deepstream-app version 5.0.0
DeepStreamSDK 5.0.0
CUDA Driver Version: 10.2
CUDA Runtime Version: 10.2
TensorRT Version: 7.1
cuDNN Version: 8.0
libNVWarp360 Version: 2.0.1d3
I am trying with the deepstream-app on Xavier. When I run the sample, it shows the following error msg:
(deepstream-app:8532): GLib-GObject-CRITICAL **: 17:37:55.290: g_object_set: assertion 'G_IS_OBJECT (object)' failed
** ERROR: <create_render_bin:95>: Failed to create 'sink_sub_bin_sink1'
** ERROR: <create_render_bin:172>: create_render_bin failed
** ERROR: <create_sink_bin:732>: create_sink_bin failed
** ERROR: <create_processing_instance:793>: create_processing_instance failed
** ERROR: <create_pipeline:1263>: create_pipeline failed
** ERROR: <main:632>: Failed to create pipeline
Quitting
App run failed
I can find /usr/lib/aarch64-linux-gnu/libGLESv2.so and /usr/lib/aarch64-linux-gnu/libnvinfer_plugin.so.7 in place. Please help.
