gstbin.c:2623:gst_bin_element_set_state:<nvmsg-broker> skipping transition from NULL to  NULL
0:00:00.141059686  1352      0x7414a00 INFO              GST_STATES gstbin.c:2954:gst_bin_change_state_func:<dstest4-pipeline> child 'nvmsg-broker' changed state to 1(NULL) successfully
0:00:00.141080295  1352      0x7414a00 INFO              GST_STATES gstbin.c:2506:gst_bin_element_set_state:<nvtee-que2> current NULL pending VOID_PENDING, desired next NULL
0:00:00.141093832  1352      0x7414a00 INFO              GST_STATES gstbin.c:2623:gst_bin_element_set_state:<nvtee-que2> skipping transition from NULL to  NULL
0:00:00.141110281  1352      0x7414a00 INFO              GST_STATES gstbin.c:2954:gst_bin_change_state_func:<dstest4-pipeline> child 'nvtee-que2' changed state to 1(NULL) successfully
0:00:00.141130378  1352      0x7414a00 INFO              GST_STATES gstbin.c:2506:gst_bin_element_set_state:<nvmsg-converter> current NULL pending VOID_PENDING, desired next NULL
0:00:00.141146698  1352      0x7414a00 INFO              GST_STATES gstbin.c:2623:gst_bin_element_set_state:<nvmsg-converter> skipping transition from NULL to  NULL
0:00:00.141160907  1352      0x7414a00 INFO              GST_STATES gstbin.c:2954:gst_bin_change_state_func:<dstest4-pipeline> child 'nvmsg-converter' changed state to 1(NULL) successfully
0:00:00.141179372  1352      0x7414a00 INFO              GST_STATES gstbin.c:2506:gst_bin_element_set_state:<nvtee-que1> current NULL pending VOID_PENDING, desired next NULL
0:00:00.141195917  1352      0x7414a00 INFO              GST_STATES gstbin.c:2623:gst_bin_element_set_state:<nvtee-que1> skipping transition from NULL to  NULL
0:00:00.141217870  1352      0x7414a00 INFO              GST_STATES gstbin.c:2954:gst_bin_change_state_func:<dstest4-pipeline> child 'nvtee-que1' changed state to 1(NULL) successfully
0:00:00.141239855  1352      0x7414a00 INFO              GST_STATES gstbin.c:2506:gst_bin_element_set_state:<nvsink-tee> current NULL pending VOID_PENDING, desired next NULL
0:00:00.141261584  1352      0x7414a00 INFO              GST_STATES gstbin.c:2623:gst_bin_element_set_state:<nvsink-tee> skipping transition from NULL to  NULL
0:00:00.141284113  1352      0x7414a00 INFO              GST_STATES gstbin.c:2954:gst_bin_change_state_func:<dstest4-pipeline> child 'nvsink-tee' changed state to 1(NULL) successfully
0:00:00.141328179  1352      0x7414a00 INFO              GST_STATES gstbin.c:2506:gst_bin_element_set_state:<nv-onscreendisplay> current NULL pending VOID_PENDING, desired next NULL
0:00:00.141350164  1352      0x7414a00 INFO              GST_STATES gstbin.c:2623:gst_bin_element_set_state:<nv-onscreendisplay> skipping transition from NULL to  NULL
0:00:00.141366709  1352      0x7414a00 INFO              GST_STATES gstbin.c:2954:gst_bin_change_state_func:<dstest4-pipeline> child 'nv-onscreendisplay' changed state to 1(NULL) successfully
0:00:00.141437368  1352      0x7414a00 INFO              GST_STATES gstbin.c:2506:gst_bin_element_set_state:<nvvideo-converter> current NULL pending VOID_PENDING, desired next NULL
0:00:00.141455801  1352      0x7414a00 INFO              GST_STATES gstbin.c:2623:gst_bin_element_set_state:<nvvideo-converter> skipping transition from NULL to  NULL
0:00:00.141497051  1352      0x7414a00 INFO              GST_STATES gstbin.c:2954:gst_bin_change_state_func:<dstest4-pipeline> child 'nvvideo-converter' changed state to 1(NULL) successfully
0:00:00.141534653  1352      0x7414a00 INFO              GST_STATES gstbin.c:2506:gst_bin_element_set_state:<primary-nvinference-engine> current NULL pending VOID_PENDING, desired next NULL
0:00:00.141570079  1352      0x7414a00 INFO              GST_STATES gstbin.c:2623:gst_bin_element_set_state:<primary-nvinference-engine> skipping transition from NULL to  NULL
0:00:00.141602560  1352      0x7414a00 INFO              GST_STATES gstbin.c:2954:gst_bin_change_state_func:<dstest4-pipeline> child 'primary-nvinference-engine' changed state to 1(NULL) successfully
0:00:00.141642882  1352      0x7414a00 INFO              GST_STATES gstbin.c:2506:gst_bin_element_set_state:<nvstreammux> current NULL pending VOID_PENDING, desired next NULL
0:00:00.141679044  1352      0x7414a00 INFO              GST_STATES gstbin.c:2623:gst_bin_element_set_state:<nvstreammux> skipping transition from NULL to  NULL
0:00:00.141716549  1352      0x7414a00 INFO              GST_STATES gstbin.c:2954:gst_bin_change_state_func:<dstest4-pipeline> child 'nvstreammux' changed state to 1(NULL) successfully
0:00:00.141764264  1352      0x7414a00 INFO              GST_STATES gstbin.c:2506:gst_bin_element_set_state:<nvv4l2-decoder> current NULL pending VOID_PENDING, desired next NULL
