Unable to create NvStreamMux
• Hardware Platform (Jetson / GPU) • Ubuntu 18.04.5 GeForce RTX 2080 Ti
• DeepStream Version 6.0
• TensorRT Version 8.0.1-1+cuda11.3
• NVIDIA GPU Driver Version (valid for GPU only) Driver Version: 460.91.03
• Issue Type( questions, new requirements, bugs) bugs
**• How to reproduce the issue ? **
I am trying to use python demo-apps in deepstream. I pulled docker image nvcr.io/nvidia/deepstream:6.0-devel and copied repo(GitHub - NVIDIA-AI-IOT/deepstream_python_apps: DeepStream SDK Python bindings and sample applications) and followed HOWTO and built gstreamer. Then installed pyds with pip3 command.
/opt/nvidia/deepstream/deepstream-6.0/sources/deepstream_python_apps/apps/deepstream-test1# python3 deepstream_test_1.py sample_qHD.h264
Creating Pipeline
Creating Source
Creating H264Parser
Creating Decoder
Unable to create pgie
Unable to create nvvidconv
Creating EGLSink
Playing file sample_qHD.h264
File “deepstream_test_1.py”, line 261, in
sys.exit(main(sys.argv))
File “deepstream_test_1.py”, line 194, in main
streammux.set_property(‘width’, 1920)
AttributeError: ‘NoneType’ object has no attribute ‘set_property’
Then I remove the cache rm ~/.cache/gstreamer-1.0/registry* and then run gst-inspect-1.0
nvbufsurftransform:cuInit failed : 804
(gst-plugin-scanner:12756): GStreamer-WARNING **:Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so’: librivermax.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:12757): GStreamer-WARNING **: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so’: librivermax.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:12758): GStreamer-WARNING **: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so’: libtritonserver.so: cannot open shared object file: No such file or directory
(gst-plugin-scanner:12759): GStreamer-WARNING **: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so’: libtritonserver.so: cannot open shared object file: No such file or directory
Please make sure your GPU driver, CUDA version are correct before you install DS 6.0 GA. Quickstart Guide — DeepStream 6.1.1 Release documentation
