Runing Deepstream3.0 sample encounter errors
Hi
when I install DeepStream SDK 3.0 on Jetson AGX Xavier, enter the samples directory to run the sample application:
$ sudo deepstream-app -c configs/deepstream-app/source30_720p_dec_infer-resnet_tiled_display_int8.txt
Error outputs:
(gst-plugin-scanner:28556): GStreamer-WARNING **: 09:31:39.993: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libcluttergst3.so’: /usr/lib/aarch64-linux-gnu/libgbm.so.1: undefined symbol: drmGetDevice2
(gst-plugin-scanner:28556): GStreamer-WARNING **: 09:31:40.031: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstopengl.so’: /usr/lib/aarch64-linux-gnu/libgbm.so.1: undefined symbol: drmGetDevice2
(gst-plugin-scanner:28556): GStreamer-WARNING **: 09:31:40.053: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstkms.so’: /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstkms.so: undefined symbol: drmModeGetFB
(gst-plugin-scanner:28556): GStreamer-WARNING **: 09:31:40.171: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvinfer.so’: /usr/lib/aarch64-linux-gnu/tegra/libnvll_infer.so.1.0.0: undefined symbol: initLibNvInferPlugins
(gst-plugin-scanner:28556): GStreamer-WARNING **: 09:31:40.337: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstopenglmixers.so’: /usr/lib/aarch64-linux-gnu/libgbm.so.1: undefined symbol: drmGetDevice2
** ERROR: <create_primary_gie_bin:120>: Failed to create ‘primary_gie_classifier’
** ERROR: <create_primary_gie_bin:170>: create_primary_gie_bin failed
** ERROR: <create_pipeline:985>: create_pipeline failed
** ERROR: main:593: Failed to create pipeline
Quitting
App run failed
I have try again after removing the GStreamer cache, but not work.
Thanks for any suggestion!
Can you do this objdump -txT /usr/lib/aarch64-linux-gnu/tegra/libnvll_infer.so.1.0.0|grep initLibNvInferPlugins, and paste the output? which TensorRT version are you using?
$ objdump -txT /usr/lib/aarch64-linux-gnu/tegra/libnvll_infer.so.1.0.0|grep initLibNvInferPlugins
0000000000000000 DF UND 0000000000000000 initLibNvInferPlugins
I use TensorRT 5.0.
can you remove the cache, and run the app again with debug enabled to get more detailed error?
deepstream-app -c configs/deepstream-app/source30_720p_dec_infer-resnet_tiled_display_int8.txt --gst-debug-level=4
[BEGIN] 2019/1/18 22:22:23
$ sudo deepstream-app -c configs/deepstream-app/source30_720p_dec_infer-resnet_tiled_display_int8.txt --gst-debug-level=4
0:00:00.000782785 7845 0x3cd36c0 INFO GST_INIT gstmessage.c:127:_priv_gst_message_initialize: init messages
0:00:00.001907345 7845 0x3cd36c0 INFO GST_INIT gstcontext.c:84:_priv_gst_context_initialize: init contexts
0:00:00.002373380 7845 0x3cd36c0 INFO GST_PLUGIN_LOADING gstplugin.c:317:_priv_gst_plugin_initialize: registering 0 static plugins
0:00:00.002663728 7845 0x3cd36c0 INFO GST_PLUGIN_LOADING gstplugin.c:225:gst_plugin_register_static: registered static plugin “staticelements”
0:00:00.002696338 7845 0x3cd36c0 INFO GST_PLUGIN_LOADING gstplugin.c:227:gst_plugin_register_static: added static plugin “staticelements”, result: 1
in
try.aarch64.bin : Failed to open file “/home/olympus/.cache/gstreamer-1.0/registry.aarch64.bin”: open() failed: No such file or directory
try.aarch64.bin : Failed to open file “/home/olympus/.cache/gstreamer-1.0/registry.aarch64.bin”: No such file or directory
egistry.aarch64.bin
0:00:00.721952966 7845 0x3cd36c0 INFO GST_REGISTRY gstregistry.c:1694:scan_and_update_registry: Registry cache changed. Writing new registry cache
0:00:00.722045514 7845 0x3cd36c0 INFO GST_REGISTRY gstregistrybinary.c:369:priv_gst_registry_binary_write_cache: Building binary registry cache image
0:00:00.770344547 7845 0x3cd36c0 INFO GST_REGISTRY gstregistrybinary.c:401:priv_gst_registry_binary_write_cache: Writing binary registry cache
0:00:00.826854678 7845 0x3cd36c0 INFO GST_REGISTRY gstregistrybinary.c:262:gst_registry_binary_cache_finish: Wrote binary registry cache
0:00:00.826909944 7845 0x3cd36c0 INFO GST_REGISTRY gstregistry.c:1703:scan_and_update_registry: Registry cache written successfully
0:00:00.826936281 7845 0x3cd36c0 INFO GST_REGISTRY gstregistry.c:1762:ensure_current_registry: registry reading and updating done, result = 1
0:00:00.827014589 7845 0x3cd36c0 INFO GST_INIT gst.c:807:init_post: GLib runtime version: 2.56.2
0:00:00.827036670 7845 0x3cd36c0 INFO GST_INIT gst.c:809:init_post: GLib headers version: 2.56.1
0:00:00.827054462 7845 0x3cd36c0 INFO GST_INIT gst.c:810:init_post: initialized GStreamer successfully
0:00:00.828453914 7845 0x3cd36c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “pipeline” named “pipeline”
0:00:00.828756998 7845 0x3cd36c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “bin” named “multi_src_bin”
ream.so" loaded
0:00:00.856470041 7845 0x3cd36c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “nvstreammux” named “src_bin_muxer”
0:00:00.857117173 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstNvStreamMux@0x417c0f0 adding pad ‘src’
0:00:00.857279675 7845 0x3cd36c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “bin” named “src_sub_bin0”
so" loaded
0:00:00.859631007 7845 0x3cd36c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “uridecodebin” named “src_elem”
nts.so" loaded
0:00:00.861006489 7845 0x3cd36c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “queue” named “src_cap_filter”
0:00:00.861236387 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x4182090 adding pad ‘sink’
0:00:00.861351688 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x4182090 adding pad ‘src’
0:00:00.861440363 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad src_cap_filter:src
0:00:00.861539983 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link src_cap_filter:src and src:proxypad0
0:00:00.861577297 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked src_cap_filter:src and src:proxypad0, successful
0:00:00.861594546 7845 0x3cd36c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.861609682 7845 0x3cd36c0 INFO GST_EVENT gstpad.c:5785:gst_pad_send_event_unchecked:<src_cap_filter:src> Received event on flushing pad. Discarding
0:00:00.861638900 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<src_sub_bin0> adding pad ‘src’
0:00:00.861659957 7845 0x3cd36c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “fakesink” named “src_fakesink”
0:00:00.861892222 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseSink@0x3fc8de0 adding pad ‘sink’
0:00:00.861926720 7845 0x3cd36c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “queue” named “fakequeue”
0:00:00.861970882 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x4182390 adding pad ‘sink’
0:00:00.862008867 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x4182390 adding pad ‘src’
0:00:00.862042053 7845 0x3cd36c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “tee”
0:00:00.862222412 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstTee@0x418b000 adding pad ‘sink’
0:00:00.862293231 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element fakequeue:(any) to element src_fakesink:(any)
0:00:00.862319248 7845 0x3cd36c0 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link fakequeue:src and src_fakesink:sink
0:00:00.862346514 7845 0x3cd36c0 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:fakequeue:sink pad has no peer
0:00:00.862406548 7845 0x3cd36c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: fakequeue and src_fakesink in same bin, no need for ghost pads
0:00:00.862433205 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link fakequeue:src and src_fakesink:sink
0:00:00.862454358 7845 0x3cd36c0 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:fakequeue:sink pad has no peer
0:00:00.862480375 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked fakequeue:src and src_fakesink:sink, successful
0:00:00.862494648 7845 0x3cd36c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.862509304 7845 0x3cd36c0 INFO GST_EVENT gstpad.c:5785:gst_pad_send_event_unchecked:fakequeue:src Received event on flushing pad. Discarding
0:00:00.862559035 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad: adding pad ‘src_0’
0:00:00.862635582 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad src_cap_filter:sink
0:00:00.862661599 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link tee0:src_0 and src_cap_filter:sink
0:00:00.862681920 7845 0x3cd36c0 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:tee0:sink pad has no peer
0:00:00.862710241 7845 0x3cd36c0 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:<src_sub_bin0:src> pad has no peer
0:00:00.862734658 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked tee0:src_0 and src_cap_filter:sink, successful
0:00:00.862748195 7845 0x3cd36c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.862774628 7845 0x3cd36c0 INFO GST_EVENT gstpad.c:5785:gst_pad_send_event_unchecked:tee0:src_0 Received event on flushing pad. Discarding
0:00:00.862814725 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad: adding pad ‘src_1’
0:00:00.862834086 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad fakequeue:sink
0:00:00.862855591 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link tee0:src_1 and fakequeue:sink
0:00:00.862887976 7845 0x3cd36c0 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:tee0:sink pad has no peer
0:00:00.862916106 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked tee0:src_1 and fakequeue:sink, successful
0:00:00.862930410 7845 0x3cd36c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.862949899 7845 0x3cd36c0 INFO GST_EVENT gstpad.c:5785:gst_pad_send_event_unchecked:tee0:src_1 Received event on flushing pad. Discarding
0:00:00.863100689 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:917:gst_element_get_static_pad: no such pad ‘sink_0’ in element “src_bin_muxer”
0:00:00.863389470 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<src_bin_muxer> adding pad ‘sink_0’
0:00:00.863412351 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad src_sub_bin0:src
0:00:00.863437952 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link src_sub_bin0:src and src_bin_muxer:sink_0
0:00:00.863484738 7845 0x3cd36c0 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:tee0:sink pad has no peer
0:00:00.863514339 7845 0x3cd36c0 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:<src_bin_muxer:src> pad has no peer
0:00:00.863626792 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked src_sub_bin0:src and src_bin_muxer:sink_0, successful
0:00:00.863647657 7845 0x3cd36c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.863663849 7845 0x3cd36c0 INFO GST_EVENT gstpad.c:5785:gst_pad_send_event_unchecked:<src_sub_bin0:src> Received event on flushing pad. Discarding
0:00:00.863690186 7845 0x3cd36c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “bin” named “src_sub_bin1”
0:00:00.863739308 7845 0x3cd36c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “uridecodebin” named “src_elem”
0:00:00.863799311 7845 0x3cd36c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “queue” named “src_cap_filter”
0:00:00.863913940 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x4182690 adding pad ‘sink’
0:00:00.863959830 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x4182690 adding pad ‘src’
0:00:00.864027289 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad src_cap_filter:src
0:00:00.864081435 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link src_cap_filter:src and src:proxypad1
0:00:00.864101084 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked src_cap_filter:src and src:proxypad1, successful
0:00:00.864114812 7845 0x3cd36c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.864134141 7845 0x3cd36c0 INFO GST_EVENT gstpad.c:5785:gst_pad_send_event_unchecked:<src_cap_filter:src> Received event on flushing pad. Discarding
0:00:00.864155550 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<src_sub_bin1> adding pad ‘src’
0:00:00.864174207 7845 0x3cd36c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “fakesink” named “src_fakesink”
0:00:00.864263299 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseSink@0x3fc6de0 adding pad ‘sink’
0:00:00.864289348 7845 0x3cd36c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “queue” named “fakequeue”
0:00:00.864328869 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x4182990 adding pad ‘sink’
0:00:00.864387592 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x4182990 adding pad ‘src’
0:00:00.864419209 7845 0x3cd36c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “tee”
0:00:00.864459915 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstTee@0x418b150 adding pad ‘sink’
0:00:00.864526926 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element fakequeue:(any) to element src_fakesink:(any)
0:00:00.864551919 7845 0x3cd36c0 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link fakequeue:src and src_fakesink:sink
0:00:00.864571728 7845 0x3cd36c0 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:fakequeue:sink pad has no peer
0:00:00.864604849 7845 0x3cd36c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: fakequeue and src_fakesink in same bin, no need for ghost pads
0:00:00.864628306 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link fakequeue:src and src_fakesink:sink
0:00:00.864647635 7845 0x3cd36c0 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:fakequeue:sink pad has no peer
0:00:00.864670740 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked fakequeue:src and src_fakesink:sink, successful
0:00:00.864685652 7845 0x3cd36c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.864709397 7845 0x3cd36c0 INFO GST_EVENT gstpad.c:5785:gst_pad_send_event_unchecked:fakequeue:src Received event on flushing pad. Discarding
0:00:00.864745911 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad: adding pad ‘src_0’
0:00:00.864764632 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad src_cap_filter:sink
0:00:00.864787449 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link tee1:src_0 and src_cap_filter:sink
0:00:00.864806649 7845 0x3cd36c0 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:tee1:sink pad has no peer
0:00:00.864830555 7845 0x3cd36c0 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:<src_sub_bin1:src> pad has no peer
