Issue running deepstream-app
• Hardware Platform (Jetson / GPU): RTX 2070
• DeepStream Version: 5.1
• TensorRT Version: 7.2
• NVIDIA GPU Driver Version (valid for GPU only): 470.63.01
I run into this error when I try to run the deepstream app from the sample configs (deepstream-app -c source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt). Am I missing something?
I followed all the install instructions for Ubuntu system given in the quickstart guide (Quickstart Guide — DeepStream 6.1.1 Release documentation)
nvbufsurftransform:cuInit failed : 100
** ERROR: <create_multi_source_bin:1320>: Failed to create element ‘src_bin_muxer’
** ERROR: <create_multi_source_bin:1411>: create_multi_source_bin failed
** ERROR: <create_pipeline:1294>: create_pipeline failed
** ERROR: main:636: Failed to create pipeline
Quitting
App run failed
How about remove the cache and run again?
rm ~/.cache/gstreamer-1.0/ -rf
Hi @Amycao ,
Thanks for your reply. I tried this and got an extra warning. But still can’t get past the intial error.
Can you find these modules:
gst-inspect-1.0 nvdsgst_jpegdec
gst-inspect-1.0 nvstreammux
also can you find this file
/usr/local/cuda-11.1/lib64/libnvjpeg.so.11
Hi @Amycao , I don’t have any of these. Should I try re-installing tensorrt or cuda?
Yes. you also can try with docker which have the dependency software installed.
https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_docker_containers.html#a-docker-container-for-dgpu
Hi @Amycao,
I’ve tried 3 different docker versions (5.0, 5.1, 6.0) and get different errors each time.
When I used deepstream 5.0, I get this error:
When I used deepstream 5.1, I get this error:
When I used deepstream 6.0, I get this error:
I make sure that my folder has all the necessary files.
I’m also using the following nvidia driver:
Driver Version: 460.91.03 CUDA Version: 11.2
I’ve attached my config files as well. Thanksdeepstream_basic.txt (1.5 KB)
model_basic.txt (767 Bytes)
For version 6.0, can you find nxstreammux?
gst-inspect-1.0 nxstreammux
Hi @Amycao,
No, I can’t find this in the docker. Did I miss something?
Sorry for the wrong typo, it’s nvstreammux not nxstreammux.
Hi @Amycao,
I don’t have that either.
Please try to remove the cache and run again
@Amycao,
I think it’s exactly the same.
Hi @Amycao,
I think I succeeded with deepstream5.1. Maybe since the nvidia driver is not the most recent one, there is some mismatch with the latest Deepstream6.0?
Also, since I’m relatively new to using dockers, I didn’t realise that I had to transfer the folders (config and data) with the configs and video file to the docker container folder.
Thanks for your help!
Which nvidia driver version you are using?
