Deepstream docker orin - Need help getting a working system up
• Hardware Platform (Jetson / GPU) Jetson AGX Orin development kit
• DeepStream Version 6.4
• JetPack Version (valid for Jetson only) 6.0DP
• TensorRT Version8.6.2.3
Questions
Looking for help running demo application on docker image nvcr.io/nvidia/deepstream:6.4-samples-multiarch.
I am running this headless.
Launch with sudo docker run -it --rm --runtime=nvidia --privileged -e DISPLAY=:0 -v /tmp/.X11-unix:/tmp/.X11-unix nvcr.io/nvidia/deepstream:6.4-samples-multiarch
gst-inspect-1.0 -b gives
(gst-plugin-scanner:40): GStreamer-WARNING **: 11:41:57.480: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstmpeg2enc.so': libmpeg2encpp-2.1.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:40): GStreamer-WARNING **: 11:41:57.525: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstmpeg2dec.so': libmpeg2.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:40): GStreamer-WARNING **: 11:41:57.632: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstchromaprint.so': libavcodec.so.58: cannot open shared object file: No such file or directory
(gst-plugin-scanner:40): GStreamer-WARNING **: 11:41:57.637: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstmpg123.so': libmpg123.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:40): GStreamer-WARNING **: 11:41:57.695: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstopenmpt.so': libmpg123.so.0: cannot open shared object file: No such file or directory
Also tried sudo docker run -it --rm --runtime=nvidia --privileged -e DISPLAY=:0 -v /tmp/.X11-unix:/tmp/.X11-unix -v /usr/lib/aarch64-linux-gnu/:/usr/lib/aarch64-linux-gnu/ nvcr.io/nvidia/deepstream:6.4-samples-multiarch
I did install outside of the container.
sudo apt install \
libssl3 \
libgstreamer1.0-0 \
gstreamer1.0-tools \
gstreamer1.0-plugins-good \
gstreamer1.0-plugins-bad \
gstreamer1.0-plugins-ugly \
gstreamer1.0-libav \
libgstreamer-plugins-base1.0-dev \
libgstrtspserver-1.0-0 \
libjansson4 \
libyaml-cpp-dev
# gst-inspect-1.0 -b
(gst-plugin-scanner:39): GStreamer-WARNING **: 11:44:18.664: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstmpeg2enc.so': libmpeg2encpp-2.1.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:39): GStreamer-WARNING **: 11:44:18.704: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstmpeg2dec.so': libmpeg2.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:39): GStreamer-WARNING **: 11:44:18.796: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstchromaprint.so': libavcodec.so.58: cannot open shared object file: No such file or directory
(gst-plugin-scanner:39): GStreamer-WARNING **: 11:44:18.801: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstmpg123.so': libmpg123.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:39): GStreamer-WARNING **: 11:44:18.853: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstopenmpt.so': libmpg123.so.0: cannot open shared object file: No such file or directory
Authorization required, but no authorization protocol specified
nvbufsurftransform: Could not get EGL display connection
(Argus) Error FileOperationFailed: Connecting to nvargus-daemon failed: No such file or directory (in src/rpc/socket/client/SocketClientDispatch.cpp, function openSocketConnection(), line 204)
(Argus) Error FileOperationFailed: Cannot create camera provider (in src/rpc/socket/client/SocketClientDispatch.cpp, function createCameraProvider(), line 106)
(gst-plugin-scanner:39): GStreamer-WARNING **: 11:44:18.988: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libtritonserver.so: cannot open shared object file: No such file or directory
(gst-plugin-scanner:39): GStreamer-WARNING **: 11:44:18.994: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so': librivermax.so.0: cannot open shared object file: No such file or directory
Blacklisted files:
  libcustom2d_preprocess.so
  libgstmpeg2dec.so
  libgstmpeg2enc.so
  libgstmpg123.so
  libgstopenmpt.so
  libnvdsgst_udp.so
Total count: 8 blacklisted files
Also tried using install scripts.
