When possible, please provide the following info:
•	Hardware Platform (Jetson / GPU) two RTX 1070 Super
•	DeepStream Version  5.0.0
•	JetPack Version (valid for Jetson only)
•	TensorRT Version 7.0
•	NVIDIA GPU Driver Version (valid for GPU only) 440.33.01
Hi, I tried to install deepstream 5.0.0 on a GPU tower with two RTX 1070 super.
I think I successfully install it since when I run
deepstream-app --version-all
I get:
deepstream-app version 5.0.0
DeepStreamSDK 5.0.0
CUDA Driver Version: 10.2
CUDA Runtime Version: 10.2
TensorRT Version: 7.0
cuDNN Version: 7.6
libNVWarp360 Version: 2.0.1d3
but when I try to run a sample file with:
$ deepstream-app -c configs/deepstream-app/source30_1080p_dec_infer-resnet_tiled_display_int8.txt
I get :
(gst-plugin-scanner:10045): GStreamer-WARNING **: 22:47:12.453: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libtrtserver.so: cannot open shared object file: No such file or directory
(gst-plugin-scanner:10045): GStreamer-WARNING **: 22:47:12.454: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_eglglessink.so': libGLESv2.so.2: cannot open shared object file: No such file or directory
(gst-plugin-scanner:10045): GStreamer-WARNING **: 22:47:12.456: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_infer.so': libnvinfer_plugin.so.7: cannot open shared object file: No such file or directory
(gst-plugin-scanner:10045): GStreamer-WARNING **: 22:47:12.457: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_msgconv.so': libjson-glib-1.0.so.0: cannot open shared object file: No such file or directory
(deepstream-app:10044): GLib-GObject-CRITICAL **: 22:47:12.885: g_object_set: assertion 'G_IS_OBJECT (object)' failed
** ERROR: <create_render_bin:95>: Failed to create 'sink_sub_bin_sink1'
** ERROR: <create_render_bin:172>: create_render_bin failed
** ERROR: <create_sink_bin:732>: create_sink_bin failed
** ERROR: <create_processing_instance:793>: create_processing_instance failed
** ERROR: <create_pipeline:1263>: create_pipeline failed
** ERROR: <main:632>: Failed to create pipeline
Quitting
App run failed