0:00:00.141784553  1352      0x7414a00 INFO              GST_STATES gstbin.c:2623:gst_bin_element_set_state:<nvv4l2-decoder> skipping transition from NULL to  NULL
0:00:00.141849868  1352      0x7414a00 INFO              GST_STATES gstbin.c:2954:gst_bin_change_state_func:<dstest4-pipeline> child 'nvv4l2-decoder' changed state to 1(NULL) successfully
0:00:00.141890318  1352      0x7414a00 INFO              GST_STATES gstbin.c:2506:gst_bin_element_set_state:<h264-parser> current NULL pending VOID_PENDING, desired next NULL
0:00:00.141914543  1352      0x7414a00 INFO              GST_STATES gstbin.c:2623:gst_bin_element_set_state:<h264-parser> skipping transition from NULL to  NULL
0:00:00.141933808  1352      0x7414a00 INFO              GST_STATES gstbin.c:2954:gst_bin_change_state_func:<dstest4-pipeline> child 'h264-parser' changed state to 1(NULL) successfully
0:00:00.141954097  1352      0x7414a00 INFO              GST_STATES gstbin.c:2506:gst_bin_element_set_state:<file-source> current NULL pending VOID_PENDING, desired next NULL
0:00:00.141970898  1352      0x7414a00 INFO              GST_STATES gstbin.c:2623:gst_bin_element_set_state:<file-source> skipping transition from NULL to  NULL
0:00:00.141985042  1352      0x7414a00 INFO              GST_STATES gstbin.c:2954:gst_bin_change_state_func:<dstest4-pipeline> child 'file-source' changed state to 1(NULL) successfully
0:00:00.142006579  1352      0x7414a00 INFO              GST_STATES gstelement.c:2676:gst_element_continue_state:<dstest4-pipeline> completed state change to NULL
Deleting pipeline
0:00:00.142058198  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstpad.c:2134:gst_pad_unlink: unlinking nvtee-que2:src(0x7acae50) and nvvideo-renderer:sink(0x7acb0a0)
0:00:00.142085175  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstpad.c:2188:gst_pad_unlink: unlinked nvtee-que2:src and nvvideo-renderer:sink
0:00:00.142119449  1352      0x7414a00 INFO           GST_PARENTAGE gstbin.c:1801:gst_bin_remove_func:<dstest4-pipeline> removed child "nvvideo-renderer"
0:00:00.142165819  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstpad.c:2134:gst_pad_unlink: unlinking nvmsg-converter:src(0x7aca070) and nvmsg-broker:sink(0x7aca2c0)
0:00:00.142189980  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstpad.c:2188:gst_pad_unlink: unlinked nvmsg-converter:src and nvmsg-broker:sink
0:00:00.142214333  1352      0x7414a00 INFO           GST_PARENTAGE gstbin.c:1801:gst_bin_remove_func:<dstest4-pipeline> removed child "nvmsg-broker"
0:00:00.142247135  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstpad.c:2134:gst_pad_unlink: unlinking nvtee-que1:src(0x7aca9b0) and nvmsg-converter:sink(0x765bd40)
0:00:00.142270080  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstpad.c:2188:gst_pad_unlink: unlinked nvtee-que1:src and nvmsg-converter:sink
0:00:00.142294593  1352      0x7414a00 INFO           GST_PARENTAGE gstbin.c:1801:gst_bin_remove_func:<dstest4-pipeline> removed child "nvmsg-converter"
0:00:00.142319714  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3251:gst_element_dispose:<nvmsg-converter> 0x7ac8150 dispose
0:00:00.142349732  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad:<nvmsg-converter> removing pad 'sink'
0:00:00.142375685  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad:<nvmsg-converter> removing pad 'src'
0:00:00.142419047  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3297:gst_element_dispose:<nvmsg-converter> 0x7ac8150 parent class dispose
0:00:00.142457225  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3328:gst_element_finalize:<nvmsg-converter> 0x7ac8150 finalize
0:00:00.142475338  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3334:gst_element_finalize:<nvmsg-converter> 0x7ac8150 finalize parent
0:00:00.142534668  1352      0x7414a00 INFO           GST_PARENTAGE gstbin.c:1801:gst_bin_remove_func:<dstest4-pipeline> removed child "nvtee-que2"
0:00:00.142571374  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3251:gst_element_dispose:<nvtee-que2> 0x7716680 dispose
0:00:00.142588783  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad:<nvtee-que2> removing pad 'sink'
0:00:00.142610928  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad:<nvtee-que2> removing pad 'src'
0:00:00.142633073  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3297:gst_element_dispose:<nvtee-que2> 0x7716680 parent class dispose
0:00:00.142653042  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3328:gst_element_finalize:<nvtee-que2> 0x7716680 finalize
