Failure While Running DeepStream-App
Hello Community.
I am having this error
(gst-plugin-scanner:9671): GStreamer-WARNING **: 09:29:43.103: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so’: librivermax.so.0: cannot open shared object file: No such file or directory
nvbufsurftransform:cuInit failed : 100
(gst-plugin-scanner:10778): GStreamer-WARNING **: 09:31:58.668: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_ucx.so’: libucs.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:11193): GStreamer-WARNING **: 09:32:52.346: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so’: libtritonserver.so: cannot open shared object file: No such file or directory
** ERROR: <create_multi_source_bin:1494>: Failed to create element ‘src_bin_muxer’
** ERROR: <create_multi_source_bin:1582>: create_multi_source_bin failed
** ERROR: <create_pipeline:1576>: create_pipeline failed
** ERROR: main:697: Failed to create pipeline
Quitting
App run failed
• DeepStream Version
• TensorRT Version
• The pipeline being used
Duplicate with this topic.
Are you running in docker?
Can you share your GPU model ,command line and Deepstream version?
This line of error means that your CUDA is not properly installed.
But I followed the installation guide Quickstart Guide — DeepStream 6.3 Release documentation
My DeepStream version is 6.3 and TensoRT is 8.6.1, and I am using a Laptop with GeForce RTX 3080Ti
We have only tested TRT 8.5.3.1 on dGPU , and higher versions may have compatibility issues.
It is recommended to use docker
docker pull nvcr.io/nvidia/deepstream:6.3-triton-multiarch
I just tried the command you sent and this what I am getting: permission denied while trying to connect to the Docker daemon socket at unix:///var/run/docker.sock: Post “http://%2Fvar%2Frun%2Fdocker.sock/v1.24/images/create?fromImage=nvcr.io%2Fnvidia%2Fdeepstream&tag=6.3-triton-multiarch”: dial unix /var/run/docker.sock: connect: permission denied
I am knew to this and dont know how to use docker
Add sudo
sudo docker pull nvcr.io/nvidia/deepstream:6.3-triton-multiarch
Thanks, it is downloading some files. What do I do after downloading?
Run the docker, use as native linux.
You can use google to search for some commands about docker
xhost +
docker run --gpus all -it --rm --net=host --privileged -v /tmp/.X11-unix:/tmp/.X11-unix -e DISPLAY=$DISPLAY -w /opt/nvidia/deepstream/deepstream-6.3 nvcr.io/nvidia/deepstream:6.3-triton-multiarch
I fixed the CUDA erro and now I am getting the following error when running the sample
ubuntu@ubuntu-Blade-15-2022-RZ09-0421:/opt/nvidia/deepstream/deepstream-6.3/samples/configs/deepstream-app$ sudo deepstream-app -c source30_1080p_dec_infer-resnet_tiled_display_int8.txt
[sudo] password for ubuntu:
Quitting
App run failed
If you execute the following cli, Is there anything like libnvdsgst_multistream.so in the blacklist?
gst-inspect-1.0 -b
Run the install.sh script in /opt/nvidia/deepstream/deepstream to clean cache
then try to excute the deepstream-app.
If it still doesn’t work properly, I think it may be a problem with the GPU driver or CUDA toolkit.