root@ad3fae1ddbb9:/opt/nvidia/deepstream/deepstream-6.4# ./install.sh
root@ad3fae1ddbb9:/opt/nvidia/deepstream/deepstream-6.4# ./user_additional_install.sh
Install goes fine. New gst-inspect-1.0 -b results
root@ad3fae1ddbb9:/opt/nvidia/deepstream/deepstream-6.4# gst-inspect-1.0 -b
(gst-plugin-scanner:622): GStreamer-WARNING **: 11:45:53.491: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libtritonserver.so: cannot open shared object file: No such file or directory
(gst-plugin-scanner:622): GStreamer-WARNING **: 11:45:53.497: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so': librivermax.so.0: cannot open shared object file: No such file or directory
Blacklisted files:
  libnvdsgst_udp.so
Total count: 3 blacklisted files
Try running sample app in this manner
root@ad3fae1ddbb9:/opt/nvidia/deepstream/deepstream-6.4/samples# deepstream-app -c configs/deepstream-app/source2_1080p_dec_infer-resnet_demux_int8.txt
(deepstream-app:636): GLib-GObject-WARNING **: 11:46:25.251: g_object_set_is_valid_property: object class 'nvv4l2h264enc' has no property named 'gpu-id'
(deepstream-app:636): GLib-GObject-WARNING **: 11:46:25.271: g_object_set_is_valid_property: object class 'nvv4l2h264enc' has no property named 'gpu-id'
Opening in BLOCKING MODE
WARNING: Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-6.4/samples/configs/deepstream-app/../../models/Primary_Detector/resnet18_trafficcamnet.etlt_b2_gpu0_int8.engine open error
0:00:06.467978928   636 0xaaaaeaf7c430 WARN                 nvinfer gstnvinfer.cpp:679:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2080> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-6.4/samples/configs/deepstream-app/../../models/Primary_Detector/resnet18_trafficcamnet.etlt_b2_gpu0_int8.engine failed
0:00:06.827435616   636 0xaaaaeaf7c430 WARN                 nvinfer gstnvinfer.cpp:679:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2185> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-6.4/samples/configs/deepstream-app/../../models/Primary_Detector/resnet18_trafficcamnet.etlt_b2_gpu0_int8.engine failed, try rebuild
0:02:31.716192248   636 0xaaaaeaf7c430 INFO                 nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:2138> [UID = 1]: serialize cuda engine to file: /opt/nvidia/deepstream/deepstream-6.4/samples/models/Primary_Detector/resnet18_trafficcamnet.etlt_b2_gpu0_int8.engine successfully
INFO: [Implicit Engine Info]: layers num: 3
0   INPUT  kFLOAT input_1         3x544x960
1   OUTPUT kFLOAT output_bbox/BiasAdd 16x34x60
2   OUTPUT kFLOAT output_cov/Sigmoid 4x34x60
nvbufsurface: Could not get EGL display connection
nvbufsurface: Can't get EGL display
0:02:32.109741508   636 0xaaaaeaf7c430 WARN                 nvinfer gstnvinfer.cpp:994:gst_nvinfer_start:<primary_gie> error: Failed to set buffer pool to active
** ERROR: <main:716>: Failed to set pipeline to PAUSED
Quitting
ERROR from primary_gie: Failed to set buffer pool to active
Debug info: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(994): gst_nvinfer_start (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInfer:primary_gie
App run failed
I see that in the config files we can change sink to be 1=FakeSink, 2=EglSink, 3=File.
Very novice in gstreamer but I understand the concept of pipeline, source and sink. Been trying many different things.
Please provide some guidance to get to something working headless with docker image? Thank you
If your board is not connected to a monitor, you can try running the following command first.
unset DISPLAY
sudo docker run -it --rm --runtime=nvidia --privileged -v /tmp/.X11-unix:/tmp/.X11-unix -v /usr/lib/aarch64-linux-gnu/:/usr/lib/aarch64-linux-gnu/ nvcr.io/nvidia/deepstream:6.4-samples-multiarch
Thank you for the hint.
Didn’t have to unset it. Just took out -e DISPLAY=:0 That fixed it to a point where app runs through successfully. I did verify that $DISPLAY is empty for both inside and outside the container.
**PERF:  FPS 0 (Avg)    FPS 1 (Avg)
**PERF:  0.00 (0.00)    0.00 (0.00)
** INFO: <bus_callback:301>: Pipeline ready
NvMMLiteOpen : Block : BlockType = 261
NvMMLiteBlockCreate : Block : BlockType = 261
** INFO: <bus_callback:287>: Pipeline running
NvMMLiteOpen : Block : BlockType = 4
===== NvVideo: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
H264: Profile = 66, Level = 0
NVMEDIA: Need to set EMC bandwidth : 846000
NvVideo: bBlitMode is set to TRUE
**PERF:  34.07 (34.00)  34.07 (34.00)
**PERF:  30.34 (32.13)  30.34 (32.13)
**PERF:  29.81 (31.33)  29.81 (31.33)
**PERF:  30.00 (30.99)  30.00 (30.99)
**PERF:  29.86 (30.75)  29.86 (30.75)
**PERF:  30.00 (30.62)  30.00 (30.62)
**PERF:  30.14 (30.56)  30.14 (30.56)
**PERF:  29.87 (30.47)  29.87 (30.47)
**PERF:  29.99 (30.41)  29.99 (30.41)
nvstreammux: Successfully handled EOS for source_id=0
nvstreammux: Successfully handled EOS for source_id=1
** INFO: <bus_callback:324>: Received EOS. Exiting ...
Quitting
App run successful
May I continue the next step questions?
