Hey!
I pulled the docker container “nvcr.io/nvidia/deepstream:4.0.2-19.12-devel” and tried to run the example deepstream-test2-app with the video file sample_1080p_h264.mp4 file but keep getting the error “One element could not be created. Exiting”.
Here’s my output when I set GST_DEBUG=4:
GST_DEBUG=4 deepstream-test2-app samples/streams/sample_1080p_h264.mp4
With tracker
0:00:00.000061392 617 0x55f9494a5e00 INFO GST_INIT gst.c:586:init_pre: Initializing GStreamer Core Library version 1.14.5
0:00:00.000092197 617 0x55f9494a5e00 INFO GST_INIT gst.c:587:init_pre: Using library installed in /usr/lib/x86_64-linux-gnu
0:00:00.000099872 617 0x55f9494a5e00 INFO GST_INIT gst.c:607:init_pre: Linux moe 4.15.0-45-generic #48~16.04.1-Ubuntu SMP Tue Jan 29 18:03:48 UTC 2019 x86_64
0:00:00.000264976 617 0x55f9494a5e00 INFO GST_INIT gstmessage.c:127:_priv_gst_message_initialize: init messages
0:00:00.000524230 617 0x55f9494a5e00 INFO GST_INIT gstcontext.c:84:_priv_gst_context_initialize: init contexts
0:00:00.000655181 617 0x55f9494a5e00 INFO GST_PLUGIN_LOADING gstplugin.c:317:_priv_gst_plugin_initialize: registering 0 static plugins
0:00:00.000718535 617 0x55f9494a5e00 INFO GST_PLUGIN_LOADING gstplugin.c:225:gst_plugin_register_static: registered static plugin "staticelements"
0:00:00.000724766 617 0x55f9494a5e00 INFO GST_PLUGIN_LOADING gstplugin.c:227:gst_plugin_register_static: added static plugin "staticelements", result: 1
0:00:00.000731525 617 0x55f9494a5e00 INFO GST_REGISTRY gstregistry.c:1727:ensure_current_registry: reading registry cache: /home/user/.cache/gstreamer-1.0/registry.x86_64.bin
0:00:00.007890997 617 0x55f9494a5e00 INFO GST_REGISTRY gstregistrybinary.c:621:priv_gst_registry_binary_read_cache: loaded /home/user/.cache/gstreamer-1.0/registry.x86_64.bin in 0.007145 seconds
0:00:00.007932416 617 0x55f9494a5e00 INFO GST_REGISTRY gstregistry.c:1583:scan_and_update_registry: Validating plugins from registry cache: /home/user/.cache/gstreamer-1.0/registry.x86_64.bin
0:00:00.008887080 617 0x55f9494a5e00 INFO GST_REGISTRY gstregistry.c:1685:scan_and_update_registry: Registry cache has not changed
0:00:00.008906750 617 0x55f9494a5e00 INFO GST_REGISTRY gstregistry.c:1762:ensure_current_registry: registry reading and updating done, result = 1
0:00:00.008929922 617 0x55f9494a5e00 INFO GST_INIT gst.c:807:init_post: GLib runtime version: 2.56.4
0:00:00.008933976 617 0x55f9494a5e00 INFO GST_INIT gst.c:809:init_post: GLib headers version: 2.56.4
0:00:00.008936795 617 0x55f9494a5e00 INFO GST_INIT gst.c:810:init_post: initialized GStreamer successfully
0:00:00.008969678 617 0x55f9494a5e00 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element "pipeline" named "dstest2-pipeline"
0:00:00.009375755 617 0x55f9494a5e00 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstcoreelements.so" loaded
0:00:00.009382871 617 0x55f9494a5e00 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element "filesrc" named "file-source"
0:00:00.009503985 617 0x55f9494a5e00 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseSrc@0x55f9496e40e0> adding pad 'src'
0:00:00.010419868 617 0x55f9494a5e00 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstvideoparsersbad.so" loaded
0:00:00.010427914 617 0x55f9494a5e00 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element "h264parse" named "h264-parser"
0:00:00.010464076 617 0x55f9494a5e00 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseParse@0x55f9496ed280> adding pad 'sink'
0:00:00.010472637 617 0x55f9494a5e00 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseParse@0x55f9496ed280> adding pad 'src'
