Failed to create element 'src_bin_muxer'
I encountered the following error when running the sample app.
deepstream-app -c source30_720p_dec_infer-resnet_tiled_display_int8.txt
** ERROR: <create_multi_source_bin:347>: Failed to create element 'src_bin_muxer'
** ERROR: <create_multi_source_bin:402>: create_multi_source_bin failed
** ERROR: <create_pipeline:949>: create_pipeline failed
** ERROR: <main:469>: Failed to create pipeline
Quitting
(deepstream-app:24365): GStreamer-CRITICAL **: gst_element_get_static_pad: assertion 'GST_IS_ELEMENT (element)' failed
(deepstream-app:24365): GStreamer-CRITICAL **: gst_pad_send_event: assertion 'GST_IS_PAD (pad)' failed
Someone also encountered the same error here.
https://devtalk.nvidia.com/default/topic/1036680/deepstream-for-tesla/nvidia-deepstream-sdk-2-0-for-tesla-now-available/
Any pointer is appreciated.
It turns out the error is misleading. After running
rm ${HOME}/.cache/gstreamer-1.0/registry.x86_64.bin
to clean the cache, the framework is reset and display more informative errors, e.g. missing of the maching tensorRT version 4.
Also, in the documentation pg. 7, it should be
not
rm $(HOME)/.cache/gstreamer-1.0/registry.x86_64.bin
please export nvidia related plugin by export GST_PLUGIN_PATH=/path to your ds pack/usr/lib/x86_64-linux-gnu/gstreamer-1.0/
export local library LD_LIBRARY_PATH=/path to your ds pack/usr/local/deepstream:/other lib need to export like cv;tensorrt;/
and then try again.
I encountered same error as below, any hints?
root@c5c0fb0d10b2:/ml/deepstream/DeepStream_Release/samples/configs/deepstream-app# deepstream-app -c source4_720p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt
(gst-plugin-scanner:2544): GStreamer-WARNING **: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstnvvidconv.so': libcudart.so.9.2: cannot open shared object file: No such file or directory
(gst-plugin-scanner:2544): GStreamer-WARNING **: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstnvtracker.so': libcudart.so.9.2: cannot open shared object file: No such file or directory
(gst-plugin-scanner:2544): GStreamer-WARNING **: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstnvmultistream.so': libcudart.so.9.2: cannot open shared object file: No such file or directory
(gst-plugin-scanner:2544): GStreamer-WARNING **: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstnveglglessink.so': libcudart.so.9.2: cannot open shared object file: No such file or directory
(gst-plugin-scanner:2544): GStreamer-WARNING **: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstnvdsexample.so': libcudart.so.9.2: cannot open shared object file: No such file or directory
(gst-plugin-scanner:2544): GStreamer-WARNING **: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstnvosd.so': libcudart.so.9.2: cannot open shared object file: No such file or directory
(gst-plugin-scanner:2544): GStreamer-WARNING **: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstnvvideocodecs.so': libcudart.so.9.2: cannot open shared object file: No such file or directory
(gst-plugin-scanner:2544): GStreamer-WARNING **: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstnvinfer.so': libcudart.so.9.2: cannot open shared object file: No such file or directory
Quitting
(deepstream-app:2543): GStreamer-CRITICAL **: gst_element_get_static_pad: assertion 'GST_IS_ELEMENT (element)' failed
(deepstream-app:2543): GStreamer-CRITICAL **: gst_pad_send_event: assertion 'GST_IS_PAD (pad)' failed
App run failed
please export nvidia related plugin by export GST_PLUGIN_PATH=/path to your ds pack/usr/lib/x86_64-linux-gnu/gstreamer-1.0/,if you
install them into system path,you can ignore this.
and then try again.
Thank you, after upgraded CUDA 9.0 to CUDA 9.2, the issue was solved.
How can I modify the file source4_720p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt to disable video output as the server has no VGA port for display.
Below error occurred when I run the demo again:
** ERROR: <main:490>: Failed to set pipeline to PAUSED
Quitting
App run failed
Type - 1=FakeSink 2=EglSink 3=File from config
this is the sink type, you can use type 1 or type 3.
@amycao, thanks a lot, it works!
What does “path to your ds pack” mean? I can find the package directly at /usr/lib/x86_64-linux-gnu/gstreamer-1.0/
These are the path that I exported:
export CUDA_HOME=“/usr/local/cuda-9.2”
export LD_LIBRARY_PATH=“/usr/local/cuda-9.2/lib64”:$LD_LIBRARY_PATH
export PATH=“/usr/local/cuda-9.2/bin”:$PATH
export LD_LIBRARY_PATH=“/usr/local/lib/:/usr/local/deepstream:${HOME}/opencv-3.4.0/build/lib/”:$LD_LIBRARY_PATH
export GST_PLUGIN_PATH=“/usr/lib/x86_64-linux-gnu/gstreamer-1.0/”
But I still get src_bin_muxer error
After I add at my ~/.bashrc
export CUDA_HOME="/usr/local/cuda-10.0"
export PATH="/home/suryadi/.local/bin:/usr/local/cuda-10.0/bin:/media/suryadi/DATA/anaconda3/bin:$PATH"
export LD_PATH_LIBRARY="/usr/local/cuda-10.0/lib64:/usr/local/lib:/opt/nvidia/deepstream/deepstream-4.0/lib"
export LD_LIBRARY_PATH="/usr/local/lib:/usr/local/cuda-10.0/lib64/"
export LIBRARY_PATH="$LIBRARY_PATH:/usr/local/cuda-10.0/lib64"
export LD_RUN_PATH="/usr/local/lib"
export GST_PLUGIN_PATH="/usr/lib/x86_64-linux-gnu/gstreamer-1.0/"
$ deepstream-app -c deepstream_app_config_yoloV3_tiny.txt ../../../deepstream-4.0/samples/streams/sample_720p.h264
0:00:00.012240788  6341 0x55945dc8a600 ERROR        NVDS_CFG_PARSER deepstream_app_config_parser.c:152:parse_config_file: Failed to load uri file: No such file or directory
** ERROR: <parse_config_file:304>: parse_config_file failed
** ERROR: <main:623>: Failed to parse config file 'deepstream_app_config_yoloV3_tiny.txt'
Quitting
App run failed
How to solve this problem? Thanks.
I have the same problem with #10. Any help?
Please check the README file.
deepstream_sdk_v4.0.1_jetson\sources\objectDetector_Yolo\README
You probably miss the steps:
deepstream_sdk_v4.0.1_jetson/sources/objectDetector_Yolo$ ./prebuild.sh
deepstream_sdk_v4.0.1_jetson/sources/objectDetector_Yolo$ CUDA_VER=10.0 make -C nvdsinfer_custom_impl_Yolo
It should work by simply run
deepstream_sdk_v4.0.1_jetson/sources/objectDetector_Yolo$ deepstream-app -c deepstream_app_config_yoloV3_tiny.txt
I am facing the exact same issue on DS 5.0 on Jetson NX where I used samples docker for DS pulled from NGC.
I wanted to try this:
But not able to find registry.x86_64.bin file anywhere inside or outside docker.
Hey @Amycao please help on this…
Can you find nvstreammux?
gst-inspect-1.0 nvstreammux
@Amycao
Getting
No such element or plugin ‘nvstreammux’
Can you run outside docker?
@Amycao
Getting same output:
How to resolve the issue?
rm ${HOME}/.cache/gstreamer-1.0/ -rf
and get more log.
Can you just tell us $HOME for jetson?
/home/nvidia/
