Hi, I have the this problem running the last cell of deepstream_test_4.ipynb using this docker image for deepstream-5.0
Starting pipeline
Error: gst-library-error-quark: Could not initialize supporting library. (3): gstnvmsgbroker.c(359): legacy_gst_nvmsgbroker_start (): /GstPipeline:pipeline0/GstNvMsgBroker:nvmsg-broker:
unable to open shared library
I’m using a gtx1080ti ubuntu 18.04. driver : 440.33.01, cuda 10.2, cudnn 7.6.5, tensorrt 7.0
Here 77996, recommended to search /gst-plugins/gst-nvmsgbroker. I also did it, and added to the PATH, but same error.
I also changed the Paths in order to find *.so, because im using docker image.
• Hardware Platform (Jetson / GPU) • DeepStream Version • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
I got problem running the last cell of deepstream_test_1.ipynb (python binding) using a docker image of your website.
I entered to the docker using
docker run --gpus all -it -p 8888:8888 --rm -v /tmp/.X11-unix:/tmp/.X11-unix -e DISPLAY=$DISPLAY -w /opt/nvidia/deepstream/deepstream-5.0 nvcr.io/nvidia/deepstream:5.0-20.07-triton
Then, I just followed the steps on each notebook and run the cells. But I found same error in deepstream_test_1.ipynb and deepstream_test_4.ipynb
Cell:
print("Starting pipeline \n")
pipeline.set_state(Gst.State.PLAYING)
try:
loop.run()
except:
pass
# cleaning up as the pipeline comes to an end
pipeline.set_state(Gst.State.NULL)
Output:
Starting pipeline