With your hint, we got a pre-compiled application to run with model provided in container. Next desirable thing is to run a sample Python application.
I took these steps (Deepstream with python bindings - #13 by junshengy) to get gi installed and pyds installed. Modified from v1.1.10 updated dependency from deepstream_python_apps/bindings/README.md at v1.1.10 · NVIDIA-AI-IOT/deepstream_python_apps · GitHub. Then, installed the hosted pyds (https://github.com/NVIDIA-AI-IOT/deepstream_python_apps/releases/download/v1.1.10/pyds-1.1.10-py3-none-linux_aarch64.whl)
I git checkout that repo and check out v1.1.10 tag since that I am on 6.4 and not 7 yet. And got blocked at running deepstream-test1
root@64358075a76b:/opt/nvidia/deepstream/deepstream-6.4/sources/deepstream_python_apps/apps/deepstream-test1# python3 deepstream_test_1.py /opt/nvidia/deepstream/deepstream-6.4/samples/streams/sa
mple_720p.mp4
(gst-plugin-scanner:1742): GStreamer-WARNING **: 03:14:15.432: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libtritonserver.so: cannot op
(gst-plugin-scanner:1742): GStreamer-WARNING **: 03:14:15.435: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so': librivermax.so.0: cannot open shared
Creating Pipeline
Creating Source
Creating H264Parser
Creating Decoder
Creating nv3dsink
Playing file /opt/nvidia/deepstream/deepstream-6.4/samples/streams/sample_720p.mp4
Adding elements to Pipeline
Linking elements in the Pipeline
/opt/nvidia/deepstream/deepstream-6.4/sources/deepstream_python_apps/apps/deepstream-test1/deepstream_test_1.py:220: DeprecationWarning: Gst.Element.get_request_pad is deprecated
  sinkpad = streammux.get_request_pad("sink_0")
Starting pipeline
Error: gst-core-error-quark: GStreamer error: state change failed and some element failed to post a proper error message with the reason for the failure. (4): ../libs/gst/base/gstbasesink.c(5878)
: gst_base_sink_change_state (): /GstPipeline:pipeline0/GstNv3dSink:nv3d-sink:
Failed to start
I checked gst-inspect-1.0 nv3dsink Other than the same warning sign about librivermax and libtritonserver. It produce normal looking output. Please advise.
Many thanks in advanced.
Deepstream_test_1.py cannot support the mp4 file. It can only support h264 file. You can use the /opt/nvidia/deepstream/deepstream-6.4/samples/streams/sa mple_720p.h264.
root@64358075a76b:/opt/nvidia/deepstream/deepstream-6.4/sources/deepstream_python_apps/apps/deepstream-test1# rm -rf ~/.cache/gstreamer-1.0/
root@64358075a76b:/opt/nvidia/deepstream/deepstream-6.4/sources/deepstream_python_apps/apps/deepstream-test1# python3 deepstream_test_1.py /opt/nvidia/deepstream/deepstream-6.4/samples/streams/sample_720p.h264
........[same probably unrelated warning as before]
Playing file /opt/nvidia/deepstream/deepstream-6.4/samples/streams/sample_720p.h264
Starting pipeline
Error: gst-core-error-quark: GStreamer error: state change failed and some element failed to post a proper error message with the reason for the failure. (4): ../libs/gst/base/gstbasesink.c(5878): gst_base_sink_change_state (): /GstPipeline:pipeline0/GstNv3dSink:nv3d-sink:
Failed to start
Appreciate the quick response. Good to know that only .h264 is allowed. However, I have the same error on nv3d-sink.
Nv3d-sink is used to display the image. Since your board is not connected to a monitor, you can not use that plugin.
We suggest you taking a brief look at our plug-ins and their fundamentals by referring to the Guide.
Excellent. Thanks for letting me know that. I was able to make the application run by making a fakesink.
--- a/apps/deepstream-test1/deepstream_test_1.py
+++ b/apps/deepstream-test1/deepstream_test_1.py
@@ -181,7 +181,8 @@ def main(args):
     # Finally render the osd output
     if is_aarch64():
         print("Creating nv3dsink \n")
-        sink = Gst.ElementFactory.make("nv3dsink", "nv3d-sink")
+        sink = Gst.ElementFactory.make("fakesink", "sinkname")
+        # sink = Gst.ElementFactory.make("nv3dsink", "nv3d-sink")
         if not sink:
             sys.stderr.write(" Unable to create nv3dsink \n")
     else:
