Deepstream error
while running this line “deepstream-app -c deepstream_app_config.txt”
i am following this code.
code URL : - " Deploy YOLOv8 with TensorRT and DeepStream SDK | Seeed Studio Wiki "
I am getting this issue
** ERROR: <create_multi_source_bin:1494>: Failed to create element ‘src_bin_muxer’
** ERROR: <create_multi_source_bin:1582>: create_multi_source_bin failed
** ERROR: <create_pipeline:1576>: create_pipeline failed
** ERROR: main:697: Failed to create pipeline
Quitting
App run failed
please help me to resolve this . thanks in advance
Hi @piyush0395 ,
This looks like a Deepstream issue, Moving it to Deepstream forum.
• DeepStream Version
• TensorRT Version
• The pipeline being used
It seems that your gpu driver or cuda may not be installed properly.
Can you try running your model with trtexec command, and share the “”–verbose"" log in case if the issue persist
You can refer below link for all the supported operators list, in case any operator is not supported you need to create a custom plugin to support that operation
Also, request you to share your model and script if not shared already so that we can help you better.
Meanwhile, for some common errors and queries please refer to below link:
