Deepstream error src_bin_muxer on jetson nano
when I ran this command to test deepstream
deepstream-app -c samples/configs/deepstream-app/source30_1080p_dec_infer-resnet_tiled_display_int8.txt
I am getting this error
(gst-plugin-scanner:16826): GStreamer-WARNING **: 20:52:37.382: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_dewarper.so': libnvdsbufferpool.so.1.0.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:16826): GStreamer-WARNING **: 20:52:37.387: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_infer.so': libnvbufsurface.so.1.0.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:16826): GStreamer-WARNING **: 20:52:37.389: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_dsexample.so': libnvbufsurface.so.1.0.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:16826): GStreamer-WARNING **: 20:52:37.392: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistream.so': libnvdsbufferpool.so.1.0.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:16826): GStreamer-WARNING **: 20:52:37.395: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistreamtiler.so': libnvbufsurface.so.1.0.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:16826): GStreamer-WARNING **: 20:52:37.397: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_tracker.so': libnvbufsurface.so.1.0.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:16826): GStreamer-WARNING **: 20:52:37.398: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_segvisual.so': libnvdsbufferpool.so.1.0.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:16826): GStreamer-WARNING **: 20:52:37.399: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_ofvisual.so': libnvdsbufferpool.so.1.0.0: cannot open shared object file: No such file or directory
** ERROR: <create_multi_source_bin:682>: Failed to create element 'src_bin_muxer'
** ERROR: <create_multi_source_bin:745>: create_multi_source_bin failed
** ERROR: <create_pipeline:1045>: create_pipeline failed
** ERROR: <main:632>: Failed to create pipeline
Quitting
App run failed
I even tried
rm ${HOME}/.cache/gstreamer-1.0/registry.aarch64.bin
but no luck still same error
I have cuda 10.0 in jetson nano
I have followed https://docs.nvidia.com/metropolis/deepstream/4.0/dev-guide/index.html#page/DeepStream_Development_Guide%2Fdeepstream_quick_start.html%23wwpID0E0BB0HA documentation
It looks to be an issue that revision of the packages does not match with each other. Please try to re-flash via sdkmanager.
can you please tell me how did you solve the problem?
my device is jetson nano 4GB, jetpack version:
$ jetson_release
  • NVIDIA Jetson Nano (Developer Kit Version)
    • Jetpack 4.5.1 [L4T 32.5.1]
    • NV Power Mode: MAXN - Type: 0
    • jetson_stats.service: active
  • Libraries:
    • CUDA: 10.2.89
    • cuDNN: 8.0.0.180
    • TensorRT: 7.1.3.0
    • Visionworks: 1.6.0.501
    • OpenCV: NOT_INSTALLED compiled CUDA: NO
    • VPI: ii libnvvpi1 1.0.15 arm64 NVIDIA Vision Programming Interface library
    • Vulkan: 1.2.70
deepstream sdk version is deepstream-5.1
problem is :
deepstream-app -c /opt/nvidia/deepstream/deepstream-5.1/samples/configs/deepstream-app/source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt
(gst-plugin-scanner:20529): GStreamer-WARNING **: 13:13:16.320: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistreamtiler.so’: libnvbufsurface.so.1.0.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:20529): GStreamer-WARNING **: 13:13:16.322: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libgstnvvideoconvert.so’: libnvdsbufferpool.so.1.0.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:20529): GStreamer-WARNING **: 13:13:16.323: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_tracker.so’: libnvbufsurface.so.1.0.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:20529): GStreamer-WARNING **: 13:13:16.331: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_dsexample.so’: libnvbufsurface.so.1.0.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:20529): GStreamer-WARNING **: 13:13:16.343: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so’: libnvbufsurface.so.1.0.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:20529): GStreamer-WARNING **: 13:13:16.345: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_segvisual.so’: libnvdsbufferpool.so.1.0.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:20529): GStreamer-WARNING **: 13:13:16.347: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistream.so’: libnvdsbufferpool.so.1.0.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:20529): GStreamer-WARNING **: 13:13:16.349: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_ofvisual.so’: libnvdsbufferpool.so.1.0.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:20529): GStreamer-WARNING **: 13:13:16.352: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_dewarper.so’: libnvdsbufferpool.so.1.0.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:20529): GStreamer-WARNING **: 13:13:16.355: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_osd.so’: libnvbufsurface.so.1.0.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:20529): GStreamer-WARNING **: 13:13:16.357: Failed to load plugin ‘/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_infer.so’: libnvbufsurface.so.1.0.0: cannot open shared object file: No such file or directory
** ERROR: <create_multi_source_bin:1320>: Failed to create element ‘src_bin_muxer’
** ERROR: <create_multi_source_bin:1411>: create_multi_source_bin failed
** ERROR: <create_pipeline:1294>: create_pipeline failed
** ERROR: main:636: Failed to create pipeline
Quitting
App run failed
Please check if you have correct link to lubnvbufsurface.so:
lrwxrwxrwx 1 root root 51  三   8 11:11 /opt/nvidia/deepstream/deepstream-5.1/lib/libnvbufsurface.so -> /usr/lib/aarch64-linux-gnu/tegra/libnvbufsurface.so
nvidia@nvidia-desktop:~$ ll /usr/lib/aarch64-linux-gnu/tegra/libnvbufsurface.so
lrwxrwxrwx 1 root root 24  一  16 07:22 /usr/lib/aarch64-linux-gnu/tegra/libnvbufsurface.so -> libnvbufsurface.so.1.0.0
nvidia@nvidia-desktop:~$ ll /usr/lib/aarch64-linux-gnu/tegra/libnvbufsurface.so.1.0.0
-rw-r--r-- 1 root root 446160  一  16 07:08 /usr/lib/aarch64-linux-gnu/tegra/libnvbufsurface.so.1.0.0