0:00:00.864854684 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked tee1:src_0 and src_cap_filter:sink, successful
0:00:00.864868252 7845 0x3cd36c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.864878493 7845 0x3cd36c0 INFO GST_EVENT gstpad.c:5785:gst_pad_send_event_unchecked:tee1:src_0 Received event on flushing pad. Discarding
0:00:00.864916542 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad: adding pad ‘src_1’
0:00:00.864935135 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad fakequeue:sink
0:00:00.864960224 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link tee1:src_1 and fakequeue:sink
0:00:00.864979425 7845 0x3cd36c0 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:tee1:sink pad has no peer
0:00:00.865006754 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked tee1:src_1 and fakequeue:sink, successful
0:00:00.865021123 7845 0x3cd36c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.865038979 7845 0x3cd36c0 INFO GST_EVENT gstpad.c:5785:gst_pad_send_event_unchecked:tee1:src_1 Received event on flushing pad. Discarding
0:00:00.865155912 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:917:gst_element_get_static_pad: no such pad ‘sink_1’ in element “src_bin_muxer”
0:00:00.865464373 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<src_bin_muxer> adding pad ‘sink_1’
0:00:00.865491510 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad src_sub_bin1:src
0:00:00.865516023 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link src_sub_bin1:src and src_bin_muxer:sink_1
0:00:00.865547065 7845 0x3cd36c0 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:tee1:sink pad has no peer
0:00:00.865588731 7845 0x3cd36c0 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:<src_bin_muxer:src> pad has no peer
0:00:00.865644989 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked src_sub_bin1:src and src_bin_muxer:sink_1, successful
0:00:00.865664990 7845 0x3cd36c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.865680670 7845 0x3cd36c0 INFO GST_EVENT gstpad.c:5785:gst_pad_send_event_unchecked:<src_sub_bin1:src> Received event on flushing pad. Discarding
0:00:00.865711072 7845 0x3cd36c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “bin” named “src_sub_bin2”
0:00:00.865745665 7845 0x3cd36c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “uridecodebin” named “src_elem”
0:00:00.865848678 7845 0x3cd36c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “queue” named “src_cap_filter”
0:00:00.865898088 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x4182c90 adding pad ‘sink’
0:00:00.865936457 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x4182c90 adding pad ‘src’
0:00:00.865996588 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad src_cap_filter:src
0:00:00.866043694 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link src_cap_filter:src and src:proxypad2
0:00:00.866062767 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked src_cap_filter:src and src:proxypad2, successful
0:00:00.866076527 7845 0x3cd36c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.866090832 7845 0x3cd36c0 INFO GST_EVENT gstpad.c:5785:gst_pad_send_event_unchecked:<src_cap_filter:src> Received event on flushing pad. Discarding
0:00:00.866111729 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<src_sub_bin2> adding pad ‘src’
0:00:00.866125553 7845 0x3cd36c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “fakesink” named “src_fakesink”
0:00:00.866157651 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseSink@0x4177de0 adding pad ‘sink’
0:00:00.866181940 7845 0x3cd36c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “queue” named “fakequeue”
0:00:00.866220949 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x4182f90 adding pad ‘sink’
0:00:00.866268855 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x4182f90 adding pad ‘src’
0:00:00.866303609 7845 0x3cd36c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “tee”
0:00:00.866344218 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstTee@0x418b2a0 adding pad ‘sink’
0:00:00.866443743 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element fakequeue:(any) to element src_fakesink:(any)
0:00:00.866464736 7845 0x3cd36c0 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link fakequeue:src and src_fakesink:sink
0:00:00.866483648 7845 0x3cd36c0 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:fakequeue:sink pad has no peer
0:00:00.866507777 7845 0x3cd36c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: fakequeue and src_fakesink in same bin, no need for ghost pads
0:00:00.866531682 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link fakequeue:src and src_fakesink:sink
0:00:00.866549539 7845 0x3cd36c0 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:fakequeue:sink pad has no peer
0:00:00.866573476 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked fakequeue:src and src_fakesink:sink, successful
0:00:00.866587045 7845 0x3cd36c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.866601093 7845 0x3cd36c0 INFO GST_EVENT gstpad.c:5785:gst_pad_send_event_unchecked:fakequeue:src Received event on flushing pad. Discarding
0:00:00.866645703 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad: adding pad ‘src_0’
0:00:00.866665736 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad src_cap_filter:sink
0:00:00.866687753 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link tee2:src_0 and src_cap_filter:sink
0:00:00.866706602 7845 0x3cd36c0 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:tee2:sink pad has no peer
0:00:00.866729931 7845 0x3cd36c0 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:<src_sub_bin2:src> pad has no peer
0:00:00.866753964 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked tee2:src_0 and src_cap_filter:sink, successful
0:00:00.866766124 7845 0x3cd36c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.866791309 7845 0x3cd36c0 INFO GST_EVENT gstpad.c:5785:gst_pad_send_event_unchecked:tee2:src_0 Received event on flushing pad. Discarding
0:00:00.866826447 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad: adding pad ‘src_1’
0:00:00.866846416 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad fakequeue:sink
0:00:00.866868785 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link tee2:src_1 and fakequeue:sink
0:00:00.866890386 7845 0x3cd36c0 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:tee2:sink pad has no peer
0:00:00.866919091 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked tee2:src_1 and fakequeue:sink, successful
0:00:00.866933203 7845 0x3cd36c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.866948436 7845 0x3cd36c0 INFO GST_EVENT gstpad.c:5785:gst_pad_send_event_unchecked:tee2:src_1 Received event on flushing pad. Discarding
0:00:00.867044408 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:917:gst_element_get_static_pad: no such pad ‘sink_2’ in element “src_bin_muxer”
0:00:00.867285890 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<src_bin_muxer> adding pad ‘sink_2’
0:00:00.867309507 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad src_sub_bin2:src
