• Hardware Platform (Jetson / GPU) • DeepStream Version • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
In sink, I set output type is 4, the output height and widht is 1080X1920, the streammux is 1440X2560, whe the pipeline is running, I find rtsp stream is 1440X2560, not 1080X1920.
Please help me, thank you.
• TensorRT Version
I set sink type is 4 and output width and height is 1920X1080, but when I use vlc to pull ‘rtsp://192.168.170.61:8555/ds-test’, I find this stream is not 1920X1080, it’s 2560X1140, this resolution is my streammux.
My sink config parameters are as following.
please refer to NvDsSinkEncoderConfig in create_udpsink_bin, it is not supported to set width and height.
the workaround is setting streammux 's dimension to 1080X1920.
This may work for your case, so I am going to suggest it.
Could you try adding nvmultistreamtiler to your pipeline before the nvdsosd element? (you should have an nvvideoconvert in between the tiler and onscreendisplay)
You don’t need to remove / modify your existing RTSP sink. All you need to do is add the two elements to your pipeline (keep your RTSP sink). Then you should get your desired resized RTSP stream.
There is a typo in “height”. You specified heigh. On hindsight, setting the caps on sink encoder is probably the quickest and easiest way to implement.
