Run issue with Deepstream 5.1
Complete information of setup.
• Hardware Platform (Jetson / GPU) : GPU
• DeepStream Version : 5.1
• JetPack Version (valid for Jetson only) : None
• TensorRT Version : 7.2.3.4
• NVIDIA GPU Driver Version (valid for GPU only) : 460.84
• Issue Type( questions, new requirements, bugs) : questions
I have done Deepstream 5.1 setup and while Run the Sample getting below error.
Can anybody help me around?
ERROR:
(deepstreamer_env) xxxx@xxxx:/opt/nvidia/deepstream/deepstream-5.1/sources/deepstream_yolov4$ deepstream-app -c deepstream_app_config_yoloV4.txt
Unknown or legacy key specified ‘is-classifier’ for group [property]
** ERROR: main:655: Failed to set pipeline to PAUSED
Quitting
ERROR from sink_sub_bin_sink1: Could not open file “yolov4.mp4” for writing.
Debug info: gstfilesink.c(431): gst_file_sink_open_file (): /GstPipeline:pipeline/GstBin:processing_bin_0/GstBin:sink_bin/GstBin:sink_sub_bin1/GstFileSink:sink_sub_bin_sink1:
system error: Permission denied
ERROR from sink_sub_bin_sink1: GStreamer error: state change failed and some element failed to post a proper error message with the reason for the failure.
Debug info: gstbasesink.c(5265): gst_base_sink_change_state (): /GstPipeline:pipeline/GstBin:processing_bin_0/GstBin:sink_bin/GstBin:sink_sub_bin1/GstFileSink:sink_sub_bin_sink1:
Failed to start
App run failed
The log has told you what is wrong!
Seems you don’t have write permission for the folder you are running. Please check by yourself. You need to run with ‘root’ in /opt/nvidia/deepstream/deepstream-5.1/sources/deepstream_yolov4