0:00:00.867344645 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link src_sub_bin2:src and src_bin_muxer:sink_2
0:00:00.867369222 7845 0x3cd36c0 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:tee2:sink pad has no peer
0:00:00.867395783 7845 0x3cd36c0 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:<src_bin_muxer:src> pad has no peer
0:00:00.867432008 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked src_sub_bin2:src and src_bin_muxer:sink_2, successful
0:00:00.867446889 7845 0x3cd36c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.867457385 7845 0x3cd36c0 INFO GST_EVENT gstpad.c:5785:gst_pad_send_event_unchecked:<src_sub_bin2:src> Received event on flushing pad. Discarding
0:00:00.867481354 7845 0x3cd36c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “bin” named “src_sub_bin3”
0:00:00.867515468 7845 0x3cd36c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “uridecodebin” named “src_elem”
0:00:00.867583983 7845 0x3cd36c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “queue” named “src_cap_filter”
0:00:00.867628593 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x4183290 adding pad ‘sink’
0:00:00.867665106 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x4183290 adding pad ‘src’
0:00:00.867730933 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad src_cap_filter:src
0:00:00.867776823 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link src_cap_filter:src and src:proxypad3
0:00:00.867796472 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked src_cap_filter:src and src:proxypad3, successful
0:00:00.867842778 7845 0x3cd36c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.867855194 7845 0x3cd36c0 INFO GST_EVENT gstpad.c:5785:gst_pad_send_event_unchecked:<src_cap_filter:src> Received event on flushing pad. Discarding
0:00:00.867871931 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<src_sub_bin3> adding pad ‘src’
0:00:00.867886268 7845 0x3cd36c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “fakesink” named “src_fakesink”
0:00:00.867974783 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseSink@0x3fbf9e0 adding pad ‘sink’
0:00:00.868003361 7845 0x3cd36c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “queue” named “fakequeue”
0:00:00.868038242 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x4183590 adding pad ‘sink’
0:00:00.868077188 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x4183590 adding pad ‘src’
0:00:00.868107973 7845 0x3cd36c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “tee”
0:00:00.868146759 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstTee@0x418b3f0 adding pad ‘sink’
0:00:00.868196617 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element fakequeue:(any) to element src_fakesink:(any)
0:00:00.868216554 7845 0x3cd36c0 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link fakequeue:src and src_fakesink:sink
0:00:00.868234890 7845 0x3cd36c0 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:fakequeue:sink pad has no peer
0:00:00.868259211 7845 0x3cd36c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: fakequeue and src_fakesink in same bin, no need for ghost pads
0:00:00.868281996 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link fakequeue:src and src_fakesink:sink
0:00:00.868300333 7845 0x3cd36c0 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:fakequeue:sink pad has no peer
0:00:00.868323758 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked fakequeue:src and src_fakesink:sink, successful
0:00:00.868402737 7845 0x3cd36c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.868417970 7845 0x3cd36c0 INFO GST_EVENT gstpad.c:5785:gst_pad_send_event_unchecked:fakequeue:src Received event on flushing pad. Discarding
0:00:00.868459508 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad: adding pad ‘src_0’
0:00:00.868480597 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad src_cap_filter:sink
0:00:00.868503382 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link tee3:src_0 and src_cap_filter:sink
0:00:00.868523607 7845 0x3cd36c0 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:tee3:sink pad has no peer
0:00:00.868546648 7845 0x3cd36c0 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:<src_sub_bin3:src> pad has no peer
0:00:00.868612282 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked tee3:src_0 and src_cap_filter:sink, successful
0:00:00.868626779 7845 0x3cd36c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.868656476 7845 0x3cd36c0 INFO GST_EVENT gstpad.c:5785:gst_pad_send_event_unchecked:tee3:src_0 Received event on flushing pad. Discarding
0:00:00.868694430 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad: adding pad ‘src_1’
0:00:00.868714847 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad fakequeue:sink
0:00:00.868736544 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link tee3:src_1 and fakequeue:sink
0:00:00.868754944 7845 0x3cd36c0 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:tee3:sink pad has no peer
0:00:00.868782049 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked tee3:src_1 and fakequeue:sink, successful
0:00:00.868819939 7845 0x3cd36c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.868835428 7845 0x3cd36c0 INFO GST_EVENT gstpad.c:5785:gst_pad_send_event_unchecked:tee3:src_1 Received event on flushing pad. Discarding
0:00:00.868902247 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:917:gst_element_get_static_pad: no such pad ‘sink_3’ in element “src_bin_muxer”
0:00:00.869185266 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<src_bin_muxer> adding pad ‘sink_3’
0:00:00.869212116 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad src_sub_bin3:src
0:00:00.869236117 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link src_sub_bin3:src and src_bin_muxer:sink_3
0:00:00.869260790 7845 0x3cd36c0 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:tee3:sink pad has no peer
0:00:00.869284951 7845 0x3cd36c0 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:<src_bin_muxer:src> pad has no peer
0:00:00.869323608 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked src_sub_bin3:src and src_bin_muxer:sink_3, successful
0:00:00.869338553 7845 0x3cd36c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.869358170 7845 0x3cd36c0 INFO GST_EVENT gstpad.c:5785:gst_pad_send_event_unchecked:<src_sub_bin3:src> Received event on flushing pad. Discarding
0:00:00.869389339 7845 0x3cd36c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “bin” named “src_sub_bin4”
0:00:00.869424509 7845 0x3cd36c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “uridecodebin” named “src_elem”
0:00:00.869480511 7845 0x3cd36c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “queue” named “src_cap_filter”
0:00:00.869556642 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x4183890 adding pad ‘sink’
0:00:00.869594532 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x4183890 adding pad ‘src’
0:00:00.869647942 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad src_cap_filter:src
0:00:00.869741098 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link src_cap_filter:src and src:proxypad4
