Failed-to-create-element-src-bin-muxer
Can someone please give valid test5_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt file?
• DeepStream Version 6.2
• TensorRT Version
**• NVIDIA GPU Driver Version (valid for GPU only)**laptop 3050ti
runtime errors
./deepstream-test5-app -c configs/test5_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt -p 0
This is how I run programm
** ERROR: <create_multi_source_bin:1490>: Failed to create element ‘src_bin_muxer’
** ERROR: <create_multi_source_bin:1583>: create_multi_source_bin failed
** ERROR: <create_pipeline:1485>: create_pipeline failed
** ERROR: main:1472: Failed to create pipeline
Quitting
test5_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt (8.7 KB)
Does the deepstream-test1-app work normally ?
What is the below command line output ? I think this error is caused by incorrect installation.
gst-inspect-1.0 nvstreammux
https://docs.nvidia.com/metropolis/deepstream/7.0/dev-guide/text/DS_Installation.html#dgpu-setup-for-ubuntu
Or use docker
