Unable to run Deepstream Docker Reference application
• Hardware Platform (GPU) NVIDIA QUADRO T2000
• DeepStream Version 6.0.1
I am running docker image nvcr.io/nvidia/deepstream:6.0.1-devel and getting this error
root@27b408fa7206:/opt/nvidia/deepstream/deepstream-6.0# deepstream-app -c samples/configs/deepstream-app/source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8_gpu1.txt
(gst-plugin-scanner:16): GStreamer-WARNING **: 06:08:43.955: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so’: libtritonserver.so: cannot open shared object file: No such file or directory
nvbufsurftransform:cuInit failed : 100
(gst-plugin-scanner:17): GStreamer-WARNING **: 06:08:44.546: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so’: libtritonserver.so: cannot open shared object file: No such file or directory
(gst-plugin-scanner:28): GStreamer-WARNING **: 06:08:50.905: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so’: librivermax.so.0: cannot open shared object file: No such file or directory
** ERROR: <create_multi_source_bin:1424>: Failed to create element ‘src_bin_muxer’
** ERROR: <create_multi_source_bin:1517>: create_multi_source_bin failed
** ERROR: <create_pipeline:1326>: create_pipeline failed
** ERROR: main:688: Failed to create pipeline
Quitting
App run failed
Please follow the following link to configure your environment first:
https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_Quickstart.html#id6
You need to ensure that your host environment has corresponding versions of dependencies too.