0:00:00.142669395  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3334:gst_element_finalize:<nvtee-que2> 0x7716680 finalize parent
0:00:00.142690292  1352      0x7414a00 INFO           GST_PARENTAGE gstbin.c:1801:gst_bin_remove_func:<dstest4-pipeline> removed child "nvtee-que1"
0:00:00.142713269  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3251:gst_element_dispose:<nvtee-que1> 0x7716380 dispose
0:00:00.142729686  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad:<nvtee-que1> removing pad 'sink'
0:00:00.142750519  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad:<nvtee-que1> removing pad 'src'
0:00:00.142771928  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3297:gst_element_dispose:<nvtee-que1> 0x7716380 parent class dispose
0:00:00.142790104  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3328:gst_element_finalize:<nvtee-que1> 0x7716380 finalize
0:00:00.142806073  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3334:gst_element_finalize:<nvtee-que1> 0x7716380 finalize parent
0:00:00.142829498  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstpad.c:2134:gst_pad_unlink: unlinking nv-onscreendisplay:src(0x765baf0) and nvsink-tee:sink(0x7aca510)
0:00:00.142853947  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstpad.c:2188:gst_pad_unlink: unlinked nv-onscreendisplay:src and nvsink-tee:sink
0:00:00.142877949  1352      0x7414a00 INFO           GST_PARENTAGE gstbin.c:1801:gst_bin_remove_func:<dstest4-pipeline> removed child "nvsink-tee"
0:00:00.142902462  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3251:gst_element_dispose:<nvsink-tee> 0x7ace000 dispose
0:00:00.142919583  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad:<nvsink-tee> removing pad 'sink'
0:00:00.142947616  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3297:gst_element_dispose:<nvsink-tee> 0x7ace000 parent class dispose
0:00:00.142967041  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3328:gst_element_finalize:<nvsink-tee> 0x7ace000 finalize
0:00:00.142983554  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3334:gst_element_finalize:<nvsink-tee> 0x7ace000 finalize parent
0:00:00.143008387  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstpad.c:2134:gst_pad_unlink: unlinking nvvideo-converter:src(0x765b650) and nv-onscreendisplay:sink(0x765b8a0)
0:00:00.143032516  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstpad.c:2188:gst_pad_unlink: unlinked nvvideo-converter:src and nv-onscreendisplay:sink
0:00:00.143059045  1352      0x7414a00 INFO           GST_PARENTAGE gstbin.c:1801:gst_bin_remove_func:<dstest4-pipeline> removed child "nv-onscreendisplay"
0:00:00.143100999  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3251:gst_element_dispose:<nv-onscreendisplay> 0x7a6d7a0 dispose
0:00:00.143120552  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad:<nv-onscreendisplay> removing pad 'sink'
0:00:00.143145609  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad:<nv-onscreendisplay> removing pad 'src'
0:00:00.143168458  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3297:gst_element_dispose:<nv-onscreendisplay> 0x7a6d7a0 parent class dispose
0:00:00.143191339  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3328:gst_element_finalize:<nv-onscreendisplay> 0x7a6d7a0 finalize
0:00:00.143207340  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3334:gst_element_finalize:<nv-onscreendisplay> 0x7a6d7a0 finalize parent
0:00:00.143232397  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstpad.c:2134:gst_pad_unlink: unlinking primary-nvinference-engine:src(0x765b1b0) and nvvideo-converter:sink(0x765b400)
0:00:00.143256175  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstpad.c:2188:gst_pad_unlink: unlinked primary-nvinference-engine:src and nvvideo-converter:sink
0:00:00.143280944  1352      0x7414a00 INFO           GST_PARENTAGE gstbin.c:1801:gst_bin_remove_func:<dstest4-pipeline> removed child "nvvideo-converter"
0:00:00.143304913  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3251:gst_element_dispose:<nvvideo-converter> 0x7a529a0 dispose
0:00:00.143320402  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad:<nvvideo-converter> removing pad 'sink'
0:00:00.143339763  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad:<nvvideo-converter> removing pad 'src'
0:00:00.143359763  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3297:gst_element_dispose:<nvvideo-converter> 0x7a529a0 parent class dispose
0:00:00.143377748  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3328:gst_element_finalize:<nvvideo-converter> 0x7a529a0 finalize
0:00:00.143393141  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3334:gst_element_finalize:<nvvideo-converter> 0x7a529a0 finalize parent
0:00:00.143442679  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstpad.c:2134:gst_pad_unlink: unlinking nvstreammux:src(0x765ad10) and primary-nvinference-engine:sink(0x765af60)
0:00:00.143485689  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstpad.c:2188:gst_pad_unlink: unlinked nvstreammux:src and primary-nvinference-engine:sink
0:00:00.143513339  1352      0x7414a00 INFO           GST_PARENTAGE gstbin.c:1801:gst_bin_remove_func:<dstest4-pipeline> removed child "primary-nvinference-engine"
0:00:00.143540636  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3251:gst_element_dispose:<primary-nvinference-engine> 0x7a4c5f0 dispose
0:00:00.143579390  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad:<primary-nvinference-engine> removing pad 'sink'
0:00:00.143619360  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad:<primary-nvinference-engine> removing pad 'src'
0:00:00.143661026  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3297:gst_element_dispose:<primary-nvinference-engine> 0x7a4c5f0 parent class dispose
0:00:00.143700804  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3328:gst_element_finalize:<primary-nvinference-engine> 0x7a4c5f0 finalize
0:00:00.143718341  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3334:gst_element_finalize:<primary-nvinference-engine> 0x7a4c5f0 finalize parent
0:00:00.143745734  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstpad.c:2134:gst_pad_unlink: unlinking nvv4l2-decoder:src(0x765aac0) and nvstreammux:sink_0(0x7acb2f0)
0:00:00.143771143  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstpad.c:2188:gst_pad_unlink: unlinked nvv4l2-decoder:src and nvstreammux:sink_0
0:00:00.143794792  1352      0x7414a00 INFO           GST_PARENTAGE gstbin.c:1801:gst_bin_remove_func:<dstest4-pipeline> removed child "nvstreammux"
0:00:00.143817993  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3251:gst_element_dispose:<nvstreammux> 0x7716080 dispose
0:00:00.143844811  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad:<nvstreammux> removing pad 'sink_0'
0:00:00.144039188  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad:<nvstreammux> removing pad 'src'
0:00:00.144075253  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3297:gst_element_dispose:<nvstreammux> 0x7716080 parent class dispose
0:00:00.144093110  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3328:gst_element_finalize:<nvstreammux> 0x7716080 finalize
0:00:00.144108759  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3334:gst_element_finalize:<nvstreammux> 0x7716080 finalize parent
0:00:00.144132344  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstpad.c:2134:gst_pad_unlink: unlinking h264-parser:src(0x765a620) and nvv4l2-decoder:sink(0x765a870)
0:00:00.144155961  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstpad.c:2188:gst_pad_unlink: unlinked h264-parser:src and nvv4l2-decoder:sink
0:00:00.144180666  1352      0x7414a00 INFO           GST_PARENTAGE gstbin.c:1801:gst_bin_remove_func:<dstest4-pipeline> removed child "nvv4l2-decoder"
0:00:00.144206524  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3251:gst_element_dispose:<nvv4l2-decoder> 0x76c00c0 dispose
0:00:00.144222780  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad:<nvv4l2-decoder> removing pad 'sink'
0:00:00.144242909  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad:<nvv4l2-decoder> removing pad 'src'
0:00:00.144263198  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3297:gst_element_dispose:<nvv4l2-decoder> 0x76c00c0 parent class dispose
0:00:00.144288800  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3328:gst_element_finalize:<nvv4l2-decoder> 0x76c00c0 finalize
0:00:00.144304768  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3334:gst_element_finalize:<nvv4l2-decoder> 0x76c00c0 finalize parent
0:00:00.144327137  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstpad.c:2134:gst_pad_unlink: unlinking file-source:src(0x765a180) and h264-parser:sink(0x765a3d0)
0:00:00.144349506  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstpad.c:2188:gst_pad_unlink: unlinked file-source:src and h264-parser:sink
0:00:00.144373028  1352      0x7414a00 INFO           GST_PARENTAGE gstbin.c:1801:gst_bin_remove_func:<dstest4-pipeline> removed child "h264-parser"
0:00:00.144395909  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3251:gst_element_dispose:<h264-parser> 0x7668a60 dispose
0:00:00.144411365  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad:<h264-parser> removing pad 'sink'
