julie
December 10, 2020, 1:11am
1
When trying to build and use the Jetson Yolov3 example in deepstream 5.0, I get the following error message:
root@jetson-xavier:~/deepstream/sources/objectDetector_Yolo# …/…/bin/deepstream-app -c deepstream_app_config_yoloV3.txt
(deepstream-app:3579): GLib-GObject-CRITICAL **: 01:04:44.956: g_object_set: assertion ‘G_IS_OBJECT (object)’ failed
(deepstream-app:3579): GLib-GObject-CRITICAL **: 01:04:44.957: g_object_set: assertion ‘G_IS_OBJECT (object)’ failed
** ERROR: <create_render_bin:95>: Failed to create ‘sink_sub_bin_sink1’
** ERROR: <create_render_bin:172>: create_render_bin failed
** ERROR: <create_sink_bin:732>: create_sink_bin failed
** ERROR: <create_processing_instance:802>: create_processing_instance failed
** ERROR: <create_pipeline:1296>: create_pipeline failed
** ERROR: main:636 : Failed to create pipeline
Quitting
App run failed
I have performed all of the steps listed in the yolov3 example:
downloaded yolov3 weights and cfg to: /opt/nvidia/deepstream/deepstream/sources/objectDetector_Yolo
didn’t install TensorRT because it’s already installed with Jetpack
changed sources/objectDetector_yolo/nvdsinfer_custom_impl_yolo/Makefile to
I am on the following platform:
**• Hardware Platform: Jetson Xavier AGX **
./bin/deepstream-app --version-all
deepstream-app version 5.0.0
DeepStreamSDK 5.0.0
CUDA Driver Version: 10.2
CUDA Runtime Version: 10.2
TensorRT Version: 7.1
cuDNN Version not available
libNVWarp360 Version: 2.0.1d3
Could you clean the cache with below command and try it again?
$ rm ~/.cache/gstreamer-1.0/ -rf
julie
December 10, 2020, 2:48am
4
I tried that, no luck. Same error.
julie
December 11, 2020, 1:41am
5
Solution found: I am using Yocto to build my platform, and I was missing
gstreamer1.0-plugins-nvvideosinks
from my image.
Good. Thanks for updating the status!
Hello, how to solve gstreamer1.0-plugins-nvvideosinks problem? I meet the difficult, I need your help. Thx.
my version is deepstream5.0.1
The follwoing is my setting.
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
type=2
If I use fakesink, it haven’t the problem , but I can’t see display.
./deepstream-app -c deepstream_app_config.txt
(deepstream-app:18495): GLib-GObject-CRITICAL **: 17:05:36.348: g_object_set: assertion ‘G_IS_OBJECT (object)’ failed
(deepstream-app:18495): GLib-GObject-CRITICAL **: 17:05:36.354: g_object_set: assertion ‘G_IS_OBJECT (object)’ failed
** ERROR: main:678 : Failed to create pipeline
Quitting
App run failed
[sink0]
enable=1
type=2
Quitting
App run failed
kayccc
July 6, 2021, 3:45am
10
Hi MingGatsby ,
Please help to open a new topic for your issue. Thanks