0:00:00.869765803 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked src_cap_filter:src and src:proxypad4, successful
0:00:00.869779660 7845 0x3cd36c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.869794092 7845 0x3cd36c0 INFO GST_EVENT gstpad.c:5785:gst_pad_send_event_unchecked:<src_cap_filter:src> Received event on flushing pad. Discarding
0:00:00.869815853 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<src_sub_bin4> adding pad ‘src’
0:00:00.869834286 7845 0x3cd36c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “fakesink” named “src_fakesink”
0:00:00.869877424 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseSink@0x3fbdbe0 adding pad ‘sink’
0:00:00.869900977 7845 0x3cd36c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “queue” named “fakequeue”
0:00:00.869942354 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x4183b90 adding pad ‘sink’
0:00:00.869980692 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x4183b90 adding pad ‘src’
0:00:00.870014582 7845 0x3cd36c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “tee”
0:00:00.870057207 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstTee@0x418b540 adding pad ‘sink’
0:00:00.870112090 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element fakequeue:(any) to element src_fakesink:(any)
0:00:00.870132923 7845 0x3cd36c0 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link fakequeue:src and src_fakesink:sink
0:00:00.870151419 7845 0x3cd36c0 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:fakequeue:sink pad has no peer
0:00:00.870213438 7845 0x3cd36c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: fakequeue and src_fakesink in same bin, no need for ghost pads
0:00:00.870237247 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link fakequeue:src and src_fakesink:sink
0:00:00.870255584 7845 0x3cd36c0 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:fakequeue:sink pad has no peer
0:00:00.870279073 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked fakequeue:src and src_fakesink:sink, successful
0:00:00.870294177 7845 0x3cd36c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.870308418 7845 0x3cd36c0 INFO GST_EVENT gstpad.c:5785:gst_pad_send_event_unchecked:fakequeue:src Received event on flushing pad. Discarding
0:00:00.870342691 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad: adding pad ‘src_0’
0:00:00.870361732 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad src_cap_filter:sink
0:00:00.870384421 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link tee4:src_0 and src_cap_filter:sink
0:00:00.870403110 7845 0x3cd36c0 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:tee4:sink pad has no peer
0:00:00.870425991 7845 0x3cd36c0 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:<src_sub_bin4:src> pad has no peer
0:00:00.870449032 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked tee4:src_0 and src_cap_filter:sink, successful
0:00:00.870462760 7845 0x3cd36c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.870478281 7845 0x3cd36c0 INFO GST_EVENT gstpad.c:5785:gst_pad_send_event_unchecked:tee4:src_0 Received event on flushing pad. Discarding
0:00:00.870513995 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad: adding pad ‘src_1’
0:00:00.870532171 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad fakequeue:sink
0:00:00.870583918 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link tee4:src_1 and fakequeue:sink
0:00:00.870604782 7845 0x3cd36c0 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:tee4:sink pad has no peer
0:00:00.870631216 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked tee4:src_1 and fakequeue:sink, successful
0:00:00.870644976 7845 0x3cd36c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.870658769 7845 0x3cd36c0 INFO GST_EVENT gstpad.c:5785:gst_pad_send_event_unchecked:tee4:src_1 Received event on flushing pad. Discarding
0:00:00.870721651 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:917:gst_element_get_static_pad: no such pad ‘sink_4’ in element “src_bin_muxer”
0:00:00.870955901 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<src_bin_muxer> adding pad ‘sink_4’
0:00:00.870980414 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad src_sub_bin4:src
0:00:00.871012192 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link src_sub_bin4:src and src_bin_muxer:sink_4
0:00:00.871043329 7845 0x3cd36c0 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:tee4:sink pad has no peer
0:00:00.871068290 7845 0x3cd36c0 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:<src_bin_muxer:src> pad has no peer
0:00:00.871135685 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked src_sub_bin4:src and src_bin_muxer:sink_4, successful
0:00:00.871149765 7845 0x3cd36c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.871169062 7845 0x3cd36c0 INFO GST_EVENT gstpad.c:5785:gst_pad_send_event_unchecked:<src_sub_bin4:src> Received event on flushing pad. Discarding
0:00:00.871193735 7845 0x3cd36c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “bin” named “src_sub_bin5”
0:00:00.871226921 7845 0x3cd36c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “uridecodebin” named “src_elem”
0:00:00.871270379 7845 0x3cd36c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “queue” named “src_cap_filter”
0:00:00.871336557 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x41dc1a0 adding pad ‘sink’
0:00:00.871374191 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x41dc1a0 adding pad ‘src’
0:00:00.871425265 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad src_cap_filter:src
0:00:00.871469971 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link src_cap_filter:src and src:proxypad5
0:00:00.871488564 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked src_cap_filter:src and src:proxypad5, successful
0:00:00.871501684 7845 0x3cd36c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.871515861 7845 0x3cd36c0 INFO GST_EVENT gstpad.c:5785:gst_pad_send_event_unchecked:<src_cap_filter:src> Received event on flushing pad. Discarding
0:00:00.871536566 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<src_sub_bin5> adding pad ‘src’
0:00:00.871554871 7845 0x3cd36c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “fakesink” named “src_fakesink”
0:00:00.871587640 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseSink@0x3fb91e0 adding pad ‘sink’
0:00:00.871613401 7845 0x3cd36c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “queue” named “fakequeue”
0:00:00.871651899 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x41dc4a0 adding pad ‘sink’
0:00:00.871690780 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x41dc4a0 adding pad ‘src’
0:00:00.871724446 7845 0x3cd36c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “tee”
0:00:00.871763423 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstTee@0x418b690 adding pad ‘sink’
0:00:00.871845571 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element fakequeue:(any) to element src_fakesink:(any)
0:00:00.871867748 7845 0x3cd36c0 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link fakequeue:src and src_fakesink:sink