0:00:00.010486882 617 0x55f9494a5e00 INFO baseparse gstbaseparse.c:3961:gst_base_parse_set_pts_interpolation:<GstH264Parse@0x55f9496ed280> PTS interpolation: no
0:00:00.012147332 617 0x55f9494a5e00 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libgstnvvideo4linux2.so" loaded
0:00:00.012155884 617 0x55f9494a5e00 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element "nvv4l2decoder" named "nvv4l2-decoder"
0:00:00.012204849 617 0x55f9494a5e00 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstVideoDecoder@0x55f9496f9f80> adding pad 'sink'
0:00:00.012213820 617 0x55f9494a5e00 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstVideoDecoder@0x55f9496f9f80> adding pad 'src'
0:00:00.035928254 617 0x55f9494a5e00 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistream.so" loaded
0:00:00.035959805 617 0x55f9494a5e00 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element "nvstreammux" named "stream-muxer"
0:00:00.036164392 617 0x55f9494a5e00 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstNvStreamMux@0x55f94978a0d0> adding pad 'src'
0:00:00.036198257 617 0x55f9494a5e00 WARN GST_ELEMENT_FACTORY gstelementfactory.c:456:gst_element_factory_make: no such element factory "nvinfer"!
0:00:00.037034077 617 0x55f9494a5e00 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_tracker.so" loaded
0:00:00.037040991 617 0x55f9494a5e00 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element "nvtracker" named "tracker"
0:00:00.037194031 617 0x55f9494a5e00 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseTransform@0x55f94978e300> adding pad 'sink'
0:00:00.037222264 617 0x55f9494a5e00 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseTransform@0x55f94978e300> adding pad 'src'
0:00:00.037228875 617 0x55f9494a5e00 WARN GST_ELEMENT_FACTORY gstelementfactory.c:456:gst_element_factory_make: no such element factory "nvinfer"!
0:00:00.037232652 617 0x55f9494a5e00 WARN GST_ELEMENT_FACTORY gstelementfactory.c:456:gst_element_factory_make: no such element factory "nvinfer"!
0:00:00.037235945 617 0x55f9494a5e00 WARN GST_ELEMENT_FACTORY gstelementfactory.c:456:gst_element_factory_make: no such element factory "nvinfer"!
0:00:00.037578839 617 0x55f9494a5e00 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libgstnvvideoconvert.so" loaded
0:00:00.037586072 617 0x55f9494a5e00 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element "nvvideoconvert" named "nvvideo-converter"
0:00:00.037713514 617 0x55f9494a5e00 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseTransform@0x55f949793610> adding pad 'sink'
0:00:00.037746065 617 0x55f9494a5e00 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseTransform@0x55f949793610> adding pad 'src'
0:00:00.039308796 617 0x55f9494a5e00 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_osd.so" loaded
0:00:00.039336938 617 0x55f9494a5e00 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element "nvdsosd" named "nv-onscreendisplay"
0:00:00.039437551 617 0x55f9494a5e00 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseTransform@0x55f9497a23b0> adding pad 'sink'
0:00:00.039460150 617 0x55f9494a5e00 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseTransform@0x55f9497a23b0> adding pad 'src'
0:00:00.039986613 617 0x55f9494a5e00 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_eglglessink.so" loaded
0:00:00.039994616 617 0x55f9494a5e00 INFO GST_ELEMENT_FACTORY gstelementfactory.c:359:gst_element_factory_create: creating element "nveglglessink" named "nvvideo-renderer"
0:00:00.040175963 617 0x55f9494a5e00 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstBaseSink@0x55f9497fc7a0> adding pad 'sink'
As you can see, I keep getting
but I do not know how to fix it. Any ideas?
