<create_multi_source_bin:1457>: Failed to create element 'src_bin_muxer'
GPU
• DeepStream Version
6.1.1
• TensorRT Version
8.4
11.7
questions
When I created a container and ran the Deepstream-app case, the following error message appeared.
Add export GST_DEBUG=WARNING, the following warning appears:
According to the forum, nvstreammux is supported after version 6.1.1. Why can’t it be created here?
Have you installed your host according to Quickstart Guide — DeepStream 6.1.1 Release documentation?
Thanks for your reply. I installed it according to the instructions, but later found that some parameters were missing when creating the container. I referred to dGpu container to solve this problem.
Can DeepStream run in the host? How did you run your container?
docker run --gpus all -it --rm --net=host --privileged -v /tmp/.X11-unix:/tmp/.X11-unix -e DISPLAY=$DISPLAY -w /opt/nvidia/deepstream/deepstream-6.1 nvcr.io/nvidia/deepstream:6.1.1-devel
The –privileged parameter was missing when the container was initially created. After it was added, no error was reported when the deepstream-app case was executed again.
Glad to hear that!