0:00:00.871885957 7845 0x3cd36c0 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:fakequeue:sink pad has no peer
0:00:00.871909254 7845 0x3cd36c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: fakequeue and src_fakesink in same bin, no need for ghost pads
0:00:00.871931879 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link fakequeue:src and src_fakesink:sink
0:00:00.871950407 7845 0x3cd36c0 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:fakequeue:sink pad has no peer
0:00:00.871974056 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked fakequeue:src and src_fakesink:sink, successful
0:00:00.871999081 7845 0x3cd36c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.872012874 7845 0x3cd36c0 INFO GST_EVENT gstpad.c:5785:gst_pad_send_event_unchecked:fakequeue:src Received event on flushing pad. Discarding
0:00:00.872051820 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad: adding pad ‘src_0’
0:00:00.872070476 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad src_cap_filter:sink
0:00:00.872092941 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link tee5:src_0 and src_cap_filter:sink
0:00:00.872110734 7845 0x3cd36c0 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:tee5:sink pad has no peer
0:00:00.872133071 7845 0x3cd36c0 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:<src_sub_bin5:src> pad has no peer
0:00:00.872155216 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked tee5:src_0 and src_cap_filter:sink, successful
0:00:00.872168465 7845 0x3cd36c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.872182321 7845 0x3cd36c0 INFO GST_EVENT gstpad.c:5785:gst_pad_send_event_unchecked:tee5:src_0 Received event on flushing pad. Discarding
0:00:00.872217427 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad: adding pad ‘src_1’
0:00:00.872235891 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad fakequeue:sink
0:00:00.872279669 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link tee5:src_1 and fakequeue:sink
0:00:00.872328791 7845 0x3cd36c0 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:tee5:sink pad has no peer
0:00:00.872357177 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked tee5:src_1 and fakequeue:sink, successful
0:00:00.872370873 7845 0x3cd36c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.872392570 7845 0x3cd36c0 INFO GST_EVENT gstpad.c:5785:gst_pad_send_event_unchecked:tee5:src_1 Received event on flushing pad. Discarding
0:00:00.872461565 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:917:gst_element_get_static_pad: no such pad ‘sink_5’ in element “src_bin_muxer”
0:00:00.872697991 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<src_bin_muxer> adding pad ‘sink_5’
0:00:00.872723592 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad src_sub_bin5:src
0:00:00.872789739 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link src_sub_bin5:src and src_bin_muxer:sink_5
0:00:00.872815404 7845 0x3cd36c0 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:tee5:sink pad has no peer
0:00:00.872839693 7845 0x3cd36c0 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:<src_bin_muxer:src> pad has no peer
0:00:00.872877326 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked src_sub_bin5:src and src_bin_muxer:sink_5, successful
0:00:00.872892143 7845 0x3cd36c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.872906352 7845 0x3cd36c0 INFO GST_EVENT gstpad.c:5785:gst_pad_send_event_unchecked:<src_sub_bin5:src> Received event on flushing pad. Discarding
0:00:00.872930513 7845 0x3cd36c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “bin” named “src_sub_bin6”
0:00:00.872963282 7845 0x3cd36c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “uridecodebin” named “src_elem”
0:00:00.873026581 7845 0x3cd36c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “queue” named “src_cap_filter”
0:00:00.873091032 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x41dc7a0 adding pad ‘sink’
0:00:00.873134041 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x41dc7a0 adding pad ‘src’
0:00:00.873187708 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad src_cap_filter:src
0:00:00.873239262 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link src_cap_filter:src and src:proxypad6
0:00:00.873260191 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked src_cap_filter:src and src:proxypad6, successful
0:00:00.873274015 7845 0x3cd36c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.873288576 7845 0x3cd36c0 INFO GST_EVENT gstpad.c:5785:gst_pad_send_event_unchecked:<src_cap_filter:src> Received event on flushing pad. Discarding
0:00:00.873309921 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<src_sub_bin6> adding pad ‘src’
0:00:00.873327970 7845 0x3cd36c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “fakesink” named “src_fakesink”
0:00:00.873360195 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseSink@0x3fb75e0 adding pad ‘sink’
0:00:00.873385156 7845 0x3cd36c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “queue” named “fakequeue”
0:00:00.873457191 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x41dcaa0 adding pad ‘sink’
0:00:00.873494729 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x41dcaa0 adding pad ‘src’
0:00:00.873534058 7845 0x3cd36c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “tee”
0:00:00.873573292 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstTee@0x418b7e0 adding pad ‘sink’
0:00:00.873624462 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element fakequeue:(any) to element src_fakesink:(any)
0:00:00.873644783 7845 0x3cd36c0 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link fakequeue:src and src_fakesink:sink
0:00:00.873663216 7845 0x3cd36c0 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:fakequeue:sink pad has no peer
0:00:00.873689233 7845 0x3cd36c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: fakequeue and src_fakesink in same bin, no need for ghost pads
0:00:00.873708306 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link fakequeue:src and src_fakesink:sink
0:00:00.873721970 7845 0x3cd36c0 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:fakequeue:sink pad has no peer
0:00:00.873779061 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked fakequeue:src and src_fakesink:sink, successful
0:00:00.873794069 7845 0x3cd36c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.873808470 7845 0x3cd36c0 INFO GST_EVENT gstpad.c:5785:gst_pad_send_event_unchecked:fakequeue:src Received event on flushing pad. Discarding
0:00:00.873844407 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad: adding pad ‘src_0’
0:00:00.873923835 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad src_cap_filter:sink
0:00:00.873948988 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link tee6:src_0 and src_cap_filter:sink
0:00:00.873967773 7845 0x3cd36c0 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:tee6:sink pad has no peer
0:00:00.873995006 7845 0x3cd36c0 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:<src_sub_bin6:src> pad has no peer
0:00:00.874017215 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked tee6:src_0 and src_cap_filter:sink, successful
0:00:00.874030047 7845 0x3cd36c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.874048000 7845 0x3cd36c0 INFO GST_EVENT gstpad.c:5785:gst_pad_send_event_unchecked:tee6:src_0 Received event on flushing pad. Discarding
0:00:00.874082881 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad: adding pad ‘src_1’
0:00:00.874102082 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad fakequeue:sink
0:00:00.874139460 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link tee6:src_1 and fakequeue:sink
0:00:00.874158245 7845 0x3cd36c0 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:tee6:sink pad has no peer
0:00:00.874183942 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked tee6:src_1 and fakequeue:sink, successful
0:00:00.874197382 7845 0x3cd36c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.874207527 7845 0x3cd36c0 INFO GST_EVENT gstpad.c:5785:gst_pad_send_event_unchecked:tee6:src_1 Received event on flushing pad. Discarding
0:00:00.874272073 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:917:gst_element_get_static_pad: no such pad ‘sink_6’ in element “src_bin_muxer”
0:00:00.874504883 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<src_bin_muxer> adding pad ‘sink_6’
0:00:00.874541461 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad src_sub_bin6:src
0:00:00.874562390 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link src_sub_bin6:src and src_bin_muxer:sink_6
0:00:00.874586327 7845 0x3cd36c0 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:tee6:sink pad has no peer
0:00:00.874608536 7845 0x3cd36c0 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:<src_bin_muxer:src> pad has no peer
0:00:00.874647609 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked src_sub_bin6:src and src_bin_muxer:sink_6, successful
0:00:00.874662522 7845 0x3cd36c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.874683131 7845 0x3cd36c0 INFO GST_EVENT gstpad.c:5785:gst_pad_send_event_unchecked:<src_sub_bin6:src> Received event on flushing pad. Discarding
0:00:00.874709436 7845 0x3cd36c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “bin” named “src_sub_bin7”
0:00:00.874762782 7845 0x3cd36c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “uridecodebin” named “src_elem”
0:00:00.874823105 7845 0x3cd36c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “queue” named “src_cap_filter”
0:00:00.874869987 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x41dcda0 adding pad ‘sink’
0:00:00.874908676 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x41dcda0 adding pad ‘src’
0:00:00.874959622 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad src_cap_filter:src
0:00:00.875006280 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link src_cap_filter:src and src:proxypad7
0:00:00.875025609 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked src_cap_filter:src and src:proxypad7, successful
0:00:00.875038698 7845 0x3cd36c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.875055499 7845 0x3cd36c0 INFO GST_EVENT gstpad.c:5785:gst_pad_send_event_unchecked:<src_cap_filter:src> Received event on flushing pad. Discarding
0:00:00.875092332 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<src_sub_bin7> adding pad ‘src’
0:00:00.875111213 7845 0x3cd36c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “fakesink” named “src_fakesink”
0:00:00.875161743 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstBaseSink@0x3fb67e0 adding pad ‘sink’
0:00:00.875205457 7845 0x3cd36c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element “queue” named “fakequeue”
0:00:00.875245011 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x41dd0a0 adding pad ‘sink’
0:00:00.875280884 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstQueue@0x41dd0a0 adding pad ‘src’
0:00:00.875316694 7845 0x3cd36c0 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element “tee”
0:00:00.875354839 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:GstTee@0x418b930 adding pad ‘sink’
0:00:00.875405529 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstutils.c:1774:gst_element_link_pads_full: trying to link element fakequeue:(any) to element src_fakesink:(any)
0:00:00.875426362 7845 0x3cd36c0 INFO GST_PADS gstutils.c:1035:gst_pad_check_link: trying to link fakequeue:src and src_fakesink:sink
0:00:00.875444379 7845 0x3cd36c0 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:fakequeue:sink pad has no peer
0:00:00.875463708 7845 0x3cd36c0 INFO GST_PADS gstutils.c:1588:prepare_link_maybe_ghosting: fakequeue and src_fakesink in same bin, no need for ghost pads
0:00:00.875515198 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link fakequeue:src and src_fakesink:sink
0:00:00.875535551 7845 0x3cd36c0 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:fakequeue:sink pad has no peer
0:00:00.875560000 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked fakequeue:src and src_fakesink:sink, successful
0:00:00.875573664 7845 0x3cd36c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.875587873 7845 0x3cd36c0 INFO GST_EVENT gstpad.c:5785:gst_pad_send_event_unchecked:fakequeue:src Received event on flushing pad. Discarding
0:00:00.875623138 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad: adding pad ‘src_0’
0:00:00.875642595 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad src_cap_filter:sink
0:00:00.875666116 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link tee7:src_0 and src_cap_filter:sink
0:00:00.875684517 7845 0x3cd36c0 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:tee7:sink pad has no peer
0:00:00.875709382 7845 0x3cd36c0 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:<src_sub_bin7:src> pad has no peer
0:00:00.875732327 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked tee7:src_0 and src_cap_filter:sink, successful
0:00:00.875746088 7845 0x3cd36c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.875759912 7845 0x3cd36c0 INFO GST_EVENT gstpad.c:5785:gst_pad_send_event_unchecked:tee7:src_0 Received event on flushing pad. Discarding
0:00:00.875794666 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad: adding pad ‘src_1’
0:00:00.875845036 7845 0x3cd36c0 INFO GST_ELEMENT_PADS gstelement.c:920:gst_element_get_static_pad: found pad fakequeue:sink
0:00:00.875869741 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2378:gst_pad_link_prepare: trying to link tee7:src_1 and fakequeue:sink
0:00:00.875888238 7845 0x3cd36c0 INFO GST_PADS gstpad.c:4230:gst_pad_peer_query:tee7:sink pad has no peer
0:00:00.875916623 7845 0x3cd36c0 INFO GST_PADS gstpad.c:2586:gst_pad_link_full: linked tee7:src_1 and fakequeue:sink, successful
0:00:00.875930799 7845 0x3cd36c0 INFO GST_EVENT gstevent.c:1517:gst_event_new_reconfigure: creating reconfigure event
0:00:00.875948464 7845 0x3cd36c0 INFO
I removed the file rm /home/olympus/.cache/gstreamer-1.0/registry.aarch64.bin and then try runing the sample again with debug mode.As a result, it printed a lot. That sounds like lack of registry.aarch64.bin?