0:00:00.144431334  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad:<h264-parser> removing pad 'src'
0:00:00.144450823  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3297:gst_element_dispose:<h264-parser> 0x7668a60 parent class dispose
0:00:00.144474664  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3328:gst_element_finalize:<h264-parser> 0x7668a60 finalize
0:00:00.144490025  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3334:gst_element_finalize:<h264-parser> 0x7668a60 finalize parent
0:00:00.144512234  1352      0x7414a00 INFO           GST_PARENTAGE gstbin.c:1801:gst_bin_remove_func:<dstest4-pipeline> removed child "file-source"
0:00:00.144534603  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3251:gst_element_dispose:<file-source> 0x7658220 dispose
0:00:00.144549868  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad:<file-source> removing pad 'src'
0:00:00.144574765  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3297:gst_element_dispose:<file-source> 0x7658220 parent class dispose
0:00:00.144593422  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3328:gst_element_finalize:<file-source> 0x7658220 finalize
0:00:00.144627888  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3334:gst_element_finalize:<file-source> 0x7658220 finalize parent
0:00:00.144648241  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3251:gst_element_dispose:<dstest4-pipeline> 0x76620f0 dispose
0:00:00.144665169  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3297:gst_element_dispose:<dstest4-pipeline> 0x76620f0 parent class dispose
0:00:00.144681266  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3328:gst_element_finalize:<dstest4-pipeline> 0x76620f0 finalize
0:00:00.144696659  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3334:gst_element_finalize:<dstest4-pipeline> 0x76620f0 finalize parent
0:00:00.144725396  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3251:gst_element_dispose:<nvmsg-broker> 0x7acc9e0 dispose
0:00:00.144741141  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad:<nvmsg-broker> removing pad 'sink'
0:00:00.144761270  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3297:gst_element_dispose:<nvmsg-broker> 0x7acc9e0 parent class dispose
0:00:00.144779863  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3328:gst_element_finalize:<nvmsg-broker> 0x7acc9e0 finalize
0:00:00.144795384  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3334:gst_element_finalize:<nvmsg-broker> 0x7acc9e0 finalize parent
0:00:00.144814073  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3251:gst_element_dispose:<nvvideo-renderer> 0x7ad61e0 dispose
0:00:00.144829689  1352      0x7414a00 INFO        GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad:<nvvideo-renderer> removing pad 'sink'
0:00:00.144848794  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3297:gst_element_dispose:<nvvideo-renderer> 0x7ad61e0 parent class dispose
0:00:00.144865467  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3328:gst_element_finalize:<nvvideo-renderer> 0x7ad61e0 finalize
0:00:00.144880508  1352      0x7414a00 INFO         GST_REFCOUNTING gstelement.c:3334:gst_element_finalize:<nvvideo-renderer> 0x7ad61e0 finalize parent
In short:
(deepstream-test4-app:1361): GLib-CRITICAL **: 10:55:22.321: g_strchug: assertion 'string != NULL' failed
(deepstream-test4-app:1361): GLib-CRITICAL **: 10:55:22.321: g_strchomp: assertion 'string != NULL' failed
(deepstream-test4-app:1361): GLib-CRITICAL **: 10:55:22.323: g_strrstr: assertion 'haystack != NULL' failed
Running...
Deleting pipeline
if you carefully see line 9, the path /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvmsgbroker/
doesn’t exists, how to fix this.
[nitin_rai]
Hi, I have the same issue. Did you manage to solve the problem?
Not yet, i have been trying to run deepstream-test4-app, from so many days there isn’t any proper explaination. I followed all the instructions on provided Readme, But that doesn’t seems to be helpful.
Is there any way to test message broker locally i.e., without having an Azure Iot account. I tried with rabbit mqtt local server but it wasn’t working.
I have tried everything from my side but still i am having issues.
:( Today in my despair, I have published this post clearly detailing the steps I am following.
I hope someone can guide us. Regards
I had the same error until I released I had not compiled and installed the client side of the rabbitmq C lib for the test4 app to use.
See the README in the test4 app.
Which points you to:
/opt/nvidia/deepstream/deepstream/sources/libs/amqp_protocol_adaptor
