Run DeepStream TestApp-4
• Hardware Platform (Jetson / GPU) DGPU
• DeepStream Version : 6.1
• TensorRT Version: 10.7.0.23-1+cuda12.6
• NVIDIA GPU Driver Version (valid for GPU only) Driver Version: 550.120
How to run the Deepstream 6.1, deepstream-test4 sample app? I got an issue. I used the follwing command with necessary parameters
“./deepstream-test4-app -i app/DS6.1/deepstream-6.1/samples/streams/1.mp4 -p /app/DS6.1/deepstream-6.1/lib/libnvds_amqp_proto.so --conn-str=“localhost;5672;guest;guest” --topic=topicname -s 1”
Now playing: app/DS6.1/deepstream-6.1/samples/streams/1.mp4
Running…
ERROR from element nvmsg-broker: Could not configure supporting library.
Error details: gstnvmsgbroker.cpp(401): legacy_gst_nvmsgbroker_start (): /GstPipeline:dstest4-pipeline/GstNvMsgBroker:nvmsg-broker:
unable to connect to broker library
Returned, stopping playback
Deleting pipeline
Please install the correct TensorRT and CUDA versions first, or use Docker
In addition, this error means that the server cannot be connected. Please make sure that the server has been started normally.
I am already running within the docker container only.
When you use a docker image, the CUDA/TensorRT version installed on the host is meaningless. The DS-6.1 docker image packages cuda11.6 and TRT-8.4.
so the above information is wrong
Please do as I said above and check the status of your server, here are the guidelines
/opt/nvidia/deepstream/deepstream-6.1/sources/libs/amqp_protocol_adaptor/README