The log seems not complete, can you run again without sudo?
in
egistry.aarch64.bin
ream.so" loaded
so" loaded
nts.so" loaded
0:00:00.875948464 7845 0x3cd36c0 INFO GST_EVENT gstpa
I try again, but the logs is too long to paste.As a result, I put the log file on my github [url]https://github.com/AirBernard/NvDeepStream-Object-Detection-/blob/master/Xavier_2019-01-18_22-22-10.log[/url]
[s]
Do any log after these lines? should have many line of log following it, gie element still not loading from the
log.[/s]
UND is undefined in the libnvll_infer.so.1.0.0,
can you do this,
objdump -txT /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvinfer.so |grep initLibNvInferPlugins
and this, dpkg -l|grep nvinfer
here is one reference
ii libnvinfer-dev 5.0.3-1+cuda10.0 arm64 TensorRT development libraries and headers
ii libnvinfer-samples 5.0.3-1+cuda10.0 all TensorRT samples and documentation
ii libnvinfer5 5.0.3-1+cuda10.0 arm64 TensorRT runtime libraries
and paste the output.
nvidia@jetson-0423218011183:~/DeepStream/deepstream_sdk_on_jetson/samples$ objdump -txT /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvinfer.so | grep initLibNvInferPlugins
nvidia@jetson-0423218011183:~/DeepStream/deepstream_sdk_on_jetson/samples$ dpkg -l | grep nvinfer
ii libnvinfer-dev 5.0.0-1+cuda10.0 arm64 TensorRT development libraries and headers
ii libnvinfer-samples 5.0.0-1+cuda10.0 arm64 TensorRT samples and documentation
ii libnvinfer5 5.0.0-1+cuda10.0 arm64 TensorRT runtime libraries
log.log (600 KB)
I met the same question when install DeepStream SDK 3.0 on Jetson AGX Xavier,please check the log #12 above @amycao . Thank you !
Here is my log when run deep-app :
nvidia@jetson-0423218011183:~/DeepStream/deepstream_sdk_on_jetson/samples$ deepstream-app -c configs/deepstream-app/source4_720p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt
(gst-plugin-scanner:24341): GStreamer-WARNING **: 14:43:23.624: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvinfer.so’: /usr/lib/aarch64-linux-gnu/tegra/libnvll_infer.so.1.0.0: undefined symbol: initLibNvInferPlugins
(gst-plugin-scanner:24341): GStreamer-WARNING **: 14:43:23.723: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstopenglmixers.so’: /usr/lib/aarch64-linux-gnu/libgbm.so.1: undefined symbol: drmGetDevice2
(gst-plugin-scanner:24341): GStreamer-WARNING **: 14:43:23.786: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libcluttergst3.so’: /usr/lib/aarch64-linux-gnu/libgbm.so.1: undefined symbol: drmGetDevice2
(gst-plugin-scanner:24341): GStreamer-WARNING **: 14:43:24.049: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstopengl.so’: /usr/lib/aarch64-linux-gnu/libgbm.so.1: undefined symbol: drmGetDevice2
** ERROR: <create_secondary_gie:160>: Failed to create ‘secondary_gie_0’
** ERROR: <create_secondary_gie:248>: create_secondary_gie failed
** ERROR: <create_secondary_gie_bin:382>: create_secondary_gie_bin failed
Quitting
App run failed
return Nothing
dpkg -l|grep nvinfer:
return nothing means initLibNvInferPlugins not defined, Can you try again with TensorRT 5.0.3 within
jetpack 4.1.1?
Hi amycao,
could you install deepstream3.0 with TensorRT 5.0.3 && jetpack 4.1.1? your jetpack version is 4.1.1??
Thanks for you any reply, I’ll be appreciated!
My jetpack is 4.1.1, which version you are using?
Amycao,
Could this be due to a dependency of TensorRT 5.0.3, currently 5.0.0 comes with the JetPack 4.1.1 installation. If so how can we update to TRT 5.0.3, which seems to only be available for server deployments.
Howdy all,
I was running into issues, upgrading my Xavier to Jetpack 4.1.1 fixed the problem. Unbeknownst to me it had originally been flashed with 4.0. Deepstream examples now run as expected.
