• Hardware Platform (Jetson / GPU) : GPU Nvidia RTX 3050 Ti Mobile
• DeepStream Version: 8.0
• TensorRT Version
• NVIDIA GPU Driver Version (valid for GPU only): 570 as per documentation
I am trying to configure deepstream with 1 IP Camera with models already present while installation.
This is error i am getting
deepstream-app -c source1_ipcamera_resnet.txt.backup
** ERROR: <main:802>: Failed to set pipeline to PAUSED
Quitting
ERROR from src_bin_muxer: Output width not set
Debug info: gstnvstreammux.cpp(3872): gst_nvstreammux_change_state (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstNvStreamMux:src_bin_muxer
App run failed
This is the config file
# SPDX-FileCopyrightText: Copyright (c) 2018-2025 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
# SPDX-License-Identifier: MIT
# Permission is hereby granted, free of charge, to any person obtaining a
# copy of this software and associated documentation files (the "Software"),
# to deal in the Software without restriction, including without limitation
# the rights to use, copy, modify, merge, publish, distribute, sublicense,
# and/or sell copies of the Software, and to permit persons to whom the
# Software is furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in
# all copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
# THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
# FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
# DEALINGS IN THE SOFTWARE.
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=1
rows=1
columns=1
width=1280
height=720
[source0]
enable=1
type=4
uri=rtsp://username:Password@ipaddress:554/cam/realmonitor?channel=1&subtype=0
num-sources=1
[sink0]
enable=1
type=3 # Display
[sink1]
enable=1
type=1
output-file=output1.mp4
codec=1
container=1
sync=0
[sink2]
enable=0
[osd]
enable=1
border-width=2
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
#[streammux]
##Boolean property to inform muxer that sources are live
#enable-padding=0
#nvbuf-memory-type=0
#live-source=1
#batch-size=1
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
#batched-push-timeout=40000
## Set muxer output width and height
#width=1280
#height=720
## If set to TRUE, system timestamp will be attached as ntp timestamp
## If set to FALSE, ntp timestamp from rtspsrc, if available, will be attached
#gpu-id=0
#attach-sys-ts-as-ntp=1
[streammux]
gpu-id=0
live-source=1
batch-size=1
width=1280
height=720
# Use 0 for Laptop/dGPU (System/Pinned memory)
# Use 3 for Laptop/dGPU (Nvidia Dedicated Device memory)
nvbuf-memory-type=3
# This ensures the muxer doesn't get stuck if the RTSP stream lags
enable-padding=0
# config-file property is mandatory for any gie section.
# Other properties are optional and if set will override the properties set in
# the infer config file.
[primary-gie]
enable=1
model-engine-file=../../models/Primary_Detector/resnet18_trafficcamnet_pruned.onnx_b1_gpu0_fp16.engine
#Required to display the PGIE labels, should be added even when using config-file
#property
batch-size=1
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
interval=0
#Required by the app for SGIE, when used along with config-file property
gie-unique-id=1
config-file=config_infer_primary.txt
[tests]
file-loop=0
Also do I have to set height and width based on camera resolution?
