Nvstreammux Issue
• Hardware Platform (Jetson / GPU) DGPU
• DeepStream Version 6.1
• TensorRT Version
Using file: …/…/…/…/samples/configs/deepstream-app/source1_usb_dec_infer_resnet_int8.txt
Running…
ERROR from element stream-muxer: Output width not set
Error details: gstnvstreammux.c(2794): gst_nvstreammux_change_state (): /GstPipeline:dstest1-pipeline/GstNvStreamMux:stream-muxer
Returned, stopping playback
Deleting pipeline
Have you modified the config file source1_usb_dec_infer_resnet_int8.txt? Could you upgrade DeepStream to our latest version: 7.1?
I didn’t change anything in config file (source1_usb_dec_infer_resnet_int8.txt). I am running deepstream 6.1 within a docker conatiner. Thank you for replying :)
Could you attach your driver version and the source1_usb_dec_infer_resnet_int8.txt file?
Apologies, I was working in the test1 app folder instead of the config/deepstream folder. It’s working now, but thanks for your help!
I got an error, when I’m into this path.
/opt/nvidia/deepstream/deepstream-7.1/sources/apps/sample_apps/deepstream-test1# ./deepstream-test1-app …/…/…/configs/deepstream-app/source1_usb_dec_infer_resnet_int8.txt
Added elements to bin
Using file: …/…/…/configs/deepstream-app/source1_usb_dec_infer_resnet_int8.txt
Running…
Error details: gstnvstreammux.cpp(3161): gst_nvstreammux_change_state (): /GstPipeline:dstest1-pipeline/GstNvStreamMux:stream-muxer
Deleting pipeline
If I am using this path “/opt/nvidia/deepstream/deepstream-7.1/samples/configs/deepstream-app” I can run the sample apps with this command : “deepstream-app -c source30_1080p_dec_infer-resnet_tiled_display_int8.txt”
The config file in the configs/deepstream-app file can only be run by the deepstream-app sample. Please refer to our Guide DS_C_Sample_Apps first.
