• Hardware Platform GPU • DeepStream Version 5.0 • TensorRT Version 7.0 • NVIDIA GPU Driver Version 440.59
So I have some code working on Jetson platform getting events and sending to Azure. I have taken this code and added it to the deepstream:5.0-dp-20.04-iot on a dGPU, and now i keeping getting the below error.
ERROR from element nvmsg-broker: Could not initialize supporting library.
Error details: gstnvmsgbroker.c(303): gst_nvmsgbroker_start (): /GstPipeline:nvdsanalytics-test-pipeline/GstNvMsgBroker:nvmsg-broker:
unable to open shared library
I am using the same /opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_azure_edge_proto.so and I can see the file. Sometimes the application will run but the detections are not send downstream.
It is unable to open the library even from the test as per below:
opt/nvidia/deepstream/deepstream-5.0/sources/libs/azure_protocol_adaptor/device_client$ ./test_azure_proto_sync /opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_azure_proto.so
Okay I was able to get the test_azure_proto_sync to work and can see the messages coming to iothub. But when I try and run deepstream-test4 i get the following:
Error: Time:Thu Jun 4 12:53:59 2020 File:/home/arg/azure/azure-iot-sdk-c/iothub_client/src/iothub_client_core_ll.c Func:IoTHubClientCore_LL_CreateFromConnectionString Line:939 Tokenizer error
Error: Time:Thu Jun 4 12:53:59 2020 File:/home/arg/azure/azure-iot-sdk-c/iothub_client/src/iothub_client_core_ll.c Func:IoTHubClientCore_LL_CreateFromConnectionString Line:1077 iotHubName is not found
Error: Time:Thu Jun 4 12:53:59 2020 File:/home/arg/azure/azure-iot-sdk-c/iothub_client/src/iothub_client_core.c Func:create_iothub_instance Line:924 Failure creating iothub handle
Running...
The Iot hub connection string is the same for both, even tried the same file location
